How to Save Energy at Home: A Measure-First Plan
Learning how to save energy at home starts with measuring your household's energy use. Start with heating, cooling, hot water, and equipment that runs for long periods.
Home energy includes more than electricity. Your largest load may use gas, oil, or another fuel.
Homeowners exploring managed power can consider the EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated). It works with EcoFlow Smart Home Panel 2 for circuit data and solar storage.
•7.2 kW AC output, expandable up to 21.6 kW with supported configurations •6 kWh starting capacity, expandable up to 90 kWh • Supports automatic home backup switchover with EcoFlow Smart Home Panel 2 • Automatic battery self-heating below 0°C for cold-weather operation
Start by finding your current energy use, so each later change has a clear purpose.
How Do You Measure Energy Use Before Trying to Save It?
To understand how to save energy in a house, first record a baseline. Review 12 months of electricity and heating-fuel use before changing equipment or habits.
Compare energy, not only cost. Electricity appears in kilowatt-hours (kWh), natural gas often appears in gigajoules (GJ), and heating oil may appear in litres. Note the billing period, season, and major changes in occupancy.
Your utility portal or smart-meter data may show daily or hourly patterns. Check overnight use to estimate the energy used while most people sleep. A certified plug-in meter can safely test a suitable appliance.
Do not open sealed electrical equipment or switch off essential systems for a test. Consider an EnerGuide home evaluation before major renovations.
Remember that watts measure power at one moment. Watt-hours and kilowatt-hours measure energy used over time. A low-power device can still use plenty of energy if it runs all day.
Measurement source
What it shows
Best use
Limitation
Utility bill
Use over a billing period
Building a seasonal baseline
Little appliance detail
Utility portal
Daily or hourly patterns
Finding peaks and baseload
Availability varies
Plug-in meter
One compatible appliance
Testing operating and standby use
Cannot test hardwired loads
EnerGuide evaluation
Whole-home performance
Planning major improvements
Requires an appointment
 Homeowner measuring the energy use of a plug-in appliance Homeowner measuring the energy use of a plug-in appliance
What Uses the Most Energy in a Canadian Home?
Space heating is generally the largest total home-energy use in Canada. Water heating and other household equipment also use a large share. The order changes with the climate, fuel, home size, and building condition.
Heat can escape through gaps, windows, walls, attics, and basements. Electric resistance heating and portable space heaters can draw plenty of electricity. In summer, air conditioning may become a major load.
Hot-water use rises with long showers, hot laundry cycles, and leaking taps. Dryers, ovens, fridges, pools, hot tubs, and electric vehicle charging may add significant use. Electronics also draw standby power, though heating and hot water often deserve attention first.
High power does not always mean high total energy use. A kettle draws high power for a few minutes. A fridge uses less power at once but cycles throughout the day.
This distinction also changes the answer to common questions. Total home energy includes every fuel, while an electric bill records only electricity. Current Natural Resources Canada residential data separates these end uses when comparing Canadian homes.
How Can You Save Energy at Home Without Buying Anything?
The simplest way to save energy is to stop heating, cooling, lighting, or running equipment when it is not needed. Start with the systems that operate longest.
Heating and Cooling
Use safe thermostat setbacks when the home is empty, or everyone is asleep. Close blinds during hot periods, then use winter sunlight when it adds warmth.
Ceiling fans cool people rather than rooms, so turn them off when everyone leaves. Keep doors and windows closed while heating or cooling equipment runs.
Hot Water and Laundry
Wash suitable clothes in cold water and wait for full loads. Air-dry clothing when the space has enough ventilation. Shorter showers and prompt leak repairs also reduce water-heating energy.
When deciding how to save the energy used each day, give priority to hot water and equipment that runs for long periods.
Kitchen and Appliances
Match the cooking appliance to the meal. A smaller appliance may use less energy for a small task than a full-size oven. Use pot lids and disable dishwasher heated drying when suitable.
Check fridge and freezer seals. Clean accessible coils and filters as directed in the manual. Avoid leaving appliance doors open longer than needed.
Lighting and Electronics
Turn off unused lights and use computer sleep settings. Unplug chargers and electronics that are rarely used. A switched power bar can make this easier.
More ways to save electricity at home can help you build a room-by-room routine.
Which Home Improvements Reduce Energy Use the Most?
Improvements to the building shell, heating system, and hot-water system often matter more than small electronic changes. Begin with a clear problem, then choose an upgrade that addresses it.
Start With Low-Cost Improvements
Add weatherstripping around doors and suitable windows. Removable window film may help. Replace frequently used bulbs with LEDs, and use smart power bars to stop real standby waste.
Low-flow showerheads and tap aerators can reduce hot-water use. Maintain HVAC filters as directed. Repair leaking hot-water taps and use a programmable thermostat when it suits the system.
Never use a candle or incense to search for drafts. Renters should also ask permission before changing plumbing fixtures, thermostats, or fixed equipment.
Plan Larger Improvements as a System
Professional air sealing, insulation, heat pumps, efficient water heating, ENERGY STAR products, and better windows can cut larger loads. One change can affect another. A tighter home, for example, may need planned mechanical ventilation.
