How Much Does a Heat Pump in Ontario Cost in 2026?
When an older furnace or air conditioner needs replacing, more Ontario homeowners are considering a heat pump rather than simply putting in the same type of equipment. A heat pump can handle both heating and cooling, but installation costs vary widely. So what should you budget? In 2026, installing an air-source or hybrid heat pump generally runs $7,000 to $22,000 CAD; a geothermal installation costs $22,000 to $48,000 CAD before rebates. The size of your home, the condition of its ductwork, and any electrical work needed will shape the quote you receive. This guide covers Ontario pricing, rebates, and practical ways to keep hydro bills manageable once your system is running.
What Types of Heat Pumps Are Available in Ontario?
The main types of heat pumps in Ontario include air-source, ground-source, and hybrid systems. Your current heating equipment and property layout, along with installation cost, efficiency, and cold-weather performance, will shape the final decision.
Heat Pump Type | How It Works | Best Suited For | Cold-Weather Performance | Typical Lifespan |
Air Source (ASHP) | Transfers heat between indoor and outdoor air. | Homes replacing old heating or cooling systems, including those without ductwork. | Cold-climate models operate down to -25°C to -30°C. | 15–20 years |
Ground Source (GSHP) | Exchanges heat through underground pipes. | Properties with space for trenching or drilling. | Consistent efficiency during extreme cold. | 20–25 years (unit); 50+ years (ground loop) |
Hybrid (Dual-Fuel) | Combines an electric heat pump with a gas or propane furnace. | Homes retaining existing furnace backup. | Switches to furnace heating during extreme cold. | 15–20 years |
Air Source Heat Pumps
Understanding how a heat pump works in winter helps explain why an air-source system can heat your home in winter and cool it in summer, contributing to its popularity across Ontario. Cold-climate models (ccASHPs) are designed to operate at temperatures down to -25°C, though their efficiency declines as conditions become more severe. In older Toronto or Hamilton homes without ductwork, a ductless mini-split can provide a practical alternative.
Ground Source Heat Pumps
Instead of relying on outdoor air, a ground-source heat pump draws on stable underground temperatures for year-round heating and cooling. Ground-source systems can operate more efficiently than many air-source options, while their underground heat source helps limit the effect of extreme outdoor temperatures. The trade-off is a higher upfront cost for drilling and excavation; over time, lower operating expenses and the system’s long service life can help offset that investment.
Hybrid Heat Pump Systems
In mild weather, a hybrid system relies on its electric heat pump. When extreme cold arrives—or gas heating becomes the more economical choice—it switches to the gas or propane furnace. This lets Ontario homeowners cut down on fuel use without giving up reliable backup heat.
How Much is a Heat Pump in Ontario?
The equipment is only part of the price, since labour, ductwork changes, and electrical upgrades can add thousands of dollars, particularly in older Ontario homes, as shown in the breakdown below.
Compare Installation Costs by Heat Pump Type
System Category | Equipment + Installation (Before Rebates) | Typical Rebate Potential (2026) | Estimated Net Out-of-Pocket Cost |
Ductless Mini-Split (Single to Multi-Zone) | $4,500 – $15,000 | $2,000 – $7,500 | $2,500 – $10,500 |
Central Ducted Cold-Climate ASHP | $12,000 – $22,000 | $2,000 – $7,500 | $6,500 – $17,000 |
Hybrid / Dual-Fuel System (HP + Furnace) | $12,000 – $20,000+ | Up to $2,000 (Gas homes) | $10,000 – $18,000+ |
Ground Source / Geothermal (Horizontal Loop) | $22,000 – $32,000 | $3,000 – $12,000 | $14,000 – $26,000 |
Ground Source / Geothermal (Vertical Loop) | $30,000 – $48,000 | $3,000 – $12,000 | $22,000 – $42,000 |
Understand the Factors That Affect Installation Costs
Even two neighbours on the same Mississauga or London street could receive quotes that differ by $5,000 or more. The difference often comes down to specific property and installation details:
Home Square Footage and Heat Loss: Rather than estimating tonnage from square footage alone, an HVAC technician should complete a CSA F280 heat-loss calculation. A home with drafty windows or insufficient attic insulation may need a 3.5- or 4-ton unit rather than a 2.5-ton model.
Electrical Panel Upgrades: Many older Ontario homes have 100-amp electrical service. Safely supporting a cold-climate heat pump and electric backup heat strips may require a 200-amp panel upgrade, which adds approximately $1,500 to $3,000.
Ductwork Modifications: A heat pump circulates a greater volume of air at a slightly lower temperature than a gas furnace. If the existing supply ducts are narrow or leaky, they may need to be resized.
Cold-Climate Certification: Although standard heat pumps generally have a lower upfront price, some current rebate programs require models included on Natural Resources Canada's (NRCan) eligible-product lists.
Site Geology (for Geothermal): Ground conditions affect the installation method and price. Drilling vertical boreholes through shallow bedrock in areas such as the Canadian Shield costs significantly more than trenching through clay or loam in Southwestern Ontario.
How Can You Manage the Energy Costs of Running a Heat Pump?
Moving from gas heating to a heat pump changes where your energy dollars go: total heating costs may fall, but your winter hydro bill may rise, especially during Ontario’s coldest months. You can limit that increase by keeping thermostat settings steady, using solar power or a compatible solar generator where practical, and shifting some electricity use to off-peak hours.
