How to Test Power Supply Problems in Your UK Desktop PC
- Signs Your Computer Power Supply Is Failing
- Four Ways to Test a PC Power Supply, Compared
- How to Test a Power Supply Unit Without a Computer
- How to Test a Computer Power Supply With a Multimeter
- How to Test Desktop Power Supply Performance Under Load
- Testing Mistakes, Safety and When to Replace a PSU
- Faulty PSU, Unstable UK Mains or a Power Cut?
- Solving the Problems a PSU Test Can’t Fix
- Conclusion
- How to Test Power Supply Frequently Asked Questions
Many PC users have faced at least one of these problems: a PC shutting down mid-game or halfway through a document you haven’t saved, or it not turning on when you press the power button. You start wondering whether it's the power supply unit (PSU), motherboard or GPU that’s causing all these issues. You can’t tell, and guessing gets expensive.
The PSU powers every component in the computer, so a weak one can cause strange symptoms elsewhere. Knowing how to test power supply faults first can stop you replacing a perfectly good graphics card.
This guide looks at:
The signs your computer power supply is failing
Four ways you can use to test your PC’s power supply
How to test a power supply unit without a computer
How to test a computer power supply with a multimeter
How to test desktop power supply performance under load
Power supply testing mistakes, safety and when to replace a PSU
Why you should never open a PSU casing
How to solve problems a PSU test can’t fix and how a home energy storage can provide stable power for your computer during power cuts
A failing computer power supply cannot hold steady voltage under demand. The obvious signs to watch for include:
Unexpected shutdowns
PC restarting on its own
PC failing to boot when you press the power button
However, some symptoms are quiet, and you can’t really see them. Your cue is to learn how to test the power supply of a computer properly.
1. A Burning Smell or a PSU Running Unusually Hot
A hot, acrid or “electrical” smell from the back of the case is a serious warning, as is exhaust air far hotter than usual. Overheating components often fail early, so stop using the PC and unplug it.
2. Clicking, Buzzing or a Fan That Behaves Oddly
Coil whine, buzzing or clicking from the PSU deserves attention, as does a loud, struggling or stuck fan. A fan spinning up and down erratically can mean a failing unit or poor airflow.
3. A PC That Needs Several Attempts to Start
Does your PC only boot on the second or third press of the power button? Perhaps the fans spin and stop. A slow-to-start PSU can fail completely soon afterwards.
4. Flickering Screens, Dropping USB Devices and Corrupted Files
Another sign is disconnecting peripherals, a flickering monitor and glitches when you are running resource intensive applications. When your PSU fails, it can corrupt your files, making you lose important data. RAM, GPU and overheating faults look identical. Learn how to test a power supply for a computer to ensure you don’t confuse either and you can actually fix the real issues in your PC.
The methods differ in effort and in what they reveal, so weigh them before choosing how to test PC power supply hardware at home.
1. Paperclip Test
If you are looking for the quickest answer to how to test a desktop power supply without extra kit, then the paperclip test is the one. This method bridges two pins on the 24-pin connector forcing the PSU to turn on without a mother board. It’s the easiest option and the only downside is that it only shows whether your PSU switches on or not.
2. Dedicated PSU Tester
A dedicated PSU tester is a small device you plug the connectors into. It shows pass/fail or voltage readouts for each rail. It’s also quick and easy, but only provides basic readings with no load.
3. Digital Multimeter
A digital multimeter measures each rail’s voltage with probes against known pin positions. This method provides a definitive answer to how to test power supply unit voltages as real numbers. It’s also quick but doesn’t apply load.
4. BIOS and Software Voltage Monitoring
BIOS and software monitoring reads the 3.3V, 5V and 12V values while the PC runs. It’s easy and live, but sensor accuracy is limited. It’s the simplest method of how to test a power supply PC when the machine still boots.
