Solar Panels for Home in South Africa: How to Choose the Right Setup
Solar panels for home use can help lower your reliance on Eskom or municipal electricity by supplying your home with power generated from sunlight. The right setup depends on your electricity use, available space and whether you want lower bills, backup power or both. Panels generate electricity; compatible equipment converts it for household use, while batteries can store energy for later.
This guide explains how home solar works, what it can offer, how to compare costs and how to choose between a fixed array and a smaller portable setup.
Key Takeaways
  • Solar panels for home generate electricity during daylight. Backup during an outage requires a system designed for that purpose; panels alone do not provide reliable household backup.
  • A high-output home solar panel costs around R3,000 in South Africa in 2026, while complete installed systems can range from roughly R60,000 to R350,000, depending on size and battery storage.
  • Under the example assumptions below, 600 kWh per month gives a 5 kWp sizing target, rounded up to 10 × 550W panels with an actual capacity of 5.5 kWp.
  • Compare wattage, efficiency, durability, warranty and compatibility when choosing panels for your home.
  • Rigid solar panels suit fixed arrays. Portable panels can recharge compatible power stations for smaller household needs.
How Do Solar Panels for Home Work?
To understand how solar panels work, start with their photovoltaic (PV) cells, which convert sunlight into direct current (DC) electricity. A compatible inverter converts DC into alternating current (AC) for household appliances. In a portable setup, this conversion takes place inside the power station when you use its AC outlets.
During the day, solar generation can supply household loads. Depending on the system, surplus energy may charge a battery or be exported through an approved grid connection. Without storage, daytime generation is not available to use after sunset.
An ordinary grid-tied solar system shuts down during a power cut to prevent electricity feeding back into the grid. Outage backup needs equipment that can safely isolate the backed-up circuits and continue supplying them, with sufficient battery storage for periods without enough sunlight.
What Are the Benefits of Solar Panels for Home?
  • Lower Electricity Purchases: Using your own solar generation reduces the electricity you buy from Eskom or your municipality. Running suitable appliances during sunny hours can improve self-consumption, but fixed charges may remain on your bill.
  • More Control Over Your Energy Supply: With a correctly sized battery and a backup-capable system, solar can help keep selected essentials running during power cuts. A fridge, lights and Wi-Fi need a different setup from electric cooking, air conditioning or a geyser.
  • A Renewable Source of Electricity: PV panels generate electricity without burning fuel at your home. They can support everyday household use or form part of a properly designed off-grid system where a grid connection is unavailable. There are trade-offs: installation costs money upfront, output changes with weather and season, and storage adds cost. Solar should be sized around the energy you can use and the backup you actually need.
Which Solar System Is Right for Your Home?
Start with the system type before comparing individual panels. This determines how your home uses the electricity they generate.
Setup
Main use
Important limitation
Grid-tied solar without a battery
Reducing daytime grid purchases
An ordinary grid-tied system does not supply the home during an outage
Hybrid solar with a battery
Combining solar generation, stored energy and grid supply
Outage backup depends on the inverter, wiring, battery and configured backup circuits
Off-grid solar
Supplying a home independently of the grid
Requires enough generation and storage for low-sun periods, sometimes with another backup source
Portable panel and power station
Charging storage for selected plug-in devices
Limited by panel output, battery capacity and power-station ratings; does not automatically power household wiring
How Much Do Solar Panels for Home Cost in South Africa?
In South Africa, a single home solar panel can cost around R2,000 or more, while complete installed systems typically run from about R60,000 to R350,000 depending on size and battery storage. Below, we break down panel prices first, then full system costs.
How Much Does a Single Solar Panel Cost?
For a high-output rooftop solar panel in South Africa, a reasonable 2026 budget is around R3,000 per panel. A September 2026 South African price survey recorded a 550W residential panel at R2,999 including VAT, although the final price can vary with wattage, efficiency and panel technology.
