Small Display Projects for Home Assistant That Put Your Energy Data in Plain Sight
- Why Build Small Display Projects With Home Assistant?
- Which Home Assistant Dashboard Ideas Work Best on a Small Display?
- How Do You Design the Best Home Assistant Dashboard for a Small Screen?
- What Are Home Assistant Template Sensors and Why Use Them?
- How Can Template Sensors Combine or Transform Your Data?
- How Do You Add a Template Sensor in Home Assistant and Show It on a Dashboard?
- Seeing Your Energy Use Is Only Part of Managing It
- Solving High Energy Demand With Home Battery Storage
- Conclusion
- FAQ About Small Display Projects for Home Assistant
Home Assistant knows everything about your house. The living room's at 19 degrees. The dryer's pulling 2.4kW. Somebody left the garage door open. Getting at any of it means unlocking a phone, finding the app and waiting for it to load. Most people stop bothering. A screen on the wall fixes that, which is why small display projects Home Assistant fans build keep turning up in forums. Searches for home assistant dashboard ideas and home assistant dashboard templates make it obvious what people want: layouts to copy, not theory. Below you'll find project ideas, design rules, template sensors and how to add one. One more thing before we start. Seeing your energy use is step one. Doing something about it, perhaps with home energy storage, is step two.
Why Is a Small Screen Better Than Checking an App?
Picture the usual routine. Phone out, unlock, open the app, wait, scroll. All to find out the heating's on. A wall display skips every step: you walk past and you know. Households with kids, shift patterns or a dog that needs letting out don't have patience for anything slower. There's a practical upside too. Phones die, and they're busy with notifications. A fixed screen has one job and does it. The best small display projects Home Assistant supports all share that stubborn single purpose, which is why even a cheap panel can beat a flagship handset here.
What Can a Compact Display Show?
Most builds boil down to four things:
Temperature, indoors and out
Weather and a short forecast
Energy use, now and for the day
Device status, such as doors, lights and heating
Your own sensors decide what's possible, so don't copy someone else's list wholesale. A flat needs different numbers from a four-bedroom house. Start with whatever you check most often. Nearly every one of the small display projects Home Assistant owners share online falls into one of those four groups, so you're not inventing anything.
Temperature and Weather at a Glance
Start here if you're new. Indoor temperature goes big and bold in the middle, outdoor conditions sit beside it, and a one-line forecast goes underneath. Hold off on the five day forecast. It's just so much crap on a small screen, and you wouldn't read it anyway.
Energy Use Dashboards That Show What Matters
Three numbers: current usage, today's total and, on a time-of-use tariff, the live unit rate. That's it. Side by side they show which appliance and which hour is costing you — the tumble dryer at 5 pm is a classic offender. Of all the small display projects Home Assistant supports, the energy panel tends to earn its spot on the wall fastest. The built-in Energy dashboard is worth borrowing from, though a cut-down version suits a small panel better.
Device Status and Quick Controls
Doors. Lights. Heating. Is the washing machine done yet? Put a couple of big buttons on there and the display becomes a control panel. Keep the number of buttons low, though. A small screen and a big finger make a poor match.
Wall-Mounted Control Panels
Hallways and front doors suit a fixed panel, because you check as you come and go. Plenty of people dust off an old tablet for this. Cheap and cheerful. One catch: a tablet left plugged in around the clock isn't kind to its battery, so read what the manufacturer says.
Desk Displays and Compact Screens
No drill? No problem. A small screen on a desk or shelf works for renters, and for information that matters to one person rather than the whole house. However, if everyone desires to see the same, then a wall panel wins. For now we're developing general hardware — hardware tends to evolve quickly.
Which Layout and Cards Work Best?
Most small display projects Home Assistant users abandon fail on design, not hardware. Cram too much on and the thing's unreadable from the sofa. Aim for few cards, big text and clear groups. A Home Assistant dashboard for a small display shouldn't attempt your whole house on one page. Tile, gauge and entity cards behave well at small sizes, with maybe one history graph for company: a gauge for power draw, a tile for door status. Card names and options shift between releases, so check your own version rather than trusting an old screenshot. The best Home Assistant dashboard for a small screen is usually the one that shows less.
How Do You Make a Dashboard Responsive Across Screen Sizes?
Test on the real thing. A layout that looks tidy on a laptop can be unreadable on a seven-inch panel. So don't force one design to fit everywhere; build separate views for your phone, a tablet and the wall panel. Home Assistant dashboards can adapt to different screen widths, but only the actual display tells you whether the text is big enough.
Are Home Assistant Dashboard Templates Worth Using?
Mostly, yes. Home Assistant dashboard templates give you a starting point, which beats a blank page every time. Treat them as a draft. Swap in your own entities, bin the cards you'll never use, and look at the source's quality and recent updates — an abandoned template can break after an update.
