Best EcoFlow Solar Panels for EcoFlow DELTA and RIVER Series Power Stations
Looking for the Perfect EcoFlow Solar Panel Pairing?
Whether you're aiming to pair EcoFlow solar panels with your DELTA or RIVER power station, seeking the fastest-charging solar combo, or exploring the best solar generator for your RV, home, off-grid cabin, or camping trip — your search ends here.
Read on to discover the perfect match for your energy needs.
Why Choose EcoFlow Solar Panels for Your EcoFlow Power Station?
EcoFlow offers a comprehensive range of solar panels — from 60W to 400W, portable to mountable, and rigid to flexible — designed to fit every lifestyle and environment.
Need a solar roof? Done.
An RV or yacht kickstand panel? Absolutely.
A solar terrace or panels for your off-grid shed? We’ve got you covered.
And yes, everything connects seamlessly through our powerful EcoFlow App.
Smart Monitoring with the EcoFlow App
With the EcoFlow app, you can monitor real-time solar input and battery charge levels — even from the comfort of your couch. This remote visibility lets you optimize sunlight exposure and troubleshoot instantly when needed.
Unmatched Solar Efficiency
Thanks to integrated PERC technology, our solar panels capture more sunlight, even in low-light conditions.
  • 100% Monocrystalline Silicon
The most efficient solar material available, delivering superior energy conversion in a compact footprint.
Engineered for All Weather Conditions
Rated IP68 waterproof and dustproof, EcoFlow solar panels are built to perform in harsh conditions — from tropical humidity to arid deserts.
Whether you're in coastal California or beside a Chihuahuan desert trail, our panels keep harnessing the sun’s energy, rain or shine.
Built to Last: Anti-Aging & Anti-Corrosion
Our solar panels feature a durable ETFE coating (except the 220W Bifacial model), providing excellent resistance to:
  • High heat
  • Thermal stress
  • UV rays
  • Corrosive chemicals
This ensures long-term performance and reliability, even under daily exposure to the elements.
Effortless Setup & All-in-One Combos
Every EcoFlow panel includes:
  • Plug-and-play universal connectors
  • Protective carrying cases
  • Kickstand support cases (for all portable models)
You can also enhance your system with EcoFlow accessories and add-ons, conveniently bundled into solar generator combos — so no need to open 50 browser tabs to piece everything together.
EcoFlow Portable Solar Panels
Perfect for camping, road trips, and nomadic lifestyles, EcoFlow Portable Solar Panels are lightweight, foldable, and easy to set up with a kickstand self-supporting case plus a plug-and-play design. All while giving you top-of-the-range solar conversion. By nature, they have the EcoFlow DNA wired—small size offers mighty power.
As to how portable they are, the “heaviest” solar panel (400W) weighs about 35 lb, pretty much like an intermediate-level dumbbell. With the comfortable-to-hold handle of its case, you’ll find it handy when the nearest gym is 50 miles away. Two is better than one as you get to beef up both biceps (and energy) at the same time.
60W, 110W, and 160W solar panels are perfect buddies for adventurous spirits. And taking them out of your trunk requires no more effort than carrying your Labradoodle puppy.
400W
160W
110W
60W
Rated Power
400W (±10W)
160W (±5W)
110W (±5W)
60W (±5W)
Efficiency
22%-23% (≥22.6%)
21%-22%
22%-23% (≥22.8%)
23.4%
Unfolded: 93.1 × 41.7 × 0.98 in.
Folded: 24.4 × 41.7 × 0.98 in.
Unfolded: 62.6 × 27.0 × 0.98 in.
Folded: 16.9 × 27.0 × 0.98 in.
Unfolded: 20.2 × 62.5 × 0.8 in.
Folded: 20.2 × 16.5 × 0.8 in.
Unfolded: 40.6 × 15.8 × 0.98 in.
Folded: 15 × 15.8 × 0.98 in.
