What to Do as British Gas Warns Households to Prepare Boilers for Winter
- What Is British Gas Telling Households to Do This Winter?
- How to Prepare Your Boiler for Winter
- Prepare for Boiler Service: What to Have Ready
- What to Do When Your Boiler Breaks Down in Winter
- Cutting Winter Heating Bills Without Losing Warmth
- Managing Winter Electricity Costs With Home Energy Storage
- Conclusion
- FAQ About British Gas Winter Boiler Advice
The first time you switch the heating on after summer, you expect the radiators to warm up and the hot water to work as usual. Sometimes everything starts without a problem. On other occasions, a radiator stays cold, the boiler pressure has dropped or the display shows a fault you have not seen before.
That is the reason behind the latest warning. British Gas warns households to prepare boilers for winter, after reporting that around 34,000 households are expected to need help with heating and hot water as colder weather arrives. The company has shared ten checks covering boiler pressure, radiators, insulation, draughts and other parts of the home.
The timing matters. A heating system that has sat unused for several months is being asked to work regularly again, often just as temperatures fall. Sorting out small problems in autumn is easier than dealing with a failed boiler when the whole household needs heating.
There is also the electricity side of winter spending. Lights stay on for longer, cooking takes place during darker evenings and household appliances continue using power. Alongside heating maintenance, home energy storage gives households another way to manage electricity use, particularly when they are on a suitable time-of-use tariff.
The latest british gas winter boiler preparation advice focuses on getting homes ready before colder weather increases demand for heating. Its service and repair engineer, Peter Knowles, says homeowners should check their boilers and radiators, protect exposed pipes and deal with jobs around the property before winter sets in.
British Gas has shared ten recommendations covering different parts of the home. Some involve checking the heating system, while others focus on preventing heat loss and preparing for common winter problems.
Winter Home Preparation Checklist for Boilers and Heating Systems
Preparing a home for winter involves more than checking the boiler. Radiators, exposed pipes, insulation and heating controls all affect how comfortably and reliably the property stays warm. Use this checklist to make sure the main areas have been covered before temperatures drop.
Check the boiler pressure: Make sure the pressure is within the range recommended by the boiler manufacturer. British Gas gives 1–1.5 bar as the normal range for many domestic systems.
Bleed the radiators: Release trapped air if radiators have cold patches, then check the boiler pressure afterwards.
Use zonal heating: Where the system allows it, heat the rooms being used rather than keeping every room at the same temperature.
Find and block draughts: Check around doors, windows and other openings where cold air can enter.
Move furniture away from radiators: Leave enough space for warm air to circulate around the room.
Insulate exposed pipes: Pay particular attention to pipes in lofts, garages and other unheated areas.
Locate the main water stopcock: Make sure everyone in the household knows how to turn off the water if a pipe bursts.
Check loft insulation: British Gas recommends around 250–270mm of insulation, where appropriate.
Clear gutters: Remove leaves and debris so rainwater can drain away properly.
Check available energy support: Households struggling with energy bills can look into support from organisations such as British Gas Energy Trust, subject to eligibility.
These recommendations cover more than the boiler itself. A heating system works within the wider home, so blocked gutters, draughty windows and poorly insulated lofts also deserve attention.
The advice is useful, but it is not a replacement for an annual boiler service. Homeowners also need to know which checks they can carry out safely and when to call a professional. British Gas urges households to prepare boilers for winter, but the practical work starts with understanding the condition of the heating system in your own property.
Preparing your boiler for winter does not mean carrying out complicated maintenance yourself. Before the heating season begins, check the pressure, test the controls, inspect accessible pipework and see how the radiators perform. These simple checks can help identify problems before the boiler is needed every day.
If you are researching how to prepare your boiler for winter, start with the manufacturer’s instructions. Filling loops, pressure gauges and control panels differ between models. A procedure that applies to one boiler is not automatically suitable for another.
