Do Home Security Systems in the UK Work in a Power Cut?
Home security systems UK households install rarely include backup for the whole chain. The Energy Networks Association reported more than 400,000 UK homes losing power at some stage in the October 2026 storms. Your alarm battery keeps the siren live, but the cameras, NVR and router go dark, and phone alerts stop. This guide examines the impact of a power outage on various types of security devices, why you might not receive an alert before the cameras and how much energy you'll need to keep your cameras running for 12, 24 or 48 hours. It also explains what to do when the power goes out and how home energy storage can help keep your essential security equipment running.
 Home security equipment and EcoFlow STREAM 5000 in a UK utility room
How Often Do Power Cuts Hit UK Homes?
How Long Do Typical UK Power Cuts Last?
In a typical year, a cut is short. UK Power Networks reports an average of 29.0 minutes off supply per customer and its London network averages just 11.4. For most households, that is well under an hour.
Which UK Areas Face Longer Power Interruptions?
Exposure rises elsewhere. Ofgem data analysed by eXp UK puts the North of Scotland at 59.24 minutes and Yorkshire at 52.12, about double the UK Power Networks average. Scroll through UK home security systems listings and you’ll see plenty of alarm battery claims, but little on the router or recorder. In a higher-exposure region, that gap matters more.
Why Winter Storms Create a Greater Security Risk
The average hides the tail. Storm Arwen in November 2021 cut power to more than a million homes and businesses and thousands stayed off for over a week. More than 400,000 homes lost power at some stage in the October 2026 storms. Those are the outages that test home security systems UK households rely on. They run to 24 hours and beyond, the same thresholds at which storm compensation starts.
Connectivity fails with the power. Uswitch’s October 2026 research found 26.7 million UK adults lost broadband in the past year, and 42% of those hit lost it to a power cut. People opting for a security system for home UK should always plan for the tail and not the average. The numbers are consolidated in Table 1.
Outage figures and compensation rules change. Check Ofgem, UK Power Networks and the Energy Networks Association for current data.
Table 1: UK Outage Scale
Measure
Figure
What it means
Average annual minutes off supply, UK Power Networks (2023/24)
29.0 (London 11.4)
Most years, a cut is under an hour
North of Scotland / Yorkshire average minutes lost
59.24 / 52.12
Exposed regions run about double
Storm Arwen, November 2021
Over 1 million homes and businesses
Multi-day tail
October 2026 storms
Over 400,000 homes
Winter events recur
Broadband outages, past year
26.7 million adults; 42% lost it to a power cut
Power and connectivity fail together
Which Security Devices Keep Working Without Mains Power?
Home security systems UK households install split into two groups: devices that carry a battery and devices that don’t. Table 2 sorts each device by what it does when the supply fails.
Do Alarm Panels and Battery Cameras Keep Working?
Yes, both carry their own power. An alarm panel switches to an internal battery. One installer guide puts that backup at 4–24 hours, ranging by system quality, with batteries replaced every 2–5 years at £25–£120. Any home security alarm system UK installers fit follows that rule.
Battery and solar cameras run on their own cells, so recording continues. Remote viewing and alerts still need the router, which is why the wireless home security systems UK renters pick keep recording but go quiet on your phone.
What Happens to Wired CCTV, PoE Cameras and Doorbells?
Wired systems have no cushion. A security camera system for home UK installers fit with PoE cameras and an NVR stops recording the moment supply fails, unless the camera, network and recorder all sit on a UPS. A wired doorbell is fed by a mains transformer and goes offline. A battery doorbell runs on its cell and keeps working.
Do Routers and ONTs Have Their Own Backup Power?
No. Your router and ONT have no backup by default. Openreach stopped fitting battery backup units alongside the ONT by default in FTTP-only areas in 2018. Without them, alerts, live view and cloud recording stop, whatever the cameras are doing.
Scan best home security system UK shortlists and look for one line: does the backup cover the router and ONT, or only the alarm?
Table 2: Power-Cut Behaviour by Device
Device
Built-in backup
In a cut
Intruder alarm panel
Internal battery, 4–24 hours
Sensors and siren stay live until the battery depletes
Wired or PoE camera with NVR
None
Recording stops
Battery or solar camera
Own rechargeable cell
Records on cell; alerts need the router
Wired video doorbell
None (mains transformer)
Offline
Router and ONT
None by default
Alerts, live view and cloud recording stop
Why Do Security Alerts Fail Before the Cameras?
Home security systems UK households use for phone alerts rely on an unbroken chain: camera, router, ONT and the street network. Table 3 shows where that chain breaks.
Device Power and Internet Connectivity Are Different Problems
Break one link and your phone stays silent, even while a battery camera keeps recording. Powering a device keeps its recording. It doesn’t keep the alert flowing. A camera can hold footage on its own cell while the router, ONT or street network stays dark.
