National Heat Pump Rebate in Canada: Eligibility, Rebate Amounts, and Home Backup Tips
Canada’s new National Heat Pump Rebate is part of a broader federal plan to retrofit one million homes over eight years. Announced on October 8, 2026, the heat pump rebate is not open yet. Once it is, eligible below-median-income households may receive up to $10,000 toward an electric cold-climate heat pump, while other eligible homeowners may receive $2,000. The federal government says the program may work alongside provincial support where available.
With final portal instructions, installer rules and documentation requirements still to come, homeowners should wait for official guidance and obtain approval before buying or installing a system. This article explains what the announcement confirms, what still depends on final rules and how to plan for winter electricity bills and backup power before switching to a heat pump.
What Is the National Heat Pump Rebate?
The National Heat Pump Rebate Program is intended to reduce eligible households’ upfront retrofit costs while supporting lower-emission home heating. Other heat pump rebates may continue under provincial or utility programs, subject to their own rules.
How the New Federal Rebate Works
This is a rebate, not a tax credit. According to the announcement, homeowners will get approved before buying and installing an eligible heat pump, and then submit their receipts through an online portal. Details on the application requirements, participating installers, and supporting documents have not yet been released.
The heat pump rebate is one stream of the federal $2 billion, eight-year plan to support one million home retrofits. Within that plan, it is expected to help up to 820,000 households switch from oil, propane, electric resistance heat, or older heating systems to more efficient cold-climate heat pumps.
How Much Can Eligible Homeowners Receive?
The federal announcement sets two main rebate levels:
Applicant Type
Federal Rebate Amount
Notes
Below-median-income households
Up to $10,000
Designed to reduce the upfront cost of switching to an eligible heat pump
Other eligible homeowners
$2,000
Can help offset part of the purchase and installation cost
Whether you can combine this rebate with a provincial program depends on where you live and on both programs' final rules. Government rebates for heat pumps can use different eligibility lists, application steps and approval timing, so check the applicable government or utility program before signing a contract.
A solar panel is a separate home-energy investment and should not be assumed eligible under the National Heat Pump Rebate unless the final program rules explicitly include it.
When Will Applications Open?
The federal government says applications will run through a secure online portal, with approvals available within 24 hours and payment approved within five days after receipts are submitted. The portal is not open yet: officials have said they aim to launch the program in early 2027. Before buying equipment, wait for official guidance and confirm that the heat pump appears on the federal Eligible Products List.
EcoFlow TITAN 5000 Whole-Home Backup PowerEcoFlow TITAN 5000 Whole-Home Backup Power
Who Qualifies for the National Heat Pump Rebate?
Eligibility is designed to direct federal money where it does the most good: bringing down household heating costs and cutting emissions from home heating. The announcement sets different rebate levels according to household income.
Household Income and Rebate Amounts
The program sorts applicants into tiers using median income thresholds. The announcement doesn’t yet say whether that median will be measured nationally, provincially, or locally, and it gives no dollar cutoff, so no one can tell you today which tier your household falls into.
Applicant Group
Federal Support
Key Point
Up to $10,000
Highest support level under the federal announcement
$2,000
Base rebate for eligible applicants
Landlords / multiple properties
Limited to one rebate per person
A person cannot claim multiple rebates for multiple properties
Homeowner and Property Requirements
The announcement focuses on homeowners installing eligible heat pumps and states that only one rebate will be issued per person: a landlord who claims it for a heat pump in a property they rent out cannot also claim one for the house they live in. Final rules may define property types and occupancy requirements in more detail, so confirm the official eligibility checklist before applying.
Eligible Cold Climate Heat Pumps
To qualify, the heat pump must appear on the federal Eligible Products List. The government says this list will include more than 100,000 electric cold-climate air-source heat pump options in a range of configurations and at different price points, all suited to Canadian conditions. Once the list is out, have your installer confirm the exact model number is on it before you accept a quote.
EcoFlow TITAN 5000 Plus Whole-Home Backup PowerEcoFlow TITAN 5000 Plus Whole-Home Backup Power
How to Apply for the Heat Pump Rebate in Canada
The new program is designed to be simpler than older retrofit programs: no pre- or post-installation energy audits are required under the federal announcement.
Check the Eligible Products List
Before requesting quotes, check that the system you are considering is a cold-climate air-source heat pump suited to Canadian weather. Once the federal Eligible Products List is public, confirm that the exact model appears on it before purchasing.
Submit the Online Application
You’ll apply through a secure federal portal. The announcement describes a simplified form that asks for basic personal details plus information on the eligible heat pump you plan to buy.
Wait for Pre-Approval Before Installation
If you plan to rely on this rebate, obtain approval before buying or installing the heat pump. The announcement says approvals will be available within 24 hours, which is meant to help households replace broken heating systems quickly.
Install the Approved Heat Pump and Submit Receipts
Once the installation is done, you submit the receipts through the online portal, and the government says payment will be approved within five days.
Check Provincial Rebate Requirements
Federal support may be combined with existing provincial heat pump programs, subject to both programs’ rules. Searches for Canada heat pump rebates can mix federal, provincial and utility offers, so confirm the current eligibility list, stacking rules and application steps for every program before signing an installation contract. A current summary of Canadian heat pump rebates can help identify programs to verify with their official administrators.
What Should Homeowners Budget for After the Heat Pump Rebate?
