October Weather in Toronto: What to Expect, What to Wear and How to Prepare
October in Toronto can feel like two different months. The first week often brings mild afternoons and bright fall colour. By Halloween, nights are colder, daylight is shorter and windy rainstorms are more common. Whether you are visiting or living here, it helps to know what is normal. This guide covers Toronto’s October averages and how the month changes. It also covers what to wear, what to do and which weather risks to watch. Finally, it explains how to ready your home before winter.
What Is the Average October Weather in Toronto?
October is when Toronto settles into true fall. Days are still comfortable for walking, but the cooling trend is steady all month. Here is what the official averages show, plus how Lake Ontario shapes them.
Toronto’s October Climate Normals at a Glance
Environment and Climate Change Canada (ECCC) publishes 30-year climate normals for the Toronto City station downtown.The 1991–2020 figures provide a useful baseline for typical October conditions. Daylight figures come from 2026 sunrise and sunset times.
Measure
Typical October value
Average daily high
14.6°C
Average daily low
7.7°C
Daily mean temperature
11.2°C
Total precipitation
About 69 mm of precipitation
Days with measurable precipitation
About 11
Average snowfall
Trace amounts only
Daylight
About 11 hours 45 minutes on October 1, falling to about 10 hours 15 minutes by October 31
Downtown readings run milder than many suburbs. Toronto sits beside Lake Ontario, and the lake stores summer heat. That stored warmth keeps downtown nights a little warmer in fall. Areas farther from the lake, like the airport and northern neighbourhoods, often cool down more after dark.
Early October vs. Late October
The month can feel very different at the beginning and end. Early October can still bring afternoons in the high teens. Patios stay open, and a light jacket is usually enough. Thanksgiving falls on Monday, October 12, in 2026, a popular weekend for fall colour walks.
Late October feels closer to winter. Afternoons are cooler, and nights can dip close to freezing outside the core. Skies are cloudy more often, and the wind picks up. October is also the bridge between a mild September and the deep cold snaps Toronto sees later in winter.
Daylight, Frost and the Clock Change
Toronto loses about an hour and a half of daylight during October. Sunset moves from about 7 p.m. to just after 6 p.m. Daylight saving time ends on Sunday, November 1, 2026. After that, sunset will come around 5 p.m.
Frost is uncommon downtown in October, thanks to the lake. Gardens in cooler suburbs and low-lying spots can still see their first frost this month. Measurable snow in October is rare, though early flurries do happen.
Knowing the averages is useful, but averages hide the rough days. October also brings some of the year’s first serious fall storms.
What October Weather Risks Should Torontonians Watch For?
Most October days in Toronto are calm and cool. Still, the month can bring strong wind, heavy rain and the odd tropical system. Here is what to keep an eye on as the season turns.
Wind and Rainstorms
Fall storms grow stronger as cold northern air meets warmer, moist air from the south. Gusty wind can bring down branches, and wet leaves block storm drains. Environment Canada issues wind warnings when strong gusts are expected in your area. Downed trees on overhead lines are a frequent cause of fall power cuts. Animals, aging equipment and planned work are other common causes of Toronto outages year round.
Wet fallen leaves gathered on a rainy street in autumnWet fallen leaves gathered on a rainy street in autumn
Remnants of Tropical Systems
The Atlantic hurricane season runs until November 30. Most storms weaken long before reaching Ontario, but their remnants can still carry heavy rain north. Hurricane Hazel is the best-known example. It hit the Toronto area on October 15, 1954. ECCC’s 1954 tropical cyclone season summary notes that Hazel dropped over 200 mm of rain in less than 24 hours. 81 people died in the Toronto region.
Early Frost and Sudden Cold
A clear, calm night in late October can drop temperatures quickly. Frost can damage tender plants and catch outdoor taps that are still connected. An early cold spell can reveal heating problems before winter arrives.
Risk
What it can do
Simple step
Strong wind
Downed branches and power lines
Trim dead branches and secure patio items
Heavy rain
Basement water and clogged drains
Clear eavestroughs, downspouts and street drains near your home
Tropical remnants
Flooding and longer outages
Watch alerts and keep an outage kit ready
Early frost
Frozen outdoor taps and plant damage
Shut off and drain outdoor taps
These risks point to one clear message. October is a practical time to prepare your home for winter, before sustained freezing temperatures arrive.
How to Get Your Toronto Home Ready for Winter in October
Getting ready in October means working in mild weather, before the first big freeze. A few hours spent now can prevent costly repairs later. Focus on heat, water and power.
Book a Furnace Check
Ontario’s Technical Standards and Safety Authority (TSSA) advises an annual inspection of all fuel-burning appliances. The work should be done by a TSSA-registered fuel contractor. Book early, because contractors get busy once the cold arrives. If you are weighing an upgrade, comparing a heat pump and furnace can help you plan.
