Aquarium Fish Tank for Home: Running Costs and How to Protect It in a Power Cut
An aquarium fish tank for home looks like a small, quiet appliance, but it runs 24 hours a day. The heater drives the bill, which comes to about £55 to £468 a year at the Ofgem price cap of 26.32p per kWh (October–December 2026). That same heater, the filter and the air pump all stop together in a UK winter storm or local network fault, while your fish keep breathing. Below: what a tank costs to run, what fails first in a power cut, how to size backup power and where home energy storage fits.
A freshwater aquarium with tropical fish and aquatic plants in a UK living room, with a home battery in the background
How Much Power a Home Aquarium Uses
Five pieces of kit set the power load of an aquarium fish tank for home: heater, filter, lighting, air pump and circulation pump. The formula is simple: daily kWh = watts × hours ÷ 1,000. Heater wattage follows the tank. Retailers size it at 1W per litre in a normally heated room and 1.5–2W per litre in a cold garage, conservatory or draughty room. Across fish tanks for the home, the heater is the number to watch.
Equipment Wattage and Daily kWh
Search fish tank for home kits and the wattages sit scattered across listings. This table pulls them together for the 180-litre medium tank used throughout.
Equipment
Typical draw
Runs
Type
Daily kWh (180 L)
Heater
50W (small tanks) to 200W (180 L)
8 full-load hours
Intermittent
1.600 (200W)
Filter
4–7W internal; 20–28W external canister
24 hours
Continuous
0.168 (7W)
LED lighting
8W small hood; 48W Helialux 1000; 90W stock Rio 180 lights
8 hours, timer
Intermittent
0.720 (90W)
Circulation pump
3.5–5W
24 hours
Continuous
0.000 (used on 400 L)
Air pump
3W planning allowance
24 hours
Continuous
0.072
That gives 2.560 kWh a day for the 180 L tank.
Note: wattages come from retailer and manufacturer figures. Check the rating label on your own kit.
Continuous Versus Intermittent Loads
Continuous loads run around the clock; intermittent ones switch on and off. Filter, circulation pump and air pump are continuous. Together they use 0.24 kWh a day on the 180 L tank, 9% of its total. The heater cycles on its thermostat but still takes 62% of the 180 L tank's daily kWh, 70% on the small tank and 66% on the large one.
Lighting runs on a timer, so hours are your choice. Planted tanks run up to 12. And a room below 20°C keeps the heater going almost without a break, according to JBL.
Aquarium Fish Tank for Home Running Costs in the UK
Here's what an aquarium fish tank for home costs at 26.32p per kWh (the Ofgem cap, 1 October–31 December 2026, electricity at 0% VAT), with 8 full-load heater hours, 8 lighting hours and no standing charge. On another tariff? Multiply annual kWh by your own unit rate.
Three Tanks Compared
Browse fish tanks for homes and three sizes cover most households: small freshwater, medium community and large tropical.
Setup
Heater
Filter and pumps
Light
Daily kWh
Annual kWh
Annual cost
Monthly
Share of 2,500 kWh home
Small freshwater (60 L)
50W
4.4W
8W
0.570
207.9
£54.72
£4.56
8.3%
Medium community (180 L)
200W
7W + 3W air
90W
2.560
934.4
£245.93
£20.49
37.4%
Large tropical (400 L)
2 × 200W
28W + 2 × 5W + 5W air
80W
4.872
1,778.3
£468.04
£39.00
71.1%
Daily cost: 15p for the small tank, 67p for the medium, £1.28 for the large. As a cross-check, Jackery UK's £240.60 a year at 24.67p for a 75-gallon-plus setup scales to £256.69 at 26.32p, so this model sits 4% below it.
Step-by-Step Cost Calculation
For the 180 L tank, here's how the daily energy use adds up in six simple steps:
  1. Note the wattage of each device: a 200W heater, 7W filter, 90W light and 3W air pump.
  2. Set the hours: 8, 24, 8, 24.
  3. Multiply watts by hours for Wh: 1,600 + 168 + 720 + 72.
  4. Add them up and divide by 1,000: 2.56 kWh a day.
  5. Multiply by 365: 934.4 kWh.
  6. Multiply by 0.2632: £245.93 a year, or 67p a day.
Then fit a plug-in energy meter to the three-pin socket. It swaps every assumed hour for a measured one.
What Happens to an Aquarium During a Power Cut?
A power cut is a break in your mains supply that switches off every plugged-in device at once. For an aquarium fish tank for home, filtration, circulation, aeration and heating all fail together. UK Power Networks recommends a battery-powered air pump and insulation to protect tropical fish. Call 105 (free) to report a fault.
