Travel Advice for Snowstorms: When to Travel, What to Pack, and What to Do
A winter drive can change character in the space of a few exits. Pavements that were merely wet outside Denver may be snow-covered higher on I-70. A clear stretch near the Great Lakes can lead directly into a lake-effect band, while a nor’easter may slow the entire I-95 corridor at once. The forecast matters, but so do road treatment, elevation, wind, and the hour you choose to leave.
Good snowstorm travel planning begins with a willingness to postpone the trip. When driving remains reasonable, the next priorities are a dependable vehicle, a route that stays near services, and enough supplies to wait safely if traffic stops. This guide explains how to make that decision, what to keep in the car, and what to do if the weather deteriorates after departure.
When Is It Safe to Travel During a Snowstorm?
There is no single snowfall amount that makes every road unsafe. A treated urban interstate may remain open while a nearby mountain pass closes, and wind can turn modest snowfall into a whiteout across an exposed highway. Practical travel advice for stormy winter weather starts with checking both the forecast and actual road conditions, including whether they will worsen during your drive.
Check Weather Forecasts and Winter Storm Warnings
Start with the National Weather Service forecast for the route, not just the weather icon for the destination. Read the full alert and review the hourly forecast for the period when you expect to be on the road. The three common alert levels have different implications:
Winter Weather Advisory: Snow, sleet, freezing rain, or a combination of hazards is expected to create significant inconvenience. Travel may be difficult even though conditions remain below local warning criteria.
Winter Storm Watch: Severe winter weather may affect the area, but the timing, location, or amount remains uncertain. A watch commonly provides about 12 to 36 hours to prepare or change travel plans.
Winter Storm Warning: Significant snow, sleet, ice, blowing snow, or a combination of hazards is expected or occurring. Criteria vary by region, but the warning means conditions may threaten life or property and travel can become dangerous.
Do not treat an advisory as a promise that the roads will be easy. A relatively small amount of snow during rush hour can cause serious delays, and freezing drizzle may be harder to see than heavy snowfall.
Check Road Conditions and Travel Restrictions
Radar shows what is falling from the sky; transportation reports show what drivers are encountering at ground level. Review the state Department of Transportation road map, 511 information, highway cameras, and current closures before leaving. Look at several cameras along the route rather than relying on the one closest to home.
Mountain corridors may have chain or traction requirements that change during the storm. Colorado, Utah, California, and other states apply their own rules, so confirm the requirements for the specific road and vehicle. Having tire chains in the trunk does not make the vehicle compliant if the driver does not know whether they fit or how to install them.
Road reports also help identify less obvious problems: a pass may be open but moving slowly behind plows, or an interstate may be blocked by a crash even after the snow has eased. Check again immediately before departure, as a saved screenshot can quickly become outdated.
Know When to Delay or Cancel Your Trip
The most useful winter travel decision is sometimes leaving the keys on the counter. Postpone a nonessential trip when officials discourage travel, a warning covers most of the route, visibility is deteriorating, or freezing rain is beginning to coat elevated surfaces. A hotel cancellation or a missed dinner is easier to manage than a night stranded in a vehicle.
Timing can make a meaningful difference. Wait until official road reports show that conditions have improved and crews have had time to clear and treat the route. If conditions are worsening, do not assume that leaving early will keep you ahead of the snow unless the entire trip can be completed before it arrives.
Alert / Road Status | What It Means on the Road | Recommended Action |
Winter Weather Advisory | Light-to-moderate snow, sleet, or ice may create slushy lanes and reduced traction | Slow down, allow extra time, and favor maintained main roads |
Chain / Traction Law Active | Packed snow or steep grades require specified tires, chains, or drivetrain equipment | Confirm that the vehicle and its equipment meet the current rule before entering the corridor |
Winter Storm Warning | Significant winter weather is expected or underway, with the potential for heavy snow, ice, wind, and poor visibility | Delay nonessential travel until conditions improve and crews have cleared the route |
Road Closure / Travel Ban | The road is impassable, or authorities have restricted travel because of immediate danger | Cancel or reroute; never drive around a barricade |
How Should You Prepare for a Trip During Snowy Weather?
