What Kind of Battery for a Trolling Motor: Voltage, Amps, Lithium, and Runtime
Choose a deep-cycle marine battery that matches the voltage and maximum current draw in your trolling motor's manual. Many motors use 12 V, 24 V, or 36 V. Divide usable amp-hours by expected average current to estimate runtime. If 100 Ah were usable at a steady 20 A, the ideal run time would be five hours. Leave a reserve for the trip back. If you choose lithium iron phosphate (LiFePO4), check that the motor supports it and that your charger uses an approved profile.
What Kind of Battery Does a Trolling Motor Need?
A trolling motor needs a deep cycle marine battery that matches the motor's voltage and maximum amp draw. Your battery's amp-hour capacity determines how long you can operate the motor between charges. Unlike a starting battery, which delivers a short burst of power to start an engine, a deep cycle battery supplies electricity over longer periods. If you're unfamiliar with the difference, understanding what a deep cycle battery is can help you choose the right battery for repeated use on the water.
A fishing boat equipped with a trolling motor and marine battery on the waterA fishing boat equipped with a trolling motor and marine battery on the water
Match the Battery Voltage to Your Motor
Before choosing a battery, check the voltage requirements of your trolling motor. Most trolling motors use 12V, 24V, or 36V systems, and each requires a specific battery configuration. Matching the battery voltage to your motor helps ensure proper operation and prevents compatibility issues.
Motor system
Batteries needed
Typical application
12V
One 12V battery
Most small boats and kayaks
24V
Two 12V batteries in series or one compatible 24V battery
Medium-sized boats
36V
Three 12V batteries in series or one compatible 36V battery
Larger boats and higher-power motors
Check how the motor and battery manufacturers allow you to build a higher-voltage bank. Use matching batteries where the instructions allow a series connection, and follow the prescribed charging and protection requirements for the complete bank.
Check Maximum Amp Draw
Check the motor manufacturer's maximum current draw to size the battery and circuit protection. Minn Kota's wiring guide lists 50 A for its standard 55 lb thrust, 12 V example and 56 A for its standard 80 lb thrust, 24 V example. The 80 lb row calls for a 60 A breaker. Confirm the actual motor model, breaker, and cable size in the installation instructions.
Choose Enough Amp-Hour Capacity
Amp-hours describe capacity. A battery with 100 Ah available at a constant 20 A would give five hours in an ideal calculation. Speed, boat load, current, and battery condition affect run time. For its general lead-acid guidance, Minn Kota recommends at least a 110 Ah deep-cycle marine battery for best results. Follow the recommendation for your motor model.
How Does a 12V Lithium Trolling Battery Compare?
For a compatible 12 V trolling motor, EcoFlow's 100 Ah LiFePO4 model is rated at 1,280 Wh and weighs about 26.7 lb. Its manual lists a 100 A continuous discharge limit. EcoFlow describes the case as a Group 27 equivalent and lists it as a possible replacement for Group 27–31 applications. Check the actual tray dimensions, terminal clearance, and mounting instructions.
Lead-Acid vs. Lithium Batteries
Lead-acid and lithium batteries are two common options for powering trolling motors, but they differ in cost, weight, charging speed, and maintenance requirements. Understanding these differences can help you choose a battery that fits your boat, usage frequency, and budget.
Feature
Lead-acid deep cycle
Lithium LiFePO4
Initial cost
Generally lower
Generally higher
Weight
Heavier
Lighter
Maintenance
Flooded models need maintenance
Generally low maintenance
Charging
Usually slower
Often faster with compatible equipment
Discharge
Avoid excessive discharge
Typically supports deeper discharge
Best suited for
Budget-conscious setups
Weight-sensitive and frequent use
Flooded lead-acid batteries require regular maintenance and proper ventilation during charging. AGM batteries are sealed and generally require less maintenance, while lithium batteries use a battery management system to monitor and protect battery operation.
What Should You Check Before Buying a Lithium Battery?
Check the motor maker's lithium guidance before buying. Minn Kota says its QUEST series is optimized for LiFePO4. It gives a lower speed limit when using lithium with motors designed around flooded lead-acid batteries. Match voltage, current, battery size, and charging equipment to your own model.
  • Voltage: Choose a battery that matches your trolling motor's 12V, 24V, or 36V requirement.
  • Continuous discharge current: Make sure the battery can consistently supply the current your motor needs during operation.
  • Capacity: Select enough amp-hours to support your expected fishing time without frequent recharging.
  • Physical dimensions: Measure your existing battery tray and compare it with the battery dimensions to confirm a proper fit.
  • Protection: Look for a battery management system (BMS) with appropriate safety features, such as overcurrent, overvoltage, and temperature protection.
  • Charging compatibility: Confirm that your charger supports LiFePO4 chemistry and meets the battery manufacturer's charging requirements.
EcoFlow Lithium 12V 100Ah Deep Cycle Marine Trolling Motor Battery
For a compatible 12V trolling motor, this battery provides 100Ah of capacity in a lighter package than many traditional lead-acid alternatives. Its current rating and physical dimensions are important considerations when checking whether it suits your boat.
•Capacity: 12.8V, 100Ah (1,280Wh), LiFePO4. • Output: 100 A maximum continuous discharge. EcoFlow lists a peak discharge of up to 300 A for 30 seconds. •Cycle life: More than 6,000 cycles under EcoFlow's stated test conditions of 0.5C, 25°C (77°F), and 80% depth of discharge. • Protection: IP65 water resistance and X-Guard BMS with low-temperature cut-off. • Charging: With a compatible 14.6 V, 50 A AC charger, EcoFlow says the battery can charge from 0% to 100% in as little as two hours. Use charging equipment approved for the battery and power source.