Method | Difficulty | Accuracy | Advantages | Limitations |
Paperclip test | Easy | On/off only | Fastest, no tools | No voltage data, no load |
PSU tester | Easy | Basic | Quick pass/fail | No load, limited detail |
Multimeter | Moderate | Precise at idle | Exact rail readings | No load, needs care |
BIOS/software | Easy | Moderate | Live readings | Limited sensor accuracy |
None of the quick checks replaces a test under real load.
Looking for how to test power supply units outside the PC? You can use either the paperclip or the tester method.
Paperclip Test Steps for a Desktop Power Supply
Like all the guides on how to test power supply computer units, start the process by disconnecting everything first.
Switch off at the wall (UK 13A socket), unplug the mains lead and disconnect the PSU from every component.
Bridge the green wire (PS_ON) to any black (ground) pin on the 24-pin connector with a paperclip.
Reconnect the mains lead, then switch on at the wall and at the PSU switch.
A spinning fan means the PSU can power on—not that it’s healthy under load.
How to Use a PSU Tester
Plug the 24-pin connector into the tester, then the CPU and PCIe connectors if it has sockets for them. Read each rail’s LED or LCD value, looking for “Pass” or out-of-range readings. Threads on how to test CPU power supply units usually mean this: the CPU has no supply of its own, so the 4+4-pin EPS cable feeding it is the socket to check. Like the paperclip method, it can’t confirm stability under load.
If you want to know how to test a PC power supply with a multimeter and why you should use this method, the answer is simple: This method provides real numbers.
Measuring the 3.3V, 5V and 12V Rails Step by Step
Set the multimeter to DC voltage (V⎓) on a range above 12V—20V works well. That answers the usual “what setting for 12V” question. Keep the PSU switched on, via the paperclip method or fitted in the PC. Put the black probe on a ground pin, then the red probe on each coloured wire’s pin: orange for 3.3V, red for 5V, yellow for 12V. Never let a probe touch two pins at once—that’s how to test a computer power supply with a multimeter safely. For how to test a CPU power supply cable specifically, probe the yellow EPS pins the same way.
ATX Voltage Reference Table
These tolerances follow Intel’s ATX specification.
Rail | Wire colour | Nominal | Acceptable range |
+3.3V | Orange | 3.3V | 3.135–3.465V |
+5V | Red | 5V | 4.75–5.25V |
+12V | Yellow | 12V | 11.4–12.6V |
−12V | Blue | −12V | −10.8 to −13.2V |
+5VSB | Purple | 5V | 4.75–5.25V |
Readings outside these tolerances point to a failing unit.
Most advice on how to test power supply health stops at idle.
Signs Your PSU Wattage Is Too Low
Before you search for how to test desktop power supply behaviour under load, check for these symptoms:
Desktop crashes or reboots only during gaming or heavy tasks
A system that’s fine at idle but fails when the GPU ramps up
Voltages that sag under load in monitoring software
PSU Capacity, GPU Requirements and Total System Power
Add up the GPU, CPU and everything else—say 300W, 125W and 75W—and you reach about 500W, so leave headroom. Check the GPU maker’s recommended PSU wattage and connectors, plus the 80 PLUS efficiency rating on any replacement—UK electricity costs make wasted heat expensive. That’s the gap in advice on how to test desktop computer power supply units: paperclip tests and testers create no load, so only a stress test with live monitoring shows how the unit copes.
Common Power Supply Testing Mistakes
Anyone learning how to test power supply on PC hardware trips over the same few things:
Leaving components connected during a paperclip test
Probing the wrong pins, misreading the range or trusting a “pass” at idle
Skipping the switch-off at the wall and PSU switch before reconnecting
The range slip is the classic when you first try how to test a PC power supply with a multimeter.
Why You Should Never Open a PSU Casing
Capacitors can hold dangerous voltage even when unplugged. Opening the case is a safety risk and usually voids the warranty. So whichever route you take for how to test a power supply on a computer, stay outside the casing.
