What Can EcoFlow TITAN Power? Output & Runtime Guide
The hardest part of choosing a home battery is not finding a big wattage number. It is knowing whether your real appliances can run at the same time and whether the battery will last through the outage.
That is where buyers often get stuck. Running watts are confused with startup surge. A 5kW limit is read as though it applies to every outlet. Adding batteries is assumed to increase output. Maximum solar input is mistaken for all-day solar production.
Here is how to separate those numbers and plan a TITAN system around your home.
What Can TITAN Run at the Same Time?
Before deciding what TITAN can run simultaneously, or comparing it with smaller portable power stations, you need to figure out two different questions:
Power: How many watts might your appliances need at the same moment?
Energy: How many kilowatt-hours will they use over time?
If you have not listed your loads yet, start with our guide to calculating the power needs of your devices.
TITAN 5000 and TITAN 5000 Plus provide 7.2kW of battery output at 120V/240V. TITAN 5000 Classic provides 4kW at 120V for essential loads. Moreover, TITAN 5000 Plus can reach up to 10kW of total output when the battery and sufficient compatible solar are working together.
That distinction matters in the 9,410W appliance example. Those loads exceed the 7.2kW battery-only limit. They could fit only as a TITAN 5000 Plus combined-output scenario, with enough compatible solar arriving at that moment, suitable connections, and startup demand remaining within the relevant limits. In other words, the example does not mean every TITAN model can run all six appliances together under all conditions.
Where Does the 5kW Limit Apply?
On TITAN 5000 Plus, the 5kW-per-leg figure describes X-Boost 2.0: up to 5kW may be available on either 120V leg in a supported configuration. This capability is not listed for the standard TITAN 5000, and it does not mean every outlet or circuit can provide 5kW.
Three limits must be considered together:
Total system limit: TITAN 5000 and TITAN 5000 Plus provide up to 7.2kW on battery power.
Per-leg X-Boost limit (TITAN 5000 Plus only): Up to 5kW may be available on either 120V leg in a supported configuration.
Connection limit: Each outlet, circuit, breaker, cable, and accessory has its own rating, which may be lower.
For example, using 5kW on one leg does not leave another 5kW available from the battery on the other leg. The 7.2kW total battery-output limit still applies.
Note: X-Boost 2.0 helps TITAN 5000 Plus handle uneven split-phase loads, but battery-powered total output remains limited to 7.2kW. Always confirm the rating of the selected outlet, circuit, cable, and connection path.
How Long Will 5kWh Last?
Power tells you what can run. Energy tells you how long it can run. The basic formula is below; for more planning examples, see our home battery backup runtime guide.
Runtime = energy delivered to the loads ÷ average load
Every TITAN main unit starts with 5kWh of nameplate capacity. For conservative planning, assume that 4kWh reaches the loads after a combined 20% allowance for reserve and conversion losses.
This 80% figure is an illustrative planning assumption—not a measured efficiency claim or an official usable-capacity specification.
For a multi-day outage, a steady 0.5kW average load uses about 12kWh in 24 hours, 24kWh in 48 hours, and 36kWh in 72 hours, before reserve and conversion losses.
Average load | Illustrative runtime from 4kWh |
0.5kW | About 8 hours |
1kW | About 4 hours |
2kW | About 2 hours |
In fact, actual household loads are less predictable. A refrigerator cycles on and off, while a space heater may run almost continuously. Air-conditioners energy use changes with the weather and thermostat settings. Whenever possible, you'd better use a plug-in energy meter or historical circuit data.
Compatible 5kWh expansion batteries can increase TITAN’s capacity up to 30kWh. But remember that adding batteries normally extends runtime, does not increase the main unit's inverter rating.
You can choose the TITAN model for the loads that need to run together, then choose the battery capacity for how long you want to run them.
How Much Runtime Can Yard Solar Add?
Maximum solar input tells you how much solar power the system can accept at a moment. It does not tell you how many kilowatt-hours your panels will generate in a day.
Our solar generator sizing guide explains the general method for matching generation and storage to a load. You must still confirm the exact TITAN input limits and panel compatibility for your configuration.
TITAN 5000 Classic supports up to 3.2 kW of compatible solar input through a MPPT.
TITAN 5000 supports up to 4kW compatible solar input through a MPPT.
TITAN 5000 Plus supports up to 8kW of compatible solar input through dual MPPTs.
Note: Always confirm the current voltage, current, connector, and input requirements for the exact TITAN model before designing an array.
