Solar Panel Installation in South Africa: Costs, Installers & Steps
- Key Takeaways
- How Much Does Solar Panel Installation Cost in South Africa?
- How to Choose the Right Solar Panel Setup
- What Approvals Do You Need Before Installing Solar Panel?
- How to Compare Solar Installers and Installation Services
- Solar Panel Installation: What Happens on Site?
- EcoFlow Rigid Solar Panels for Fixed Installations
- After Installation: Documentation, Monitoring and Maintenance
- Conclusion
- FAQs
Solar panel installation is a major investment, so it helps to know exactly what you are paying for before accepting a quote. In South Africa, costs can vary depending on system size, battery storage, roof conditions, installer rates and local approval requirements. Start with your electricity use, decide what needs to stay on during an outage, and check the requirements of your electricity supplier. This guide covers what to include in your budget, how to compare installers and what happens before, during and after installation.
Key Takeaways
Solar panel installation costs in South Africa depend on more than system size. Battery capacity, roof conditions, electrical work and local approval requirements can all affect the final price.
Choose the system around your actual electricity needs. Power demand, backup requirements and available installation space should guide panel, inverter and battery sizing.
Grid-tied, hybrid and off-grid systems suit different goals. The right choice depends on how much you want to rely on the grid and whether battery backup is needed.
Check Eskom or municipal requirements before installation. An electrical Certificate of Compliance (CoC) and permission to connect are separate requirements.
For a 2026 budget reference, the installed systems below range from R74,500 for a 5kW system with 8kWh of battery storage to R147,500 for a 12kW system with 15kWh. Use these figures as an indicative guide rather than a fixed national price.
Indicative Solar Panel Installation Costs
System size | Battery included | Installed price |
5kW | 8kWh | R74,500–R90,500 |
8kW | 15kWh | R94,500–R110,500 |
12kW | 15kWh | R125,500–R147,500 |
Source: Energybee. Prices are indicative and may vary based on system specifications and installation requirements.
What Affects the Solar Panel Installation Cost?
The final cost of a solar panel installation depends on the system specification and the conditions at the property, not just the number of panels.
System size: Larger systems require more panels, mounting hardware and higher-capacity electrical equipment.
Battery capacity: More battery storage can add significantly to the overall cost, especially where longer backup time is required.
Roof conditions: Roof material, pitch, height, access and any structural or waterproofing work can affect installation time and labour.
Electrical requirements: Longer cable runs, distribution board upgrades and additional protection equipment may increase both material and labour costs.
Equipment specification: The capacity and specification of the panels, inverter and battery can change the overall system price.
Site and connection requirements: Travel distance and any Eskom or municipal registration, inspection or approval requirements may also affect the final cost.
When comparing projected savings, ask which electricity tariff, daytime consumption and seasonal generation estimates were used. For Eskom customers, solar does not remove the fixed charges for remaining connected to the grid. See Eskom’s SSEG guidance.
The right solar setup depends on what you need it to power, how much backup you want and what the property can support. Work through these points before settling on the final equipment.
Check Your Energy Needs and Property
Use the kWh consumption on your electricity bills or prepaid meter records. The amount you spend in rand alone will not show how much electricity you use. Look at seasonal changes and how much of your consumption happens during daylight hours.
Then list your essential loads, such as the fridge, lights, Wi-Fi router and home office equipment. Decide separately whether the geyser, oven or pool pump needs to run on backup. Including these appliances changes the system requirements.
For a simple energy calculation, a steady 100 W load running for five hours uses 500 Wh, or 0.5 kWh. Battery sizing also needs to allow for conversion losses, usable capacity and the reserve you want to keep. Appliances that cycle on and off need a realistic consumption estimate.
Ask the installer to assess roof condition, shading, orientation and usable space. In South Africa, a north-facing roof is a useful starting point for solar generation, but the final layout should suit the site and when you use electricity. Wind exposure, roof loading and waterproofing also need attention.
Choose the System Type and Size
The three common system types serve different purposes. Confirm which configuration your electricity supplier allows before ordering equipment.