Check Boiler Pressure and Bleed the Radiators
Searches for “prepare boiler for winter” usually lead straight to the pressure gauge, and for good reason: it is the quickest check you can make. With the heating switched off and the system cool, the gauge should usually read between 1 and 1.5 bar. British Gas gives this as the normal range for many domestic systems.
If the reading is low, consult the boiler manual to see how to top up the liquid. Most of the sealed systems have a filling loop, which may be located in the system and its shape may vary. Slowly add water until the gauge indicates within the recommended parameters. Never let the valve filling hole open or let the pressure exceed the specified value.
Radiators need a separate check. If the top feels cooler than the bottom, trapped air is a likely explanation. Switch off the heating and allow the radiators to cool. Slowly open the bleed valve using a radiator key, until water is seen coming out. Bleed the valve and then check the boiler pressure again, bleeding may cause the boiler pressure to drop.
A radiator that remains cold after bleeding is not necessarily an air problem. The valve, pipework or system balance could be responsible. Repeatedly topping up a boiler that keeps losing pressure is not a solution either. A persistent drop needs investigation by a heating engineer.
Inspect the Condensate Pipe and Outdoor Pipework
Most advice on how to prepare boiler for winter skips the condensate pipe. It carries wastewater from a condensing boiler to a drain. Where the pipe runs outside, freezing temperatures freeze the water inside and block the discharge.
If the boiler stops working during a cold spell, check the display for a fault code and consult the manual. One of the potential causes is the freezing of the condensate pipe, but there are other causes that give the same symptoms.
If you identify an accessible frozen section at ground level, follow the boiler manufacturer’s guidance for thawing it. Worcester Bosch advises to apply warm (not boiling) water to the affected pipe and to insulate any exposed parts to help minimize the risk of re-freezing.
Do not dismantle pipework or open the boiler casing. If the pipe is difficult to reach, the blockage returns or you are unsure what has caused the shutdown, contact a qualified heating engineer.
Also look at water pipes in colder parts of the property. Loft spaces, garages and unheated cupboards are common places for exposed pipework. Suitable foam insulation helps protect these pipes from freezing. British Gas includes pipe insulation in its own winter checklist.
Test the Thermostat, Timer and Heating Controls
A boiler that fires up is only part of the system. The thermostat, programmer and radiator valves determine when rooms receive heat and how the household uses it. Test them before the first cold snap, because the controls complete any winter boiler preparation routine.
Set the heating to come on at a time when someone is home. Check that the boiler responds and that the room thermostat registers the temperature correctly. Check batteries if the display does not respond or is blank. Return clock and heating schedule to normal after a power cut.
A room thermostat should be set to a comfortable temperature. Energy Saving Trust identifies 18–21°C as a suitable range for most people, although individual comfort needs differ. It also advises using programmers and thermostatic radiator valves to heat rooms when they are needed rather than running the whole house at the same level throughout the day.
The boiler’s flow temperature is another setting to understand. This controls the temperature of the water sent to the radiators; it is not the same as the room thermostat setting. Energy Saving Trust recommends trying around 60°C on the radiator circuit of many combi boilers. For a conventional or system boiler with a hot-water cylinder, the flow temperature should not be reduced below 65°C because the cylinder needs to reach a safe temperature.
Check your boiler type before changing the setting. If you are unsure which control adjusts the radiator flow temperature, ask an engineer during the next service.
An annual boiler service gives a qualified engineer the opportunity to inspect the appliance, check its operation and identify faults that are not obvious during everyday use. It is different from the basic checks a homeowner carries out.
If you are looking up prepare for boiler service, the first step is to arrange an appointment with a Gas Safe registered engineer. Check the engineer’s registration and make sure they are qualified to work on your type of gas appliance. HSE advises that gas appliances should be maintained and serviced regularly by competent, registered professionals.
Before the appointment:
Clear boxes, cleaning products and stored items from around the boiler.
Make a note of the boiler’s make and model.
Write down unusual noises, pressure drops, error codes or heating problems.