The panel price is only one part of your overall budget. You will also need to account for the inverter, battery storage if you want backup power, mounting hardware, electrical protection, cabling and installation. For that reason, the full system cost is usually much more useful when planning what you can afford for your home.
How Much Does an Installed Home Solar System Cost?
The following Handld budget estimates, updated in July 2026, illustrate how costs change with the equipment included. They are published guide ranges, not installer quotations or independently verified market averages.
Example configuration
Indicative installed budget
3 kW inverter + 3 kWp PV + 5 kWh battery
R60,000–R120,000
5 kW inverter + 6 kWp PV + 10 kWh battery
R110,000–R200,000
8 kW+ inverter + 10 kWp PV + 15 kWh+ battery
R180,000–R350,000
*Ask each installer to specify VAT, mounting, distribution-board work, protection equipment, compliance documentation and connection-related costs. Roof access and the circuits selected for backup can also change the final quote.
When looking at quotes, do not focus on the inverter size alone. Two systems, both described as “5kW”, can come with very different amounts of solar generation and battery storage. Check the inverter rating in kW, solar-array capacity in kWp and battery capacity in kWh together to see what you are actually getting.
How Many Solar Panels Does Your House Need?
Start with how much electricity your home actually uses. Your monthly kWh consumption, the wattage of the panels, and the amount of usable sunlight your roof receives all affect how many panels you may need.
To estimate the array size, divide your average daily electricity use by the number of effective sun hours your panels receive, then allow for normal system losses:
PV array size (kWp) = daily electricity use (kWh) ÷ peak sun hours ÷ system efficiency
South Africa receives average daily solar radiation of around 4.5 to 6.5 kWh/m². For the examples below, we use 5 peak sun hours per day, 80% system efficiency, and 550W panels as a practical reference.
Monthly usage (kWh)
Approx. PV array size (kWp)
Example 550W panels
300 kWh
~2.5 kWp
~5
600 kWh
~5 kWp
~10
900 kWh
~7.5 kWp
~14
1,200 kWh
~10 kWp
~19
These figures are a starting point rather than a fixed rule. A shaded roof, less favourable orientation or lower winter output may mean you need a larger array.
A home using around 600kWh a month would need about 10 × 550W panels under these assumptions. Your final panel count may be higher or lower depending on electricity use, roof space, shading and orientation.
What Should You Look for When Choosing Solar Panels?
Once you have an idea of how much solar capacity your home needs, the next step is choosing panels that suit your roof, climate and daily energy needs. Wattage matters, but it is not the only number worth checking.
Do the Panel Dimensions and Wattage Suit Your Roof?
Higher-wattage panels can reduce the number of modules needed for a target capacity, but they are often physically larger. Fewer panels do not automatically mean less roof space. Compare dimensions, efficiency and the layout your roof can accommodate.
That does not make a lower-wattage panel unsuitable for home use. What matters is whether you have enough space to install the number of panels needed for your target array size.
How Important Is Panel Efficiency?
Panel efficiency tells you how much of the sunlight hitting the panel can be converted into electricity. Higher efficiency is most useful when roof space is tight, because you can get more output from a smaller surface area. For a home with plenty of unshaded roof space, however, the difference between two efficiency ratings may matter less than overall system capacity, price and durability.
Will the Panels Suit Local Conditions?
For South African homes, the panel also needs to cope with the conditions around your property. Strong sun, heat, wind and coastal air can all affect long-term performance. If you live near the coast, look closely at corrosion resistance. In hotter inland areas, check how the panel performs at higher temperatures, while homes in exposed areas should also pay attention to wind-load ratings and mounting requirements.
What Do the Warranties Cover?
Solar panels are expected to stay on your roof for years, so look at both the product warranty and the performance warranty. The product warranty covers faults in the panel itself, while the performance warranty tells you how much output the panel should retain over time. A long performance warranty is useful, but it should not be the only figure you compare.
Are the Panels Compatible With Your Equipment?
