How Virtu PVT Could Slash Heat Costs in UK Buildings
- What Is Virtu PVT and How Does It Make Heat and Power?
- Virtu PVT vs Solar PV Panels vs Other Solar PVT Systems
- Which UK Buildings Get the Most from Virtu PVT?
- Virtu PVT Cost, Price and Payback in the UK
- How to Store Solar Electricity and Solar Heat
- Solving the Storage Pain Points of a Solar PVT Setup
- Conclusion
- Virtu PVT Frequently Asked Questions
Rising gas and electricity bills in the UK are making homeowners start thinking about generating their own energy. However, there is also another pain point: limited roof space that may be sufficient for one solar panel. Virtu PVT is Naked Energy’s British-made answer: a single solar PVT collector that simultaneously generates electricity and captures heat. It isn’t a typical home install. It suits buildings with steady, year-round heat demand, such as hotels, leisure centres, flats and industrial sites, where hot water gets drawn every day. If that sounds like your building, read on.
This guide looks at:
What Virtu PVT is and how it works
A comparison between Virtu PVT vs Solar PV Panels vs Other Solar PVT Systems
The type of UK buildings that can make the most from Virtu PVT
Virtu PVT Cost, price and payback in the UK
How to store solar electricity and solar heat
How to solve the storage pain points of a solar PVT setup using modern home energy storage
Virtu PVT is a solar PVT collector built inside an evacuated glass tube that produces electricity and heat together. PVT stands for photovoltaic-thermal. So if you’ve ever searched “what is a PVT solar panel?”, that’s your answer: one unit, two outputs, and no need to split your roof between them.
Inside the Tube Where Cells, Absorber, Vacuum and Reflector Work Together
PERC monocrystalline cells sit on an absorber plate inside the tube. Fluid flowing through the absorber carries away heat, which helps keep the cells cooler. A reflector between the tubes redirects extra sunlight onto them.
The vacuum ensures that less heat escapes and the tubes keep working during cold, grey UK weather days. According to Naked Energy, it produces heat output of up to 75°C. The standard model generates 70W of electrical and 275W of thermal at peak performance. However, on bad-weather days, it produces a fraction of these figures.
What the Heat Can Actually Be Used For
At up to 75°C, the heat suits low-temperature jobs. The main ones are pre-heating hot water, feeding hot-water cylinders and acting as a heat source for heat pumps. It won’t drive high-temperature industrial processes. For those, Naked Energy makes a heat-only collector called VirtuHOT, which reaches 120°C. Buildings with year-round hot-water draw, like hotels and leisure centres, use this heat almost daily.
Virtu PVT is one of four roof options you’ll weigh up, alongside conventional solar PV, solar thermal and flat-plate PVT. The pain point is simple: you have one roof, so which technology gets the most from it? Let’s look at each.
Virtu PVT vs Conventional Solar PV
Solar PVs convert sunlight into electricity, which means you get power but no usable heat. Therefore, you rely on other sources like gas to run your boilers. A good PV panel out-produces a Virtu PVT collector in terms of electricity per square metre. However, the Virtu PVT adds heat, which means its total energy captured is higher than that of the Solar PVT.
Virtu PVT vs Solar Thermal Collectors
Solar thermal collectors make heat and nothing else. If your building also needs power, you’ll need a separate PV array, and that means more roof. Virtu PVT adds electricity to the heat on the same footprint. The trade-off is temperature. Dedicated thermal collectors can run hotter, so very hot process water may still favour them.
How It Differs from Flat-Plate Solar PVT
Flat-plate solar PVT panels also make both outputs, but heat escapes from them more easily in cold weather. Evacuated tubes lose less, which matters in a UK winter. Installation works on flat roofs, pitched roofs and façades. As trust signals, the collector is certified by TÜV Rheinland and holds an ICC-SRCC OG-100 certification.
Feature | Virtu PVT | Conventional solar PV | Solar thermal collectors | Flat-plate solar PVT |
What it produces | Electricity and heat | Electricity only | Heat only | Electricity and heat |
Roof-space use | One collector type serves both needs | Needs separate heat system elsewhere | Needs separate PV array for power | One panel type serves both needs |
Cold-weather heat retention | Strong, thanks to vacuum insulation | Not applicable (no heat captured) | Strong with evacuated tubes, weaker with flat plates | Weaker, as heat escapes more easily |
Mounting options | Flat roof, pitched roof, façade | Mostly roof, some ground-mount | Roof or ground | Mostly roof |
Best suited to | Buildings with steady heat and power demand | Buildings with mainly electricity demand | Buildings with mainly hot-water demand | Lower-temperature heat needs |
The best buildings for Virtu PVT use heat every day of the year, such as hotels, hospitals, leisure centres with pools, apartment blocks and industrial facilities. A typical semi-detached home with low hot-water use is a poor fit. UK sunshine is modest, so the business case rests on a building that can use every kilowatt-hour of heat.
Pairing Virtu PVT with Heat Pumps and Hot-Water Cylinders
Hot-water cylinders take heat directly, making them the easiest pairing. If you want your heat pumps to operate optimally, give them a heat source that’s warm. Solar heat can raise the source temperature and reduce the pump’s running load. Less load means less electricity for the same output. For this setup you need an MCS-certified installer for any heat pump work because controls, pipework and sizing all matter.
Why Thermal Storage Matters
Heat generated at midday rarely matches demand. A buffer tank stores it until you need it especially for evening showers or early-morning pool top-ups. Without storage, the collectors would stall once the water in the system is hot. Install a tank that matches your real draw.
