How Much Electric Underfloor Heating Costs in UK Homes
- How Electric Underfloor Heating Systems Warm a UK Room
- Where Electric Underfloor Heating Works Best in UK Homes
- What Electric Underfloor Heating Costs to Install and Run
- Electric Underfloor Heating vs Wet Systems and Radiators
- Cut Wasted Electricity With Smarter Controls and Insulation
- Using Solar Panels and Cheaper Tariffs to Lower Heating Costs
- Will Electric Underfloor Heating Work During a UK Power Cut?
- Solving Winter Heating Pain Points With Solar and Battery Storage
- Conclusion
- Electric Underfloor Heating Frequently Asked Questions
Electric underfloor heating is the fastest way to fix freezing room floors in your home. However, with rising energy tariffs across the UK, it is entirely reasonable to ask whether installing a system will send your monthly electricity bills skyrocketing—or if it is a clever, cost-effective upgrade for your home. Then there’s the maze of mats, cables, foil and kits, and the question of whether any of it suits a renovation or extension.
This guide looks at:
How electric underfloor heating systems warm UK homes
Where electric underfloor heating works best in UK homes
The electric underfloor heating cost in the UK
A comparison between electric underfloor heating vs wet systems and radiators
How to prevent wasting electricity using smarter controls and insulation
How to use solar panels and take advantage of cheaper tariffs to lower heating costs in the UK
How to solve winter heating pain points using solar panels and home energy storage
An electric underfloor heating system is a set of heating elements—cables or thin heating film—that sit beneath your floor finish and warm its surface using mains electricity. Most arrive as an electric underfloor heating kit, which usually bundles the element, a thermostat and a floor sensor. Three main types exist.
Electric Underfloor Heating Mats for Regular Rooms
An electric underfloor heating mat is a heating cable attached to a mesh that you roll out across the subfloor. You can lay it under tiles, and it can be used in regular-shaped rooms. Most electric underfloor heating mats are rated at around 150W/m², so a 4 m² mat draws roughly 600W.
Loose Cables for Awkward Layouts
Loose cable is the better pick when a room is anything but square. It copes with awkward layouts, such as bathrooms with a toilet, bath and vanity unit, because you route it around each fixture. It also suits adding heat under screed. The catch is time—even spacing takes patience, and sloppy spacing leaves warm and cold stripes.
Foil Systems Under Laminate and Wood Floors
Foil systems are thin, low-profile films made for floating floors and are installed under laminate or engineered wood. This electric heating underfloor type’s thermostat should cap surface temperature at 27°C.
Electric underfloor heating works best in small rooms with hard floors and an obvious cold-feet problem.
Bathrooms Where Warm Tiles Matter Most
A bathroom is the obvious home for underfloor electric heating. The floor area is small, so heat-up is quick and running cost stays modest—a 4–5m² room needs only 600–750W, well under a typical 2kW fan heater. Cold tile is the biggest pain point here, and warm tile fixes it.
Kitchens With Hard Tiled Floors
Kitchens suit tile, stone and some vinyl, so check the vinyl maker’s temperature limit first. Heat only the open floor, not the areas under fitted units, because heating beneath cabinets wastes power. An electric underfloor heating mat can be cut at the mesh and turned around units. A kitchen with 6m² of open floor draws roughly 900W.
Conservatories and Extensions
Conservatories need strong insulation to prevent heat loss through the glass and the base. Otherwise, the electrical underfloor heating just warms the garden. Extensions are easier. Extensions are easier because you can install the system before the screed or floor is laid—keeping labour and disruption to a minimum. Either way, the insulation board comes first.
Renovated Properties With Low Floor Build-Up
Low build-up avoids raising floor levels, door heights and thresholds. Thin mats and foil add only a few millimetres, which makes underfloor heating electric setups practical in older properties. The main effort is floor prep, so check the subfloor is flat, dry and sound before anything goes down.
Room | Best system type | Floor finish | Installation effort | Response time | Suitability rating |
Bathroom | Mat or loose cable | Tile, stone | Low to medium | Fast | High |
Kitchen | Mat (cable around units) | Tile, stone, vinyl | Medium | Fast to moderate | High |
Conservatory | Mat or cable with insulation board | Tile | Medium | Moderate | Medium (depends on insulation) |
Extension | Mat or cable in screed, or foil | Tile, engineered wood | Low (before floor is laid) | Depends on build-up | High |
Renovation | Low-profile mat or foil | Tile, laminate, engineered wood | Medium (floor prep) | Fast | High |
Electric Underfloor Heating Installation Cost in the UK
Electric underfloor heating installation cost depends on room size, system type, floor prep and electrician labour. The installation costs run from about £40 to £90 per m²—this value includes materials and labour. Small rooms are at the top end. Mats alone typically cost £30–£60 per m², a thermostat adds £80–£250, and electrician connection runs roughly £150–£350. So the electric underfloor heating kit price is only part of the bill.