Your panels also need to work with the inverter or power station they connect to. Check voltage, current and connector requirements before adding panels to an existing setup. For a permanent rooftop array, compatibility with the inverter is the main concern. Portable panels are better suited to flexible setups where you want to charge a compatible power station from a patio, balcony or garden. If you are planning a permanent rooftop array, it is also worth checking the roof, mounting and electrical requirements before you install solar panels.
Which EcoFlow Solar Panels Suit Different Home Needs?
The right EcoFlow solar panel depends on whether you want a permanent rooftop array or a more flexible setup for everyday backup. Rigid panels are designed for fixed installations, while lightweight portable models are easier to move, store and connect to a compatible power station.
EcoFlow 400W Rigid Solar Panel — For Permanent Home Solar
The EcoFlow 400W Rigid Solar Panel is the strongest fit for homeowners planning a permanent rooftop, carport or ground-mounted array. Its rigid frame is designed to stay in place, making it better suited to regular household solar generation than a portable panel.
- 400W rated output - 23% conversion efficiency - Monocrystalline cells - Anti-corrosive aluminium frame - IP68-rated weather protection - 10-year workmanship warranty
EcoFlow 160W Lightweight Portable Solar Panel — For Flexible Home Backup
The EcoFlow 160W Lightweight Portable Solar Panel is better suited to homes that need flexibility rather than a permanent rooftop array. You can place it outside in direct sunlight and use it to charge a compatible power station for household backup.
That makes it useful for renters, balconies, patios or homes where a fixed rooftop installation is not practical.
- 160W rated output - Up to 25% conversion efficiency - 30–60° adjustable support stand - Built-in 2.5m XT60 cable - 5-year warranty
EcoFlow 110W Lightweight Portable Solar Panel — For Smaller Household Loads
The EcoFlow 110W Lightweight Portable Solar Panel is the more compact option for lighter energy needs. Paired with a compatible power station, it can support smaller everyday loads such as a router, laptop, phone charging or lighting. Its compact, lightweight design makes it easy to set up where sunlight is best, then pack away when you are done, which suits smaller home backup and day-to-day charging needs.
- 110W rated output - Up to 25% conversion efficiency - 544 × 413 × 36 mm folded dimensions - Approx. 3.3 kg panel weight - 5-year warranty
Your final choice should reflect your available space, expected energy use and how much solar generation you want to add to your home.
Choosing solar panels for home use in South Africa starts with your electricity use, available space and budget. Choose the system type first, then compare array capacity, inverter output, battery storage and installed cost. Rigid panels suit fixed arrays, while portable panels can recharge compatible power stations for smaller needs.
Is 5kW enough to run a house in South Africa?
It can be. A 5kWp solar array can produce about 20kWh per day using the assumptions in this article, which is close to the needs of a home using around 600kWh per month. What you can run at the same time still depends on the inverter, battery and household loads.
How many solar panels does a 3-bedroom house need?
The bedroom count is less useful than the actual electricity use. A home using around 600kWh per month would need about 10 550W panels under the assumptions used in this article. Check your recent Eskom or municipal bills for a more accurate estimate.
Can I sell solar power back to the grid in South Africa?
Yes, in some areas. Your system must meet Eskom or municipal requirements, and export rates vary by provider. In Cape Town, the 2026/27 residential SSEG feed-in tariff is R1.2418/kWh including VAT, with a further R0.2875/kWh including VAT incentive, bringing the total to about R1.53/kWh for eligible exported electricity.
How many solar panels do I need to run a geyser?
A typical 2 to 3kW geyser is a relatively heavy household load. Around 4 to 6 550W panels provide a similar level of rated solar capacity, but actual output changes throughout the day. It is better to include geyser use when sizing the whole home array rather than dedicate a fixed number of panels to it.
Are solar panels worth it in 2026?
Yes, solar panels can lower your electricity bill by reducing how much power you buy from the grid. In South Africa, a home solar system may take roughly 5 to 11 years to pay back, depending on the installed cost, local tariff, battery size and how much solar power you use directly.
Solar Panels