Improve Heat Pump Efficiency Through Proper Temperature Settings
A gas furnace delivers hot air in cycles, while a heat pump usually works more effectively when it maintains an even indoor temperature. Letting the house drop from 21°C to 16°C overnight may backfire, because the system has to work harder the next morning and could switch on costly electric backup heat. Small adjustments of 1°C to 2°C are a better approach. Cleaning the air filters regularly also helps maintain efficiency.
Use Solar Energy to Reduce Grid Electricity Consumption
A rooftop solar panel system can cover part of the extra electricity your heat pump uses. Spring and autumn sunshine may be enough for much of the daytime heating or cooling load, so you can draw less electricity from the grid. South-facing panels can still contribute on clear winter afternoons, but shorter days restrict total production.
Store Excess Solar Power for Later Household Use
On bright afternoons, solar production may exceed what your household is using at that moment. A battery can store some of that surplus for the evening or another period of low generation, reducing how much electricity you need to buy from the grid. Storage needs vary with the appliances you intend to run: small electronics use much less energy than a heat pump or other major household equipment.
EcoFlow RIVER 520 Gen4 Portable Power Station: Built for users who want lightweight, portable power for small electronics and daily essentials, it features a 512Wh battery capacity and 500W AC output (with up to 1,000W X-Boost) to keep phones, laptops, Wi-Fi routers, task lighting, and other compatible low-wattage devices running smoothly.
EcoFlow TITAN 5000 Plus Whole-Home Backup Power: For heavier whole-home demand, capacity starts at 5kWh and can expand to 30kWh. Rated output is 7.2kW, with 120V/240V split-phase support for larger household loads. Add a compatible solar array for up to 10kW of combined PV and battery output, giving heat pumps and other high-demand appliances substantial power support when their voltage and wattage match the unit.
A battery sized for evening use can give an Ontario household greater energy flexibility; before connecting a heat pump, check its running wattage, startup surge, and 240V requirements against the storage system.
Manage Electricity Use During Peak Pricing Hours
If your Ontario household is on a Time-of-Use (TOU) or Ultra-Low Overnight (ULO) plan, moving some heating demand to lower-priced hours can reduce costs. One approach is to raise the thermostat by 1°C to 2°C during an off-peak period so the home retains some of that warmth after rates rise. Standard TOU off-peak hours run from 7:00 p.m. to 7:00 a.m. on weekdays and throughout the weekend; ULO follows a different schedule.
What Heat Pump Rebates Are Available in Ontario?
Although the Canada Greener Homes Grant has closed, current heat pump rebates can still reduce eligible Ontario installation costs. The federal government has announced an upcoming National Heat Pump Rebate, but its official page had not yet published full launch dates, eligibility rules, or rebate amounts as of November 16, 2026. Check the program page before assuming a new installation qualifies, and keep your installation receipts and AHRI documentation.
Home Renovation Savings Program
The Home Renovation Savings Program, offered by Enbridge Gas and Save on Energy, bases its rebates on the heating system currently in your home. Pre- and post-installation EnerGuide audits are no longer required for standalone heat pump upgrades.
Electrically Heated Homes: Receive $1,250 per ton, up to $7,500 for cold-climate air-source heat pumps, or $2,000 per ton, up to $12,000 for geothermal systems.
Natural Gas Heated Homes: Enbridge customers can receive $500 per ton, up to $2,000 for eligible air-source or hybrid systems, or $3,000 for geothermal.
Oil, Propane, or Wood Heated Homes: Receive $1,250 per ton, up to $7,500, when switching to an eligible cold-climate heat pump.
Energy Affordability Program
Eligible low-income Ontario households can receive fully funded energy-efficiency upgrades through Save on Energy’s Energy Affordability Program (EAP). Available upgrades include heat pumps, insulation, draft proofing, and smart thermostats. Whether you own or rent, you may qualify; tenants need their landlord’s approval. Eligibility may depend on your income or heating type, or on participation in ODSP, Ontario Works, or the Guaranteed Income Supplement.
A heat pump is a substantial investment for an Ontario home. Air-source and hybrid systems generally cost $7,000 to $22,000, while geothermal installations can reach $48,000, though available rebates may significantly reduce what you pay. Ask qualified local installers for quotes, and make sure they assess your home’s heating needs, ductwork and electrical capacity. A system suited to your house can keep it comfortable through every Ontario season. You can then manage running costs with small thermostat adjustments and off-peak electricity use, adding solar or battery storage if it is practical for your home.
Why Is My Bill so High with a Heat Pump?
High bills often trace back to frequent electric backup heating, especially when large thermostat changes or cold weather push up electricity use. After leaving natural gas, compare your annual hydro and gas costs together rather than looking at the hydro bill on its own.
How Long Do Heat Pumps Last in Ontario?
Expect about 15 to 20 years from an air-source or hybrid heat pump. Geothermal units generally last 20 to 25 years, and their underground loops can remain in service for more than 50 years. Whichever type you choose, have it serviced regularly and keep snow, ice, and debris from building up around the outdoor unit.
Are Heat Pumps Worth It in Ontario, Canada?
Yes, heat pumps can be a worthwhile investment, particularly in homes replacing electric baseboards, oil or propane heating systems, or aging air conditioners. If your household uses natural gas, a hybrid system and available rebates can help improve the financial return.
Why Does My House Feel Cold with a Heat Pump?
A heat pump normally supplies air at 32°C to 40°C—compared with 55°C to 60°C from a gas furnace—so that cooler feel is to be expected. If your rooms stay cold, however, check for dirty filters, blocked vents, or an undersized system that is struggling in extreme weather.