Connector Type
Universal Solar Connector
Open Circuit Voltage
48V (Vmp 41V)
21.4V (Vmp 18.2V)
21.8V (Vmp 18.4V)
24.5V (Vmp 20.2V)
Short Circuit Current
11A (Imp 9.8A)
9.6A (Imp 8.8A)
6.5A (Imp 6.0A)
3.5A (Imp 3.3A)
Weight (Panel)
35.3 lb
12.3 lb
8.8 lb
Weight (Kickstand Case)
6.6 lb
3.1 lb
2.2 lb
Weight (Panel & Case)
41.9 lb
15.4 lb
11 lb
7 lb
Waterproof & Dustproof
portable power stations and solar panel outside of the house
EcoFlow 220W Bifacial Solar Panel
Two sides, both work relentlessly to capture more sunlight for you. Light comes in all directions and you get to benefit from them all. Ambient light or some reflection bouncing back from the ice, this panel devours every beam it sees. So you can deposit up to 25% more solar energy in your pocket.
The thin, one-piece seamless tempered glass makes it five times stronger than other panels in a similar range. It withstands heat up to 300°F. What does that mean? Mercury, the second hottest planet in our solar system, features a mean temperature of 333°F while the hottest day on Earth set the record at 134°F. As long as you’re still on this beautiful blue planet, nothing can stop your panel from getting its job done.
Rated Power
Front: 220W (±5W)
Rear: 155W
Efficiency
22-23% (≥22.8%)
Unfolded: 72.2 × 32.3 × 0.98 in.
Folded: 32.3 × 19.7 × 1.3 in.
Connector Type
21.8V (Vmp 18.4V)
Front: 13A (Imp 12.0A)
Rear: 8.8A (Imp 8.4A)
Weight (Panel)
20.9 lb
4.4 lb
25.4 lb
Please note that all the data on the above sheet are of the latest version of EcoFlow Solar Panels.
EcoFlow Mountable Solar Panels
When it comes to mountable solar panels, what everyone concerns about is:
Are they strong enough?
The answer is yes.
Weatherproof: All panels are IP68 dustproof and waterproof, which means they stay intact under varying weather conditions.
Hurricane-Level Strength & Durability: With a sturdy anti-corrosive aluminum frame, these EcoFlow solar panels can withstand a wind speed of up to 130 mph and a snow load of up to 113 lb. According to the National Weather Service of the United States, a storm is 64 to 75 mph, and a hurricane, the most destructive type of wind, features a speed of over 75 mph. That is to say, our mountable solar panels will survive most hurricanes’ horrifying wind speeds and carry on their divine duty when the sun’s up.
And that’s not the end of the list.
They also offer a top-ranking conversion efficiency of up to 23% and a simple, modern look with a compact design that fits into terraces, balconies, yards, and many other spaces.
EcoFlow Rigid Solar Panels & Flexible Solar Panels
What are the major differences between rigid solar panels and flexible ones?
First of all, EcoFlow 100W Flexible Solar Panel can curve to a maximum of 258°, perfectly fitting your van roof, boat, or any curved surfaces. Rigid solar panels are stiff and heavier but allow for better fixtures, thus resilient against bad weather like gales, storms, and even hurricanes.
Second, our 100W Flexible Solar Panel is 70% lighter than traditional ones. It offers the same solar input as a 100W Rigid Solar Panel but weighs less than half of it. The lesser weight is due to its thinness, which, to be frank, exposes it to a shorter lifespan compared to the rigid one.
One thing noteworthy is that all of our rigid and flexible solar panels have pre-drilled mounting holes for hassle-free installation.
EcoFlow Mountable
Solar Panels
400W Rigid
100W Rigid
100W Flexible
Rated Power
400W (±3%)
100W (±5W)
100W (±5W)
Cell Type
Monocrystalline silicon
Efficiency
23%
67.8 × 44.6 × 1.38 in.
38.6 × 23.1 × 1.2 in.
41.5 × 24.1 × 1.0 in.
Connector Type
37.10 V
20.3 V
20.3 V
13.79 A
6.3 A
6.3 A
Solar Panel Weight
48.1 lb
13.7 lb
5.1 lb
Please note that all the data on the following sheets were obtained under optimal conditions.