How Long Does a 100Ah Trolling Motor Battery Last?
Use the available amp-hours after allowing for your reserve and divide by the estimated average current draw. Minn Kota gives the same basic method and shows an example using a capacity allowance.
Estimated runtime (hours) = usable capacity (Ah) ÷ average motor current (A)
The examples below assume that 100 Ah is available to the motor and that current stays constant.
Motor current draw
Assumed usable capacity
Ideal runtime
10A
100Ah
About 10 hours
20A
100Ah
About 5 hours
40A
100Ah
About 2.5 hours
These are theoretical estimates, not guaranteed fishing times. They assume a constant current draw and do not account for usable capacity limits, changing conditions, or battery protection cutoffs. For a more realistic estimate, consider how you operate your motor. Running at a lower speed generally draws less current than running continuously at maximum speed. Wind, waves, water current, and boat loading can also increase the power needed to maintain your position. If you're planning a longer outing, estimate how long a 100Ah lithium battery lasts by comparing its capacity with your expected current draw and leaving a suitable reserve.
Does Your Charger Work With Lithium?
Buying the right battery is only part of the setup. You also need a compatible charger to recharge it safely and maintain its performance. Lithium and lead-acid batteries have different charging requirements, so a charger designed for an AGM battery may not work properly with a LiFePO4 battery. Before connecting your charger, check the following specifications.
1. Check the Charging Voltage
The charger must provide the voltage recommended by the battery manufacturer. For this EcoFlow model, follow the manual's LiFePO4 charger instructions. EcoFlow documents an example using 14.6 V and 50 A with constant-current/constant-voltage charging. Understanding how to charge a deep-cycle battery starts with matching the charger's output to the battery's requirements. Using an unsuitable voltage can affect charging performance and potentially damage the battery.
2. Check the Charging Current
EcoFlow recommends up to 50 A for normal charging and lists 100 A as the maximum. Use a compatible charger set within the recommended range for your installation.
3. Use the Correct Charging Profile
Choose a charger with a dedicated LiFePO4 charging profile to meet the battery's specific requirements. Avoid assuming that a generic marine charger is compatible simply because its connector fits. If you're building a 24V or 36V battery bank, keep the battery chemistry, voltage, and specifications consistent rather than mixing lithium and lead-acid batteries. Follow the battery and equipment manufacturers' configuration instructions.
What About Mounting and Cold Weather?
A battery's installation environment can affect its safety, performance, and lifespan. Boats are exposed to constant vibration, moisture, and changing temperatures, which can create challenges for battery storage. Proper mounting helps keep the battery stable and protects its electrical connections. You should also check the manufacturer's temperature limits and cold-weather charging requirements before using the battery.
Marine batteries secured inside a bass boat compartmentMarine batteries secured inside a bass boat compartment
Secure the Battery Properly
Proper battery installation helps prevent movement, electrical issues, and damage while your boat is in use. Before mounting, check the available space, battery orientation, and connection requirements. A secure setup also helps protect the battery from vibration, accidental contact, and moisture.
  • Measure the battery compartment: Check the available space and compare it with the battery's dimensions to ensure a proper fit.
  • Check the installation orientation: Confirm that the battery can be installed in the position recommended by the manufacturer.
  • Secure the battery: Use an appropriate mounting system to prevent movement caused by boat vibration or rough water.
  • Protect the terminals: Keep battery terminals covered or protected to prevent accidental contact with metal objects.
  • Use suitable cables and circuit protection: Follow the motor and battery manuals when selecting cable sizes and breakers.
  • Keep connections protected: Make sure electrical connections are clean, secure, and protected from moisture.
The EcoFlow battery has an IP65-rated enclosure, but it should not be submerged or exposed to improper installation conditions.
Understanding Lithium Batteries in Cold Weather
Cold-weather charging and discharging have separate limits. This EcoFlow model includes a low-temperature charging cutoff. Use the temperatures below to check when the battery can charge or run the motor.
Operation
Temperature range
Charging
32°F to 131°F
Discharging
14°F to 131°F (−10°C to 55°C)
If temperatures drop below the permitted charging range, allow the battery to warm up before charging. Never bypass its built-in temperature protection. Cold conditions can also reduce available battery performance. Understanding how lithium batteries perform in cold weather can help you prepare for early-morning fishing trips and seasonal changes.
Match the battery to the motor's voltage and maximum current, then estimate runtime from usable amp-hours and expected average draw. Check the charger, tray, and circuit protection before installation. The EcoFlow 12V 100Ah trolling motor battery is a model to compare for compatible 12 V setups.
What battery do I need for a 12V trolling motor?
You need a 12V deep-cycle marine battery that supports your motor's maximum current draw. Choose an amp-hour capacity based on how long you plan to operate the motor.
How long will a 100Ah battery run on a trolling motor?
At a constant 20 A, an assumed 100 usable Ah gives an ideal five hours. Allow for the reserve and actual current draw when planning an outing.
Can I use lithium in a trolling motor?
A compatible motor can use a LiFePO4 battery. Check the motor maker's lithium guidance and any speed limits, as well as the battery's voltage, discharge rating, and charger requirements.
Can I mix lithium and lead-acid in a 24V system?
No. Mixing different battery chemistries in the same battery bank can cause charging and discharging problems. Follow the manufacturer's instructions and use compatible batteries throughout the system.
Does EcoFlow sell trolling motor batteries in the US?
EcoFlow documents the 12V 100Ah Lithium Deep Cycle Marine Trolling Motor Battery on its U.S. product overview and wholesale listing. Confirm retail availability through the seller before ordering.
Outdoors