The electrical work must meet BS 7671 (the IET Wiring Regulations), including RCD protection, and Part P of the Building Regulations covers it in England and Wales. Hiring a qualified electrician is safer than DIY wiring.
Note: Prices change with materials and labour. Always get written quotes. You can use the Energy Saving Trust from current guidance. |
Is Electric Underfloor Heating Expensive to Run?
One of the most Googled questions in the UK is: is electric underfloor heating expensive to run? This answer depends on room size, wattage, insulation, daily hours and tariff. Let’s look at an illustrative example:
The cost estimates are for a 5m(2) bathroom:
5m² bathroom × 150W/m² = 750W
4 hours/day × 0.75kW = 3kWh/day
Converting this figure into actual costs at the current Ofgem rate of 26.32p per kWh, you get about £0.77 per day or roughly £24 per month. With a thermostat cycling, then this figure is slightly lower because it only runs part of the time. You can swap in using your own tariff rate to get your actual value. Area also matters, for example a 15m² room draws three times as much if the usage pattern is the same.
Note: This cost estimate is using the current Ofgem electricity price cap of 26.31p per kWh (which is active for the October to December 2026 quarter). Ofgem usually revises the pricing each quarter, therefore, check on their official website for the up-to-date electricity pricing.
Let’s compare underfloor heating electric against wet systems and radiators on five factors, then summarise in a table.
Installation Complexity and Disruption
Electric underfloor heating systems are cheaper and simpler to install. There’s no plumbing, so it suits retrofits and small rooms, and most need only an electrician for the final connection. Wet systems need pipework, a manifold and usually screed, so they suit new builds or major renovations. Radiators are familiar but need plumbing and wall space.
Energy Efficiency Compared
Electric underfloor heating systems are efficient at the point of use, but electricity costs more per kWh and there’s no whole-house efficiency. Wet systems run at low flow temperatures, so they’re most efficient with a heat pump and better for whole-house heating. Radiators depend on the boiler and higher flow temperatures.
So, is it cheaper to run radiators or underfloor heating? If we are comparing against a gas boiler, then the current Ofgem price cap for gas is 7.97p/kWh and that for electricity is 26.32p per kWh.
Note: Fuel prices change every quarter. Check Ofgem for current rates. |
Comfort Underfoot and Across the Room
Electric gives even warmth at foot level and a quick response, which is its key comfort benefit. Wet is even too, but slow to respond. Radiators give uneven heat, hot spots and cold floors. For warm feet on demand in a small room, electric wins.
Maintenance and Repairs
Electric underfloor heating systems have fewer moving parts which makes a fault under the floor difficult to assess. Wet systems need manifold and pump servicing, plus balancing. Radiators need bleeding and boiler servicing. Each option carries upkeep but in different places.
Long-Term Costs and Electric Underfloor Heating Pros and Cons
Electric underfloor heating systems have low installation costs but higher running costs, especially if deployed in large areas. Wet systems are the reverse—high installation cost, lower running cost with an efficient heat source. Radiators cost little to fit, and running cost depends on the fuel. The electric underfloor heating pros and cons are straightforward: you get comfort and saved wall space, against running cost and no whole-house efficiency.
Factor | Electric underfloor heating | Wet underfloor heating | Radiators |
Installation complexity | Simple, no plumbing, electrician for connection | Complex, pipework, manifold, usually screed | Moderate, pipework and wall space |
Efficiency | Efficient at point of use, higher cost per kWh | Efficient at low flow temperature, best with heat pump | Depends on boiler and flow temperature |
Comfort | Even foot-level warmth, quick response | Even warmth, slow response | Uneven heat, cold floors |
Maintenance | Few parts, harder to reach faults | Pump and manifold servicing | Bleeding, boiler servicing |
Long-term cost | Low install, higher running | High install, lower running | Low install, running varies by fuel |
Electric Underfloor Heating Thermostat and Controller Settings
An electric underfloor heating thermostat switches the element on and off to hold your chosen temperature. Programmable or smart models handle zoning and schedules—for example, warm the bathroom 30–45 minutes before use. A floor-sensing electric underfloor heating controller avoids overheating by reading the floor, not the air. Some learn how long your floor takes to warm, so a good electric underfloor heating controller starts heating at the right moment. Practical savings include:
Heat only when the room is in use.