EcoFlow DELTA 2 Max
Set
EcoFlow DELTA 2 Max
Solar input
11-60V, 15A, 500W Max per port, 1000W Max in total
Recommended Solar Generators:
– EcoFlow 400W Portable Solar Panel
– EcoFlow 220W Portable Solar Panel (Bifacial)
110W
2
11.5 hr
3
7.5 hr (1+2)
4
5.5 hr
5
4.5 hr
6
3.5 hr
7
Not Advised
8
2.5 hr
160W
1
16 hr
2
8 hr
3
5 hr
4
4 hr
220W Bifacial
1
11.5 hr
2
5.5 hr
3
3.5 hr
4
3 hr
400W
1
6 hr
2
3 hr
100W Flexible
2
12.5 hr
3
8.5 hr
4
6 hr
5
5 hr
6
4 hr
7
Not Advised
8
3 hr
100W Rigid
2
12.5 hr
3
8.5 hr
4
6 hr
5
5 hr
6
4 hr
8
3 hr
400W Rigid
1
6 hr
2
3 hr
EcoFlow DELTA mini, DELTA, & EcoFlow DELTA 2
Set
EcoFlow DELTA mini
EcoFlow DELTA (1000)
EcoFlow DELTA (1300)
EcoFlow DELTA 2
EcoFlow DELTA 2 + Extra Battery
Solar input
11-75V, 300W Max
10-65V, 400W Max
10-65V, 400W Max
11-60V, 500W Max
11-60V, 500W Max
Fastest Recharge Combo
3 hr:
100W Flexible/Rigid × 3
2.5 hr:
100W Flexible/Rigid × 4
400W Portable/Rigid × 1
3 hr:
160W Portable × 3
2 hr:
110W Portable × 4
160W Portable × 3
220W Bifacial × 2
4 hr:
160W Portable × 3
110W
1
8 hr
9 hr
11.5 hr
9 hr
18.5 hr
2
4 hr
4.5 hr
6 hr
4.5 hr
9 hr
3
3 hr
4 hr
3 hr
6 hr
4
2.8 hr (parallel)
3.5 hr (parallel)
2 hr
4.5 hr
160W
1
5.5 hr
6 hr
8 hr
6.5 hr
13 hr
2
3 hr
4 hr
3 hr
6.5 hr
3
3 hr
2 hr
4 hr
220W Bifacial
1
4 hr
4.5 hr
6 hr
4.5 hr
9 hr
2
2.8 hr (parallel)
3.5 hr (parallel)
2 hr
4.5 hr
400W
1
2.5 hr
3 hr
2.5 hr
5 hr
100W Flexible
1
9 hr
10 hr
12.5 hr
10 hr
20.5 hr
2
4.5 hr
5 hr
6 hr
5 hr
10 hr
3
3 hr
3 hr
4 hr
3.5 hr
7 hr
4
2.5 hr
3 hr
2.5 hr
5 hr
100W Rigid
1
9 hr
10 hr
12.5 hr
10 hr
20.5 hr
2
4.5 hr
5 hr
6 hr
5 hr
10 hr
3
3 hr
3 hr
4 hr
3.5 hr
7 hr
4
2.5 hr
3 hr
2.5 hr
5 hr
400W Rigid
1
2.5 hr
3 hr
2.5 hr
5 hr
EcoFlow DELTA Max & EcoFlow DELTA Max Extra Battery
Set
EcoFlow DELTA Max (1600)
EcoFlow DELTA Max (2000)
EcoFlow DELTA Max + Extra Battery × 1
EcoFlow DELTA Max + Extra Battery × 2
Solar input
11-100V, 800W Max
11-100V, 800W Max
11-100V, 800W Max
11-100V, 800W Max
220W Bifacial Solar Panel × 4
400W Portable/Rigid Solar Panel × 2
2 hr
2.5 hr
5 hr
7.5 hr
110W
1
14.5 hr
18 hr
36.5 hr
55 hr
2
7 hr
9 hr
18 hr
27.5 hr
3
5 hr
6 hr
12 hr
18 hr
4
3.5 hr
4.5 hr
9 hr
13.5 hr
160W
1
10 hr
12.5 hr
25 hr
37.5 hr
2
5 hr
6 hr
12.5 hr
19 hr
3
3 hr
4 hr
8 hr
12.5 hr
4
2.5 hr
3 hr
6 hr
9.5 hr
220W Bifacial
1
7 hr
9 hr
18 hr
27.5 hr
2
3.5 hr
4.5 hr
9 hr
13.5 hr
3
2.5 hr
3 hr
6 hr
9 hr
4
2 hr (parallel)
2.5 hr (parallel)
5 hr (parallel)
7.5 hr
400W
1
4 hr
5 hr
10 hr
15 hr
2
2 hr
2.5 hr
5 hr
7.5 hr
100W Flexible
1
16 hr
20 hr
40 hr
60.5 hr
2
8 hr
10 hr
20 hr
30 hr
3
5 hr
6.5 hr
13.5 hr
20 hr
4
4 hr
5 hr
10 hr
15 hr
100W Rigid
1
16 hr
20 hr
40 hr
60.5 hr
2
8 hr
10 hr
20 hr
30 hr
3
5 hr
6.5 hr
13.5 hr
20 hr
4
4 hr
5 hr
10 hr
15 hr
5
3 hr
4 hr
8 hr
12 hr
6
2.5 hr
3 hr
