Home Battery Storage in Canada: What to Know Before You Buy It
Electricity costs keep climbing, and severe weather keeps knocking out power more often, so it makes sense that more Canadian homeowners are looking at battery storage. The problem is that "home battery" covers a huge range of products at very different price points, from a five-figure whole-home installation to a portable unit you can set up yourself in an afternoon.
This guide walks through what home battery storage actually is, the two main paths you can take, what things cost in Canada right now, and how to figure out the right size for your household before you buy.
What Is Home Battery Storage?
At its core, home battery storage is a system that stores electricity, whether from solar panels or the grid, so you can use it later. That "later" is usually during a power outage or during peak-price hours when electricity costs more.
Most systems have three parts working together:
  • The battery — stores the electricity itself.
  • The inverter — converts stored DC power into the AC power your home actually runs on.
  • Solar panels (optional) — feed the battery during the day, in addition to or instead of grid charging.
If you want a deeper look at how that middle piece works, our guide on choosing the right inverter battery for a home setup breaks it down further.
Once you understand what a home battery system actually does, the next decision is how big a system your household needs, and that comes down to one basic choice.
Whole-Home vs. Portable Battery Storage: Which Fits Your Home?
Whole-Home vs. Portable Battery StorageWhole-Home vs. Portable Battery Storage
Broadly, you are choosing between two approaches:
Whole-Home Systems
Portable Power Stations
Installation
Built into your electrical panel, requires a professional installer
Plug-and-play, no installation needed
Coverage
Most or all household circuits
Specific devices or rooms (fridge, medical equipment, home office)
Upfront cost
Higher
Lower
Best for
Homeowners wanting full outage protection
Renters, condo owners, or partial/flexible backup
If you want your furnace, well pump, HVAC, and every outlet in the house covered without thinking about it, whole-home is the right path. If you mainly need to keep specific essentials running, portable is usually the simpler and cheaper way in.
EcoFlow DELTA Pro Ultra
Starts at 6.1kWh (6,144Wh) in a single unit, expandable up to 90kWh with additional batteries, enough for weeks of essential backup in a typical household. A single inverter delivers 7,200W continuous output with a 10.8kW surge; pairing three inverters with the EcoFlow Smart Home Panel 2 unlocks up to 21.6kW, enough to run a central air conditioner alongside everything else. It's the only portable power station certified to both UL1973 and UL9540, the two safety standards most relevant for home battery installations, and carries a 5-year warranty. Listed at $5,799 CAD for the base unit as of this writing; full whole-home bundles with the Smart Home Panel and extra batteries run higher.
With that decision framework in mind, here is a closer look at the portable side for households that do not need, or cannot install, a whole-home system.
Portable Power Stations for Home Backup
Portable power stations have become a popular middle ground for exactly the reasons above: no electrician, no permits, and no long installation timeline. For condo and apartment dwellers who cannot modify their electrical panel at all, they are often the only realistic option. For homeowners, they work well as a starting point you can expand later, or as dedicated backup for specific rooms or devices.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
Starts at 3,072Wh, expandable up to 11kWh with add-on batteries. 3,600W continuous output with a 7,200W surge, and a full charge from empty to 80% in about 48 minutes using solar and generator input together. Runs at a quiet 25dB, switches over in 10ms during an outage, and comes with up to a 5-year warranty. A strong fit for households wanting UPS-style protection for sensitive electronics along with genuine backup capacity.
EcoFlow DELTA 3 Max Plus (2048Wh)
Holds 2,048Wh out of the box, expandable to 10kWh. 3,000W continuous output with a 6,000W surge, and a full charge in about 43 minutes. Shares the same 25dB quiet operation, 10ms switchover, and up to 5-year warranty as its bigger sibling, in a smaller, easier-to-store package. A sensible choice for smaller households or partial backup without paying for capacity you won't use.
Capacity and use case matter, but so does cost, so it is worth breaking down what Canadian homeowners are actually paying in 2026.