Set the lowest floor limit you find comfortable.
Zone each room separately.
Insulate below the element—the cheapest way to run any system is to lose less heat.
Installation Mistakes That Push Bills Up
Poor electric underfloor heating installation is one of the main reasons for inflated bills, and these are some of the signs to check out for:
No insulation board under the element, making heat to escape downward
Poor thermostat placement or sensor positioning
Oversized wattage for the room
Heated zones covered by thick rugs or fixed units
Not testing the element before and after laying the floor
A quick resistance test costs nothing and can save a torn-up floor.
Solar panels can help reduce reliance on grid electricity, helping lower your energy bills. However, since solar panels rely on sunlight, they can only offset heating during daytime. And their efficiency drops during the winter seasons. With this in mind, remember that most of your heating runs in the morning and evening. So, if you are using solar panels alone, you won’t be lowering your heating bill.
UK time-of-use tariffs, such as Economy 7 or smart tariffs, give users cheaper overnight electricity rates. With solar battery storage, you can store daytime solar generation and use it during evening hours, or recharge it at cheaper overnight prices. With this setup, you can lower your monthly underfloor electric heating bill.
Note: Tariffs and availability change. Check Ofgem and the Energy Saving Trust before you switch. |
By default, no. Electric underfloor heating systems need mains power, so when the grid drops, the element goes cold. A compatible battery may run it, depending on system wattage, electrical compatibility and available output. A small bathroom is the best case, because electric heating underfloor there draws well under 1kW.
For example, if you have a 5kW battery and you have a 750W bathroom heating mat, you can get 6 hours of continuous output (or less after conversion losses). And if you have a 1.5kW kitchen system, you can get 3 hours.
Both worries from earlier—the bill and the power cut—have the same fix: store power for when you need it.
Make Evening Heating Cheaper With Solar You Generate
In a UK home, the evening hours are when most of the electricity is consumed. During this time, solar panels don’t generate electricity. If you have storage, then you can really save on your monthly heating bill. A storage unit like the EcoFlow STREAM 5000 pairs up to 5,000W of solar input with a 5kWh battery. It stores your surplus daytime generation instead of exporting it back to the grid at cheaper electricity rates. Your electric underfloor heating can use this power to warm your home. Its Intelligent mode can also use cheaper off-peak rates.
Stop Wasting Surplus Solar From Panels You Already Have
Surplus midday solar often goes unused unless something stores it. Most homes fear adding storage because they are afraid about expensive rewirings. A unit like the EcoFlow STREAM AC 5000 you don’t have to worry about because it works with your existing solar setup. You get a 5kWh battery that’s sufficient to meet your household demand. Schedule it around cheaper overnight rates and it can top up before the morning warm-up. In an outage it can supply loads on its AC outlet, up to 2,500W, so check your heating’s wattage first.
An electric underfloor heating system provides fast, foot-level warmth without complex plumbing of traditional wet systems. However, the rising UK energy tariffs can make running these units running costs a concern. However, with smart planning you can shift the equation entirely. Combining low-profile heating mats with proper subfloor insulation, precise thermostat zoning and floor-sensing controllers, you can eliminate cold spots in bathrooms, kitchens and extensions, while preventing wasted electricity. If you add a time-of-use tariff and pairing your system with solar and battery storage, you can heat your home using cheap and self-generated power.
What is the lifespan of electric underfloor heating?
Heating cables and mats have an average lifespan of 20–30+ years and a manufacturer warranty of 10 to 25 years while thermostat and controller have a lifespan of 5–10 years and a manufacturer warranty of 2 to 5 years. One of the major causes of early failure is damage during fitting.
What furniture can you not put on underfloor heating?
Avoid low furniture sitting flush on the floor, thick rugs and anything that traps heat. Furniture on legs lets air move underneath. Check the manufacturer’s guidance for your system.
Is underfloor heating unhealthy?
It is generally considered safe when properly installed. Screened cables limit electromagnetic fields, and with little air circulation there’s less dust movement. Keep floor temperatures moderate.
Should you turn off your heated floors in the bathroom in summer?
Yes, switch them off or schedule them off. They add nothing in warm months and cost money if left on.