6.5 hr
10 hr
400W Rigid
1
4 hr
5 hr
10 hr
15 hr
2
2 hr
2.5 hr
5 hr
7.5 hr
EcoFlow DELTA Pro & EcoFlow DELTA Pro Extra Battery
Set
EcoFlow DELTA Pro
EcoFlow DELTA Pro + Extra Battery × 1
EcoFlow DELTA Pro + Extra Battery × 2
Solar input
11-150V, 1600W Max
11-150V, 1600W Max
11-150V, 1600W Max
400W Rigid Solar Panel × 4
2 hr
4 hr
6.5 hr
110W
2
16 hr
29 hr
49 hr
3
11 hr
19 hr
32.5 hr
4
8 hr
14.5 hr
24.5 hr
160W
2
11 hr
20 hr
33.5 hr
3
7.5 hr
13 hr
22.5 hr
4
5.5 hr
10 hr
17 hr
220W Bifacial
2
8 hr
14.5 hr
24.5 hr
3
5.5 hr
9.5 hr
16 hr
4
4 hr
7 hr
12 hr
5
3 hr
6 hr
10 hr
6
2.5 hr
5 hr
8 hr
400W
1
9 hr
16 hr
27 hr
2
4.5 hr
8 hr
13.5 hr
3
3 hr
5 hr
9 hr
100W Flexible
2
18 hr
32 hr
54 hr
3
12 hr
21 hr
36 hr
4
9 hr
16 hr
27 hr
100W Rigid
2
18 hr
32 hr
54 hr
3
12 hr
21 hr
36 hr
4
9 hr
16 hr
27 hr
5
7 hr
13 hr
21.5 hr
6
6 hr
10.5 hr
18 hr
400W Rigid
1
9 hr
16 hr
27 hr
2
4.5 hr
8 hr
13.5 hr
3
3 hr
5 hr
9 hr
4
2 hr
4 hr
6.5 hr
EcoFlow RIVER Compatible Solar Panels
EcoFlow RIVER Series
Set
EcoFlow RIVER Mini
RIVER
EcoFlow RIVER Max
EcoFlow RIVER Pro
EcoFlow RIVER Pro
+ Extra Battery
EcoFlow RIVER Plus
EcoFlow RIVER Max Plus
Solar input
11-39V, 100W Max
10-25V, 200W Max
10-25V, 200W Max
10-25V, 200W Max
10-25V, 200W Max
10-25V, 200W Max
10-25V, 200W Max
Fastest Recharge In
2 hr
1.5 hr
3 hr
3.5 hr
7 hr
2 hr
3.5 hr
110W
1
2 hr
3 hr
5 hr
6.5 hr
13 hr
3 hr
6.5 hr
2
1.5 hr (parallel)
3 hr (parallel)
3.5 hr (parallel)
7 hr (parallel)
2 hr (parallel)
3.5 hr (parallel)
160W
1
2 hr
3.5 hr
4.5 hr
9 hr
2.5 hr
4.5 hr
220W Bifacial
1
1.5 hr
3 hr
3.5 hr
7 hr
2 hr
3.5 hr
400W
Not Advised
100W Flexible
1
2 hr
3 hr
6 hr
7 hr
14 hr
3.5 hr
7 hr
2
1.5 hr
3 hr
3.5 hr
7 hr
2 hr
3.5 hr
100W Rigid
1
2 hr
3 hr
6 hr
7 hr
14 hr
3.5 hr
7 hr
2
1.5 hr
3 hr
3.5 hr
7 hr
2 hr
3.5 hr
400W Rigid
Not Advised
EcoFlow RIVER 2 Series
Set
EcoFlow RIVER 2
EcoFlow RIVER 2 Max
EcoFlow RIVER 2 Pro
Solar input
110W, 11-30V 8A Max
220W, 11-50V 13A Max
Fastest Recharge In
2.5 hr
2.5 hr
3.5 hr
110W
1
2.5 hr
4.5 hr
7 hr
2
2.5 hr
3.5 hr
160W
1
3 hr
5 hr
220W Bifacial
1
2.5 hr
3.5 hr
400W
100W Flexible
1
2.5 hr
5 hr
7 hr
2
2.5 hr
3.5 hr
100W Rigid
1
2.5 hr
5 hr
7 hr
2
2.5 hr
3.5 hr
400W Rigid
EcoFlow Solar Generators for Houses, RVs, and More
Best Solar Generators for Homes
  • For Small to Medium Homes (2-3 people)
    EcoFlow DELTA 2 Max + 220W Portable Solar Panel
    EcoFlow DELTA 2 + 220W Solar Panel
  • For a Family of 3 with a Small to Medium-Sized Home
    EcoFlow DELTA Max + 400W Solar Panel
  • For Large Family Homes with Heavy-Duty Appliances
    • Portable: EcoFlow DELTA Pro + 400W Portable Solar Panel
    • Mountable: EcoFlow DELTA Pro + 400W Rigid Solar Panel
Expandable capacity - 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit a capacity of 6144Wh. Ideal for home backup, RVing, outdoors or even everyday use.