Preparation should reduce the number of decisions you have to make once the storm begins. Set the route, inspect the vehicle, fill the tank or charge the battery, and tell someone where you are going before the first difficult stretch of road. If you pack a solar generator, charge its battery fully before departure rather than relying on sunlight during the storm.
Plan Your Route and Identify Alternative Roads
The fastest route in clear weather may be the wrong one in snow. Navigation apps sometimes divert traffic onto steep residential streets or rural county roads to avoid a delay. Those roads may be untreated, poorly lit, and outside reliable cell coverage. During a storm, a longer route on a maintained interstate is often the more dependable choice.
Review the map before leaving and identify two or three communities with fuel, food, lodging, or a public place to wait. Note where mountain passes, bridges, and long service gaps occur. An alternate route is only useful if it avoids the hazard; a parallel back road at the same elevation and with the same weather may be worse than staying on the highway.
Download the route or carry a paper map if cell service is uncertain. Do not rely on a phone to load new directions after entering a dead zone.
Check Your Vehicle's Winter Readiness
Cold weather exposes marginal batteries, worn wipers, and low tire pressure. A short inspection before the trip is easier than diagnosing the same problem by the side of a snowy highway.
Battery and Fluids: Have an aging battery tested, check coolant and oil, and fill the washer-fluid reservoir with winter windshield washer fluid rated for the lowest temperatures expected along your route. Keep the fuel tank close to full whenever possible so an unexpected wait does not immediately become a fuel problem.
Tires and Wipers: Check tread condition and inflate each tire to the pressure listed by the vehicle manufacturer. Tire pressure commonly changes by roughly 1 PSI for every 10°F change in temperature. Replace wiper blades that streak, chatter, or leave areas of the windshield uncleared.
Clear snow and ice from the roof, hood, windows, mirrors, lights, and license plate before moving. Snow blowing from the roof can obscure your own view or strike the vehicle behind you. For an electric vehicle, start with a full charge and account for the additional energy used by cabin heating and cold-weather battery management.
Prepare Emergency Contacts and Communication Plans
Send a family member or friend the route, departure time, vehicle description, and expected arrival window. Agree on when that person should check in if you have not arrived. This simple step gives responders a useful starting point if you lose service or cannot later explain your location.
Save roadside assistance, insurance, and relevant nonemergency numbers in the phone before leaving. A mile marker, exit number, nearby crossroad, or GPS location is more helpful than saying you are “somewhere on I-80.” Keep a charging cable within reach of the driver’s seat instead of packed under luggage. If a long delay leaves your phone running low, use that cable with a charged portable power station to keep it available for calls and location updates.
What Should You Pack for Snowstorm Travel?
Pack for a closure, not just the expected drive time. A crash, disabled truck, or sudden whiteout can stop traffic for hours even when your own vehicle is working properly. Emergency supplies belong in the passenger compartment when possible so they remain accessible if snow blocks the trunk or rear hatch. A snow storm packing list should account for everyone in the vehicle and an unexpectedly long stop.
Pack Warm Clothing and Personal Winter Gear
Dress for the possibility of stepping outside. A moisture-wicking base layer, a fleece or wool mid-layer, and a wind-resistant winter coat retain heat more effectively than a single heavy cotton layer. Bring waterproof gloves, a warm hat, wool socks, and insulated boots with usable tread.
Keep the boots and outer layers inside the cabin rather than buried beneath suitcases. A driver wearing light shoes for comfort may need the heavier footwear to clear an exhaust pipe, add traction material, or walk a very short distance to a nearby building.
Blankets are useful, but they should supplement winter clothing rather than replace it. Include any personal medication and cold-weather items needed by children, older passengers, or pets.
Bring Essential Winter Car Safety Equipment
A winter kit should help with visibility, minor traction problems, and communication while you wait for assistance. Useful equipment includes:
Extraction & Traction: Pack a compact metal shovel, a long-handled snow brush with an ice scraper, and traction mats or a bag of coarse sand or non-clumping kitty litter. Use recovery equipment only when you can work safely away from moving traffic and the vehicle is not deeply buried.