Even with a rebate bringing down the upfront cost, switching fuels changes the shape of your monthly bills, not just the size.
Account for Ongoing Electricity Bills
Switching from gas or oil to a heat pump can raise electricity use even if total heating costs fall. Homeowners switching from oil or propane may reduce annual energy costs, but results depend on the home, equipment, local rates and installation cost. Understanding how a heat pump works in cold Canadian weather helps explain why outdoor temperature, defrost and auxiliary heat affect winter electricity use.
Factor in Seasonal Heating Costs
How much electricity a heat pump uses tracks the outdoor temperature:
  • Mild shoulder seasons (late fall / early spring): An air-source heat pump generally works more efficiently when the outdoor temperature is higher, though running costs also depend on how much heat your home needs and your electricity rate plan.
  • Mid-winter cold snaps (–15°C to –30°C): Efficiency and capacity may fall as the compressor works harder, and electric resistance backup heat, if installed, increases electricity use.
To take some of the swing out of those bills, an equalized payment plan from your utility smooths out the monthly payments rather than lowering them, and any difference from actual use still gets settled up later.
Plan for Electrical Upgrades if Needed
Some older Canadian homes have limited spare electrical capacity. A central cold-climate heat pump, especially one with electric auxiliary heat, may require panel or service work depending on the home’s load calculation. Ask a licensed electrician for an itemized assessment and quote rather than assuming a standard service size or national upgrade cost.
How Can Homeowners Prepare for Power Outages After Installing a Heat Pump?
A heat pump keeps a house warm without burning fossil fuels on site. That also means it runs entirely on electricity: when freezing rain brings down a power line and there’s no backup power, the heat goes off.
Understand Heat Pump Power Requirements
A portable power station that can run a fridge may not be able to run a central heat pump. Check the manufacturer’s specifications for voltage, power input, maximum current, starting behaviour and auxiliary electric heat. The complete HVAC system and other selected loads must remain within the backup system’s output and energy limits.
Use a Home Backup System for Essential Circuits
For households looking to keep essential appliances such as refrigerators, lights, and routers running during a power outage, the EcoFlow TITAN 5000 Whole-Home Backup Power paired with the Smart Home Panel 10 offers a home backup solution. The Smart Home Panel 10 can manage up to 10 selected household circuits, making it easier to allocate backup power based on household needs. If you want to keep a heat pump running during an outage, confirm in advance that its rated voltage, starting power, and running power are compatible with the system, and check the home’s electrical panel and circuit configuration. The Smart Home Panel 10 must be installed by a qualified electrician in accordance with local electrical codes.
7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. 5–30kWh battery capacity. Use more solar. Buy less grid power. Save more at peak rates.
Choose Higher-Output Backup for More Demanding Loads
If more appliances need to run simultaneously during a power outage, consider the EcoFlow TITAN 5000 Plus Whole-Home Backup Power paired with the Smart Home Panel 10 for higher-output backup power. The TITAN 5000 Plus delivers 7.2 kW of battery output and up to 10 kW of total output when paired with compatible solar input, providing more flexibility when planning backup power for refrigerators, lighting, and other compatible household loads. A qualified electrician must confirm system compatibility and the installation plan for the Smart Home Panel 10 and complete the installation in accordance with local electrical codes.
7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 50% lower upfront cost. Smarter choice.
For households looking to replace costly oil, propane, or electric resistance heating, the rebate could help cover the cost of an eligible cold-climate heat pump. Follow the official sequence: confirm the product, apply online, wait for approval, install the system, and submit your receipts.
While you wait for the final program rules, check your panel capacity, estimate how your winter hydro bills could change, and decide which circuits you’ll need during an outage. A heat pump may lower long-term heating costs in a suitable home, and sorting out the electrical side early can improve planning for normal winter operation and outages.
Who Is Eligible for the Ontario Heat Pump Rebate in 2026?
Ontario homeowners may qualify for the federal National Heat Pump Rebate once the federal program opens, subject to its final eligibility rules and approved equipment requirements. Additional Ontario-specific rebates or utility programs may have separate requirements, so check both the federal portal and provincial program rules before applying.
Can Renters Apply for the National Heat Pump Rebate?
Renters are unlikely to be able to apply directly, because the announcement is aimed at homeowners installing eligible heat pumps. Final portal rules should clarify documentation requirements, landlord participation, and how rental properties are handled.
Can You Claim a Heat Pump on Your Taxes in Canada?
There is no general federal income-tax deduction simply for buying a heat pump for personal use. Self-employed individuals running home offices or landlords claiming capital cost allowance (CCA) on rental units may be able to write off the eligible portion, subject to federal tax rules.
What Is the Most Economical Way to Use a Heat Pump?
Keeping the thermostat steady, rather than turning it down hard every night, is usually the best place to start. Bringing the house back up to temperature after a setback forces the system to run at maximum capacity and often triggers inefficient auxiliary electric heat strips, which consume more electricity. Suitable setbacks vary by system and electricity rate plan, so follow the manufacturer’s and the installer’s guidance.
At What Temperature Should I Not Run My Heat Pump?
There is no single cutoff temperature for every heat pump. Rated operating range, capacity and efficiency vary by model and conditions. Follow the manufacturer’s controls and operating instructions, and have a qualified HVAC professional set any dual-fuel changeover or auxiliary-heat strategy for the home and local climate.
Save Bills