Best Solar Generators for RVs
  • For Full-Time Van Lifers
    EcoFlow DELTA Pro 3 + 400W Portable Solar Panel
    With an impressive 3.6kWh capacity and 3600W output, this setup powers luxury RVs and off-grid appliances with ease.
  • For Moderate RV Needs
    EcoFlow DELTA Max + 400W Portable Solar Panel
    Offering 2kWh capacity, 2400W output, and 6 outlets, this option is ideal for most RV setups and is more affordable than the DELTA Pro.
  • For Smaller RVs or Camping Trips
    EcoFlow RIVER 2 Pro + 220W Portable Solar Panel
    Compact and lightweight, perfect for short trips or as a backup power solution.
  • EcoFlow Power Kits
    Designed for energy independence on the road, starting at 2kWh and scaling up to 15kWh, you can choose the ideal kit for your RV lifestyle.
Solar Input - 2600W solar input with 2 PV ports for both high volt and low volt options. Conversion Efficiency - High conversion efficiency rating ensures faster solar charging.
Best Solar Generators for Boats
  • Built to Endure the Wobbly Boat Life
All EcoFlow solar panels are IP68 waterproof, and the portable power stations are designed to handle the marine environment.
  • For a Boater's Essential Setup
All options are rugged and waterproof, perfect for powering your boat with ease, no matter the weather conditions.
Best Solar Generators for Camping
  • Overnight Camping
    EcoFlow RIVER 2 + 110W Portable Solar Panel
    Ideal for powering your essentials for a short camping trip.
  • Weekend Camping
    EcoFlow RIVER 2 Max + 160W Portable Solar Panel
    The perfect solution for weekend getaways, offering enough power for all your camping needs.
  • Extended Glamping
    Perfect for extended stays, with ample power for both comfort and convenience.
Best Solar Generators for Off-Grid Living
  • EcoFlow DELTA mini + 160W Portable Solar Panel
    With 882Wh capacity and 1400W output, this setup is perfect for small off-grid homes.
  • EcoFlow DELTA + 160W Portable Solar Panel
    Offering 1260Wh capacity and 1800W output, this is a reliable solution for slightly larger off-grid setups.
Best Solar Generators for Power Tools
  • For High-Power Tools
    Powers appliances up to 1600W, including angle grinders, drills, jigsaws, and disc sanders.
  • For Smaller Power Tools
    EcoFlow DELTA + 110W Portable Solar Panel
    With 1.2kWh capacity, it powers circular saws, electric hammers, cutting machines, and electric drills for up to an hour.
  • For Heavy-Duty Power Tools
    This powerful generator provides 3600W output (surging to 7200W under X-Boost), running electric hammers for over 2.5 hours and cutting machines for 3 hours.
Solar Generators
