How to Keep Electric Gates Working During a Power Cut
- What Happens When Electric Gates Lose Power?
- How to Open Electric Gates During a Power Cut
- Which Backup Power Option Suits Your Gate?
- How Long Will Electric Gate Backup Batteries Last?
- Prepare Your Electric Gates Before Winter Power Cuts
- Keeping Electric Gates and Essential Household Equipment Powered
- Conclusion
- FAQ About Electric Gates
Electric gates stop dead when the mains drops, and in the UK that happens more often than you'd like. A storm drops a tree, the tree drops a local line, and you're sat in the car at the end of your drive with a gate that won't budge. Every gate depends on a motor, a control board and a supply. Some have battery backup. All need a manual release — and those are two different things. We cover outages, manual release, backup options, runtime and winter prep. Home energy storage gets a look too.
Electric gates are motorised barriers that need a live supply to move, so a power cut freezes them wherever they are. The control board goes dark, the safety sensors with it, and the motor locks the leaf in place. Some gates stay locked, some you can free by hand, and some run on a backup battery for a few cycles.
UK winters make this a real risk. Storms, ice on overhead lines and local network faults all cause power outages, and a Met Office wind warning is a decent cue to check your gate.
How Different Gate Mechanisms Respond to Power Cuts
Swing, sliding and rolling gates all lose drive in a cut, but each frees differently. On a swing gate, a key usually disengages the arm and you push each leaf by hand. With electric sliding gates, the release disconnects the motor from the rack and the leaf rolls along its track. An electric rolling gate in UK use is simply a sliding gate on a track or cantilever, so the same applies.
Commercial electric gates carry extra duties. Drivers, residents and emergency services all need in, so write down an outage procedure.
24V Versus 230V Gate Motors
A 24V gate motor runs on low-voltage DC from a transformer; a 230V motor runs straight off the mains. 24V boards can often take a backup battery. 230V operators need a different arrangement, which your installer designs.
CAME and FAAC both make 24V and 230V operators, so read your model's datasheet. Don't assume a 24V gate can take a battery, either — some boards have no connection for one. Got an electric driveway gate on 24V? Ask your installer to check.
Manual release is how you open electric gates in a power cut when no battery backup is fitted. Every operator has one — a key lock, lever or handle — that disconnects the motor so the leaf moves by hand. Find yours now, not by torchlight.
Using the Manual Release Mechanism
On many operators the release hides behind a small cover on the motor housing. Turn the key, then ease the leaf along by hand. Never force a gate that resists — you could wreck the gearing or trap someone. With automatic electric gates, keep people and cars well clear.
Swing gates need each leaf released separately; sliding gates need the leaf pushed the full length of the track. When power returns, re-engage the release, check the path and run a test cycle. And keep the key within your household's reach, not in the car.
Note: follow your manufacturer's instructions and current HSE guidance on powered gates.
What to Check When Electric Gates Stop Working After Power Returns
Check the supply and isolation switch.
Inspect the battery and charging connections for corrosion or loose terminals.
Look for debris, obstructions and damaged safety devices. A photocell that fails to respond stops the gate closing.
If the electric gate still won't respond, or it grinds or reverses, call a gate technician. Never bypass safety devices.
The right backup for electric gates depends on your control board, how long outages last and what else you want to run
Dedicated Electric Gate Backup Batteries
A dedicated backup battery is a small sealed pack wired to the control board that runs the gate when the mains fails. Packs come in 12V and 24V; your board decides which fits. The Nice PS324, for example, is quoted at roughly 10 operations. Many electric gate kit packages leave the battery out, and it adds to your electric gates cost, so check what's in the box.
Portable Power Stations for Electric Gates
A portable power station is a rechargeable battery with built-in sockets that runs compatible kit through a normal three-pin plug. Most gates are hardwired, though, so you can't just plug one in. Check the continuous output covers the motor's starting surge. For electric driveway gates on a fixed supply, ask an electrician to design a safe connection. Do not feed power back into the power outlets or into the wiring of a home. This is called "backfeeding," and it can be dangerous for the engineers who work on the lines.
Home Battery Storage for Gates and Essential Equipment
Home battery storage feeds chosen loads when the mains fails — a fridge, router, boiler controls and, if your installer designs it in, your gate. It needs a compatible backup circuit and professional installation. Home energy storage suits electric gates for driveways that share a supply with the house, though a long cable run complicates things. Table 1 compares all three.
Table 1: Electric Gate Backup Power Options Compared
Comparison | Dedicated gate battery | Portable power station | Home battery storage |
Main purpose | Compatible gate controls | Compatible electrical loads | Selected household loads |
Gate compatibility | Specific control board | Suitable AC or DC connection | Compatible backup circuit |
Installation | Integrated with operator | Portable or professional connection | Professional installation |
Other equipment | Generally limited | Within output limits | Supported backup circuits |
Main limitation | Limited operating reserve | Connection and output compatibility | Higher installation complexity |
Backup runtime for electric gates is better counted in operations than hours. A manufacturer's cycle figure beats any universal hours claim.
What Determines Backup Battery Runtime?
Gate weight and friction: a heavy leaf or stiff rollers makes for a harder run. Heavy electric sliding gates on worn tracks suffer most.
How often the gate opens: A family driveway might only need a few openings a day, while a shared entrance used by several households will see much more activity.
Standby power use: Even when the gate isn't moving, the control board, photocells, intercom and GSM module continue to draw power, gradually using up the battery.
