2 Best Power Banks to Keep Your Laptop Charged Anywhere
Running out of battery mid-journey is frustrating, especially if you rely on your laptop for work or entertainment. That’s where a high-quality power bank comes in. EcoFlow’s RAPID Power Banks offer reliable backup energy in compact, travel-friendly designs that are small enough to fit in your pocket. Whether you’re off for a weekend getaway or an extended trip without access to outlets, these power banks ensure your laptop and essential devices stay charged when you need them most.
EcoFlow’s Best Power Banks to Keep Your Laptop Charged
  1. Best for Weekend Trips: EcoFlow RAPID Power Bank 5000mAh
  2. Best for Extended Journeys: EcoFlow RAPID Power Bank 10000mAh
The EcoFlow RAPID Power Bank 5000mAh is the perfect traveling companion for weekend getaways to boost your laptop's energy while on a plane, train, bus, in a tent, or out on a hike. It’s smaller than your phone, so it will easily fit in your pocket, yet it’s powerful enough to give your 13” MacBook an extra 2 hours of energy. Then, you can quickly recharge it from 0% to 70% in under 33 minutes, making it easy to top it up at the airport or bus station while you wait for a transfer, or anywhere else you can find access to a USB-C port or a wall outlet.
With its 30W built-in Type-C cable, you don’t even have to worry about carrying extra cables. This is perfect for charging a laptop without a charger, adding heaps of convenience on those quick weekend getaways. You can also charge other devices, including phones, tablets, Kindles, fitness bands, and earbuds, with wired or Qi2-certified wireless charging options. The built-in kickstand for upright or side use offers hands-free use as a desktop stand for added versatility.
EcoFlow RAPID Power Bank 5000mAh Specifications
  • Capacity: 5000mAh
  • Ports: C1: Type-C built in cable (input/output) C2: Type-C Ports (input/output)
  • Wired Charging Input: 30W
  • Recharging Time: 33min-70% 59min-100%
  • Wired Charging Output: 30W
  • Wireless Charging Output: Qi2.0 15W
  • Wireless Charging Time: 42min - iPhone15 Pro to 50%
Pros
  • Compact and lightweight, it easily fits in your pocket
  • Built-in 30W Type-C wired charging option, so you don’t need to pack a charger
  • Also has Qi2-certified fast wireless charging for phones and other devices
Cons
  • It will only give you a couple of extra hours on your laptop, but it can be quickly recharged when you get to an outlet
  • Not for extended journeys
If you want more energy but don’t want to pack the weight of a portable power station, the EcoFlow RAPID Power Bank 10000mAh is perfect. It’s still ultra-compact and portable, no bigger than your phone, just a little thicker and heavier than the 5000mAh model. But you get the convenience of twice as much power. With its 10000mAh capacity, it can provide your 13” MacBook Air with an extra 4 hours of energy.
This model also has a 65W built-in Type-C charging cable to charge your laptop about twice as fast. This makes it perfect for extended journeys when you will be away from electricity for more than a few hours. Then, when you reach your destination, or have a layover in between journeys and can find an outlet on the go, the power bank will still recharge from 0% to 70% in under 33 minutes. So, you can quickly get back on the road and still have energy for work or play. The kickstand for hands-free use and Qi2-certified wireless charging are also included for added versatility, such as charging your phone and other wireless-compatible devices.
EcoFlow RAPID Power Bank 10000mAh Specifications
  • Capacity 10000mAh
  • Ports C1: Type-C built in cable (input/output) C2: Type-C Ports (input/output)
  • Type C Charging Input: 65W
  • Built-in Cable Charging Input: 60W
  • Wired Charging Output: 65W
Pros
  • Can boost a 13” MacBook Air with 4 hours of run time
  • Still compact and portable, about the size of a phone
  • Great for extended journeys without access to electricity for more than a couple of hours
  • Built-in 65W Type-C charging cable charges quickly, without having to pack extra cables
  • Offers wireless charging for phones and other compatible devices
Cons
  • A bit more expensive than the 5000mAh model (but still very affordable)
How to Choose a Laptop Power Bank
Consider the following factors when choosing a laptop power bank to ensure it meets your needs.
Energy Capacity
One of the most important factors to consider is the power bank capacity. Remember, power banks are meant for top-ups, not full charges, but they’re great when portability is key. Since different laptops have different energy requirements, you must check your model to see how much it needs. Then, choose a capacity that will charge your computer enough for the time you need it.
Energy Output
The energy output determines how quickly your laptop can be charged. Most standard laptops charge best at around 60W, but smaller ones may work well at 30W. Bigger laptops can still charge at 30W, but it will take longer.
Portability and Size
Portability is key for backpackers or anyone else who likes to travel light. Look for compact and lightweight models. Also, think about where you want to store it, especially if you need quick access on the go. In that case, ensure it fits easily in your pocket or anywhere else you might normally keep your phone.
Recharging Time
Look for power banks that can be rapidly recharged to top them up anytime you can access a wall outlet or USB-C port. For instance, look for ones that will recharge up to 70% in less than 40 minutes. If it takes a couple of hours to only partially recharge, you’ll lose a lot of that convenience you’re looking for when you shop for a power bank.
Connections
Finally, consider what types of ports it has available for output (charging devices) and input (to recharge the power bank), and ensure it is compatible with your devices’ connections. Most devices nowadays are switching to universal Type-C ports, so it's a good idea to look for that in both output and input.
Can a Laptop Be Charged With a Power Bank?
Yes, a laptop can be charged with a power bank. However, how many more hours you get on your laptop depends on its energy requirements and the power bank's capacity. Most power banks will only boost your laptop for a couple of hours rather than fully charging it.
Are There Power Banks That Can Charge Laptops?
Many (but not all) power banks can charge a laptop. However, the amount of charge they will give you depends entirely on your laptop's energy requirements and the capacity of your power bank. Compare the capacity to your laptop's energy needs to see how long it will last.
Can a Portable Power Station Charge a Laptop?
A portable power station is larger than a power bank and can usually charge a laptop fully once or many times, depending on its capacity. If you’ll be off-grid for an extended period of time and don’t mind a little extra weight, a small portable power station might suit your needs well.
Whether you’re heading out for a weekend adventure or a longer journey, a reliable laptop power bank is a travel essential. The EcoFlow RAPID Power Bank 5000mAh is perfect for quick trips when you just need a little extra juice, while the EcoFlow RAPID Power Bank 10000mAh offers enough capacity for an extended trip where you will be away from electricity for more than a few hours. Both deliver fast charging, built-in cables, and wireless capabilities without the bulk of a power station, so you can stay powered up no matter where you go and how light you need to travel.
