Solar Panel Cleaning in South Africa: When and How to Clean
Effective solar panel cleaning is simple: rinse cool glass with clean, low-mineral water and wipe gently with a soft brush or microfibre cloth from the ground, leaving high or steep roofs to a professional. Knowing when a wash is needed and keeping the method gentle makes looking after your system straightforward.
Key Takeaways
  • Use visible dirt and changes in monitored output to decide whether cleaning is needed.
  • A soft brush, a microfibre cloth and clean, low-mineral water cover most everyday dirt.
  • Keep your feet on the ground for DIY cleaning and use a professional for hard-to-reach rooftop arrays.
  • Adjust the cleaning interval to local dust, rainfall, and coastal conditions.
  • Use each portable panel’s care instructions and let it dry fully before folding.
How to Tell if Your Solar Panels Need Cleaning
A dirty-looking panel and a lower reading in your app tell you different things. Look at both before deciding whether a wash is the next useful step.
Start with What You Can See
Sometimes the clue is obvious: a dusty film across the glass, a splash of bird mess, or leaves caught along the bottom edge. Coastal homes may also pick up a fine salt residue. A look from the garden, or a zoomed-in phone photo taken from the ground, is often enough to spot the build-up and decide whether solar panel cleaning belongs on your weekend list.
See What Your Monitoring App Shows
Your app adds another piece of the picture. Compare a few similarly clear days and look for a change that lasts beyond a passing cloud. A tree casting a new shadow or the changing of the seasons can explain a dip, too. When the numbers look unusual and the glass is visibly dirty, you have a clear reason to investigate. If the panels already look clean, your installer can help find what else has changed.
How Often Should You Clean Solar Panels in South Africa?
The right interval depends on how quickly dirt builds up where you live. Use a regular check as your starting point, then adjust it to your surroundings and the weather.
A Routine That Fits Your Surroundings
For many households, solar panel cleaning once or twice a year is a sensible starting point. From there, let your surroundings set the pace. A home beside a gravel road may collect dust sooner than one in a leafy suburb, while farms, building work and coastal salt can all bring the next clean forward. A quick visual check between washes helps you find the interval that suits your home without turning maintenance into a monthly chore.
Let Local Weather Shape the Schedule
A decent shower can take care of loose dust, so have another look before booking a wash straight after rain. Bird droppings and stubborn deposits are more likely to stay put. After a long dry spell or a particularly dusty week, check again. Planning solar panel cleaning around the weather where you live makes more sense than using one calendar for the whole country, especially when local water restrictions affect outdoor washing.
Preparing for Solar Panel Cleaning: Tools and Safety Checks
A little preparation makes the job easier. Gather gentle cleaning tools, check your system’s instructions and make sure you can reach the panels safely before starting.
Tools and Water to Have Ready
You do not need a shed full of solar panel cleaning equipment. Start with a clean soft brush, a microfibre cloth and a bucket. An extension pole is handy for panels you can comfortably reach from the ground. Clean, low-mineral water, such as deionised water, helps the glass dry with fewer spots. If you use borehole water or collect rainwater, check for grit and mineral content before filling the bucket.
Gentle wet cleaning is also the approach described in the SAPVIA Solar PV Installation Guidelines. Wet the surface before brushing, and rinse the brush as you go so that yesterday’s grit does not become today’s scratch.
It also helps to know what you are working with, and understanding the main types of solar panels makes it easier to judge how much care each surface needs. For the wash itself, keep your own panel’s care instructions handy: they will tell you which tools and cleaning products suit its surface.
Cleaning Products and Tools to Avoid
Save the scouring pad and metal scraper for other jobs. Abrasive tools, strong solvents and a direct high-pressure jet can damage solar glass, coatings or seals. Water is a good place to start; if a mark needs more help, choose a mild solar panel cleaner listed in the panel’s care instructions and use the recommended dilution. More soap rarely makes solar panel cleaning better, and it gives you more residue to rinse away.