Battery age, charge and temperature: Batteries lose capacity as they get older. Leaving one partially charged or exposing it to cold weather can also reduce how long it lasts.
Calculating the Backup Power You Need
To estimate energy, use: Wh = (standby W × hours) + (motor W × seconds ÷ 3,600 × operations). Say you have an electric driveway gate that has a 300W motor and a 5W standby. Suppose you have a 5W standby and a 300W motor on your electric driveway gate, and that it takes 40 seconds to move. A total of 60Wh standby and 26.7Wh of movement is more than 12 hours with 8 operations (87Wh standby). It is consumed by standby.
Table 2 compares needs against the Nice PS324's roughly 10 operations remember treat them as illustrations, not runtime forecasts.
Table 2: Example Backup Operation Planning
Required gate operations | Comparison with a 10-operation battery |
4 operations | Within stated approximate capacity |
8 operations | Within stated approximate capacity |
10 operations | Uses stated approximate capacity |
12 operations | Exceeds stated approximate capacity |
Preparing electric gates for winter means sorting batteries, charging, drainage and release before the first storm. A small solar panel can trickle-charge a gate battery, but winter output is thin.
Electric Gate Installation, Kits and Backup Costs
An electric gate kit usually bundles operators, a control board, photocells and remotes. Automating gates you already own costs less than a new entrance. As a rough guide, a 3m aluminium swing gate starts from around £3,000 and sliding electric gates from around £5,000, installed, excluding VAT. Electric gate installation adds groundworks, cabling, safety devices and any backup battery. Search electric gates cost and prices vary widely, so get written quotes from TrustMark-registered installers.
Note: prices change and vary by installer. Check current quotes and the TrustMark website. |
Winter Power-Cut Preparation Checklist
Test the manual release; show your household how it works.
Check battery condition and charging.
Clear tracks, hinges and moving parts of grit, leaves and ice, especially on sliding electric gates.
Inspect photocells, safety edges and emergency access arrangements.
At your next service or electric gate installation visit, ask whether your board supports backup.
Keep maintenance records for commercial electric gates, with a named key holder.
Home energy storage is a battery system that holds solar or cheap overnight electricity for later — on a time-of-use tariff such as Octopus Go, the off-peak rate. Grid-connected operation and true off-grid backup aren't the same thing. With the STREAM range, the grid-connected port disconnects during an outage, but compatible loads on the AC outlet can receive off-grid power while there's enough stored energy.
A hardwired gate needs a professionally designed connection, so talk to your installer before you plan to power electric gates this way. Neither product below replaces a dedicated gate battery.
Building Solar and Storage Together from Scratch
Planning panels and a battery together means you can design the outage plan up front. For example, the EcoFlow STREAM 5000 offers 5kWh (5,024Wh) of storage, expandable up to 90kWh. It takes 5,000W of PV input across four 1,250W MPPT channels and gives 3,000W AC output, managed by Intelligent Mode+. During a cut, that stored energy can support selected compatible equipment — perhaps your electric gates. First, though, an installer must confirm motor compatibility and design a safe connection.
Adding Battery Storage to Existing Solar Panels
Rooftop panels alone keep nothing running in a cut. Storage moves daytime generation into the evening and into an outage. For example, the EcoFlow STREAM AC 5000 has 5kWh (5,024Wh) of capacity, expandable up to 90kWh, with 10,000 guaranteed cycles. It adds 3,000W AC output, Intelligent Mode+ and Local Mode for offline stability. Its grid-connected port doesn't supply power during an outage, so compatible loads — which could include electric gates — connect to the AC outlet through a professionally designed connection and run while enough energy is stored.
Note: Compliant generation-only plug-in solar kits have been legal to buy and use in Great Britain since 27 August 2026, but these rules do not cover plug-in batteries or solar-plus-storage systems. Home batteries and systems with integrated batteries (like the EcoFlow STREAM range) are not plug-in solar products. They must be professionally installed and must comply with IET Wiring Regulations (BS 7671) and DNO connection requirements. Check current GOV.UK guidance and speak to a qualified installer about the requirements for your home. |
Your electric gates stop when the power does, so three things matter: a back-up battery suitable for your board (if available), a manual override that all users can access, and regular maintenance. Dedicated batteries, portable power stations and home energy storage all serve different functions – it is up to you to choose the right combination for your motor and the duration of your outage.
Once the gate is sorted, think about the rest of your household's essentials. Explore the EcoFlow STREAM 5000 and EcoFlow STREAM AC 5000 on the EcoFlow UK to find a home energy storage solution that suits your solar setup and backup requirements.
Do Electric Gates Need Planning Permission in the UK?
It depends where you live. In England, gates next to a road need consent if they're over 1m high, or over 2m elsewhere — so tall electric driveway gates onto a road usually do. Listed buildings and some conservation areas need consent regardless. Scotland, Wales and Northern Ireland have their own rules. Ask your local planning authority.
Can Electric Gates Work Without an Internet Connection?
Yes. Automatic electric gates open with remotes, keypads and intercoms that talk straight to the control board. Wi-Fi or GSM modules only add app control. If your router drops in a power cut, your electric gate still works on mains or battery.
Are Electric Gates Suitable for Sloping Driveways?
Often, with limits. Sliding gates need a fairly level run, though a cantilever design — the usual electric rolling gate in the UK — can help on uneven ground because the leaf doesn't touch the floor. Electric gates for driveways with steep falls usually need a site survey, so ask your installer first.
