The Best Solar Generators for Canadian Home Backup This Year
- What Makes a Solar Generator "the Best" for a Canadian Home?
- The 3 Best Solar Generators for Canadian Homes in 2026: Quick Picks
- Best Overall: EcoFlow DELTA 3 Ultra Plus
- Best for Whole-Home Backup: EcoFlow DELTA Pro Ultra
- Best Value and Most Compact: EcoFlow DELTA 3 Max Plus
- Solar Generator vs. Gas Generator: Which Is Actually Better in Canada?
- How Much Solar Generator Capacity Do You Actually Need?
- Conclusion
- FAQs
"Best solar generator" means something different depending on who is asking. A renter in a Toronto apartment wants enough power to keep a fridge and a Wi-Fi router running through a blackout. A family on an acreage outside Calgary wants to run the well pump, the furnace fan, and half the kitchen during a multi-day ice storm outage. This guide separates those two problems and compares picks by battery capacity, output, and pricing in Canadian dollars, not figures pulled from a US listing and converted after the fact.
Every product mentioned here is sold through Ecoflow's Canadian store, so the pricing, availability, and specifications reflect what a Canadian household would actually see at checkout.
Before comparing individual units, it helps to agree on what actually matters when a unit is powering a home rather than a weekend campsite. A handful of criteria separate a genuinely useful backup unit from one that looks good on paper:
Battery capacity (Wh or kWh), since this determines how long the essentials stay running
Continuous AC output and surge capacity, which decide what appliances can start and keep running at once
Solar input speed, for households that want to recharge during a multi-day outage rather than just once
Safety certifications and cold-weather performance, given how much of the country deals with sub-zero winters
Total cost in CAD, including how that cost compares over several years of use, not just at purchase
There is a real trade-off worth naming here. Solar generators cost more upfront than a comparable gas generator, but they run silently, need no fuel supply, and are safe to use indoors, which matters a great deal during a winter storm when running an extension cord out to a gas unit isn't practical. It also helps to know how a battery stores and discharges electricity before comparing specific units, since the underlying technology is the same whether it's sitting in a portable case or bolted to a wall. The main downside is a hard capacity ceiling on portable units compared with a permanently installed standby generator, though as the picks below show, that ceiling is higher than most people expect.
With the criteria set, here are the top picks for Canadian households heading into this year.
For readers who want the short version before the details, here are the three picks and who each one actually suits.
Pick | Model | Capacity | Continuous output | Best for |
Best overall | EcoFlow DELTA 3 Ultra Plus | 3,072Wh | 3600W | Most Canadian households |
Best for whole-home backup | EcoFlow DELTA Pro Ultra | 6.144 kWh, expandable to 90 kWh | 7200W | Larger homes, extended outages |
Best value / most compact | EcoFlow DELTA 3 Max Plus | 2048Wh | 3000W | Apartments, condos, secondary backup |
The DELTA 3 Ultra Plus earns the top spot for the widest range of households because it balances capacity, output, and portability without requiring a whole-home installation. The DELTA Pro Ultra exists for households that don't want to compromise on what stays powered, since it scales well beyond what a single portable unit can normally offer. The DELTA 3 Max Plus rounds things out as the lower-cost, smaller-footprint option for anyone who doesn't need that much headroom.
Here is a closer look at why each pick earned its spot, starting with the overall winner.
At 3,072Wh, this unit is positioned for indoor emergency and local backup power, everyday household electricity use, and UPS-style backup power that kicks in automatically if the grid drops. That combination is what makes the DELTA 3 Ultra Plus portable power station a strong fit for the widest range of Canadian households, rather than a niche pick for one specific use case.
Spec | Figure |
Battery capacity | 3,072Wh |
Continuous AC output | 3,600W |
Surge output | 7,200W |
Fastest recharge | Roughly 48 minutes to 80 percent with combined solar and generator charging |
Price (CAD) | Around $1,899, though EcoFlow runs periodic sales, so it's worth checking the current listing |
This is the right fit for a household that wants to keep the fridge, the Wi-Fi, and a handful of essentials running through a multi-day outage without stepping up to a whole-home installation. It is not the pick for a household planning to run central air conditioning or an electric range off battery power alone.
For households that want to go further and cover the whole house, the next pick scales up considerably.
The DELTA Pro Ultra starts at 6.144kWh and can scale up to 90kWh across a full system, which puts it in a different category from a standard portable power station. Households looking at this as a genuine whole-home solution rather than a supplemental backup unit will find the EcoFlow DELTA Pro Ultra system built to run HVAC and major appliances through an outage, not just the essentials.
Set up as a whole-home backup system, it switches over automatically the moment the grid drops, and it sits well below the cost of a five-figure whole-home installation while still covering major appliances rather than just the essentials.