Solar panel cleaning with a brush and water on a glass module
Check Your System Before Cleaning
Before getting the bucket out, follow your installer’s shutdown or isolation procedure to prepare your setup for solar panel cleaning. Even with the inverter switched off, rooftop modules still generate voltage in daylight, so locate isolator switches, junction boxes, and cabling beforehand to keep them completely dry and undisturbed. From the ground, look for cracks, burn marks, or exposed cables. If you spot any damage, leave cleaning until your installer has checked it; a clear photo can help explain what you have found.
How to Clean Solar Panels on a Roof from the Ground
The easiest DIY job is one you can do with both feet on firm ground and the brush comfortably in reach. Keep the pole clear of overhead power lines, and keep your weight off the panels. If the job involves a ladder or reaching over a roof edge, that is a good point to hand it over to a professional.
How to Clean Solar Panels Step by Step
Wondering how to clean solar panel glass without leaving streaks? Once you have a safely accessible panel, your kit ready, and the system prepared, solar panel cleaning follows a simple rhythm: wet the surface, loosen the dirt, and rinse it away.
1. Rinse the Surface Gently
For panels designed for water cleaning, begin with a gentle flow across the glass to loosen dust and grit. Work from the top so the water carries loose dirt downwards. Aim at the front surface, keeping connectors, junction boxes, and other electrical equipment out of the spray.
2. Soften Stubborn Deposits and Clean Gently
Use the wet soft brush or cloth to lift the remaining dirt with light strokes. Bird droppings often need a few minutes to soak, so leave the water to do some of the work before trying again. Rinse your brush frequently. If a stubborn patch still refuses to lift after soaking, resist the urge to scrape at it and ask a professional cleaner to take a look.
3. Rinse and Allow the Panel to Dry
Finish with a thorough flow of clean water, washing away all loosened deposits and any diluted detergent you have used. Taking your time with this final stage of solar panel cleaning ensures no soapy film is left behind on the glass. Let the panels air-dry, or use a soft squeegee where the care instructions recommend one and you can reach comfortably.
Portable panels need their own care routine. Follow the panel’s instructions: disconnect it safely from connected devices, allow the surface to cool to room temperature, and wipe it with a soft cloth dampened with clean water and wrung out. Avoid wiping or washing the photovoltaic connectors, and let the panel dry fully before folding and storage.
4. Restart and Compare Similar Sunny Days
Restart the system using its normal procedure and note the cleaning date in your app or maintenance diary. Then see how generation looks over the next few comparable sunny days. Keeping a simple solar panel cleaning record helps you judge whether your current interval is about right, or whether the next wash can wait a bit longer.
It also pays to look beyond the glass: routine solar panel maintenance, from tightening mounts to spotting new shading, keeps small problems from turning into lost output.
Professional Solar Panel Cleaning and Costs
When access makes a DIY clean awkward, a professional team can take care of the job. A few questions about their methods and quotation will help you compare the service on offer.
Some Roofs Are Better Left to the Pros
You can enjoy looking after your solar setup without making the roof part of your weekend DIY. A professional solar panel cleaning service is particularly practical for double-storey homes, steep tiles, fragile roofing or panels spread across several roof sections. The team brings the reach and access equipment, while you get the job done without spending Saturday trying to work out where to put a ladder.
Questions to Ask Before Booking
A short chat before booking tells you a lot. Ask solar panel cleaners what water and brushes they use, how they reach the array, and whether their insurance covers work at height. Clarify how their pricing works too, as South African residential quotes typically combine a per-panel rate (around R35 per panel) with a minimum call-out fee (often around R750 excluding VAT), and ask whether you will receive inspection photos afterward.
For a solar installation that stays in place, the EcoFlow 400W Rigid Solar Panel combines efficient monocrystalline cells with a robust frame for fixed installations on homes or motorhomes. It can supply solar input to a compatible setup without daily unpacking. Plan the mounting layout with your installer so that future inspection and solar panel cleaning remain accessible.