Why Filtration and Water Movement Matter
The filter cleans the water by trapping waste and providing a home for beneficial bacteria. These bacteria break down toxic ammonia from fish waste into less harmful substances. When the filter stops, the bacteria receive less oxygen. Water movement also slows, reducing the amount of oxygen entering the tank. Don't leave it too long and stagnant media can turn bad, test it before re-starting. This is the reason why battery-powered aeration is the first choice in fish keeping recommendations for UK fishkeepers.
Why Tropical and Cold-Water Tanks Face Different Risks
Tropical fish need a heater to keep their water warm, usually in the mid-20s °C. Goldfish are comfortable in cooler water, while danios can live without a heater, helping to reduce electricity costs. However, both still need enough oxygen and clean water to stay healthy. Smaller tropical tanks also lose heat faster during a power cut. Guides to the best fish for home fish tank setups and the best fish for fish tank at home often focus on daily care but overlook power outages. Neon tetras, for example, are particularly sensitive to sudden drops in temperature. Whatever fish for home fish tank you choose, check its temperature tolerance and outage resilience before buying.
Equipment
Backup priority
Risk when power stops
Filter
High
Reduced filtration and water movement
Air pump
High
Lower oxygen exchange
Aquarium heater
High for tropical tanks
Water cools below the species' range
Circulation pump
High where essential
Stagnant areas, poorer oxygen distribution
Aquarium light
Low
Temporary loss of lighting
Automatic feeder
Low
Feeding continues when it should pause
How Long Can Fish Survive Without Aquarium Electricity?
There’s no set amount of time that fish can safely survive without electricity. It depends on the conditions in your aquarium fish tank for home and the room around it. Larger tanks lose heat more slowly than smaller ones, giving fish more time. Tanks with fewer fish also tend to cope better because they use less oxygen and produce less waste. Active, sensitive or oxygen-hungry fish need closer attention.
Room temperature, insulation, water volume and surface movement all affect how quickly conditions change. Even in a warm room, the water starts cooling once the heater stops. Oxygen levels also drop, while waste continues to build up. Clear water doesn't always mean safe water. Without circulation, beneficial filter bacteria also struggle, and ammonia levels can rise.
A brief power cut might cause no lasting harm, but a longer one can put fish at risk, especially without a battery-powered air pump. Keep an eye on fish behaviour and test the water rather than relying on a fixed survival time.
What to Do Before, During and After a Power Cut
Your aquarium fish tank for home needs a plan for three stages: before the cut, during it and once power returns.
Prepare an Aquarium Emergency Kit
Keep a few essentials ready so you aren't caught off guard during a power cut:
  • A battery-powered air pump, spare batteries, airline tubing and an air stone.
  • A reliable thermometer, water-testing kit, treated replacement water and clean containers.
  • Blankets or suitable insulation to help keep the tank warm in cold weather.
  • Equipment manuals and supplier contact details somewhere easy to find.
Protect Fish While the Electricity Is Off
If the electricity goes off, a few simple steps can help keep your fish safe:
  • Cover the tank and insulate the sides, leaving room for gas exchange.
  • Run the battery-powered air pump to keep the surface moving.
  • Stop feeding to limit waste and oxygen demand.
  • Keep checking the water temperature and watching your fish for signs of stress. Never add untreated hot water directly to the tank.
    Note: This is general guidance, not veterinary advice. If your fish show signs of distress, ask your aquatic retailer or a vet.
Check the Aquarium When Power Returns
  • Confirm the filter, heater and circulation equipment restart correctly.
  • Inspect filter media and follow suitable aquarium guidance before normal operation.
  • Test ammonia and nitrite over the following days, especially after a long outage.
  • Resume feeding cautiously once water quality has stabilised.
How to Choose Backup Power for an Aquarium
Size backup power around essential equipment, not every device.
Calculate the Essential Load
Reviews of the best fish tanks for home often list supplied wattage, such as the Juwel Rio 180's 297W rated load, and photos of beautiful fish tanks for home hide extras behind the rockwork. Browse fish tank ideas for home, then list every device. Take Table 1's medium tank without the light: a 200W heater, 7W filter and 3W air pump make a 210W load. Energy (Wh) = running watts × hours. If the heater ran non-stop for 12 hours, that is 2,520Wh. At 8 full-load heater hours a day it is nearer 920Wh. A cold-water tank needs about 10W. A 5,024Wh battery is not a 23.9 hour answer: Conversion losses, usable capacity, equipment loads such as heater cycling etc. alter the actual runtime, and you need to match your output equipment with the inverter's output rating and continuous running rating of your motor.
