100 Watt Solar Panel: Specs, Output, Uses, and Prices
- Key Takeaways
- 100 Watt Solar Panel Specifications and Size
- How Much Power Does a 100 Watt Solar Panel Produce per Day?
- What Can a 100 Watt Solar Panel Run?
- 100 Watt Solar Panel Price in South Africa (2026)
- How to Use a 100W Solar Panel with Batteries and Power Stations
- How to Get Better Output From a 100W Solar Panel
- Conclusion
- FAQs
A 100 Watt solar panel is a compact option for small-scale solar use, typically producing around 300–500Wh of electricity per day under good conditions. This guide explains what that output can realistically support, how 100W panels compare in size and price, and how to pair one with a battery or portable power station for camping, caravanning, connectivity and light backup needs.
Key Takeaways
A 100 Watt solar panel can produce around 300–500Wh per day under good conditions, with lower output in cloud, shade or poor positioning.
It is better suited to small electronics, lighting, connectivity and light off-grid use than high-energy household appliances.
Voltage, current, dimensions and weight vary between 100W panel designs, so check the exact specifications before connecting one to a battery or power station.
Current EcoFlow models around the 100W range provide a useful price reference of roughly R2,100–R4,000, depending on the panel type.
A battery or portable power station can store daytime solar generation for use later, provided its solar input is compatible with the panel.
A 100 Watt solar panel is rated to produce up to 100 watts under Standard Test Conditions (STC), which use 1,000W/m² solar irradiance and a 25°C cell temperature. Real-world output varies with factors such as sunlight, temperature, shading and panel angle. When comparing panels, check the datasheet for key specifications including voltage, current, dimensions, weight and efficiency.
Specification | Typical 100W panel value |
Maximum power (Pmax) | 100W |
Operating voltage (Vmp) | Around 18–23V |
Operating current (Imp) | Around 4–5.5A |
Open circuit voltage (Voc) | Around 22–27V |
Module efficiency | Around 15–20%, depending on cell technology |
Dimensions | Around 90–100 × 55–70 cm |
Weight | Around 5–8 kg |
Actual specifications vary between models. A 100W panel designed for permanent mounting may have a different size and weight from a lightweight portable version, so always check the exact datasheet before choosing a panel for your setup.
Typical 100 Watt Solar Panel Size and Weight
A rigid 100 watt solar panel is commonly around 90–100 cm long and 55–70 cm wide, although the exact dimensions depend on the cell layout, frame design and materials used. For South African users, size and weight are important when choosing between different applications. A lighter panel is easier to carry for camping, caravans and 4WD trips, while a framed panel is better suited to more permanent installations where durability matters. The right balance depends on where the panel will be used: a portable setup benefits from lower weight, while a fixed installation can prioritise strength and long-term outdoor performance.
Rigid, Flexible or Foldable?
100W solar panels come in different designs for different uses. Rigid panels use glass and aluminium frames for durability and fixed mounting, while flexible panels are lighter and can fit some curved surfaces, such as caravan or marine applications. Foldable panels focus on portability, making them suitable for camping and mobile solar setups.
Choose the right type based on where you will use the panel, how often it needs to be moved, and whether it will charge a battery or portable power system.
Is a 100W Solar Panel Right for You?
A 100W solar panel works well for compact solar setups such as camping, caravans, 4WD trips and other low-power applications. When paired with a battery or portable power station, it can store solar energy for use when sunlight is unavailable. A single 100W panel is not designed for high-energy appliances or whole-home solar systems. Devices such as air conditioners, electric heaters, kettles and large household appliances require a larger solar setup with more generation capacity.
Before choosing a panel, consider the devices you plan to power, how much energy they use each day, and whether additional battery storage is needed.
In South Africa, a 100 watt solar panel can typically produce around 300–500Wh of electricity per day under good conditions. Actual output varies with location, season, weather, panel angle, temperature, shading and system losses.
