How Many Plug-In Solar Panels Can I Have in the UK?
Try plug-in solar panels in your home outlet and save electricity and switch to clean energy production at home. It seems like a viable option for UK homes, but how many plug-in solar panels can I use? Familiarise yourself with the new regulations in the UK, inverter requirements, and installation regulations before you go ahead.
Find out how to select a proper solar system and look for smarter ways to produce energy at home and outdoors.
Plug-in solar panel capacity and energy storage on the home roof in the UK.
1. Understanding UK Plug-In Solar Panel Limits and System Configurations
Plug-in solar panels give UK households an easier way to produce renewable energy, but the number of installations and the output are regulated by special safety and grid connection laws. Knowing what regulations came into effect on 27 August 2026 will help you make a compliant decision, regardless of whether you want to get one solar device or use multiple devices.
UK Plug-In Solar Rules: What Changed on 27 August 2026?
From 27 August 2026, new laws in the UK made it possible for compliant solar plug devices to be connected to domestic electric sockets, thus making the use of smaller solar devices easier for the public.
According to the updated laws, people living in the UK can use only one compliant plug solar device for their residential needs under the following terms and conditions:
  • Maximum output of the inverter: The output of the inverter shall not exceed 800VA AC.
  • Appliance-per- household rule: Current G98 Network regulations restrict households to the use of one plug-in solar appliance.
  • Compliant equipment: The entire system must comply with the government’s interim product specification version 2.0.
  • Approved connection: The appliance must use a fused UK plug supplied by the manufacturer.
  • Grid notification: Anyone who installs the appliance is required to inform their local DNO within 28 days of installation.
It’s important to note that the rule restricting one appliance does not mean that households can have just one solar panel installed. Depending on the inverter used and the approved configuration of the installation, the number of solar panels in the compliant installation may vary.
Can One Plug-In Solar System Support Multiple Panels?
It is true. One approved plug-in solar system can operate with multiple connected solar panels that share one compatible micro-inverter. According to government regulations, the system can use up to four photovoltaic modules per inverter, provided all technical and safety standards are met.
The key difference is in solar module capacity (DC) and inverter performance (AC):
  • The solar module capacity (DC): Refers to the overall amount of electricity produced by all the installed solar modules in a system.
  • The inverter performance (AC): Refers to the maximum amount of electricity that the system can deliver to your residential unit through a plug-in connection.
According to the Product Specification, the combined capacity of the PV modules could be 2,000W, while the maximum performance of the inverter is limited to 800VA.
This means that it is possible for a residential homeowner to have more than one PV module to exploit solar power, but the devices must be compatible.
Plug-In Solar Panel Configurations: One, Two or Multiple Panels Compared
The number of solar panels that you can utilise is determined by the wattage of each panel, specifications of the inverter and the configuration endorsed by the manufacturer. The table below depicts how different configurations can operate under current UK law.
Solar panel configuration
Combined PV capacity (DC)
Maximum inverter output (AC)
Compliance considerations
1 × 400W panel
400W
Up to 800VA
Subject to complete system compliance
2 × 400W panels
800W
Up to 800VA
Potentially compliant
3 × 400W panels
1,200W
Up to 800VA
Professional assessment should be considered
4 × 500W panels
2,000W
Up to 800VA
Maximum permitted PV capacity, subject to specification
Note: These configurations are just examples and do not mean that all combinations of panels and inverters are approved. The rules allow for a maximum of four PV panels, a total capacity of solar panels which may not exceed 2000 W, and no more than two panels in series in any one string. It is advisable to obtain professional advice if the capacity of solar panels exceeds 960W.
For example, a household with limited space in its yard may choose to install two solar panels, while a household with a bigger yard or a good balcony may prefer to have several panels. In all cases, any inverter has to fall within the limits of 800VA of AC output.
Can You Have More Than One Plug-In Solar Panel Kit at Home?
Although one plug-in solar kit might have several panels, in line with the current G98 regulations in Great Britain, two different plug-in solar kits cannot be installed in a single home. Thus, for example, connecting a solar kit of 800VA to the power supply in a kitchen and another one to that in a garden cannot be considered compliance with the requirement. The regulation pertains to the home in general rather than to the number of sockets available.
Generally, a household should never:
  • Connect two different plug-in solar kits to various sockets.
  • Connect solar appliances through an extension lead or multi-way adapter.
  • Use daisy-chaining methods to set up independent solar systems.
  • Change either the provided plug or wiring.
  • Go over the recommended configuration of the inverter and panels.
Your best option may be to simply choose one multi-panel-compliant kit instead in order to get the requisite capacity. Further, if you want to get a bigger output than the plug-in system is able to provide, you can consider the installation of a professional solar PV system.
Being aware of how many plugs in solar panels can I have is just the first step. You must also learn about the electrical safety requirements, product certification, and DNO notification standards necessary to ensure your installation meets the legal requirements before connecting your system.
