Snow Warnings in the UK: What to Expect and How to Prepare Your Home
- Is There a Snow Storm Coming to the UK?
- Met Office Snow Warning: Are Any Alerts in Place?
- Snow Warning by Region: London, England and Scotland
- How Severe Could a UK Snow Storm Get?
- How to Prepare Your Home for a UK Snow Storm
- Scaling Up: Choosing a Higher-Capacity EcoFlow DELTA
- Conclusion
- FAQs About UK Snow Warnings and Snow Storms
If you're asking is there a snow storm coming to the UK, the short answer is no. The Met Office's warnings page lists no snow warning UK-wide for the coming days, and its forecast points to something calmer but colder: frost, icy patches, wintry showers in the north and the best chance of snow in northern and north-eastern Scotland. Cold weather and a snow storm aren't the same thing, and the headlines don't always make that clear. Here's what the forecast actually says, how Met Office warnings work, who might see snow first and what's worth doing before a real one turns up. Preparing your home also means thinking ahead about possible power cuts, and a portable power station can help keep essential devices such as phones, routers and lights running during an outage.
What Does the Latest UK Snow Forecast Say?
The Met Office says Thursday 12 November is one of the coldest days of the week, with the greatest chance of snow and wintry showers across northern and north-eastern Scotland. Highs are around 4°C to 6°C in some areas and nearer 9°C in the south. Friday is drier inland with some sunshine, and Saturday stays cold, with lighter winds and clearer skies bringing back overnight frost and fog. After that, the pattern is expected to change gradually.
That fits what the Met Office said when “big freeze” headlines first appeared earlier this month: there was “little within the forecast to support the idea of widespread snow blanketing large parts of the country”. A cold spell isn't a snow storm, so check any weather forecast snow storm headline against the real forecast.
You may also have seen polar vortex stories. The Met Office explains that a disruption high in the stratosphere doesn't automatically mean cold UK weather, that it most often leads to cold, dry conditions, and that the effects can take several weeks to work down to the surface. Snow depends on the set-up: northerly winds can bring wintry showers, ice or snow depending on temperature and moisture. None of that adds up to a UK snow storm.
Then there are the viral snow maps. Some outlets run computer model charts (WXCharts is a common source) showing heavy snow in parts of northern Scotland. Those are model output, not Met Office forecasts or warnings, and they change from one run to the next.
Note: Weather forecasts and computer model outputs are updated regularly. Check the latest Met Office forecast before publication, particularly when referring to specific temperatures, snow locations and expected conditions. |
When Is the Snow Storm Coming?
So, when is the snow storm coming? There's no date, because no storm is forecast. “Snow storm” isn't a term the Met Office uses for its warnings: it warns about snow, ice and wind by colour. With no snow storm coming in any current forecast, the useful question is how a real threat would appear. Typically it shows up in stages: first as snow in the forecast, then in the outlook for the days ahead, then as a yellow, amber or red warning. Confidence drops sharply beyond a few days, so a precise date a week or more away deserves a pinch of salt. Is there a snow storm coming later in the month? Nothing in the Met Office forecast says so.
As of 12 November, the Met Office warnings page lists no weather warnings for the UK from Wednesday 11 to Tuesday 17 November. The page itself notes that warnings may be out of date, so always check the live version.
The yellow cold-health alert you may have seen is something different. UKHSA issued it for the North West and West Midlands from 9am on Thursday 12 November to midday on Saturday 14 November, and it's about health risks for vulnerable people, not snow.
Note: Weather warnings can change at short notice as forecasts develop. Check the live Met Office warnings page before publication to confirm the current warning status, affected areas and dates. |
How to Check the Latest Met Office Snow Warnings
The quickest way to check for a snow warning UK-wide or in your area is the Met Office warnings page or app, where you can set your location. Any Met Office snow warning appears there first, and BBC Weather shows the same warnings. Check before you travel, not after.
What Do Yellow, Amber and Red Snow Warnings Mean?
A snow warning is the Met Office's alert that snow or ice could cause disruption. People often search for a snow storm warning, but what you'll actually see is a warning for snow, ice or wind. The colour reflects both how likely the impacts are and how serious they could be, not just how deep the snow gets.
Warning level | What it means | What you should do |
Yellow | Low-level impacts are possible, or more serious impacts are less likely. | Check the forecast, allow extra travel time and prepare for disruption. |
Amber | Significant impacts are more likely, including travel disruption, power cuts and risks to life. | Consider changing your plans and follow official safety advice. |
Red | Severe impacts are very likely, creating a serious risk to life and property. | Take immediate action to stay safe and avoid travel where advised. |
The Met Office updated its warning matrix in October 2026, so check its current guidance for the latest wording.
Snow Warning London: Is Snow Expected in the Capital?