How Broadband and Mobile Backup Affect Remote Monitoring
Ofcom's 1 hour timeframe is not about your cameras, it's about emergency calling. At least one solution shall be provided by the provider to make it possible to reach the emergency organisations for a minimum of one hour during a power failure. No guarantees with cloud recording or app alerts.
GSM sidesteps broadband. A GSM module uses the mobile network, keeps working in a local power cut and sends SMS or app alerts. That’s why home security alarm systems UK installers fit with GSM keep reporting when broadband drops.
Which Security Features Still Work Without Broadband?
Smart systems fail at the router first. Search smart home security systems UK and nearly every result leans on app alerts, which need router power. Even the best smart home security system UK reviews rank is no exception, and home security systems UK wireless kits behave the same way. Local recording and GSM alarm reporting survive. Phone alerts and cloud recording don’t.
Table 3: What Still Works (Logic, Not Measured)
Scenario
Local recording
Phone alerts
Cloud recording
Battery camera, router off
Yes
No
No
PoE cameras and NVR on UPS, router off
Yes
No
No
Cameras, NVR and router on backup, ONT unpowered
Yes
No
No
Cameras, NVR, router and ONT powered, street network live
Yes
Yes
Yes
Alarm with GSM module, router off
Alarm logs
Yes
n/a
How Much Backup Energy Do You Need?
Calculate the Power Needed by Your Security Equipment
Home security systems UK households size backup with one formula: energy needed in kWh equals watts × hours ÷ 1,000. Your essential kit is a basic alarm (7–8W), a router (5–15W) and a four-camera PoE system with NVR (40–70W), which adds up to 52–93W.
Compare Backup Requirements for 12-, 24- and 48-Hour Outages
Anchor on UK durations: 1 hour, the minimum Ofcom expects providers to offer for reaching emergency organisations; 12 hours; 24 hours, the category 1 storm compensation threshold; and 48 hours, category 2. The alarm battery inside a home security system UK households buy covers the alarm alone. Nothing else in the kit carries one.
Now read Table 4. The alarm alone needs 0.17–0.19kWh for 24 hours, while the essential kit needs 1.25–2.23kWh for 24 hours and 2.50–4.46kWh for 48 hours. A security camera system for home UK households fit is the heaviest line, at 1.92–3.36kWh over 48 hours. Anyone comparing the best home security systems UK has to offer for resilience should size backup to this table.
Table 4: Energy Needed During an Outage (kWh)
Kit
Load
12 hours
24 hours
48 hours
Alarm only
7–8W
0.08–0.10
0.17–0.19
0.34–0.38
Alarm and router
12–23W
0.14–0.28
0.29–0.55
0.58–1.10
Four-camera PoE with NVR
40–70W
0.48–0.84
0.96–1.68
1.92–3.36
Essential kit (alarm, router, PoE and NVR)
52–93W
0.62–1.12
1.25–2.23
2.50–4.46
Note: The energy figures shown are estimates based on typical power ranges, not guaranteed runtimes. Real consumption will depend on the equipment and settings used, and battery losses will diminish the amount of energy that will be available.
When Is a UPS Enough, and When Is Home Storage More Suitable?
A small UPS designed for routers usually provides 2–8 hours of backup. That's enough for a typical power cut, which Section 1 shows usually lasts less than an hour. However, your cameras and NVR will still lose power. Longer outages lasting 24–48 hours require backup for the entire security setup. As Table 4 shows, the essential equipment needs 2.50–4.46kWh over 48 hours. Rather than buying separate backup units for each device, a single larger power source offers a simpler solution. This is where home energy storage becomes useful.
What Should You Do During a UK Power Cut?
A cut is easier to handle when you know who to call and what to protect. Each step below takes a few minutes.
Report the Power Cut to the Correct Network Operator
Call 105. It’s a free call that connects you to your electricity network operator, which is not your energy supplier. It covers England, Scotland and Wales, and Northern Ireland has its own network operator. Report the cut first, because the operator is the only party that can restore supply or log the outage.
Know Who to Contact and When Compensation Applies
ENA research at launch found 72% of people didn’t know who to contact, and 43% named their supplier. Keep the right contacts for your home security systems UK together: the network operator for the cut, your broadband provider for the connection, and your installer or monitoring centre for the alarm.
Compensation follows the same thresholds as the outage figures earlier in this guide. You receive £90 after 24 hours in a category 1 storm or 48 hours in a category 2 storm. Claims go to the network operator within one month.
Compensation amounts and thresholds change. Check Ofgem and the Citizens Advice website for current rules.
Prepare Your Security Equipment Before Winter
Prepare before winter by checking every device in your security systems for home UK:
  • Replace alarm batteries older than 2–5 years.
  • Charge battery cameras and a power bank.