2. What Are the UK Safety and Installation Requirements for Plug-In Solar Panels?
How many plug-in solar panels can I install in the UK? In the UK, installing plug-in solar panels is not just about selecting the appropriate number of panels and identifying an appropriate plug. There are additional steps that homeowners need to consider, including checking product certification and ensuring electrical safety features and grid connection requirements are met so that the system complies with 2026 standards. Knowing the requirements ahead of time means that the chances of electrical hazards and problems with the utility provider will be reduced.
Does Your Plug-In Solar Kit Meet the Interim Product Specification?
Before making the purchase of a solar kit, you have to ensure that the entire product falls within the parameters of the Plug-In Solar Device Interim Product Specification (IPS), Version 2.0, which came into force in July 2026. This specification by the government ensures compliance with minimum technical and safety standards of plug-in solar devices that are going to be sold and connected in the UK.
The following checks regard compliance that could be considered by house owners:
  1. Compliance with PS Version 2.0: You need to check if the entire plug-in solar device follows the current standards set by the government and not merely the claims made by its individual parts.
  2. Verification in the ENA G98 Type Test Register: Ensure that the particular device model has been tested for the necessary compliance in the Energy Networks Association (ENA) Type Test Register.
  3. Approved UK plug: Make certain that the system contains the fused UK plug that has been cleared in a way that now meets the BS 1363 requirements.
  4. The inverter output: Ensure that the appliance has an AC output that reaches no more than 800 VA.
  5. Manufacturer data: Check if the product states its electrical ratings, the manufacturer’s data, as well as required safety notifications.
A claim regarding the appropriateness of a solar kit for UK sockets does not necessarily prove compliance. Always check the proper model and all the documents confirming it prior to the purchase.
Essential Electrical Safety Requirements Before Installation
A certified plug-in solar system requires a proper electrical connection and installation. Before you plug in your solar panels into the wall socket, you need to adhere to the following safety requirements:
  • Anti-islanding protection: The inverter should automatically shut off electricity flowing from the solar panels to the utility grid in case of a blackout, thereby protecting workers from electrocution.
  • Fixed socket: The plug should go directly into an appropriate socket that is in perfect condition and suitable for the intended purpose.
  • No extension leads: Always refrain from using extension leads, power strips, or daisy-chain connections, as this method is unsuitable for the certified plug-in installation method.
  • Weatherproofing: Always use a weatherproof socket-outlet and connections for the installation outside. This job should be performed by a qualified person.
  • Correct panel mounting: Mount your solar panels correctly using approved mounting hardware.
  • Labelling: Follow the instructions from the manufacturer on how to attach a warning sticker to the consumer unit.
For outdoor installations, it is essential to consider protection against weather conditions in the UK, where rain and humidity can interfere with electrical connections. London Fire Brigade also recommends that outdoor sockets used in these installations should be of the appropriate type. IP65 waterproofing standard is the minimum requirement for such fittings
How to Notify Your DNO After Installing Plug-In Solar
In accordance with the G98 connect-and-notify procedure, homeowners in England and Wales are required to inform their local Distribution Network Operator (DNO) about the functioning and compliance of the plug-in solar system within a period of 28 days.
  • Find your DNO: To locate your appropriate local electricity company, you may use your postcode.
  • Gather the system details: Note down the specifications of the inverter, AC rating, installation address, and commissioning date.
  • Make the notification: You can make a notification to the DNO according to the manufacturer’s registration process.
  • Keep the confirmation: You need to keep a record of your notifications and compliance.
  • Timelines: It is vital to make sure that you have informed the DNO within 28 days after installation.
    Note: Eligible G98 installations use this notification procedure and do not need to apply for a DNO approval in advance.
3. What If You Need More Solar Power Than a Plug-In System Can Provide?
There are several advantages to using plug-in solar, especially for those who want to create their own power. Plug-in solar panels have a rated output of 800VA, so it is possible to get more electricity at home, but in limited amounts. However, the situation changes if one plans to increase energy output significantly or install extra equipment. In such cases, it is wise to call specialists to install solar PV systems and home batteries.
Plug-In Solar vs Professionally Installed Solar PV Systems
Plug-in solar panels are perfect for homes that need a quick and easy way to generate solar power without requiring full installation. However, in the case of nee something more powerful than plug-in capacity, it may be better to invest in a solar PV system and get more benefits.
Feature
Installation
Direct connection to a suitable socket
Installed by a qualified solar professional
Solar capacity
Up to 2,000W PV capacity under the specification
Can support larger solar arrays
Inverter output
Maximum 800VA AC
Depends on inverter specifications
Panel placement
Suitable balconies, gardens and other approved locations
Rooftops, gardens and ground-mounted systems
Grid connection
G98 notification requirements
G98 or G99, depending on system capacity and connection characteristics
Best suited for
Small-scale household electricity generation
Greater household energy generation and consumption
For UK residents, professionally fitted rooftop or ground-mounted solar PV systems potentially offer greater generation capacity and flexibility. Moreover, installation must adhere to the roof's suitability, electrical needs, planning considerations, and the appropriate DNO connection process.
