Water Pump for Home: Electricity Costs and How to Keep It Running in a Power Cut
A water pump for home rated at 550W doesn't use that much electricity every minute of the day. It only draws power when running, so your bill depends on how often you use water and how long the pump stays on. If you're comparing water pumps for home, the specifications tell only part of the story. The real question is how much the pump costs to run. We've calculated the costs for four common pump types using Ofgem's October–December 2026 Great Britain average of 26.32p/kWh (Direct Debit). Even a water pressure pump for home can cost just pennies a day. We'll also look at simple ways to reduce running costs and how home energy storage can help keep essential equipment running if you have solar.
Domestic water pressure booster pump with connected pipework in a UK home utility room, with a home battery in the background
How Much Electricity Does a Water Pump Use?
A water pump for home uses an electric motor to move water or increase pressure. The wattage on its label tells you how much power it needs while running, not how much it uses throughout the day. For example, a 550W pump running for one hour uses 0.55kWh. When switched off, it uses no electricity. To work out your consumption, multiply the pump's power in kW by the number of hours it runs. Most listings for water pumps for home show the wattage but say little about daily running time. That's the detail that makes the difference to your electricity bill.
Typical Water Pump Wattage and Daily Consumption
Product specifications give us a useful starting point. The Grundfos STR2-1.5C shower booster uses 340W, while Grundfos's variable-speed home booster has a 550W input. The T-T Pumps Goliath Super submersible pump is rated at 400W, as are some garden pumps sold by Toolstation. These figures show how much power each electric water pump for home needs while running. They don't tell you how much electricity it uses each day. For that, we need to consider how long the pump operates. Table 1 uses estimated running times to show the difference. These are examples, not national averages.
Pump type
Rated power
Assumed daily running
Daily use
Shower booster
340W
1 hour
0.34kWh
Household pressure booster
550W
1.5 hours
0.825kWh
Submersible pump
400W
2 hours
0.80kWh
Garden irrigation pump
400W
30 minutes
0.20kWh
Note: The garden example assumes a watering day, not every day. Figures draw on manufacturer specifications and retailer listings.
Motor Power Versus Automatic Standby
An automatic water pressure pump for home starts when a pressure switch or flow sensor detects demand and stops when it ends, so it doesn't draw full power while the house is quiet. That's what shoppers want from a water booster pump for home automatic model. It is compromised by leaks: a small leak can cause pressure to drop and re-start the pump over and over again, and result in wastage of electricity. But the same short cycling occurs due to worn pressure vessels and bad switches. Variable-speed boosters regulate their output according to demand and CIBSE says they can consume less energy than fixed-speed pumps.
Water Pump Running Costs in UK Homes
Even a water pressure pump for home costs pennies a day. All figures use 26.32p/kWh (Ofgem, October–December 2026, Direct Debit). Standing charges are not considered fixed as they are paid whether the pump is running or not. If it is a fixed rate or regional rate then use the unit rate.
Daily, Monthly and Annual Electricity Costs
Table 2 applies that rate to Table 1. The shower, booster and submersible examples run 365 days; the garden pump runs 120 watering days. For the shower booster: 0.34kWh × 365 = 124.1kWh, and 124.1kWh × 26.32p ≈ £32.66.
Pump setup
Annual use
Annual cost
Monthly average
Shower booster, 340W
124.1kWh
£32.66
£2.72
Household pressure booster, 550W
301.1kWh
£79.25
£6.60
Submersible pump, 400W
292kWh
£76.85
£6.40
Garden pump, 400W
24kWh
£6.32
£0.53
Note: Planning examples based on stated wattages and running times, not measured bills. Even though the garden pump is used only during the watering season, the monthly cost of the pump is averaged over a 12-month period.
On each day they run, the shower booster costs about 9p, the household booster 22p, the submersible pump 21p and the garden pump 5p. You can work out your own water pump for home running costs by multiplying its wattage (divided by 1,000) by running hours, days and your unit rate. For context, Ofgem's typical household uses 2,500kWh a year. The household booster in our example uses 301.1kWh, or about 12% of that total. Its £79.25 annual cost is also around 12% of a typical £658 electricity bill. That's a noticeable expense, but hardly a reason to panic. Choosing an oversized booster water pump for home or ignoring a leak can push costs higher without giving you better water pressure.
What Happens to a Water Pump During a Power Cut?
When the power goes out, your water pump for home stops working too. The water hasn't disappeared from your borehole, loft tank or mains pipe. The problem is that the pump can no longer move it to your taps. What happens next depends on your water supply. Homes connected to the mains usually experience low pressure, while borehole homes can lose their water supply altogether. Gravity-fed cold taps will keep running until the loft tank empties, but pumped showers won't work. Storm Arwen in 2021 left some UK households without electricity for more than a week. It's a good reminder to prepare for longer outages. If your power goes off, call 105 free of charge to report the outage.
