Here Is What You Will Actually Pay for a Home Backup Generator
- How Much Does a Home Backup Generator Cost? (Quick Answer)
- Battery Backup vs. Gas Generator: Where EcoFlow TITAN Fits In
- What Affects the Cost of a Home Backup Generator
- Standby Generator vs. Portable vs. Battery Backup: Cost Comparison
- Installation, Maintenance, and Ongoing Costs
- Is a Home Backup Generator Worth the Cost?
- Conclusion
- FAQs
Looking for the real cost of a backup generator for your home before the next storm rolls through? You're not alone, and you probably want a straight number, not a stack of sales calls. Prices swing widely, the grid feels shakier every year, and you just want to know what it takes to keep your lights on, your fridge running, and your family comfortable when the power quits.
So let's skip the guesswork. This guide breaks down what a home backup system really costs, what pushes the price up or down, and how the main options compare, so you leave with a realistic range for your own home.
Here's the question most people search first: how much does a backup generator cost, fully installed? The short answer is a wide one. According to HomeAdvisor, most homeowners pay between $1,512 and $8,803 to have a whole-house generator installed, with an average of $5,157 and larger projects reaching as high as $13,500. Looking at fully installed systems on their own, NWI Generator puts partial-home units starting near $6,000 and whole-home systems near $8,000.
Why the huge gap? Because the final backup generator price depends on the unit's size, its fuel, and how complex the install is. So if you're wondering how much a backup generator costs on its own, the unit is only part of the story. The unit alone might be a few thousand dollars, but permits, wiring, and professional labor can push the fully installed total much higher.
Those figures all assume a fuel-burning generator, but that's no longer your only route to whole-home backup. Battery systems now back up the home circuits you choose with no fuel, no fumes, and far less upkeep, so it's worth comparing the two.
A standby generator's cost keeps climbing after the purchase: fuel, annual servicing, and a gas line or tank. A home battery puts the spend into hardware you install once. The EcoFlow TITAN is built for that role, powering the 120V and 240V circuits you choose from a 5kWh base that expands as your outage needs grow, with no engine to maintain.
Not every home needs 240V backup. If your priority is keeping the refrigerator, lights, and Wi-Fi running through an outage, a simpler setup can do the job. The EcoFlow TITAN Classic is the entry model, built for those 120V essentials.
Three factors explain most of the cost of backup generator options: the type of unit, its size, and the fuel it runs on. Here's how the ranges break down.
Cost factor | Option | Typical cost |
Generator type | Portable generator | A few thousand dollars (essential loads only) |
Standby generator (unit) | $3,000–$6,000; premium $10,000+ | |
Inverter generator | $500–$4,000 | |
Portable power station | $300–$1,500 up to $1,500–$8,000+ | |
Generator size | Essential-circuit (7–10 kW) | $2,000–$4,500 |
Medium (16–20 kW) | $4,500–$8,500 | |
Large whole-home (20–25 kW+) | $6,000–$12,000+ | |
Fuel source | Natural gas | $3,000–$10,000+ |
Propane | Similar, plus $500–$3,000 for a tank | |
Diesel | $5,000–$18,000 | |
Solar / battery backup | $3,500–$15,000+, no fuel cost |
Because solar and battery systems carry no fuel cost after purchase, choosing the right home battery backup can shift the long-term math in your favor even when the upfront number looks similar.
One cost that's easy to miss is labor, which typically makes up 30–40% of the total project cost for a professionally installed system. That's a big reason the backup generator price on a spec sheet rarely matches the final invoice.
With the drivers clear, here's how the three main backup types stack up side by side.
Sometimes the clearest way to weigh how much does a home generator costs against the alternatives is a straight side-by-side:
Type | Typical unit cost | Installation | Fuel / ongoing cost | Noise / emissions |
Portable generator | Lowest upfront | Minimal setup | Fuel storage + refueling | Noise and emissions |
Standby generator | Higher upfront | Higher (fuel line, wiring) | Fuel + maintenance | Some noise; emissions |
Battery / solar backup | In the hardware | Varies by setup | None; optional solar | Silent; no emissions |
In short: portable units are cheapest upfront but manual and noisy; standby units cost more yet start automatically and can power your whole home; battery and solar systems run silent with no fuel bill, putting the cost upfront in the hardware.
But the sticker price is only half the story. Installation and the costs that follow can add thousands.
If you're asking how much to install a backup generator, it depends on how much wiring your home needs, and that's where a lot of the backup generator for home installation cost hides:
Basic portable setup (inlet box and wiring): $300–$1,200
Manual or automatic transfer switch: $500–$2,500, by circuit count and labour
Standby generator install: $3,000–$5,000; homes needing trenching, extended wiring, or panel upgrades can reach $5,000–$10,000+
So the cost of installing backup generator equipment can rival the cost of the unit itself. Most areas also require a permit and an inspection, which add a small fee and a few days to the timeline, so it's worth asking your installer about local rules up front. Fuel-based generators also bring recurring costs, like regular servicing and refuelling, while battery and solar systems skip most of that, since there's no fuel to buy and less to maintain.
With the full picture in view, the real question is whether that spend pays off for your household.
Is it worth it? That's a household-by-household call. A backup generator makes the most sense for homes with vulnerable family members, such as small children, elderly relatives, or anyone who relies on powered medical equipment, and for households in areas with frequent, extended outages. If a long blackout would put someone's health at risk, reliable backup power during an outage is hard to overstate.
For everyone else, it comes down to weighing the upfront cost and upkeep against your real outage risk. A good gut check is your own outage history: if you lose power only briefly once or twice a year, a smaller battery unit may be plenty, while frequent, multi-day outages make a full system far easier to justify. FEMA's Ready.gov power outage guide helps you inventory what in your home actually relies on electricity, a practical way to right-size what you need to back up. And if you choose a fuel-burning generator, the U.S. Consumer Product Safety Commission warns to run it outdoors only, well away from doors and windows, because of carbon monoxide risk, one more reason some families lean toward a battery system.
A complete backup generator system typically costs $1,512 to $8,803 installed, and larger whole-home projects can reach $13,500. Generator type, size, and fuel source remain the biggest drivers of backup generator ownership cost, and the complexity of the installation can move the final price significantly. Battery-based whole-home backup is a fuel-free alternative worth considering alongside a traditional standby generator. If that category fits your situation, the EcoFlow TITAN, on its own or paired with solar panels, is worth a look before committing to a fuel line and a concrete pad, especially if quieter operation and no refueling matter as much as raw backup capacity. If you only need to cover 120V essentials, the EcoFlow TITAN Classic is the entry model.
How much does it cost to install a whole house generator?
A fully installed whole-house generator typically costs $7,000 to $15,000. Permits, gas line work, and electrical upgrades such as trenching, wiring, or panel work are usually billed separately and can add substantially to the total. For a fuller price breakdown, see EcoFlow's whole-house generator cost guide.
What's the cheapest type of home backup generator? Portable generators are generally cheapest, often a few thousand dollars, though they're manually operated and cover essential loads only.
Is a battery backup system cheaper than a gas generator?
It depends on what's compared. Battery backup avoids ongoing fuel costs and most routine maintenance, and options like the EcoFlow TITAN let you start at 5kWh and add capacity as your needs grow, though the final cost ultimately depends on capacity.
How long does it take to install a home backup generator? Portable setups can be ready the same day. Standby generator installation typically takes anywhere from several days to a few weeks once permitting, site work, and inspection are factored in, depending on your local timeline.