How Can Home Battery Storage Help You Use More Solar Energy?
Using solar energy is very valuable during the day, but what will happen once the sun sets? The answer lies in Home Battery Storage Solutions, which utilise excess solar energy that can be used for electricity needs during the night or cloudy hours.
Some advantages of owning a home battery storage include:
  • Storing Extra Solar Energy: No longer depends on immediate use of solar energy.
  • Powering Houses After Dark: Using stored energy to power anything from lights and televisions to fridges and pools.
  • Help out Outdoor Working Areas: Utilise stored power for garden offices, workshops and electric tools.
  • Manage Electricity Bills: Use more of the generated solar power instead of relying solely on electricity from the main grid.
  • Enjoy Energy Flexibility: Combine compatible solar technology and battery storage to have even more renewable energy options.
It is critical to differentiate between conventional solar-plus-battery units and plug-in solar installations. The inclusion of battery storage does not enable homeowners to bypass the one-device rule and to exceed the allowed plug-in inverter output.
For homeowners wanting to install an extensive solar-plus-storage setup, or those who want to add battery storage to their previously installed compatible solar panels, EcoFlow STREAM offers two models to consider.
If you want to install a solar system for your dwelling or plan to use the power generated by existing solar panels more efficiently, selecting the correct battery storage system will enhance your solar generation. Learn more about how EcoFlow STREAM 5000 and STREAM AC 5000 models can help different households.
Powering Home and Outdoor Energy Needs with EcoFlow STREAM 5000 Solar Battery 5kWh
EcoFlow STREAM 5000
Battery capacity: 5kWh / 5024Wh. Maximum solar PV input: 5000W (1250W × 4 MPPTs). Features 4 independent MPPTs for solar panel connections. AC output: Up to 3000W. Grid-connected output: 800W / 3000W. AC charging input: 3000W. Battery cycle life: Up to 10,000 cycles. Expandable storage capacity: Up to 90kWh. IP65 protection rating and 10-year warranty.
Adding Battery Storage to Existing Solar Panels with EcoFlow STREAM AC 5000
Battery capacity: 5kWh / 5024Wh. AC charging input: 3000W. Off-grid AC output: Up to 3000W. Grid-connected AC output: 800W / 3000W. Maximum bypass output: 3000W. Designed for homes with existing solar panel systems and AC-based battery charging. Expandable storage capacity: Up to 90kWh. IP65 protection rating and 10-year warranty. Supports smart home energy management through OASIS 3.0.
To make a more informed decision regarding generating energy for the home, it is important to know how many plug-in solar panels you could have installed in the UK. Although currently the law allows homeowners in the UK to use only one approved plug-in solar system with no more than 800VA AC generation, there’s a possibility of connecting multiple solar panels to a single compliant unit.
Before proceeding with the installation, check how powerful your inverter is, whether the device complies with the regulations, is electrically safe, and whether the DNO notification needs to be submitted within 28 days. If you want to get higher solar energy production or use some renewable energy during the night, it is better to install a solar PV system with batteries by professionals.
If you are looking for a solar and storage unit, check out EcoFlow STREAM 5000 solar battery 5KWh or EcoFlow STREAM AC 5000 as an additional storage unit for existing solar power systems. Learn how efficient solar power systems, together with battery units, can be in managing energy consumption at home or outdoors.
How Many Solar Panels Can One Plug-In Solar Inverter Support?
The UK Interim Product Specification Version 2.0 states that one compliant plug-in solar system may incorporate four photovoltaic panels as long as the overall configuration fulfils relevant technical requirements. The PV capacity must not exceed 2000W, and the maximum AC output of an inverter must not exceed 800VA either.
Can I Install Two 800W Plug-In Solar Kits in One House?
No, the current G98 regulations in Great Britain allow for only one plug-in solar system in a household. This means that having two plug-in systems of 800VA capacity is an overstepping of this limit, even if both devices are connected to different power sources.
Can You Use More Than One Plug-In Solar Panel on Different Sockets?
A single plug-in device is permitted to utilise multiple solar panels. However, the use of separate plug-in systems to circumvent the policy of one system per household is not allowed. Follow the specific configurations and instructions laid out by the manufacturer.
Does the 800W Limit Apply to Solar Panel Capacity or Inverter Output?
The 800W limit is applicable to the output of the electric inverter and not the capacity of the solar panels put together. As per the Interim Product Specification, a compliant system can be connected to solar panels with a maximum DC capacity of 2000W, but the output of the inverter cannot exceed 800W.
What Type of Solar System Should I Install If I Need More Than 800W of AC Output?
If your home requires in excess of 800VA of AC power, then think about investing in a professional roof- or ground-mounted solar PV system. A professional installer will evaluate your electrical needs and suggest the best inverter for your installation, as well as inform you whether G98 notification or G99 approval will be needed. You might also want to look into compatible battery storage solutions for your home to make sure you reap the benefits of the electricity you generate.