UK Examples
The British Library in London is the best-known UK reference. Monitoring of its 180 m² PVT field recorded 297 kWh/m² of solar heat, ahead of simulation, and 72 kWh/m² of electricity, about 2.5% below expectations. Westgate leisure centre and the Active Office in Swansea are other UK installations. One site’s results won’t transfer exactly to yours, but they show what a well-matched building looks like.
Virtu PVT pricing is quote-based and project-specific. So, there is no honest cost per square feet figure. But, before giving you quotes, the installers must see your roof first to give you a figure that matches your unique needs. These are some of the factors that affect the total cost of Virtu PVT setups:
What Drives the Virtu PVT Price
The Virtu PVT price you’re quoted depends on four things:
The number of tubes
The mounting type
Plumbing and storage integration
Design work
These four factors influence the Virtu PVT cost of your project. Heat-as-a-Service financing exists through Naked Energy and E.ON, which typically means less upfront capital. Ask for a purchase quote and a service quote, then compare the Virtu PVT price in both forms.
Note: Costs, tariffs and funding schemes change. To get up-to-date figures, visit Ofgem official website for energy price cap, the official UK government portal for current funding and Naked Energy for your project quote. |
Payback Depends on Using Both Outputs
Consuming both the electricity and heat onsite gives you the strongest payback. Electricity helps lower your dependency on the grid while heat helps lower your dependency on gas. However, the major source of risk is wasted heat in the summer when demand drops and tanks fill. A pool, a laundry or constant hot-water draw soaks up that surplus. So, when setting up your setup, model your summer demand first, not your winter demand.
Roof Space, Maintenance and Monitoring
When sizing, consider your available roof space or façade area. Your heat demand should come in second. Virtu PVT maintenance demands are low but your pumps and controls require routine checks. Naked Energy has a Clarity monitoring system for tracking heat and power output, which helps spot underperformance early before it eats into payback.
Solar output peaks at midday, but your building’s demand often peaks in the evening. Storage closes that gap, and a solar PVT system needs two kinds.
Storing Solar Electricity in a Battery
A battery holds midday surplus electricity for evening use, in a home or a commercial building. The electrical output from a Virtu PVT array can feed one. But a battery stores electricity only. It can’t hold the heat the collector captures.
Storing Solar Heat in Cylinders and Buffer Tanks
Hot-water cylinders and buffer tanks hold the heat. They cover evening showers, pool heating and heat pump demand after the sun has gone. Per kWh, thermal storage is typically far cheaper than electrical storage, since it’s mostly insulated water. Ask your designer for a cost-per-kWh comparison of both.
Why a Virtu PVT System Needs Both Types of Storage
A Virtu PVT system needs both a battery and a cylinder. The battery stores surplus electricity generated while the hot-water cylinder stores the generated heat. If you install only one, then the other goes to waste or exported to the grid at low prices.
Keep Surplus Solar Electricity for the Evening Peak
Starting a solar system with storage means midday surplus can power your evening. For example, the EcoFlow STREAM 5000 pairs solar input with a 5kWh battery, expandable to 15kWh per unit and up to 90kWh across a system. Its Intelligent mode can shift charging towards cheaper time-of-use tariffs. It suits households exploring solar plus a battery, and it won’t replace the thermal side of a Virtu PVT array. In the UK, a registered electrician must install it.
Add a Battery to Solar Panels You Already Own
If you already own solar panels but export surplus cheaply, AC-coupled storage lets you keep them and store the extra instead. For example, the EcoFlow STREAM AC 5000 offers the same 5kWh base, expandable capacity and a 10-year warranty. It stores electricity only, so the heat from Virtu PVT still needs a cylinder or buffer tank. Treat it as the electrical half of your storage plan, and have a registered electrician fit it.
Virtu PVT is a space-saving solution for UK buildings that need both electricity and low-temperature heat, making them not suitable for all households. Virtu PVTs let you generate your own electricity and heat, reducing your reliance on gas and grid electricity, lowering your monthly energy bills. A single evacuated-tube solar PVT collector outperforms separate systems on roofs with smaller surface areas and retains heat during the harsh UK winters.
Before requesting a Virtua PVT price, assess your daily summer heat draw to ensure the system pays itself without wasting surplus energy. The overall Virtu PVT cost is affected by tube count, mounting and system integration. In your project planning ensure to include a hot-water cylinder or buffer tank and storage battery to capture midday generation for evening use.
Will solar panels heat my radiators?
Standard PV panels can’t heat your radiators. Their main task is generating electricity for running a heat pump or electric heating. Heat producing collectors reach 75°C and perform better during the summer season. They mostly feed hot water or a heat pump rather than radiators directly.
Is it better to have more solar panels or more batteries?
It depends on your household needs. If you are using most of your generation, then you need more panels. However, if your midday generation is exported back to the grid at cheaper SEG export rates and you buy it back at peak prices in the evening, you need more solar battery storage systems. With a solar battery, you can lift self-consumption from 40-60% up to 80-85%.
What is the biggest disadvantage of solar panels?
Upfront cost. Solar panels payback depends on how much of your own generation you consume and the output is affected by weather and seasons. For hybrid collectors, the added catch is needing steady heat demand all year.
Why is it harder to sell a house with solar panels?
The main reason for this is when solar panel installations are leased or tied to a roof-rental agreement. When selling a house, your buyers’ solicitors and lenders usually review the paperwork. If you own the panels and have an MCS certificate and warranty documents, then selling the property is far simpler. Therefore, before putting your house up for sale, speak with your solicitor and verify all the details are correct.