Find the previous service record.
Make sure the engineer has safe access to the boiler and its controls.
There is no need to dismantle anything or attempt a repair before the engineer arrives. The most useful preparation is to give them clear access and explain what you have noticed. A radiator that takes longer to heat, for example, is worth mentioning even if it eventually warms up.
Landlords have additional responsibilities. They must arrange an annual gas safety check for gas appliances and flues they provide, using a Gas Safe registered engineer. Existing tenants must receive a copy of the gas safety record within 28 days of the check, while new tenants must receive it before moving in.
Carbon monoxide protection belongs on the household safety list as well. HSE recommends using an audible carbon monoxide alarm that complies with BS EN 50291 and following the manufacturer’s instructions for installation and maintenance. An alarm is an extra alert – it is not a substitute for servicing or safety checks.
A boiler fault does not always mean the appliance needs replacing. Any “winter home preparation checklist boiler and heating systems” covers pressure and radiator checks, but it is incomplete without a breakdown plan. A low pressure reading, an incorrect timer setting or a frozen condensate pipe interrupts heating without meaning the boiler has reached the end of its life.
If the heating or hot water stops, work through the checks that do not involve opening the appliance:
Check the thermostat: Make sure it is set above the current room temperature and calling for heat.
Check the timer: Confirm that the heating schedule is correct and the programmer has power.
Read the pressure gauge: Check against the manufacturer's recommended pressure range.
Look for an error code: Use the boiler manual to understand what the displayed code means.
Inspect accessible outdoor pipework: In freezing weather, look for signs of a frozen condensate pipe.
Follow the manufacturer’s reset instructions if the manual recommends a reset for that fault. If the boiler still does not operate, contact a Gas Safe registered engineer. Do not remove the casing, interfere with gas components or keep resetting a boiler that repeatedly locks out.
A suspected gas leak is an emergency. If you smell gas, do not operate electrical switches or use naked flames. Open doors and windows, turn off the gas supply at the meter if it is safe to reach, leave the property and call the National Gas Emergency Service on 0800 111 999.
For a burst water pipe, turn off the water at the stopcock and open cold taps to help drain the system. British Gas recommends locating the stopcock before an emergency because it is often under the kitchen sink, although its position differs between properties. Make sure everyone in the household knows where it is.
A working boiler does not automatically mean a warm, efficient home. If heat escapes through gaps around doors, windows, floors and the roof, the heating system has to work harder to maintain the temperature.
Start with the small jobs. Fit draught excluders beneath external doors, use suitable seals around window frames and check for gaps around letterboxes. British Gas also recommends moving sofas and other large furniture away from radiators so warm air can circulate around the room. Thicker curtains and rugs on bare floors add another layer of comfort.
Loft insulation is a larger improvement. British Gas recommends a depth of around 250–270mm. Check the existing material before adding more, and do not cover ventilation points or electrical equipment. If access to the loft is restricted, have a professional inspect it, don't go over stored items or exposed joists.
Heating controls make a difference to everyday use. Set the programmer around your household routine, turn down radiators in rooms that are rarely occupied and avoid heating unused spaces unnecessarily. Keep the main living areas comfortable rather than turning the thermostat up sharply when the house feels cold. A higher setting does not make the room heat up faster.
The October–December 2026 Ofgem price cap sets the average Direct Debit electricity rate at 26.32p per kWh and gas at 7.97p per kWh across England, Scotland and Wales. These are the mean unit rates (i.e. per household and not a fixed bill). Actual charges will depend on region, type of payment and amount of energy used.
Households struggling with energy debt should also check what support is available. British Gas Energy Trust provides advice and financial support for eligible households experiencing energy debt. Its published announcement says eligible applicants can receive grants of up to £1,700, subject to the Trust’s criteria.