System type | Main purpose | What to understand |
Grid-tied without backup | Use solar generation to reduce electricity bought from the grid | It normally shuts down during a grid outage |
Hybrid with battery backup | Combine solar, grid supply and stored energy | Backup depends on the inverter, battery and circuits connected to its backup output |
Supply a property independently of the grid | It needs enough generation and storage for the intended loads, including periods of poor weather |
A hybrid solar system can provide backup power, but it may not supply every appliance in your home. Ask your installer which circuits will stay on during an outage and how much power they can supply at once.
Keep these three specifications separate when comparing systems:
Solar array capacity, in kWp, is the combined rated panel output under standard test conditions. It is not a daily energy figure.
Inverter output, in kW, helps determine which appliances can run at the same time. Starting loads also matter.
Battery capacity, in kWh, describes stored energy. Usable capacity and discharge limits affect how much backup it can provide.
These capacities do not always need to increase together. Longer backup time may call for more battery storage, while several high-power appliances operating together may place greater demands on the inverter.
Choose Compatible Panels, Inverter and Battery
Ask the installer to check the complete array against the inverter or charge controller’s PV input specifications. This includes its operating voltage range, maximum voltage and current limits, with allowance for temperature effects. Matching the plug or adding up panel wattages is not enough. The battery must also suit the inverter’s voltage, communication and charging requirements. Get confirmation of compatibility for the exact models in the quote.
Cables, connectors, isolators and protection devices should match the same electrical design. A qualified installer should confirm the final configuration, especially when multiple panels are connected in series or parallel.
Before installing solar in South Africa, check the registration and connection requirements with your electricity supplier, whether that is Eskom or your local municipality. You can find the supplier’s details on your electricity bill.
For Eskom-supplied homes, grid-connected systems require registration even if they do not export electricity. Check the current SSEG application requirements before work starts. If your municipality supplies your electricity, confirm its application process, equipment requirements and any metering changes with the municipal electricity department.
Ask your installer who will handle the application, electrical testing and any required professional sign-off, and confirm which permissions are needed before installation and switch-on. If you live in a complex or estate, check whether the body corporate or homeowners’ association also needs to approve the work.
An electrical Certificate of Compliance (CoC) confirms compliance after inspection and testing. It does not replace any required approval from your electricity supplier.
Look for Relevant Experience and Qualifications
Ask for examples of similar installations and recent customer references. Check who will design the system, carry out the electrical work and take responsibility for testing. The Department of Employment and Labour advises using competent, legally registered electrical contractors and requires proper inspection and testing before a CoC is issued.
Local experience matters too. Ask whether the installer has completed approved installations in your electricity supply area. An installation elsewhere may have followed a different approval process.
Check What the Installer Will Handle
Get the following in writing before paying a deposit:
The equipment models, panel layout and circuits included in the installation
Who submits the application and obtains any required professional sign-off
Responsibility for roof damage, leaks and making good after the work
Payment stages, exclusions and how extra work will be approved
Installation workmanship cover and the process for equipment warranty claims
The manufacturer’s panel warranty and the installer’s workmanship warranty cover different things. Ask who pays for fault-finding, removal and refitting if equipment needs attention.
Once the design and any required pre-installation permissions are in place, the installer can schedule the work. The steps below explain what to expect from the team.
Step 1: Finalise the Layout and Prepare the Roof
The team confirms panel positions, fixing points and cable routes. Any roof defects should be addressed before mounting begins. The layout needs to account for shading, roof loads and access for maintenance.
Step 2: Install the Mounting System and Panels
The installer uses a mounting system suited to the roof material and structural design, then secures the panels. Roof penetrations need proper weatherproofing, and the layout must allow for ventilation and drainage.
Step 3: Connect the Solar Panel Array
The installer connects the array according to the electrical design and checks cable sizing, polarity, connectors and protection. Series connections increase voltage, while parallel connections increase current. The right approach to wiring solar panels in parallel or series depends on panel specifications, array size, shading and inverter input limits. Cable sizing, polarity, connectors and protection must match the approved system design.
Step 4: Install the Inverter, Battery and Protection Equipment
The team fits the inverter and any battery in suitable locations, following the manufacturers’ installation requirements. The electrical work includes the specified protection, earthing and DB board connections. If backup is included, confirm which circuits have been connected to it.