How Different Water Pumps Respond to Power Loss
Grundfos confirms its SCALA booster pumps stop boosting in a power cut without backup power, though some mains flow may remain. An automatic water booster pump for home can't restart itself without a live supply.
Pump type
Example power
Effect of power loss
Main concern
Mains booster pump
550W
Stops; some mains flow may remain
Weak pressure
Private well pump
Check rating plate
Delivery stops
No household water
Submersible supply pump
400W
Transfer stops
Empty tanks
Sump pump
Check rating plate
Drainage stops
Basement flooding
Gravity-fed system
None
Flows until storage runs low
Limited remaining water
Which Homes Are Most Vulnerable?
Rural homes on private boreholes, springs or wells take the biggest hit, followed by electrically pumped storage tanks and basements relying on sump pumps. Work out which kind of system you have. Mains-fed homes fare better: with a water booster pump for home, you'd normally lose pressure, not supply. To check, trace the incoming pipe from your stopcock and look for a pump beside it or near the storage tank.
How Much Backup Power Does a Water Pump Need?
Backup for a water pump for home takes more than matching a battery to the label: running power, the short starting surge above it and daily running time decide the answer.
Wattage, Surge and Running Time
Check the rating plate for input power, voltage and current. Take the 550W booster from Table 1: 550W × 1.5h = 0.825kWh a day, or about 0.95–0.99kWh with 15–20% added for conversion losses. A 15-minute run uses 0.1375kWh. Starting surges frequently catch buyers off guard. An electric motor can draw three to five times its continuous running power for a fraction of a second when starting up, which the inverter must be able to handle. A 1,000W inverter won't necessarily run a 550W motor if the peak starting surge exceeds the inverter's maximum output limit. For automatic water booster pump for home, if you start it regularly for short periods, it really does add up, so if the manufacturer gives you the starting current, then count each time a pressure water pump for home bursts. The approximate daily requirement will be pump kW x hours pump is running, plus 15-20%.
Which Backup Power Solution Suits Your Water Pump?
Three routes suit a water pump for home: dedicated pump batteries, portable power stations and home battery storage. The real split is automatic changeover versus connecting equipment by hand, and hardwired connections need a qualified electrician working to BS 7671.
Dedicated Water Pump Backup Batteries
These backup batteries are designed for a specific pump and usually switch on automatically when the mains power goes out. That means your pump can keep running even when you're away from home. Before buying, check the battery capacity, inverter output and built-in protection to make sure they're suitable for your pump. If you're backing up a water pressure booster pump for home, pay close attention to how well the system handles frequent starts. Well and sump pumps also need enough starting power and reliable restart protection.
Portable Power Stations for Domestic Pumps
A portable power station supplies AC outlets for compatible plug-in pumps during a temporary outage. Compare continuous and peak output with the surge of the pump. Only use indoors, in dry and well-ventilated spaces, away from damp spaces. It requires manual connection which is not automatic backup.
Home Battery Storage for Water Pumps
Home battery storage can feed selected compatible circuits and holds more than a dedicated pump battery. Running with the grid is no backup—there's a way to do that. A hardwired water pump booster for home is professionally designed and your installer deals with DNO notification in G98 or G99.
Backup solution
Main advantage
Main limitation
Best suited to
Dedicated pump battery
Built around a specific pump
Limited to compatible equipment
Essential well or sump pump
Portable power station
Portable; simple for plug-in pumps
Surge limits; manual connection
Temporary backup
Supports several loads
Needs suitable set-up and installation
Whole-household resilience
How to Cut Pump Costs and Prepare for Winter Outages
Reduce Unnecessary Pumping
Give your water pump for home a quick check before storm season arrives. Make sure you've chosen the right pump for the job. A booster increases pressure in existing pipework, while a submersible pump moves water from a tank or sump. Setting the pressure too high wastes electricity and puts extra strain on pipe joints. A variable speed model may be more suitable for changing water requirements. When selecting a silent water pump for home, get it in anti-vibration mounting to minimize noise. Remember, quiet operation doesn't necessarily mean lower electricity use. Fix any leaks, clean the inlet filters and inspect the pressure vessel if the pump keeps switching on and off. If your installation increases demand above 12 litres per minute, you must notify your water company. For drinking-water systems, choose WRAS- or Kiwa-approved boosters.
Prepare for a Power Cut
  • Confirm whether you rely on a mains booster, private well, pumped tank or sump pump.
  • Store three litres of drinking water per person per day for three days, as UK Government guidance recommends.
  • Save your water company's emergency number; Ofwat expects companies to arrange alternative supplies, and private supply owners should arrange their own.
