Spelunking Gear Checklist: Helmet, Lights, Clothing, and Emergency Items
Spelunking gear has one job: help you get through a cave and back out safely, even when there's no natural light. The National Speleological Society (NSS) recommends carrying three independent light sources, with the main one mounted on your helmet. Your combined light supply should last at least three times the planned trip. Carry spare batteries, and make sure both backup lights can mount to your helmet and take over if the main light fails. Warm clothing, sturdy boots, food, and a few emergency items belong in your pack, too. This checklist covers what to bring and how to prepare it before you leave.
What Spelunking Gear Do Beginners Need?
Start with a properly fitted caving or climbing helmet with the chin strap fastened, three independent lights, and enough spare batteries for the trip. Check that both backup lights can mount to your helmet and serve as the main light. Add warm layers, gloves, sturdy boots, food, and water. You don't need an overloaded pack, but every item should have a purpose, especially when you're far from the cave entrance.
What Spelunking Gear Do Beginners Need?What Spelunking Gear Do Beginners Need?
Use this beginner equipment checklist
The NSS caving guidance provides the foundation for this equipment list. The table below brings those recommendations together with a few practical items to help you manage a trip.
Item
Why
Source
Caving or climbing helmet meeting UIAA or equivalent European standards, with a mounted light
Protect your head and keep both hands free. Adjust the fit and fasten the chin strap.
NSS
Second and third lights
Each backup must mount to the helmet and work independently as the primary light.
NSS
Spare batteries
For each light
NSS
Warm, abrasion-resistant clothing
Caves are cold; wet clothes chill
NSS
Food and water
Long trips
NSS
Emergency items (space blanket and whistle)
Stay warm while waiting and signal for help.
NSS (space blanket), NPS (whistle)
Choose a caving or climbing helmet that meets UIAA or equivalent European standards. Adjust it for a snug fit and buckle the chin strap before entering the cave. A loose helmet can shift at the wrong moment. Make sure the headlamp mount also holds your light firmly. Your boots should have dependable traction on wet, uneven ground. Gloves can protect your hands when you're moving over rough rock, while a small pack keeps food, water, and spare equipment together. Avoid packing so much that the bag gets in the way when you need to move through a narrow section.
Pack for an unexpected delay
Even a well-planned trip can take longer than expected. A difficult passage, a minor injury, or a route that's harder to follow can keep the group underground past its planned exit time. Carry a few basic emergency items so you're not relying on the supplies in someone else's pack. Consider bringing:
  • Emergency blanket: A compact space blanket can help retain body heat while someone waits for assistance.
  • Whistle: A whistle can help group members signal one another without shouting.
  • Small first-aid kit: Pack supplies for minor cuts, scrapes, and other basic injuries.
  • Extra food and water: Carry enough for the planned trip, with some additional supplies in case of a delay.
  • Waterproof storage bags: Protect spare batteries, food, and other items that shouldn't get wet.
Keep emergency supplies somewhere you can reach without unpacking everything. Tell the group where they're stored, too. A first-aid kit won't help much if nobody knows which pack has it. Lighting deserves extra attention because caves can become completely dark when your lights fail. Before buying replacement headlamps or rechargeable lights, check how many watts camping lights use. The battery's watt-hour rating is also useful when estimating how much energy you'll need to recharge it.
Charging spelunking gear at camp
Charge rechargeable headlamps and phones before leaving the vehicle or campsite. Charge only batteries marked rechargeable and use a charger designed for that battery type. Pack fresh spares for lights that use single-use batteries. If your group doesn't have access to a wall outlet, set up a portable power station outside the cave in a dry, ventilated spot sheltered from rain. Start every trip with fully charged lights and enough spare batteries to cover the planned time underground.
Set up a charging area outside the cave
If you're camping near a cave for a weekend or taking several trips over a few days, charging equipment at the vehicle can save time. EcoFlow power stations provide AC and USB charging sources for compatible lights, battery chargers, and phones. Use the station outside the cave between trips. Set it up at your vehicle or campsite in a dry, ventilated spot sheltered from rain. The EcoFlow DELTA 3 Classic Portable Power Station (1024Wh) is one option for groups that need to recharge several devices at camp. It has a 1,024Wh LFP battery and supports four charging methods. Its AC charging can take the battery from 0% to 80% in about 45 minutes, so you can top it up between outings when a suitable wall outlet is available.
EcoFlow DELTA 3 Classic Portable Power Station (1024Wh) with carrying bag
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Estimate how many times you can recharge your lights
For this estimate, assume one fully charged 1,024Wh DELTA 3 Classic delivers about 870Wh of usable energy, or roughly 85% of its rated capacity. Actual results depend on the battery capacity of your equipment and energy lost during charging.
Charging job
Energy
EcoFlow DELTA 3 Classic (870Wh usable est.)
Rechargeable headlamp battery
Battery Wh from the label or manual
870 ÷ (battery Wh × 1.2) full recharges
Rechargeable AA battery set in a compatible charger
Add the Wh ratings of all cells in one set
870 ÷ (total Wh per set × 1.2) full-set recharges
The calculation includes a 1.2 multiplier for estimated charging losses. For example, if a headlamp battery holds 10Wh, the estimate is 870 ÷ (10 × 1.2), or about 72 charges. That's a planning figure, not a guaranteed result. The actual number may be lower depending on the charger and battery. For more options, browse EcoFlow's portable power stations and compare capacity with the devices your group plans to recharge. Before leaving camp, check every light again and make sure each person has the required backups.
How Do You Choose Caving Lights?