The South African Department of Electricity and Energy reports that most parts of the country receive more than 2,500 hours of sunshine a year, with average daily solar radiation of about 4.5–6.5 kWh/m². For a rough output estimate, that is equivalent to about 4.5–6.5 hours of full-rated solar input. A 100W panel would therefore have a theoretical daily output of roughly 450–650Wh before losses.
In practice, panels rarely operate at their rated output throughout the day. Allowing roughly 20–30% for factors such as heat, panel angle, wiring and controller losses gives a more realistic range:
Peak Sun Hours per Day | Ideal Daily Output | Estimated Real-World Output |
~ 4.5 hours | 450Wh | About 315–360Wh |
~ 5.5 hours | 550Wh | About 385–440Wh |
~ 6.5 hours | 650Wh | About 455–520Wh |
These figures are useful for planning rather than guaranteed daily output. A well-positioned panel may reach the upper end on clear days, while cloud, partial shade or poor orientation can bring production well below it. For everyday planning, around 300–500Wh per day is a practical range, while cloudy weather or partial shade can reduce output further.
If you are asking what a 100-watt solar panel will run, the short rule is this: it runs small electronics and light-duty loads comfortably, and anything with a heating element or a big compressor is out of reach. Watts describe instant power; watt-hours describe daily energy, and confusing the two causes most disappointment.
A panel also does not power devices directly in most setups. It charges a battery or power station, and that storage runs your gear when you actually need it, including after sunset.
Device | Typical energy demand | What one 100W panel covers |
Smartphone | 10–20Wh per charge | Several full charges per day |
Laptop | 50–80Wh per charge | One full charge, sometimes two |
LED light | 5–10W while on | Several lights for an evening |
Wi-Fi router | 8–15W while on | All day with storage |
USB or 12V fan | 5–20W while on | Several hours of cooling |
32-inch LED TV | 30–60W while on | Two to four hours of viewing |
12V camping fridge | 40–60W cycling | Marginal, needs a 100Ah-class battery |
Devices It Runs Comfortably
Phones, tablets, power banks, cameras, LED lighting, routers and small fans sit well inside a 100W budget. These are the loads where a single panel feels generous rather than tight, even on an average day.
A laptop fits too, with one caveat: charging it while it sleeps is far easier than powering it during heavy use. Efficient ultrabooks are a much better match than gaming machines.
Borderline Loads: TVs and 12V Camping Fridges
A small, efficient LED TV is workable for a few hours of evening viewing through a battery and inverter. A 12V compressor camping fridge is the classic edge case: possible, but only with a 100Ah-class battery buffer and decent sun, and one cloudy day can break the rhythm.
A full-size kitchen fridge is a different category entirely. If that is your goal, our guide on the solar panels needed to power refrigerator loads in South African homes breaks down the numbers properly.
What a 100 Watt Solar Panel Will Not Run
Anything that makes heat or cold at household scale is out: kettles, microwaves, toasters, coffee machines, hair dryers, space heaters, geysers and air conditioners. Their instant draw of 1,000W or more is ten times what the panel produces at its peak.
A full-size refrigerator also fails on daily energy, not just surge. It typically consumes 1,000Wh or more per day, two to three times what one panel harvests.
The price of a 100 watt solar panel can vary considerably depending on its design, materials and intended use. For a current reference, EcoFlow models around the 100W range are listed at roughly R2,100 to R4,000, with rigid and flexible panels generally costing less than lightweight portable options.
Panel Type | Current Price Reference | Typical Use |
100W flexible panel | Around R2,100 | Lightweight installations and suitable curved surfaces |
100W rigid panel | Around R2,700–R3,000 | Fixed mounting on roofs, frames or vehicles |
110W lightweight portable panel | Around R4,000 | Camping, travel and portable power stations |
These figures are based on current EcoFlow South Africa listings and should be treated as a price reference rather than a fixed market rate. Prices can change with promotions, availability and product updates.