Visibility & Recovery: Carry reflective warning triangles or LED road flares, a bright headlamp, heavy-duty jumper cables, and a tow strap. A tow strap is useful only when it is rated appropriately and attached at the recovery points specified for the vehicle.
Add a basic first-aid kit and work gloves. Check the kit at the beginning of winter; flashlight batteries, packaged food, and other stored supplies can deteriorate between seasons. A winter car emergency kit checklist also helps keep visibility, traction, warmth, and communication supplies together.
Pack Food and Water
Choose food that can be eaten without heating or preparation. Trail mix, protein bars, peanut butter crackers, and dried fruit store easily and provide more practical energy than candy alone. Avoid packing only salty snacks, which may increase thirst.
Carry at least a gallon of drinking water for the vehicle and add more for several passengers or a long rural route. Keep bottles in the cabin or wrap them in a blanket to slow the freezing process. A partially frozen bottle can still be useful; a container that has split and leaked into the trunk cannot.
Prepare Backup Power for Unexpected Travel Delays
Begin with a short list of what actually needs power. Phones, headlamps, and everyday electronics have modest charging requirements, so carrying a large battery solely for those devices may take up unnecessary cargo space. A compact unit is easier to keep accessible rather than burying beneath luggage.
Weighing just 6.6 lb, with a small footprint and a detachable woven strap, the EcoFlow RIVER 260 Gen4 Portable Power Station fits behind a seat or in a footwell. It covers essential device charging while helping keep the vehicle load light and organized.
An extended closure presents a different problem: maintaining warmth without continuously idling. A blocked tailpipe can allow carbon monoxide to enter the vehicle, while hours of idling steadily reduce the remaining fuel supply. A compatible low-wattage warming device and a dedicated source of stored electricity can provide another option.
Equipped with a 512Wh battery, the EcoFlow RIVER 520 Gen4 Portable Power Station can power low-draw devices such as a portable heated blanket for several hours, provided the blanket’s wattage matches the unit’s output specifications. That provides travelers with an additional layer of warmth while they wait for road crews or rescue teams.
What Should You Do If You Encounter a Snowstorm While Traveling?
Conditions may deteriorate faster than expected after you leave. The first response should be to reduce speed before visibility and traction become critical. At the same time, begin looking for a safe place to stop instead of waiting until the roadway can no longer be seen clearly.
Reduce Speed and Maintain a Safe Following Distance
A posted speed limit assumes favorable conditions. On snow or ice, lift off the accelerator early, keep steering inputs gradual, and avoid abrupt lane changes. Brake before entering a curve rather than trying to slow down while turning.
Increase your following distance enough to allow additional stopping time on snow or ice. Measure the gap by watching the vehicle ahead pass a fixed object, then count until your vehicle reaches the same point. Leave even more room on a downgrade or behind a snowplow, truck, or vehicle that is already struggling for traction.
Four-wheel drive can help a vehicle move through snow, but it does not shorten the stopping distance on ice. Cruise control should remain off so the driver can respond directly to changes in traction.
Pull Over to a Safe Location When Visibility Drops
When falling or blowing snow begins hiding lane markings, take the next safe exit. A staffed gas station, rest area, hotel, or open parking lot is preferable to the highway shoulder because it provides greater separation from moving traffic and may offer shelter or assistance.
Do not continue simply because the destination is close. Whiteout conditions can remove the visual references needed to stay in a lane, and drivers behind you are dealing with the same limited view. Avoid stopping on the shoulder unless the vehicle is disabled or no safer option remains.
If you must stop near the roadway, move as far from traffic as conditions allow and follow official instructions for that location. Do not park beneath a snow-loaded tree or where the vehicle will obstruct plows and emergency equipment.