Note: the rates shown are for illustration only. The energy price cap changes every three months, and your own rates depend on your region, payment method and meter. For the latest figures, always check the Ofgem official website. |
Boiler maintenance deals with gas heating, but winter electricity use needs its own plan. Lighting, cooking and household appliances all contribute to the evening demand that builds when people return home. A home battery stores electricity for use later. On a suitable time-of-use tariff, a household can charge it during cheaper periods and use stored electricity when rates are higher. The potential saving comes from the difference between the charging and usage rates, after allowing for battery losses and the cost of the system. Storage does not reduce the amount of gas a boiler uses, improve its efficiency or replace annual servicing. It addresses the electricity side of household energy management.
Note: time-of-use tariff availability and pricing vary by supplier and change over time. Always check the Ofgem official website for current guidance. |
A Storage-Led Starting Point for Households Without Solar Panels
Households without solar panels can consider storage as part of a wider plan for managing electricity costs. The EcoFlow STREAM 5000 has a 5kWh capacity (5,024Wh), expandable up to 90kWh, and provides 3,000W of AC output. It is designed to store electricity for later use, with the value of that arrangement shaped by the household’s tariff and consumption pattern. The unit also supports up to 5,000W of solar input across four MPPT channels rated at 1,250W each. This allows a household to install solar electricity to their energy system in the future. When considering the costs of winter maintenance of your home, you should separate the two functions: the boiler supplies heat and the battery supplies electricity.
Adding Battery Storage When Solar Panels Are Already in Place
Homes with solar panels have a different storage question. Solar generation is usually strongest during daylight hours, while household electricity use often rises later in the afternoon and evening. Without storage, some of the electricity generated during the day may be exported rather than used in the home. The EcoFlow STREAM AC 5000 is designed for households adding battery storage to an existing solar setup. It offers 5kWh of capacity (5,024Wh), expansion up to 90kWh and a stated cycle life of 10,000 cycles. Intelligent Mode+ manages charging and energy use, while Local Mode supports operation without an internet connection. A battery does not guarantee a lower winter bill. The outcome depends on the household’s electricity use, solar generation, tariff structure and system settings.
Note: Rules for plug-in solar in Great Britain are new and still developing. EcoFlow STREAM 5000 and STREAM AC 5000 are home battery storage systems that need professional installation. They are not sold as plug-in solar products, and a battery does not qualify as a compliant plug-in solar microgenerator just because its setup is straightforward. Check current GOV.UK guidance and speak to a qualified installer about the requirements for your home. |
Anyone searching for a “winter home preparation checklist boiler and heating systems” needs the same few checks before the heating season. Check the boiler pressure, bleed radiators that have cold patches, inspect exposed pipework and test the timer and thermostat. Arrange an annual service with a Gas Safe registered engineer, locate the stopcock and make sure the carbon monoxide alarm is working. British Gas warns households to prepare boilers for winter because a system that has been checked before the cold arrives is in a better position to handle regular use.
Winter preparation also involves looking beyond the boiler. Draught-proofing, suitable heating schedules and loft insulation help reduce heat loss, while home energy storage addresses electricity use rather than gas consumption. EcoFlow offers the STREAM 5000 and STREAM AC 5000 for households considering battery storage alongside their heating preparations. Explore the options at EcoFlow UK and compare them with your household’s energy needs and electricity tariff.
When should I book a boiler service before winter?
Book the service before the main heating season, ideally in early autumn. This will allow you to prepare for any necessary changes in advance of the colder seasons, when the need for engineers in the cold season is greater. Maintain the manufacturer's maintenance plan and record.
How much does a boiler service cost in the UK?
The price varies according to location, boiler type and the work included. Get quotes from Gas Safe registered engineers and check whether the price covers a full service or a separate safety check. Ask what inspection and paperwork are included before booking.
Is boiler breakdown cover worth having?
Compare the annual premium with the cost of a standalone service and a possible repair. Read the policy terms carefully, particularly the excess, call-out arrangements, annual service inclusion and restrictions on older boilers. Check that the cover applies to your specific boiler and heating system.
