Nova Scotia Heat Pump Rebates: Programs and Eligibility
Heating a house through a damp, windy Nova Scotia winter can get expensive fast, whether you’re topping up a furnace-oil tank at a Cape Breton farmhouse or keeping the baseboards on in a century-old Halifax Victorian. Provincial and federal rebates can help with the upfront cost of switching to a cold-climate heat pump. This guide sets out the main programs, who may qualify, how to apply, and how to keep heating costs down after installation.
What Heat Pump Rebates Are Available in Nova Scotia?
Heat pump rebates in Nova Scotia vary by household income and by how you heat your home now.
Program Name
Target Group
Key Benefit
Current Status
Home Energy Assessment (HEA) Rebates
All income levels (single-family and other eligible homes)
Rebates on qualifying heat pumps and home-envelope upgrades
Open through Efficiency Nova Scotia
Moderate Income Rebate
Low- to moderate-income homeowners
Higher rebates for qualifying heat pumps and insulation, plus a waived $199 assessment fee
HomeWarming Program
Lower-income homeowners
Free energy assessment and covered upgrades, including heat pumps, with nothing to pay up front
Canada’s National Heat Pump Rebate
Homeowners using electric heating or an existing heat pump
Up to $10,000 for low- to median-income households, or $2,000 for above-median-income households
Portal expected to open in early 2027
Efficiency Nova Scotia Home Energy Assessment Rebates
The Home Energy Assessment (HEA) pathway is open at every income level and covers more than the heating system. A Registered Energy Advisor looks at the whole house before any rebate is claimed. Homeowners may then be eligible for rebates on qualifying ductless mini-split, centrally ducted, or ground-source heat pumps, as well as air sealing and insulation. The rebate is paid after the contractor finishes the work and an advisor verifies the upgrades.
This rebate is for households that earn too much to qualify for low-income assistance programs but still find winter heating expensive. It pays more than the standard HEA route on eligible upgrades. Cold-climate heat pumps, attic or basement insulation, and draft-proofing may qualify for the higher rebate. Approved homeowners also receive a case number that lets them have the standard $199 initial assessment fee waived.
HomeWarming Program
HomeWarming is for lower-income homeowners and can cover the upfront cost of eligible upgrades. Once an application is approved, a Registered Energy Advisor assesses the house and helps arrange for qualified local contractors to do the work. Recommended work may include a cold-climate heat pump and insulation, at no cost to the applicant.
The federal National Heat Pump Rebate is expected to open in early 2027. Eligible low- to median-income households may receive up to $10,000 toward installation, while eligible above-median-income households may qualify for $2,000. Homes using electric, oil, propane, natural gas, diesel, coal, wood, or biomass heating may be eligible, and qualifying systems installed on or after November 1, 2026, may receive retroactive support once the portal opens. Funding is currently committed through 2034.
What Are the Eligibility Requirements for Nova Scotia Heat Pump Rebates?
For a heat pump rebate in Nova Scotia, each program sets its own requirements for your home, income, and equipment, so check those before you sign a contractor’s quote.
Homeownership and Primary Residence Requirements
You generally need to own the home and use it as your primary residence to get the main Nova Scotia heat pump rebates.
  • Eligible properties: Rebates may apply to detached and semi-detached houses, row townhouses, and most year-round mobile homes on permanent foundations.
  • Proof of ownership: You may be asked to provide a recent property tax assessment, a municipal tax bill, or a bill of sale, each showing your name and civic address.
  • Plans to sell: HomeWarming applicants must confirm that they don't plan to sell the home within 12 months of applying. Renters can't apply directly, but landlords may be eligible through Efficiency Nova Scotia's Affordable Multi-Family Housing Program.
Household Income Limits
Income-tested programs use after-tax household income based on the latest Canada Revenue Agency (CRA) Notice of Assessment for each adult aged 18 or older in the home. T1 returns and T4 slips are not accepted. For each person, subtract Line 43500 (Total Taxes Payable) from Line 23600 (Net Income) on their notice, then add the results together to get the household figure.
Household Size
HomeWarming Program (After-Tax Limit)
Moderate Income Rebate (After-Tax Limit)
1 person
$30,187
$37,260
2 people
$57,075
$77,050
3 people
$57,075
$98,900
4 people
$57,075
$120,750
5 or more people
$79,163
$126,500
Eligible Heat Pump Types and Equipment Requirements
Nova Scotia winters can bring temperatures well below freezing, so the programs call for equipment suited to cold-weather operation.
  • Cold-climate certification: Air-source heat pumps, including ductless mini-splits and centrally ducted systems, must be on a qualifying cold-climate product list from Efficiency Nova Scotia or Natural Resources Canada (NRCan) on the installation date.
  • Installation type: Standard Efficiency Nova Scotia rebates generally apply to new heat pump installations, not like-for-like replacements of working units.
  • AHRI matching: The indoor air handler and outdoor compressor must be a matched pair with a verified Air-Conditioning, Heating, and Refrigeration Institute (AHRI) certificate number that appears on the approved list.
EcoFlow DELTA 3800 Gen4 Portable Power StationEcoFlow DELTA 3800 Gen4 Portable Power Station
How to Apply for a Heat Pump Rebate in Nova Scotia
Nova Scotia heat pump rebates can be put at risk if you buy equipment or book work before a required assessment is complete. Check the order of steps for your program before committing. A solar panel or battery project follows separate eligibility rules and should not be assumed to qualify.