  • Note where the router and ONT sit, so you can check them quickly in a cut.
Keep Home Security Running in a Power Cut With Home Energy Storage
Home security systems UK households run have a gap. The alarm carries 4–24 hours of its own battery, while cameras, NVR, router and ONT carry none, and outages of 24–48 hours open that gap. One home energy storage source covers the whole essential kit instead of five small batteries.
Treat the numbers as arithmetic only. A 5,024Wh capacity exceeds the 48-hour worst case of 4.46kWh and equals 54–97 hours of the 52–93W essential kit before conversion losses. Unlike the street network, which is powered by storage, the GSM alarm path remains your alert path. The connection of storage to home circuits must be done by a professional electrician and require registration with the DNO.
Power Cut Backup When Building Solar and Storage Together
A cut leaves cameras, NVR and router dead within the first minute if your home has no solar and no storage. For example, the EcoFlow STREAM 5000 suits a household building solar generation and home energy storage together, so the essential kit has a source of its own. It offers 5kWh (5,024Wh) of capacity, expandable up to 90kWh, with 5,000W of PV input across four MPPT channels at 1,250W each and 3,000W AC output. The compact unit has a built-in handle, and Intelligent Mode+ manages energy automatically. That makes a practical base if you want your home security systems UK setup to keep running.
EcoFlow STREAM 5000
Installed home battery for homes without solar. UK rules require installation, and the setup is designed to be simple 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for high-demand appliances like stoves, dryers or kettles (when solar is generating or an Expansion Battery is paired) 5,000W solar input makes full use of your solar generation Up to 2500W AC charging for fast recharge Smart meter, main unit and solar panels are designed to connect easily, with step-by-step app guidance for setup Compact 45.4kg body with a built-in handle for easier placement during installation Residential-grade protection with pressure-release and fire-resistant materials, designed to reduce thermal runaway risk with high-voltage solar panels Rated for 10,000 cycles Local Mode keeps the system running and communicating even if the network drops
Power Cut Backup When Adding Storage to Existing Solar Panels
Solar panels on your roof don't keep cameras running in a cut. Standard grid-tied systems switch off when the grid fails. For example, the EcoFlow STREAM AC 5000 adds storage to an existing array, with 5kWh (5,024Wh) of capacity, expandable up to 90kWh, 10,000 guaranteed cycles and 3,000W AC output. Intelligent Mode+ handles energy management automatically, and Local Mode keeps it stable offline. Pair it with the home security systems UK kit you already own, and the essential devices gain a source beyond the alarm battery.
Installed home battery for homes with existing solar. UK rules require installation, and the setup is designed to be simple Works with existing rooftop PV systems, home battery systems and leading third-party meters 5024Wh capacity, expandable to 90kWh with Expansion Batteries Up to 3000W AC output for heavy household appliances (when solar is generating or an Expansion Battery is paired) AC coupling adds storage alongside your current solar setup, and a Gateway simplifies expanding later Compact 44.6kg body designed to fit into spaces around the home Rated for 10,000 cycles
Note: Compliant generation-only plug-in solar kits have been legal to buy and use in Great Britain since 27 August 2026, but these rules do not cover plug-in batteries or solar-plus-storage systems. Home batteries and systems with integrated batteries (like the EcoFlow STREAM range) are not plug-in solar products. They must be professionally installed and must comply with IET Wiring Regulations (BS 7671) and DNO connection requirements. Ensure you look at the current GOV.UK guidance and speak to a qualified installer about the requirements for your home.
The average UK power cut lasts under an hour, but storms push outages to 24–48 hours and beyond. Only the alarm carries its own battery, so a home security system UK households rely on loses cameras, NVR and router first. The essential kit needs 2.50–4.46kWh for 48 hours, and that figure is the number to plan around for home security systems UK setups.
That backup gap points to home energy storage as one source for essential security. Explore the EcoFlow STREAM 5000 and EcoFlow STREAM AC 5000 on the EcoFlow UK website to find the right home energy storage for your household.
FAQ About Home Security Systems in the UK
Is It Legal to Put CCTV on My House in the UK?
Planning home security systems in UK homes starts at your boundary. Cameras covering only your own property fall outside most data-protection duties. Cameras that capture neighbours or the street bring ICO guidance: signage, retention limits and access requests. Check current ICO wording before you fit.
How Many Cameras Does a UK Home Need?
Size by entry points, not room count. Cover the front door, back door and driveway first, then ground-floor windows. Most homes start at two to four cameras.
Do I Need a Monitored Home Security System in the UK?
Compare self-monitored app alerts with a monitoring-centre subscription for your home security systems UK setup. App alerts cost nothing extra but rely on your phone, router and power. A monitoring centre adds a human response. Ask your installer whether the system qualifies for police response under your local force's policy.
Home Solutions