Continuous output sits at 7200W with surge output up to 10.8kW, and a single inverter accepts up to 5.6kW of solar input, which climbs to 16.8kW across a three-inverter system. Pricing starts around $5,799 CAD for a base configuration, though the final cost depends heavily on how much capacity and how many inverters a household adds.
This is the clear step up for larger homes, for regions prone to multi-day outages such as ice storm corridors or wildfire-adjacent areas, and for anyone who simply isn't willing to compromise on what stays powered during an emergency.
Not every household needs that much capacity, and the value pick below covers smaller spaces just as well.
At 2,048Wh, the DELTA 3 Max Plus covers the same core use cases as the Ultra Plus, meaning indoor emergency backup, everyday household electricity, and UPS scenarios, but in a smaller and considerably less expensive package. Continuous output comes in at 3000W with a 6000W surge rating, and the fastest recharge time lands around 43 minutes to 80 percent using generator charging.
Pricing sits around $1,399 CAD, which is worth factoring in alongside the specs above when weighing it against the higher-capacity picks. For anyone shopping specifically in this tier, the DELTA 3 Max Plus lineup covers the current configuration options worth comparing against the specs above.
This is the practical choice for apartments, condos, or anyone who wants reliable backup for the essentials without paying for capacity they will likely never use.
With the top picks covered, the next common question is how a solar generator actually stacks up against a traditional gas generator.
Gas generators carry a lower sticker price, but that number doesn't tell the whole story. They come with ongoing fuel and maintenance costs, they produce exhaust that makes them unsafe to run indoors, and they depend on a fuel supply chain that can be disrupted during the same emergencies that cause the outage in the first place, whether that's a winter storm blocking roads or a regional fuel shortage.
Solar generators cost more upfront, but they run silently, need no fuel at all, and are safe to use indoors, which matters during a winter power outage when opening a window or garage door to vent exhaust isn't an option. The real advantage shows up before a storm actually arrives, when a charged unit is already part of the plan rather than a last-minute scramble once the wind picks up and the shelves are empty.
Whichever type a household ultimately chooses, the last step is sizing the unit correctly.
The simplest way to size a unit is to list the essentials a household actually needs during an outage rather than everything in the home. That typically means the fridge, a Wi-Fi router, a few lights, phone and device charging, and any medical devices that need continuous power. Adding up the wattage for those items gives a realistic target instead of a guess.
Fridge: roughly 100 to 200W continuous, with a higher surge on startup
Wi-Fi router and modem: under 20W combined
LED lighting for a few rooms: 20 to 60W total
Phone and laptop charging: under 100W combined
A CPAP machine or similar medical device: 30 to 60W
Most households land comfortably within a 2,000 to 3,000Wh unit unless they're also planning to run something demanding like central air conditioning or an electric range, in which case the larger DELTA Pro Ultra tier makes more sense than trying to stretch a smaller unit past its limits.
Adding up the wattage this way also doubles as a quick gut-check on where the biggest draws in the house actually are, the same starting point most people use when they're trying to trim the electricity bill rather than just size a backup unit.
With sizing covered, here is the short version to remember.
The best solar generator for a Canadian household really does depend on household size and outage risk more than any single spec on a page. The DELTA 3 Ultra Plus is the strongest fit for most homes, the DELTA Pro Ultra is built for whole-home coverage, and the DELTA 3 Max Plus makes sense for smaller spaces or tighter budgets.
The most useful habit is sizing to actual essential-appliance wattage rather than defaulting to the biggest unit available, and treating backup power as something to have ready before ice storm, wildfire, or hurricane season peaks rather than scrambling for it once an outage is already underway. Comparing capacity, output, and CAD pricing side by side, as laid out above, is the fastest way to land on the right unit rather than the most expensive one.
What is the best solar generator for home backup in Canada?
It depends on household size. The DELTA 3 Ultra Plus suits most homes, the DELTA Pro Ultra fits whole-home needs, and the DELTA 3 Max Plus works well for smaller spaces or tighter budgets.
Can a solar generator power an entire house?
A standard portable unit usually can't, but a scalable system like the DELTA Pro Ultra, which expands up to 90kWh, is built specifically to cover whole-home electricity needs during an outage.
Is a solar generator worth it compared to a gas generator?
It depends on outage frequency and priorities. Solar generators cost more upfront but need no fuel, run silently, and are safe indoors, which often closes the cost gap over several years.
How long does a solar generator last during a power outage?
Runtime depends on capacity and what's plugged in. A 2000 to 3000Wh unit typically covers a fridge, lighting, and device charging for a day or more between recharges.
How much solar generator capacity does an average Canadian home need?
Most households need 2000 to 3000Wh to cover essentials like a fridge, Wi-Fi, lighting, and device charging, though larger homes running major appliances should size up considerably.
Do solar generators work well in cold Canadian winters?
Battery performance can dip in extreme cold, so units are best stored indoors or in a heated space when possible, with manufacturer cold-weather guidance followed for outdoor use.