Replace Rather Than Repair
Replace a PSU that fails any rail check, smells burnt, makes persistent noise or is several years old and unstable. If you have learned how to test a power supply unit and then your device fails checks, don’t repair it at home because it's not safe. In the UK, take the old one to a household recycling centre or a WEEE-compliant drop-off point, not the bin.
How to Tell a Faulty PSU From Unstable Mains and Power Cuts
How to test power supply faults versus supply faults comes down to pattern. A faulty PSU fails the tests above on any outlet. Unstable mains hits several devices, often with flickering lights. A power cut takes everything at once. Any result is only as trustworthy as the socket behind it.
How UK Mains Surges and Dips Affect Your PC and Electronics
UK homes have a nominal 230V supply. The permitted range is +10% and -6%. When there are sudden surges and brief dips, your PSU gets affected. Also, other electronic appliances, such as routers, monitors and NAS drives are affected with these.
Note: Limits can change, so check Ofgem official website or your network operator |
Practical Steps When the Power Keeps Misbehaving
If your guide on how to test PC power supply produces inaccurate results, try moving the PC to another socket. Follow the same procedure provided in the how to test the power supply of a computer guide there, try a surge-protected extension and ask your neighbours if they’re affected. For a suspected area-wide outage, call 105 to report a power cut. Repeated outages are what a household resilience setup is for.
Backup Power for a New Solar and Battery Setup
Once you know how to test power supply faults and have ruled out the unit itself, the next worry is the grid. If you’re fitting solar and storage together, then you need a home battery solution that can help provide stable power supply. The EcoFlow STREAM 5000 is such an option. It is a 5kWh hybrid battery with direct solar input and up to 3,000W of AC output. Fitted by a certified electrician, it can keep compatible equipment running through a power cut, with solar topping it up by day.
Adding Battery Storage to Existing Solar Panels
If your PC keeps shutting down during outages, learning how to test power supply health only solves half the problem. If you already have solar panels and an inverter, you can add storage alongside them—for example, the EcoFlow STREAM AC 5000—which is a 5kWh AC-coupled battery designed to work with an existing system. Fitted by a certified electrician, it can supply backup electricity to compatible equipment when the mains drops.
Learning how to test power supply issues is one of the best ways you can use to eliminate costly guesswork, protect sensitive hardware and keep your desktop running smoothly. This guide has looked at various methods, including using paperclip, a tester, precision multimeters and load tests, and how you can use each to identify whether your PSU is failing, voltage rails are drifting or your mains electricity is the issue behind your system crashes. If you are experiencing external grid fluctuations or sudden power cuts, then it's time you add a reliable backup solar battery storage to guarantee total power stability.
What Makes a Power Supply Bad?
A bad power supply is a unit that can no longer deliver stable, in-spec voltage. Age, heat, dust, overloading, surges and low-quality components are the usual causes, whether you’re chasing how to test CPU power supply faults or how to test desktop computer power supply problems.
How to Tell if You Fried Your Power Supply?
A fried PSU usually shows a burning smell, no power at all, a tripped plug fuse or visible damage after a surge. Run the paperclip test—the quickest answer to how to test a power supply on a computer that won’t boot. For how to test power supply on PC hardware beyond that, use the multimeter steps, including how to test a CPU power supply cable.
How to Fix a Bad Power Supply?
Fixing a bad power supply means replacing it, not repairing it. Never open the casing. Confirm the fault with the how to test a power supply PC checks and how to test a desktop power supply steps above, then buy a unit with enough wattage.
Why Is My 12V Power Supply Not Working?
A 12V supply that isn’t working has usually lost its input, its connection or its ability to carry the load. Check the wall socket, plug fuse and connections, then whether the device draws more than the unit’s rating. For a PC’s 12V rail, take the yellow-wire reading, as any how to test power supply computer guide would. Still nothing? Run the how to test a power supply unit steps and replace the unit if it fails.