When comparing options, look beyond the panel price itself. Some setups may also need cables, mounting hardware, a charge controller, a battery or portable power station, depending on how you plan to use the panel. A broader look at solar panel prices in South Africa can also help you compare costs across different panel sizes and system types.
A 100W solar panel can charge a standalone battery through a compatible charge controller or connect to a portable power station with built-in storage and outputs. With around 300–500Wh of daily solar production under good conditions, the setup works best when the storage capacity and solar input are matched to the panel.
A 110W panel sits close to the same power range as a 100W model, with only a small increase in rated output. The EcoFlow 110W Lightweight Portable Solar Panel is rated at 110W, weighs 3.3 kg and folds for transport, making it practical for camping, caravanning and other setups where the panel needs to be moved or repositioned.
If you want to store the electricity generated during the day for later use, a portable power station combines the battery, charging system and power outputs in one unit. The EcoFlow RIVER 3 Portable Power Station ( 10 ms UPS) has a 245Wh capacity, 300W AC output and up to 110W solar input, so its solar input closely matches a panel in this power range.
Together, the panel and power station provide a compact setup for keeping smaller essentials powered at home or away from the grid. The power station does not increase the panel's solar output; it stores the energy generated during the day so it can be used later.
If a 100W panel is producing less energy than expected, start with its position and surroundings before assuming there is a problem with the panel.
Position and angle: Give the panel as much direct sunlight as possible. For fixed installations, a north-facing orientation generally provides strong year-round exposure, while portable panels can be repositioned as the sun moves.
Shading: Keep nearby trees, roof features and other objects from casting shade across the panel. Even partial shading can noticeably reduce output.
Temperature: Solar panels generally produce less power as cell temperature rises, so allow ventilation around the panel where the installation permits.
Dust and debris: Check the surface for dust, leaves or bird droppings and clean it according to the manufacturer's instructions when needed.
Connections: Make sure the cables, charge controller or power station are compatible with the panel's voltage and current specifications.
These checks can help you identify common causes of lower output before changing the size of the solar setup.
A 100 Watt solar panel is a practical size for smaller solar needs such as device charging, lighting, connectivity and portable setups. Under good conditions, around 300–500Wh of daily generation is a useful planning range, although weather, shading and panel position will affect the result.
Before choosing a setup, add up the daily energy needs of the devices you want to cover and check that the panel, storage capacity and solar input are compatible. If those needs grow, you can then consider a larger panel or storage system.
Will a 100W solar panel run a 12V fridge?
Yes, but only with the right support. A 12V compressor camping fridge draws 40–60W while cycling, so one 100W panel can keep up in good sun if you add a 100Ah-class battery to cover nights and cloudy spells. Without storage, the fridge will drain faster than the panel can replenish it.
How long will a 100 watt solar panel take to charge a 100Ah battery?
It may support a small 12V compressor fridge, but check the fridge's daily energy consumption rather than its running wattage alone. The panel needs to generate enough energy over the day, while the battery must store enough for overnight use and periods of weaker sunlight. There is no single battery size that suits every fridge and setup.
How much power does a 100 watt solar panel produce in a day?
Under good conditions, around 300–500Wh per day is a practical planning range for a 100W panel. Daily output can be lower with cloud, partial shade, high panel temperatures or poor positioning, and it will also vary by location and season.
Is a 100 watt solar panel worth it in South Africa?
It can make sense when your energy needs match what a small panel can generate, particularly for camping, connectivity, device charging or other light off-grid uses. Any financial saving depends on the upfront cost of the panel and storage, how much of the solar energy you use, and the electricity tariff that applies to your property.
Do I need a battery with a 100 watt solar panel?
Not in every setup. Some portable panels can charge compatible devices directly, while a battery or portable power station lets you store solar energy for use after sunset or when sunlight drops. If you connect a conventional panel to a standalone battery, you will also need a compatible charge controller.