- 400W Rated Output per Panel - 23% Conversion Efficiency - Monocrystalline Solar Cells - IP68 Water and Dust Resistance
How to Care for Portable Solar Panels
A Little Care After a Weekend Away
Portable solar panel cleaning is easy to overlook when you are packing up camp. Sand, roadside dust and a splash of mud can all come home with the panel. Before putting it away, give the surface a gentle clean using the method in its care guide. Foldable surfaces can need a softer touch than rigid glass, so a damp microfibre cloth is often more practical than bringing out the whole brush kit.
For day trips and outings where easy carrying matters, the EcoFlow 160W Lightweight Portable Solar Panel offers a lightweight folding design and an integrated connection cable. It provides solar charging for a compatible power station without taking over your packing space. After the trip, let the cleaned panel dry fully before folding it away for the next outing.
- 160W Rated Output Under STC - Up to 25% Conversion Efficiency - Approx. 3.8 kg Panel Weight - Built-In 2.5 m XT60 Cable - IP68 Water and Dust Resistance
Dry Panels Before Folding and Storage
Give the panel and its fabric sections time to dry fully before folding. Check the creases and carry bag for grit, tuck the cable away neatly and store everything somewhere dry. You will thank yourself when the next sunny weekend comes around and your kit is ready to go.
For weekends at the campsite, the EcoFlow 220W Lightweight Portable Solar Panel pairs a compact folding design with an adjustable stand for easy positioning once you arrive. Wiping the surface down as you strike camp fits naturally alongside shaking out the tent, keeping trail dust out of the carry bag.
- 220W Rated Output Under STC - Up to 25% Conversion Efficiency - Approx. 5.1 kg Panel Weight - Built-In 2.5 m XT60 Cable - IP68 Water and Dust Resistance
For longer stays away or a portable setup with greater solar charging needs, the EcoFlow 400W Lightweight Portable Solar Panel combines a foldable format with an adjustable stand. Its integrated angle guide helps you position it towards the sun, while the folding design makes packing and transport practical between campsites or other off-grid stops.
- 400W Rated Output - Up to 25% Conversion Efficiency - Approx. 10.2 kg Panel Weight - IP68 Water and Dust Resistance
Solar panel cleaning works best as a small, regular habit. Have a look at the glass, keep an eye on your app and give accessible panels a gentle wash when they need it. For a high roof, let a professional handle the reach. And whether your next setup is staying at home or heading out with you, explore the solar panel range for fixed and portable options. A bit of thought about everyday care now makes living with solar that much easier.
How much does it cost to have solar panels professionally cleaned in South Africa?
Start with the total price for the visit rather than the per-panel rate alone. For example, RobCon Electrical’s published rates list solar panel cleaning at R35 per panel for fewer than 100 panels, with a R750 minimum call-out excluding VAT. For a typical 12-panel home system, that brings the visit to the R750 minimum before VAT. When comparing quotes, check the panel count, travel, access equipment and VAT together; the lowest price per panel is not always the lowest final bill.
Do you need to turn off solar panels before cleaning?
Yes. Prepare the system using the shutdown or isolation procedure supplied by your installer. Keep in mind that panels still produce electricity in daylight, even with the inverter switched off. Leave cables and connectors alone while cleaning. With a portable setup, use the panel and power station instructions to disconnect before the wash and reconnect afterwards.
What time of day should I clean solar panels?
Early morning or late afternoon usually works well because the glass is cooler and water dries more slowly. A cool, overcast day can be a good opportunity too. Choose dry, calm conditions with enough light to see clearly, and let hot panels cool before washing. That makes the job more comfortable and helps avoid streaks and sudden temperature changes at the glass.
What happens if you never clean your solar panels?
Persistent dirt blocks sunlight and gradually reduces your daily energy generation. Over time, baked-on bird droppings and grime create uneven shading across individual cells, which can cause localised overheating (hot spots) and accelerate wear. Periodic solar panel cleaning removes those stubborn deposits before they bake hard onto the glass, helping protect both daily output and long-term panel health.