Natural Resources Canada treats the building shell, equipment, indoor conditions, and occupants as one connected system. An EnerGuide evaluation can identify sensible steps. Solar panels usually make more sense after avoidable demand falls.
Improvement
Energy area affected
Renter-friendly?
Professional help?
Result to measure
Weatherstripping
Heating and cooling
Often
Usually no
Seasonal heating or cooling use
Low-flow fixture
Hot water
With permission
Sometimes
Hot-water or fuel use
Smart thermostat
Heating and cooling
With permission
Depends on system
Heating or cooling runtime
Air sealing and insulation
Heating and cooling
No
Recommended
Seasonal energy use and comfort
Heat pump
Heating and cooling
No
Yes
Annual electricity and fuel use
How to Use Tech to Save Energy at Home
Knowing how to use tech to save energy means choosing tools that measure waste, stop needless operation, or control equipment more accurately. Adding a connected device without a useful task may only add another standby load.
Monitor Before You Automate
Utility portals, smart-meter data, plug-in meters, and whole-home monitors can reveal rising use. Appliance reports may also show a change that needs attention.
A dashboard does not save energy by itself. It helps when you change a setting, repair a fault, or stop needless operation. Home energy management systems can bring monitoring and controls together.
Automate Loads That Do Not Need to Run Constantly
Smart thermostats can follow household schedules. Occupancy controls can switch off lights in empty spaces. Smart plugs and timers can stop selected devices from staying on.
Eco modes may reduce appliance use. Automated blinds can manage solar heat, while EV charging can follow a schedule. Hot-water scheduling may help when safely supported.
Smart devices use some energy themselves. Use them only when they control a larger, meaningful load.
Separate Energy Efficiency From Energy Storage
A battery does not reduce the energy an appliance needs. It stores electricity for later, with some loss during charging and discharging. Compatible storage can increase solar electricity used at home.
The DELTA Pro Ultra base configuration has 6,144 Wh of storage and 7,200 W of continuous output. One inverter accepts up to 5.6 kW of solar input. With EcoFlow Smart Home Panel 2, homeowners can view energy data and control supported circuits through Self-Power, Scheduled Tasks, and time-of-use modes.
These controls manage when stored energy is used. They do not make household equipment more efficient. Hardwired integration also requires compatible equipment and a qualified electrician.
For selected plug-in loads instead of an integrated home system, consider the EcoFlow DELTA 3 Max Series Portable Power Station (2048Wh).
EcoFlow DELTA 3 Max (2048Wh)
•2400 W AC output with 4800 W surge output • 2048 Wh battery capacity for home backup and mobile power • 4 charging options, with 0–80% in 68 minutes using wall or generator charging •20.3 kg design with a 10 ms auto-switch for compatible critical devices
The DELTA 3 Max has 2,048 Wh of battery capacity, 2,400 W of rated AC output, and 4,800 W of surge output. OASIS 3.0 shows real-time battery status, electricity prices, and savings information, while Scheduled Tasks and Self-Powered Mode can manage when stored energy is used.
The unit does not measure the whole home or power hardwired circuits by itself. Compare each load’s running watts, starting demand, and energy use before connecting it.
What Order Should You Make Energy-Saving Changes?
The best way to learn how to save energy is to measure first and make free changes before buying larger equipment. Move ahead only when the last step gives you useful information.
 Homeowner planning energy-saving changes after checking household use Homeowner planning energy-saving changes after checking household use
Stage
Action
When to move forward
1. Measure
Record current use and major loads
When you have a useful baseline
2. Stop waste
Change schedules and avoid needless operation
When the habits become consistent
3. Maintain
Clean, repair, and service equipment
When equipment works correctly
4. Add controls
Use timers, smart plugs, or thermostats
When there is a clear load to control
5. Improve the home
Seal, insulate, or replace inefficient systems
After an evaluation or clear diagnosis
6. Add generation or storage
Assess solar, batteries, and integration
After demand and system needs are known
Measure the result in the same units as your baseline. Compare similar seasons and weather when possible. Avoid using bill dollars as the main test because rates and fees can change even when energy use falls.
Measure One Change Before Adding Another
Choose one large or long-running use, make one suitable change, and measure the result. Add automation, solar, or storage only when your household has a clear load and a measurable reason.
Once you understand those needs, compare EcoFlow portable power stations by capacity, output, charging options, and the loads you plan to support.
Does turning off lights really save energy?
Yes, a light that is off no longer uses electricity. The reduction depends on its wattage and how long it would otherwise stay on. The effect is smaller with an efficient LED, but it is still real.
Do smart plugs save energy?
They can reduce standby use or stop equipment from running on an unneeded schedule. However, the plug uses a small amount of power too. It works best when it controls a meaningful load.
Can renters make a home more energy efficient?
Yes, renters can change daily habits and use reversible measures. Fixed wiring, plumbing, thermostats, and structural work normally need the landlord’s approval. Report leaks, failed seals, and faulty equipment promptly.
Does battery storage reduce household energy consumption?
Usually not by itself. Storage moves electricity between times and has conversion losses. It can support solar self-use, load control, and lower grid reliance, but it does not reduce an appliance’s basic energy needs.