Every person should carry three independent light sources, and each one should be reliable enough to help them get out of the cave. Mount the primary light on your helmet. Keep two independent backups within reach. Each should mount to the helmet and give enough light to take over if the primary fails.
Choose three lights that can work independently
The NSS recommends at least three independent lights. Both backups should fit on your helmet and work as your primary light if needed. That means carrying three dependable lights rather than counting on one headlamp with several batteries. If the headlamp fails, you need another complete light source ready to use. A practical setup looks like this:
  1. Primary headlamp: Mount it securely on your helmet so you can see while keeping both hands free.
  2. Second light: Carry a backup headlamp with its own power source. Check that it fits your helmet and gives enough light to replace your primary.
  3. Third light: Pack another independent light that you can mount on your helmet and use as your primary.
Don't count a candle as a backup. The NSS specifically says candles aren't alternate light sources. A phone flashlight also shouldn't replace one of your three reliable lights.
Plan for three times the trip length
The NSS lighting guidance recommends enough combined runtime for at least three times the planned trip. Each light should also be able to last the planned trip on its own. If your group expects to spend four hours underground, plan for at least 12 hours of combined lighting capacity. That extra time gives you room to handle a slow section, help another person, or find your way out after an unexpected delay.
Check the manufacturer's runtime information for each light, but don't assume the advertised maximum will match actual use. Brightness settings, battery condition, and temperature can affect runtime. Test your lights before the trip and replace weak batteries rather than hoping they'll last. Pack the right spare batteries for each light. Keep them protected from moisture and organized so you can find the right size quickly. If you're driving to a remote cave, the NPS camping packing list can also help you organize the rest of your supplies before leaving home.
What Clothing and Cleaning Steps Matter?
Caves often stay cold, even when the temperature outside is comfortable. Wear warm layers that can handle damp conditions, and avoid clothing that stays wet against your skin. After the trip, follow the land manager's instructions for cleaning and decontaminating gear. Check the rules at both sites before reusing gear in a different cave.
What Clothing and Cleaning Steps Matter?What Clothing and Cleaning Steps Matter?
Choose clothing for cold, damp conditions
The NSS notes that caves tend to be cold and that wet clothing can make you colder. Choose layers that help retain warmth if they get damp. Avoid relying on cotton as your main insulating layer because it holds moisture and can take a long time to dry. Your clothing list should include:
  • Base layer: Choose a material that moves moisture away from your skin.
  • Insulating layer: Bring a warm layer suited to the cave's conditions.
  • Outer layer: Wear durable clothing that can handle contact with rough rock.
  • Gloves: Protect your hands from cold surfaces and abrasion.
  • Footwear: Use sturdy boots with good traction on uneven ground.
Check the cave's conditions before choosing your layers. A short, dry passage and a long, wet trip may call for different clothing. Keep a dry change of clothes in your vehicle for after the outing.
Clean equipment and follow cave access rules
White-nose syndrome has affected bat populations across North America. The fungus associated with the disease can spread on clothing and equipment, so cleaning your items after a trip is part of responsible caving. Check both land managers' rules before moving gear to a second cave. The national White-Nose Syndrome decontamination protocol prohibits moving gear from a bat roost where the fungus has been detected to one where it is absent or its status is unknown. It also restricts transfers from more contaminated states or counties to less contaminated ones. Decontaminate your gear between visits only where reuse is allowed. Removing visible dirt is the first step. Keep potentially contaminated gear sealed and separate from clean gear until it can be treated. Also, check access rules before visiting. Some caves close to protect bats, and others require registration or permits. Don't enter a closed cave or assume that the rules are the same at every site.
A well-planned spelunking gear checklist helps you prepare for the conditions underground. Start with a certified caving or climbing helmet with the chin strap fastened, three independent lights, spare batteries, and warm clothing. Pack sturdy boots, gloves, food, water, and basic emergency supplies, too. Before entering, test all three lights. Make sure each backup can mount to your helmet and take over for the primary. Follow NSS guidance and check the land manager's rules for your cave. If you're camping between outings, the EcoFlow DELTA 3 Classic can power compatible headlamp and battery chargers. Use it outside the cave in a dry, ventilated spot sheltered from rain.
What gear do I need for spelunking?
Start with a caving or climbing helmet that meets UIAA or equivalent European standards. Adjust the fit and fasten the chin strap. Bring three independent light sources, spare batteries, warm clothing, sturdy boots, gloves, food, and water. A small first-aid kit, emergency blanket, and whistle are also useful additions. Check the cave's rules before deciding what else to pack.
How many lights should I bring caving?
The NSS recommends at least three independent lights per person. Mount the primary light on your helmet. Bring two backups that each fit the helmet and can serve as the primary. Pack spare batteries and plan for a combined runtime of at least three times the expected trip.
Are candles a backup light for caving?
No. The NSS says candles aren't alternate light sources. Carry three reliable electric lights instead, and make sure each one has enough battery power to help you get out.
What should I wear caving?
Wear warm layers that can handle damp conditions, sturdy boots with good traction, and gloves. Caves can stay cold even when it's warm outside. Avoid relying on cotton as your main insulating layer because wet cotton can leave you cold.
How do I charge headlamps on a caving trip?
Charge rechargeable headlamps before entering the cave. For spare cells, charge only those marked rechargeable and use a compatible charger. Bring fresh spares for lights that use single-use batteries. If there's no wall outlet nearby, set up a portable power station at your vehicle or campsite outside the cave. Choose a dry, ventilated spot sheltered from rain. Bring fully charged lights and the spare batteries you'll need for the trip.
Outdoors