Check Your Eligibility and Choose the Right Rebate Program
Gather the latest CRA Notice of Assessment for each adult aged 18 or older in the home, along with your municipal property tax bill. Compare your combined after-tax household income with the HomeWarming and Moderate Income thresholds above. If that combined figure is over those limits, the standard Home Energy Assessment route may be the right provincial option.
Complete Required Assessments and Get Pre-Approval
For HomeWarming and the Moderate Income Rebate, send in your application and income documents first. Book the audit only after the approval email and case number arrive, usually within 10 business days. For the standard HEA route, book an initial EnerGuide Home Energy Assessment through an Efficiency Preferred Partner. The advisor checks where the house loses heat, sometimes with a blower-door test, then recommends upgrades.
Install Eligible Heat Pumps and Submit Your Application
Once the initial assessment is on file, follow your program’s instructions for arranging the work. If you need to hire your own contractor, choose a licensed Nova Scotia refrigeration and air-conditioning contractor to install a qualifying cold-climate heat pump. Comparing heat pump installation prices across written quotes can help separate equipment costs from electrical, ductwork, and labour charges. Keep your itemized invoice and check that it lists the heat pump’s make, model, AHRI number, and installation date. If you paid any part of the installation cost, keep proof of payment as well. Book the follow-up assessment by the program deadline so the advisor can verify the work and send in the rebate claim.
EcoFlow DELTA 3000 Gen4 Portable Power StationEcoFlow DELTA 3000 Gen4 Portable Power Station
How to Lower Home Heating Costs Beyond Heat Pump Rebates
Even with a high-efficiency heat pump, your home can still use more electricity than you expect if a leaky attic lets warm air out or the system leans heavily on backup electric heat. A portable power station may support selected compatible loads during an outage, but it does not reduce the home’s heating demand.
Improve Home Insulation and Heating Efficiency
In a well-sealed house, the heat pump doesn’t have to work as hard because the heat stays inside. Sealing gaps around rim joists, window frames, and attic hatches can reduce drafts, while better attic and basement insulation slows heat loss during cold snaps. If you’re considering R-50 or R-60 insulation, ask an energy advisor what suits your home and climate. Keeping the thermostat fairly steady may also help; large overnight setbacks can prompt the system to use backup electric resistance heat to bring the temperature back up.
Store Excess Solar Energy for Household Use
Once the heat pump is installed, electricity still shapes your monthly costs. If your home has rooftop solar, a battery can store some of the excess generated during the day for the evening or cloudy periods. That can help you use more of your own solar power.
The EcoFlow DELTA 3000 Gen4 Portable Power Station has a 3,072Wh battery capacity and a 3,600W rated output. It’s a flexible backup option that can power compatible heat pumps and household appliances when their voltage and wattage requirements match the unit’s specifications.
1. Longest Runtime: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest portable power station in its class with 3kWh capacity and 3,600W output.
The EcoFlow DELTA 3800 Gen4 Portable Power Station gives households with higher energy needs more room to expand. It starts with a base capacity of about 4kWh and can grow to 12kWh in total, so you can add storage as demand grows. As with any portable power station, check that the heat pump’s electrical requirements match the unit before connecting it.
1. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 2. Compact Yet Powerful: The smallest and lightest portable power station in its class with 3-4kWh capacity and 3,600W output. 3. 4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery.
Rebates through Efficiency Nova Scotia and federal programs can lower the upfront cost of a cold-climate heat pump. Check the income limits, complete the required assessment before buying equipment, and confirm the heat pump’s AHRI number is on the approved list. Good insulation, along with battery storage where it makes sense, can also help manage electricity use after installation.
Disclaimer: Rebate programs, eligibility requirements, funding availability, and application deadlines may change. Always check the latest requirements and confirm your eligibility directly with Efficiency Nova Scotia, Natural Resources Canada, or the relevant program administrator before purchasing equipment or starting installation work. Rebate approval and amounts are subject to official program terms and available funding.
Can You Stack Heat Pump and Insulation Rebates?
Yes. Efficiency Nova Scotia programs may let you combine a heat pump rebate with support for insulation and air sealing. Completing several recommended upgrades within the assessment window may also qualify you for multi-upgrade incentives.
Is the Oil to Heat Pump Affordability Program Still Open?
No. Efficiency Nova Scotia closed the Oil to Heat Pump Affordability (OHPA) program to new applicants on July 2, 2026, after available funding was allocated. Homeowners already approved have until January 31, 2027, to upload final receipts and the required attestation. Lower-income households using oil may still be able to apply for eligible upgrades through HomeWarming.
Why Is My Bill So High with a Heat Pump?
When the bill comes in higher than expected, check whether backup electric heat has been running a lot or whether the indoor filters are dirty. Heat pumps warm a home gradually, so large thermostat swings may trigger electric resistance heat. Make sure snow or ice isn’t blocking airflow around the outdoor unit.
What Is the Average Lifespan of a Heat Pump?
With regular maintenance, a cold-climate heat pump typically lasts 15 to 20 years. Near the coast, salt spray and winter weather can add strain to the unit. You can help it last by rinsing the outdoor coil with fresh water each spring, keeping the unit above the snowpack, and cleaning the indoor filters regularly.