Step 5: Inspect, Certify and Commission the System
The responsible professionals complete the required inspections, tests, electrical certification and commissioning records. Any outstanding documents go to the electricity distributor. Routine operation should begin only when the applicable authorisation requirements have been met.
Our rigid solar panels are designed for permanent mounting, from home rooftops to smaller off-grid setups. Choose the panel size around your available space and electricity needs, then have your installer confirm the right mounting system and electrical configuration.
EcoFlow 400W Rigid Solar Panel
Planning a rooftop or ground-mounted solar array? Our EcoFlow 400W Rigid Solar Panel offers more rated power per panel than our 100W model, helping you reach your planned array capacity with fewer panels. Its all-black design blends neatly with your roof, while the anti-corrosive aluminium frame supports long-term outdoor use.
EcoFlow 100W Rigid Solar Panel
For a smaller installation on a caravan or off-grid build, our EcoFlow 100W Rigid Solar Panel gives you a compact option for charging a compatible battery system or portable power station. Pre-drilled mounting slots make it easier to secure, while the all-black finish keeps the installation looking neat. Size the array around your daily energy use and the space available.
*Actual solar output varies with sunlight, shading, temperature and panel position. Whichever panel you choose, use compatible equipment and mounting suited to the installation site.
Commissioning confirms that the system is operating, but the project doesn’t end there. Complete records, routine monitoring and timely maintenance help protect long-term performance.
Keep the Required Installation Records
Keep the following records together in a secure place:
Approved system design, component models, serial numbers and product data sheets
Test results, the CoC and any municipal or utility approval
Warranty certificates and the installer’s contact details
Dated photographs showing roof fixing points and concealed cable routes
These files make it easier to arrange support, claim under warranty, expand the array or complete later roofing work without disturbing concealed equipment.
Monitor Output and Maintain the System
If monitoring is included, review generation over time and compare similar weather conditions. A cloudy day or a seasonal change is different from a persistent fault.
Check for visible damage or roof leaks from a safe, accessible position.
Arrange a professional inspection after severe weather if you notice damage or a sustained drop in performance.
Follow the manufacturers’ cleaning and maintenance instructions.
Don’t climb onto the roof or open electrical equipment to investigate a fault. Contact a qualified professional if performance doesn’t recover or you find a serious defect.
Solar panel installation in South Africa is easier to plan when you know what the system should cost, what setup suits your electricity needs and property, and what to expect from the installation company. Compare system specifications and service scope carefully, make sure the required electrical and local approval requirements are handled, and keep your CoC, warranties and system records after commissioning. A well-matched system and properly completed installation will make it easier to manage performance, maintenance and future support.
How Long Does Solar Panel Installation Take?
For a straightforward residential system in South Africa, the on-site installation itself will often take a few days. More complex roofs, larger systems, distribution board upgrades or extra electrical work can extend the job, while the full project may take much longer if SSEG registration or municipal approval is required. In Cape Town, for example, the City currently advises that issuing a Permission to Install (PTI) letter can take 3–6 months.
Can Solar Panels Be Installed on a Flat Roof?
Yes. Solar panels can be installed on flat roofs in South Africa using either a ballasted system or fixings anchored to the roof structure, depending on the building and structural design. The mounting must allow for wind loads, drainage, waterproofing and maintenance access, and the roof must be able to carry the additional load. South African municipal PV specifications explicitly allow both ballasted and anchored installations on flat roofs.
How Long Do Solar Panels Last in South Africa?
Around 25 years is a practical planning figure for solar panels in South Africa. Municipal guidance notes that PV panel production warranties commonly range from about 12 to 30 years, while some public solar projects use a 25-year system lifespan as a planning benchmark. Actual output over time will depend on the panel, installation quality, weather exposure and maintenance.
Do I Need Approval If I Do Not Export Electricity?
A zero-export setting does not automatically remove registration requirements. Eskom requires registration for grid-connected residential systems even when they do not export. Check the process with your electricity distributor before installation. See Eskom’s SSEG guidance.