Home Assistant template sensors are custom entities whose value is worked out from other entities you already have. They're what lift small display projects Home Assistant owners build from tidy to properly useful.
Think of a template sensor as a calculation you set up once. Add two power readings together. Turn watts into kilowatts. Squash a pile of door sensors into a single "is the house locked up?" answer. You don't need to be a programmer — you describe the sum, and the sensor keeps itself current.
Which Custom Readings Are Most Useful on a Small Display?
Daily energy use. One averaged room temperature. An "appliance running" light. Single numbers win on small screens because nobody does sums while walking past. Energy's the obvious one: add the readings from several appliances and show one figure instead of five.
How Do You Add a Template Sensor Step by Step?
Pick your source entities first. Then create the template, set the unit and a name, and check the sensor shows up. Search for home assistant add template sensor and you'll find two routes: the interface (Settings, Devices & services, Helpers) or YAML in the configuration file. Developer Tools has a template editor for testing the result before you save. Check the units match — kWh or Wh, not a mix — and name it something you'll recognise at 2am. Menus change over time, so the official documentation has the current steps.
How Do You Display the New Sensor on Your Dashboard?
Edit your dashboard, add or change a card, and choose the new entity. Then go and look at it on the small screen. Text size, units and rounding all behave differently there. For most small display projects Home Assistant users build, this last check on the real screen is where the awkward problems show up.
What Common Mistakes Should You Avoid?
Three trip people up most:
Generally, incorrect units are used next to correct units, e.g. watts next to kilowatts.
Missing values, because a source entity isn't available
Sensors with the "unknown" or "unavailable" status.
Check the source entities first, then the template. The fault's usually upstream. And if a reading feeds energy statistics, the device class and state class need to be right too.
A dashboard tells you when usage is high. It won't change the bill. You still pay for every kilowatt-hour, and the heavy loads — cooking, heating, the kettle, the telly — bunch up in the early evening, bang in the middle of the peak and off-peak window you'd rather avoid. It's not always possible to move them. So, you're standing there and not much you can do about a number rising. That's frustrating, and not knowing is worse, and worse. Here, stored electricity comes in handy: charge when it is cheaper, or when you've got more solar than you need, use it later. Speedometer versus brakes. The screen displays what's on it and storage is what lets you do something about it. Be realistic, though. It's not about how much electricity you use, but about how much you buy that shifts a battery; your tariff and battery capacity determine this.
Storage doesn't replace a good display. It responds to what the display reveals – using at moments when you are not in control.
A Practical Battery Option for Homes Without Solar
No solar panels? EcoFlow STREAM 5000 is the recommended place to start for storing electricity to use later. Its 5 kWh capacity supports all-night home power use, and AC output of 2,500W from a single unit, rising to 3,000W with an Expansion Battery or solar, can handle high-demand appliances such as a stove, dryer or electric kettle. Intelligent Mode+, Self-generation & Self-consumption and Custom modes run energy management automatically, with no daily checking, so it sits neatly beside small display projects Home Assistant owners already run. It's compact, there's a built-in handle for moving it to an attic or garage, and capacity can grow later.
Adding Battery Storage to an Existing Solar System
Already got rooftop solar? EcoFlow STREAM AC 5000 adds storage to it. It can hold surplus solar for when demand is higher, and it works with existing rooftop PV systems and mainstream third-party meters. Automatic energy management and flexible modes cut the fiddling, and a wall screen shows the results at a glance — exactly the payoff small display projects Home Assistant fans are after. Expand later if you need to; pair it with a Gateway and there's no rewiring.
Small display projects Home Assistant users build put the numbers you care about where you can see them. Simple layouts, a few good cards and templates keep a small screen usable, and template sensors turn data you already have into clear custom readings. But accurately tracking the amount of energy used is not sufficient. To be truly effective, users need a battery storage solution.
EcoFlow UK makes home batteries for that gap, from STREAM 5000 for homes without solar to STREAM AC 5000 for existing solar. See the range at EcoFlow UK and find a system that fits the way your household really uses electricity.
Do I need a separate device to run a Home Assistant display?
Not necessarily — many small display projects Home Assistant supports start on a spare tablet. A phone or computer works too. If you'd rather have information in a fixed spot, a dedicated wall panel or compact screen is the other route. Budget, space and touch controls decide it.
Can a small Home Assistant display work without an internet connection?
It can keep showing local information if Home Assistant and the display still talk over your home network. Cloud-based integrations, remote access and some outside data sources may stop updating, though. Test your own setup rather than assuming everything works offline.
How do I keep a small Home Assistant display readable and responsive?
Only display what you monitor frequently. Set the text size large, and make labels clear; do not overcrowd the screen. Test at actual show resolution and orientation and consider whether the device will lock upon awakening and how bright the display is.