In fact, daily production depends on various factors, including:
Location and season
Peak sun hours
Weather and shading
Panel angle and orientation
Temperature and cable losses
Available battery capacity
Energy being consumed while the panels are producing
So, a practical estimate is:
Daily solar energy = array size × peak sun hours × system factor
For example, a 4kW array receiving four peak sun hours, with a 75%–85% planning factor, may generate approximately 12–13.6kWh in one day. That does not mean the array will produce 4kW continuously from sunrise to sunset. Production rises and falls throughout the day, and even partial shade can reduce the result. Moreover, solar can stretch battery runtime significantly in good conditions.
When Does a Generator Make Sense?
When the weather or available panel space cannot meet the load, a generator provides another replenishment option. It can support TITAN in two fundamentally different ways.
Method 1: Charging the battery
A compatible generator can supply AC power to recharge TITAN. This is conventional generator charging and remains subject to the charging input and operating limits of the selected system.
Method 2: Supporting combined-power operation
TITAN 5000 Plus can use the approved FlowMaster configuration for generator-and-battery operation. This is a specific system arrangement, not the same as connecting an arbitrary generator to an AC charging port.
While choosing a generator and connection path, you can consider:
Output voltage and frequency
Output quality and grounding requirements
Required charging power
Approved accessories
Current EcoFlow TITAN support
Note: Operate fuel-burning generators outdoors, at least 20 feet away from the home, with exhaust pointed away from the home. Never run one inside a house, basement, shed, or garage, even with the garage door open. See the CPSC carbon-monoxide safety guidance.
Will Every Device Stay On During the Transfer?
Power, capacity, solar, and generator charging explain what happens after an outage begins. But can all devices keep running during the transfer?
With Smart Home Panel 10 in a supported configuration, TITAN can switch selected backed-up circuits in under 20 milliseconds. That is fast, but it does not guarantee uninterrupted operation for every device. For example, lights and refrigerators may tolerate a brief transfer that causes a desktop computer, server, medical device, or sensitive control system to restart.
If uninterrupted operation matters:
Check the device manufacturer’s requirements.
Test the device with the completed backup configuration.
Use a dedicated UPS where required.
Note: Do not use this product to power life-sustaining medical equipment. For other medical equipment or implanted electronic devices, consult the relevant manufacturer and maintain the recommended separation distance.
Besides, transfer time should not be confused with runtime. One describes the brief handoff from grid to battery; the other describes how long the battery can keep supplying energy.
Which TITAN Setup Fits Your Home?
If you need… | Suggested starting point |
120V essential loads with up to 4kW output | |
120V/240V loads with 7.2kW battery output | |
Up to 10kW combined output with sufficient compatible solar | |
Automatic backup for selected household circuits | Compatible TITAN system, Smart Home Panel 10, and professional installation |
More hours of backup | Compatible 5kWh expansion batteries after confirming output requirements |
With output, capacity, recharging, transfer behavior, and connection path defined, choosing a TITAN configuration becomes much simpler. Before choosing, write down:
The appliances that may run at the same time.
Their running and startup power.
Which loads require 240V.
Their average daily energy use in kWh.
Which circuits need automatic backup.
Whether solar or generator charging will be available.
This produces a more realistic configuration than starting with the largest battery or the highest headline output.
Can TITAN run the 9,410W appliance example at once?
Yes, but not on 7.2kW of battery output alone. It requires TITAN 5000 Plus operating in a supported combined-output scenario with sufficient compatible solar at that moment. Connections and startup demand must also remain within their limits.
Can 5kWh last overnight?
Yes, 5 kWh can last overnight with a modest average load. Under the illustrative 4kWh delivered-energy assumption, a 0.5kW average load lasts about eight hours. Higher or continuous loads shorten that time.
Does sub-20ms switching guarantee that my computer stays on?
No. Compatibility depends on the device’s power supply and tolerance. Use a dedicated UPS when uninterrupted operation is essential.
Is 8kW of solar input equal to 8kWh every hour?
No. Kilowatts measure power at a moment; kilowatt-hours measure energy accumulated over time. Actual daily production depends on available sunlight and system conditions.
Can I use any generator to charge TITAN?
No. The generator, connection method, and accessories must meet the relevant electrical requirements and current product instructions. Standard AC charging and FlowMaster combined-power operation are different configurations.
The right TITAN configuration must provide enough output for the appliances that may overlap and enough energy to keep those loads running for the required time.
Solar can extend that runtime during favorable conditions. A compatible generator can add another charging option. Smart Home Panel 10 can provide automatic backup for selected circuits. Each solves a different part of the backup plan.
After measuring one-day appliance use, you can use the TITAN loads and runtime planning guide to match your household with the appropriate TITAN model, battery capacity, charging sources, and home-integration path.