Not on current forecasts. Highs are nearer 9°C in the south on Thursday, and the Met Office puts the best chance of snow in the far north. A snow warning London residents need to worry about isn't in sight this week.
Snow Storm England: Which Areas Could Be Affected?
For a snow storm England forecast to make sense, you'd need widespread snow and wind, and there's no sign of that. Instead, expect frost, patchy fog and showers in places exposed to the northerly wind, including parts of eastern England. Icy patches are the bigger everyday risk than snow.
Snow Storm Scotland: Where Is Heavy Snow Most Likely?
This is where the action is. For snow storm Scotland searches, the Met Office puts the greatest chance of snow and wintry showers across northern and north-eastern Scotland, with soft hail possible on Shetland. Higher ground tends to see snow first, so check conditions before driving hill routes.
What Is the Difference Between Snow Showers and a Snow Storm?
Snow showers are brief and patchy: one village gets a dusting while the next stays dry. A snow storm means widespread, prolonged snow, usually with strong winds, and that's a different order of event. So if you're wondering is there going to be a snow storm in the UK, the current forecast shows showers and frost, not a storm.
Could Heavy Snow Disrupt Travel and Cause Power Cuts?
It can. Heavy snow and ice disrupt roads and rail, and the Met Office's amber warning wording specifically includes power outages. Snow and ice weighing on trees and overhead lines is one way outages happen, and bad conditions can slow repair crews getting to remote areas. Call 105 to report a power cut or damaged line, and stay well away from fallen lines.
A power cut during freezing weather can leave your phones, router and essential lighting without electricity. The EcoFlow DELTA 3 Plus provides backup power for these essentials while you wait for the mains supply to return. It's a practical way to keep important devices running until electricity is restored.
None of this needs to wait for a snow warning UK forecasters haven't issued yet. It's cheap to do now.
Protect Pipes and Outdoor Taps From Freezing
Lag exposed pipes and outdoor taps, and find your stopcock before you need it. If a pipe freezes, turn the water off at the stopcock and never use a naked flame to thaw it.
Keep Warm and Prepare Supplies, Lighting and a Power-Cut Plan
UKHSA's advice is to keep your home heated where possible, dress warmly and check on vulnerable neighbours and family. The Energy Networks Association adds a charged phone, a torch within reach, warm clothes and blankets, food that needs no heating, and a battery or wind-up radio with spare batteries. Save 105 in your phone, and look at the free Priority Services Register if someone at home needs extra support. Remember that gas boilers need electricity to run, so heating can fail even when the gas is still flowing. A power bank covers a phone for a while, but it won't keep a router and lights going for days.
A portable power station isn't a heating system, and it isn't a whole-home backup. What it can do is keep your essentials running while the network is repaired: phones, a router, lamps and some selected appliances. How long it lasts depends on what you plug in, the battery capacity and how you recharge it. As a rough guide, a 50W router running for ten hours uses around 500Wh before conversion losses.
Run More Appliances When Your Household Needs Power
The EcoFlow DELTA 3 Max Plus offers more capacity for households that need to run several essential devices and selected appliances at once. It's a useful middle ground when keeping everyone connected and comfortable requires more than phone and lighting backup.
Get More Backup Capacity for Longer Power Cuts
The EcoFlow DELTA Pro 3 is a good option for households that want extra backup power for longer outages or need to run more demanding appliances. You can also recharge it with compatible solar panels when there's enough daylight and the weather allows.
No snow storm is forecast, and no snow warning UK-wide is in force, but the cold is real and the warnings are the thing to watch. If a yellow, amber or red warning does appear, preparing in advance is cheap compared with scrambling once it's snowing.
If you want reliable backup for phones, a router and lighting, EcoFlow's DELTA range runs from compact to extended outages. Explore the options at EcoFlow UK and choose the one that matches what you'd actually need to keep running.
Do you get paid if you can't get to work because of snow?
Not automatically. GOV.UK says employees aren't automatically entitled to pay if bad weather stops them getting to work, so check your contract first. If your workplace closes and you don't normally work from home, your employer usually can't deduct your pay.
What should you keep in your car in snowy weather?
The Met Office suggests an ice scraper and de-icer, a torch with spare batteries, warm clothing and blankets, food and drink including a flask of something hot, a shovel, high-visibility clothing, an in-car phone charger and jump leads. A paper road atlas helps if your phone or navigation fails.
Can a portable power station be used in freezing temperatures?
Yes, but only within certain temperature limits. EcoFlow says the DELTA 3 Plus and DELTA 3 Max Plus can discharge between -10°C and 45°C and charge between 0°C and 45°C. Cold temperatures can also reduce the available battery capacity. Keep your power station indoors or somewhere sheltered, and check the operating limits for your specific model, including the DELTA Pro 3.