Compare Backup Options
Backup option
Best suited to
Main advantage
Main limitation
Dedicated aquarium battery
Small tanks, emergency aeration
Targeted backup for an air pump
Limited support for heaters and filters
Portable power station
Small and medium aquariums
Runs several compatible devices
Runtime depends on capacity and load
Home battery storage
Larger aquariums, wider household needs
Supports essential circuits when configured for backup
Professional installation and backup configuration required
A battery-powered air pump helps keep oxygen levels up, but it won't run a heater or larger filter. Check how long its battery lasts, the battery type and how quickly it switches on when the power fails. A portable power station can run compatible aquarium equipment through standard three-pin sockets, but a powerful heater will drain it quickly. Keep the unit indoors, allow proper ventilation and keep cables tidy. Regular grid-connected home battery storage also needs a backup setup to supply power during an outage. Your installer must also notify the distribution network operator (DNO).
Protect Your Aquarium With Home Energy Storage
Protecting filtration, circulation and temperature comes down to the essential load of your aquarium fish tank for home and your household's backup needs. Home energy storage can help with both when set up for backup operation, and by holding midday solar for evening and overnight loads it can ease running costs too.
Building Solar and Storage Together From Scratch
Starting solar from scratch? Plan the aquarium's backup from day one. For example, the EcoFlow STREAM 5000 offers 5kWh (5,024Wh) of capacity, expandable up to 90kWh, with 5,000W of PV input across four MPPT channels at 1,250W each and 3,000W of AC output. Intelligent Mode+ manages energy automatically, and the compact unit has a built-in handle. For your aquarium fish tank for home, confirm equipment compatibility, backup configuration and installation requirements before relying on it in an outage.
EcoFlow STREAM 5000
Installed home battery for homes without solar. UK rules require installation, and the setup is designed to be simple 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for high-demand appliances like stoves, dryers or kettles (when solar is generating or an Expansion Battery is paired) 5,000W solar input makes full use of your solar generation Up to 2500W AC charging for fast recharge Smart meter, main unit and solar panels are designed to connect easily, with step-by-step app guidance for setup Compact 45.4kg body with a built-in handle for easier placement during installation Residential-grade protection with pressure-release and fire-resistant materials, designed to reduce thermal runaway risk with high-voltage solar panels Rated for 10,000 cycles Local Mode keeps the system running and communicating even if the network drops
Adding Battery Storage to Existing Solar Panels
Already have panels on your roof? A battery can store what you generate. For example, the EcoFlow STREAM AC 5000 also offers 5kWh (5,024Wh), expandable up to 90kWh, with 3,000W of AC output and 10,000 guaranteed cycles. Intelligent Mode+ handles energy management automatically, and Local Mode keeps it stable offline. Before treating it as protection for your aquarium fish tank for home, have an installer assess your actual aquarium load, output compatibility and backup configuration. Don't assume either system switches over automatically or guarantees a set runtime.
Installed home battery for homes with existing solar. UK rules require installation, and the setup is designed to be simple Works with existing rooftop PV systems, home battery systems and leading third-party meters 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for heavy household appliances (when solar is generating or an Expansion Battery is paired) AC coupling adds storage alongside your current solar setup, and a Gateway simplifies expanding later Compact 44.6kg body designed to fit into spaces around the home Rated for 10,000 cycles
Note: Compliant generation-only plug-in solar kits have been legal to buy and use in Great Britain since 27 August 2026, but these rules do not cover plug-in batteries or solar-plus-storage systems. Home batteries and systems with integrated batteries (like the EcoFlow STREAM range) are not plug-in solar products. They must be professionally installed and must comply with IET Wiring Regulations (BS 7671) and DNO connection requirements. Ensure you follow current guidance given by GOV.UK and contact a qualified installer to find out what is needed for your home.
The heater accounts for 62-70% of the bill. A small tank costs £54.72 a year, a medium £245.93 and a large tropical tank £468.04 at 26.32p. The total is reduced by a cold-water setup, LED swap and reduced heater hours. Before you buy an aquarium fish tank for home, price the heater first.
Once the tank's load is in proportion, the bigger savings sit with household energy management and home energy storage. Explore the EcoFlow STREAM 5000 and EcoFlow STREAM AC 5000 on the EcoFlow UK to find home energy storage that suits your solar plans.
FAQ About an Aquarium Fish Tank for Home
What Size Aquarium Is Best for a Home?
Beginners should use a minimum size of 60 litres as smaller tanks are more susceptible to changes in temperature and water quality. The compromise is space and weight; the 180 litre tank will add approximately 180kg of weight plus the stand.
Where Should You Place a Fish Tank in Your Home?
Choose a stable, level surface away from direct sunlight, draughts, radiators and busy walkways, with a socket within reach and room for maintenance.
How Long Before You Add Fish to a New Aquarium?
Run the filter and heater for four to six weeks first, so the bacteria that process waste can establish. Add a few hardy fish, then test ammonia and nitrite before each addition.
Home Solutions