How Much Does Home Battery Storage Cost in Canada?
Pricing varies enormously depending on which path you take:
System
Starting Price (CAD)
Installation
$1,399
None, plug-and-play
$1,999
None, plug-and-play
EcoFlow DELTA Pro Ultra (base unit)
$5,799
Optional, scales up with Smart Home Panel bundles
Typical installed whole-home system (general market)
$3,000 to $15,000
Professional installation required
Tesla Powerwall 3, fully installed (for reference)
roughly $16,500 to $24,000
Note: Prices reflect current listings as of this writing and shift often with promotions, province, and contractor. Treat these as a starting point for research rather than a quote.
One thing worth understanding regardless of which system you choose is the battery chemistry. LFP, or lithium iron phosphate, has become the standard in 2026 for home battery storage because it handles more charge cycles before degrading and carries a lower thermal runaway risk than older lithium chemistries. If you want to see how that compares to other common battery types, our AGM battery vs lithium comparison covers the differences in plain language.
Rebate and incentive programs are another moving piece. Ontario, British Columbia, and other provinces and utilities offer their own programs, and they change over time, so check current eligibility directly rather than assuming a past rebate still applies. Our breakdown of the Ontario Home Renovation Savings Program is a good place to start if you are in Ontario specifically.
Cost is only half the picture. Sizing the system correctly matters just as much.
How to Choose the Right Battery Storage Size for Your Home
Choose the Right Battery Storage Size for Your HomeChoose the Right Battery Storage Size for Your Home
Start by asking what you actually need to keep running during an outage:
  • Just the essentials, like a fridge and some lighting?
  • Larger appliances, like a furnace or sump pump?
  • Anything non-negotiable, like medical equipment or a home office setup?
Write that list out before you shop, since it tells you more than any spec sheet.
Household size and your typical daily electricity use are the other main inputs. A one-bedroom condo and a five-bedroom house with central air conditioning are not sizing for the same system, even if both households technically want "backup power."
If you are not sure where to start, a portable power station is a reasonable entry point precisely because it is expandable. You can begin with something like the DELTA 3 Max Plus for essential backup, see how it performs during a real outage, and scale up later, either by adding batteries or eventually moving to a whole-home system, without having committed to a full installation from day one.
Once you have sized the right system, here is a quick recap to help you decide with confidence.
Home battery storage in Canada ranges from full whole-home systems to flexible, plug-and-play portable power stations, and the right choice depends on your budget, your home type, and how much outage risk you are willing to live with.
Start with what you actually need to keep powered during an outage, then match that to a whole-home or portable system rather than starting from a specific product and working backward. Whether that means going straight to a whole-home solution or starting smaller with a portable unit you can expand later, both paths get you to the same place: real protection the next time the power goes out.
What is home battery storage and how does it work?
It is a system that stores electricity from solar panels or the grid using a battery and inverter, then supplies that stored power to your home during an outage or during peak-price hours.
Is a whole-home battery or a portable power station better for my home?
It depends on your budget and goals. Whole-home systems cover your entire electrical panel but cost more and need installation. Portable power stations are cheaper, need no installation, and suit partial or flexible backup needs.
How much does home battery storage cost in Canada?
Portable power stations start under $1,500 CAD, while whole-home systems, including installation, commonly range from a few thousand dollars up into the tens of thousands depending on capacity and brand.
How long can a home battery power my house during an outage?
It depends entirely on capacity and what you are running. A small portable unit might cover a fridge and some lighting for a day or more, while an expandable whole-home system can be sized for days or even weeks of essential backup.
Do I need solar panels to use a home battery system?
No. You can charge most home battery systems from the grid alone. Solar panels are optional and mainly useful for recharging during extended outages or for reducing daily electricity costs.
Are there rebates for home battery storage in Canada?
Some provinces and utilities offer rebates or incentive programs for battery storage, and eligibility varies by location and sometimes by whether the system is paired with solar. Check current programs directly, since they change over time.