Stay Inside Your Vehicle if You Become Stranded
Knowing how to stay safe during blizzards includes recognizing when remaining with the vehicle is safer than setting out on foot. Your vehicle provides shelter from the wind and makes it easier for rescuers to locate you than if you walk through blowing snow. Stay inside unless a clearly visible shelter is very close, and it is safe to reach. Distance and direction are difficult to judge in a whiteout, and familiar surroundings can become disorienting within minutes.
Make the vehicle visible by tying a bright cloth or reflective ribbon to an antenna, window, or door handle. Use the interior dome light at night while the engine is running. Contact emergency services if there is an immediate medical or safety threat; otherwise, contact roadside assistance or local authorities and provide your road name, direction of travel, mile marker, and GPS coordinates, if available.
Deciding what to do when your car is stuck in snow starts with assessing traffic exposure and whether any recovery attempt is safe. Avoid strenuous digging if the vehicle is deeply stuck. Clear only what is necessary for ventilation and safety while waiting for trained help.
Conserve Fuel and Battery Power
Once stranded, treat fuel, stored electricity, and phone power as limited supplies. Use them deliberately rather than trying to maintain normal cabin conditions.
Run the Heater in Intervals: Run the engine and heater for about 10 minutes each hour rather than idling continuously. Use warm clothing and blankets between cycles.
Clear the Tailpipe First: Before running the engine, confirm that drifting snow has not blocked the exhaust pipe. Open a downwind window slightly to allow fresh air into the cabin. Recheck as snow continues to drift.
Preserve Phone Battery: Switch the phone to low-power mode, reduce screen brightness, and use a portable power station instead of repeatedly drawing from the vehicle’s 12V starter battery.
Eat and drink periodically, and move your arms and legs gently to maintain circulation without sweating or overexerting yourself. Continue monitoring official instructions when a signal is available, but avoid draining the phone by continuously refreshing road maps.
The safest snowstorm trip is often the one moved to another day. A weather warning, a mountain pass closure, or rapidly deteriorating conditions shown on highway cameras should be treated as reasons to reconsider your trip, not obstacles to drive around. When the road remains open, staying on maintained routes and carrying winter clothing, food, water, recovery equipment, and charging power gives you more options if traffic stops.
If snow covers the road, slow down while there is still room to do so and exit the highway at a safe location. A stranded traveler is usually better protected inside the vehicle, with the tailpipe clear and the engine used only in short intervals. Those choices may feel cautious at the start of the trip, but they matter once the road ahead disappears into the blowing snow.
Should You Use Cruise Control When Driving in Snow?
No, you should never use cruise control on snow-covered, icy, or slushy roads. If your tires hit a patch of ice and lose traction, cruise control will keep applying throttle to maintain speed, which can cause your wheels to spin faster and send the vehicle into an uncontrollable skid. Keeping your foot on the pedal lets you feel subtle changes in road grip and ease off the gas immediately.
What Should You Do If Your Car Starts to Skid on Ice?
Ease your foot off the accelerator immediately, avoid slamming on the brakes, and steer gently in the direction you want the front of the car to go. If your rear wheels slide to the right, steer smoothly to the right until the tires regain grip, then straighten the wheel. Sudden braking or overcorrecting the steering wheel can reduce traction and make the skid worse.
Should You Keep Your Gas Tank Full During a Snowstorm?
Yes. Keeping your fuel tank at least half to three-quarters full, or topping it off before a storm, is a good winter driving precaution. A fuller tank buffers against higher winter fuel consumption and potential power outages at gas stations, provides extra weight over the rear axle for slightly better traction, and ensures you have enough gas to run your heater intermittently if traffic stalls for hours.
Is It Safe to Sleep in Your Car During a Snowstorm?
Sleeping in your car during a snowstorm is only safe if the engine is turned off and your exhaust pipe is completely clear of snow. Leaving the engine running while you sleep creates a severe risk of fatal carbon monoxide buildup inside the cabin if drifting snow blocks the tailpipe. Bundle up in extra layers, use a portable heated blanket powered by a safe battery pack if available, and set an alarm if you need to wake up periodically to check your surroundings.