  • Inspect sump pumps, float switches and discharge pipes before heavy rain, and test backup batteries.
  • Keep electrical equipment clear of floodwater, and never enter flooded areas to run it.
    Note: Regulations and guidance can change and vary by region. Check GOV.UK, Ofwat, the Drinking Water Inspectorate and your water company.
Protect Your Pump With Home Energy Storage
Your pump is part of many loads, and it's a good idea to have storage that is meant to carry multiple critical loads. Rated watts is not the only way to be compatible; starting current, connection, continuous demand and available output are all important, and running from the grid is not backup.
Planning Solar and Storage Together
If you're planning to install solar panels, think about both generation and storage, based on the appliances you want to keep running. The EcoFlow STREAM 5000 provides 5kWh (5,024Wh) of storage, expandable up to 90kWh. It supports 5,000W of solar input across four 1,250W MPPT channels and delivers up to 3,000W AC output. The compact unit also has a built-in handle, while Intelligent Mode+ manages energy use automatically. If you plan to run a water pump for home with this system, ask a qualified installer to check the pump's starting surge, running load and backup configuration first.
EcoFlow STREAM 5000
Installed home battery for homes without solar. UK rules require installation, and the setup is designed to be simple 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for high-demand appliances like stoves, dryers or kettles (when solar is generating or an Expansion Battery is paired) 5,000W solar input makes full use of your solar generation Up to 2500W AC charging for fast recharge Smart meter, main unit and solar panels are designed to connect easily, with step-by-step app guidance for setup Compact 45.4kg body with a built-in handle for easier placement during installation Residential-grade protection with pressure-release and fire-resistant materials, designed to reduce thermal runaway risk with high-voltage solar panels Rated for 10,000 cycles Local Mode keeps the system running and communicating even if the network drops
Adding Battery Storage to Existing Solar Panels
Already have panels? A battery can store daytime surplus for the evening. The EcoFlow STREAM AC 5000 offers 5kWh (5,024Wh), expandable up to 90kWh, with 3,000W AC output. Intelligent Mode+ manages energy automatically and Local Mode keeps it stable offline. When installing a water pump for home, an installer will need to ensure the motor's surge is within the pump's output and that the connection can support backup. While home energy storage operates as whole-house or sub-circuit backup rather than an inline pump battery, it offers substantial capacity to keep essential pumps running during extended outages.
Installed home battery for homes with existing solar. UK rules require installation, and the setup is designed to be simple Works with existing rooftop PV systems, home battery systems and leading third-party meters 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for heavy household appliances (when solar is generating or an Expansion Battery is paired) AC coupling adds storage alongside your current solar setup, and a Gateway simplifies expanding later Compact 44.6kg body designed to fit into spaces around the home Rated for 10,000 cycles
Note: Compliant generation-only plug-in solar kits have been legal to buy and use in Great Britain since 27 August 2026, but these rules do not cover plug-in batteries or solar-plus-storage systems. Home batteries and systems with integrated batteries (like the EcoFlow STREAM range) are not plug-in solar products. They must be professionally installed and must comply with IET Wiring Regulations (BS 7671) and DNO connection requirements. Ensure you follow current guidance given by GOV.UK and contact a qualified installer to find out what is needed for your home.
At 26.32p/kWh the example pumps cost about £32.66 (shower booster), £79.25 (household booster), £76.85 (submersible) and £6.32 (seasonal garden) a year. In a power cut, mains boosters lose pressure, well pumps lose supply and sump pumps risk flooding, so check wattage, surge and running time before buying backup. Fix leaks and store three days of drinking water.
Your water pump for home is one load among many, and home energy storage can support wider household resilience for compatible equipment. Explore the EcoFlow STREAM 5000 and EcoFlow STREAM AC 5000 on the EcoFlow UK website to find a home energy storage solution that suits your solar setup and backup requirements.
FAQ About Water Pumps for Home
Can a Water Pump for Home Use Run From a Standard UK Three-Pin Socket?
It depends on the size. Some smaller pumps ship with a three-pin plug, but larger or permanently installed systems need a suitable electrical connection fitted by a competent electrician. Follow the manufacturer's instructions and circuit requirements, including the fuse rating.
Can I Use a Water Pump With a Combi Boiler?
Not automatically. Shower pumps designed for gravity-fed systems aren't suitable for combi boilers, which rely on mains pressure. Diagnose the supply problem first, then check a product's stated compatibility with a Gas Safe registered engineer.
Is a Generator Better Than a Battery for Running a Household Water Pump?
A generator can run longer if you have fuel and handles motor starting well, but needs maintenance, ventilation and safe outdoor use, and it's noisy. A battery is quieter and makes no exhaust at the point of use.
Home Solutions