Test your carbon monoxide (CO) alarms at the same time. Under the Ontario Fire Code, homes with a fuel-burning appliance, fireplace or attached garage need CO alarms. Ontario’s carbon monoxide safety page explains that alarms belong near each sleeping area.
Clean Gutters and Check Downspouts
Falling leaves fill eavestroughs fast in October. The City of Toronto recommends cleaning eavestroughs at least twice a year and checking elbows for debris. Its mandatory downspout disconnection rules require downspouts to be disconnected from the City’s sewer system. Water should drain away from your foundation, not onto a neighbour’s property or the sidewalk.
  • Clear leaves from eavestroughs after most leaves have fallen.
  • Fix sagging sections and leaky joints.
  • Add downspout extensions to move water away from the house.
  • Store rain barrels before the first hard freeze.
Plan for Power Outages
A gas furnace still needs electricity to run its blower and controls. That means a fall power cut can also mean a cold house. Public Safety Canada advises households to be ready to cope on their own for at least 72 hours. Start with a 72-hour emergency supply kit that includes flashlights, water, warm layers and phone chargers.
Some homeowners also add a home battery for backup. The two models below suit different home sizes.
Model
Best fit
Output
Home circuit backup
EcoFlow TITAN 5000
Houses that need 240V support
7.2kW, 120V/240V
Selected 120V and 240V circuits with the compatible 120V/240V SHP10
EcoFlow TITAN 5000 Classic
Condos and smaller homes
4kW, 120V only
Selected 120V essentials with the 120V SHP10
The TITAN 5000 suits Toronto houses that want selected 120V and 240V circuits backed up. With the right setup, that can include a furnace circuit.
EcoFlow TITAN 5000
• 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. • 100% Whole-Home Savings. Save up to $1,000/year. • Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
The TITAN 5000 Classic suits condos and smaller homes that mainly need 120V essentials in a fall outage.
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. •5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <30 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Plug-in devices can run from either model directly. Home circuits or hard-wired appliances, like a furnace, need the compatible SHP10 installed by a qualified electrician. The SHP10 covers up to 10 selected circuits, not every appliance at once. Runtime always depends on what you power and for how long. Both units are rated IP20, so keep them indoors in a dry spot.
With the house in order, you can enjoy the best of the season. Here is how to dress for it and where to spend it.
What to Wear and Do in Toronto in October
October rewards people who dress in layers. Mornings and evenings are cool, while afternoons can feel pleasant. Plan for both, and keep rain gear close.
What to Pack and Wear
Layers handle the wide daily temperature swing best. A typical October packing list includes:
  • A water-resistant jacket with a hood
  • A sweater or fleece for layering
  • Long pants and a long-sleeve shirt
  • Closed, waterproof shoes for wet sidewalks and leaves
  • A compact umbrella
  • A light hat and gloves for late October evenings
Early in the month, you may only need a light jacket by afternoon. By the last week, a warmer coat makes evenings far more comfortable.
Fall Activities in and Around Toronto
October is one of the best months to enjoy Toronto outdoors. Fall colour fills the city’s ravines and parks. Popular choices include:
  • Walking ravine trails, High Park or the Toronto Islands for fall colour
  • Visiting farms in the Greater Toronto Area for apples and pumpkins
  • Enjoying Thanksgiving weekend events and Halloween activities
  • Exploring museums and markets on rainy days
Field of orange pumpkins at a farm on a sunny autumn dayField of orange pumpkins at a farm on a sunny autumn day
Farms near Brampton and Milton turn into weekend favourites, and many pumpkin patches and fall festivals run through the month. Check opening dates before you go, because hours change in late fall.
October weather in Toronto shifts from mild, colourful days to cold, windy nights. Downtown averages sit near 15°C by day and 8°C at night. Early October suits light layers, while late October calls for a warm coat. It is also the best time to check your furnace, clear gutters and plan for outages. If backup power is on your list, an EcoFlow TITAN 5000 or TITAN 5000 Classic can keep chosen essentials running.
Is October a Good Time to Visit Toronto?
Yes. October brings mild afternoons, fall colour and fewer crowds than summer. Pack layers and rain gear, because cool and wet days are common.
Does It Snow in Toronto in October?
Rarely. October snowfall downtown averages only a trace. Early flurries can happen, but snow usually waits until November or later.
How Cold Does Toronto Get at Night in October?
The average downtown low is 7.7°C, based on ECCC’s 1991 to 2020 normals. Late October nights are colder, and suburbs away from the lake can approach freezing.
When Do the Clocks Change in Toronto in the Fall?
Daylight saving time ends on Sunday, November 1, 2026. Clocks go back one hour, so evenings get dark about an hour earlier.
Can a Home Battery Keep My Furnace Running During an Outage?
It can, in the right setup. A hard-wired furnace needs a compatible SHP10 installed by a qualified electrician, with the furnace on a selected circuit. Runtime depends on the furnace and everything else connected.
Home Solutions
