Solar Panel Price in South Africa: Panel and System Costs
The solar panel price in South Africa varies by panel type, wattage and what the package includes. Selected 400W–460W rigid panels cost roughly R1,100–R2,000 each, while a complete home setup also needs an inverter, mounting, installation and optional battery storage. Whether you want to power a few devices or reduce daytime grid use, your energy needs shape the budget. This guide breaks down panel prices, system costs and quote essentials to help you choose a suitable setup.
Key Takeaways
  • Selected 400W–460W rigid solar panels cost roughly R1,100–R2,000 each, excluding installation and accessories.
  • Budget for the complete setup, including panels, an inverter, battery storage if needed, and installation.
  • Compare fixed and portable panels separately, checking wattage, package contents, warranties and compatibility.
  • Size your setup around daily electricity use, available sunlight and the appliances you want to power.
  • Check current EcoFlow product pages for pricing, promotions and included accessories before purchasing.
Solar Panel Prices at a Glance in South Africa
When choosing a solar panel, check the construction, rated output and package contents alongside the price. A bare rooftop module and a foldable panel with an integrated stand serve different purposes, even when their wattages look similar.
Solar Panel Prices by Wattage
The following rounded figures provide a starting point for selected panel categories.
Panel category
Approximate price per panel
What you are buying
Small rigid panels, 100W–200W
R500–R1,400
A fixed panel for a compatible small solar setup
Conventional rigid panels, 400W–460W
R1,100–R2,000
A rooftop or ground-mounted module, generally without installation
*These indicative price bands include South African VAT, which is currently charged at the standard rate of 15%. They are not market-wide minimum or maximum prices. Delivery, accessories and installation may cost extra.
Portable panels need a separate budget. Selected foldable models around 100W–200W can cost roughly R3,000–R7,000, with some models outside that range. Construction, including cables, stands, and charge-controller options, affects the total, as shown in local portable-panel listings.
If you are checking prices for 500-watt solar panels, compare the actual wattage on each listing. A 500W panel and a 550W panel should not be treated as identical simply because both appear in the same search results.
How to Compare Solar Panel Prices per Watt
Price per watt helps you compare panels within the same category:
Price per watt = panel price ÷ rated wattage
For example, a hypothetical 450W rigid panel priced at R1,500 works out at approximately R3.33/W. A 550W rigid panel priced at R1,800 works out at approximately R3.27/W.
The second panel costs more upfront but slightly less per rated watt. That does not automatically make it the right purchase: it must still fit your available space and your inverter’s input requirements.
Use the same basis for both prices. Check whether VAT, delivery and accessories are included, and avoid comparing a portable panel directly against a bare rooftop module on price per watt alone.
Single-Panel, Multipack and Pallet Prices
Always confirm how many panels the advertised price includes. A two-panel pack may show the wattage of each panel in the product name while displaying the price for the entire pack.
For multipacks, divide the package price by the number of panels before calculating the price per watt. For pallet purchases, also check delivery arrangements, unloading requirements and how damage during transport is handled.
Bulk buying only helps your budget if you need the quantity supplied. Extra panels still need suitable mounting space and electrical capacity before you can use them.
What Does a Complete Solar System Cost?
A solar panel generates electricity, but a complete setup determines how you can use it. The inverter supplies compatible AC appliances, the battery stores energy, and the mounting and electrical components connect everything. When asking how much solar panels cost for your home, request both the panel-only price and the total installed price.
Solar Panel, Inverter and Battery Package Prices
A package described as a “5kW system” does not tell you everything. Ask for three separate figures:
  • Panel capacity in kWp: the combined rated peak output of the array.
  • Inverter output in kW: the power the inverter can supply within its operating limits.
  • Battery capacity in kWh: the energy the battery can store, with usable capacity stated separately.
A complete solar setup includes more than panels. Use these indicative price ranges to plan your budget, then compare itemised quotes for your chosen configuration.
Component
Approximate Price Range
What to Check
What Affects the Cost
Solar panels
R1,100–R2,000 per conventional 400W–460W rigid panel
Panel quantity, wattage and total array capacity
Panel type, efficiency and warranty
Inverter
R12,000–R20,000 for selected 5kW hybrid models
Rated output and compatibility with panels and batteries
Solar-input capacity, features and warranty
Battery storage
R14,000–R22,000 per approximately 5kWh lithium battery
Usable capacity and discharge limits
Battery design, compatibility and warranty
Mounting and electrical equipment
Allow around R10,000–R15,000 for a small residential installation
Brackets, cables, connectors and protection
Roof type, cable distances and existing wiring
Installation
Around R10,000–R20,000 for labour and setup on selected 5kW–8kW installations
Labour, testing and commissioning
Roof access, location and electrical work required
*These are approximate budgeting figures, not fixed quotes. Hardware prices exclude installation unless stated otherwise. Confirm VAT, delivery, and inclusions, and check for overlap between installation and equipment charges before adding the figures.
Do not use the inverter rating alone to determine whether a package can power your entire home. Simultaneous appliance demand, available sunlight and battery discharge limits all affect what it can run.
Battery Storage Costs and Capacity
Battery capacity can substantially affect the total budget. If most of your electricity use happens after sunset, storage deserves more attention than it would in a home with steady daytime demand.
As a general budgeting reference, a standalone lithium battery with around 5kWh of capacity may cost approximately R14,000–R22,000 before installation and additional equipment. Prices vary by usable capacity, battery design, compatibility and warranty.
When comparing solar panel battery prices, check usable energy, supported discharge power, inverter compatibility, and warranty conditions. A battery’s kWh rating describes stored energy; it does not indicate how many high-power appliances can operate simultaneously.
For example, a steady 500W load running for four hours requires 2kWh at the appliances. The battery must supply more than this once conversion losses and the selected reserve level are included.
Inverter and Charge Controller Costs
The inverter should match both your appliances and your solar array. A low purchase price is less useful if the unit cannot accept your planned panels or support the loads you need.
Selected 5kW hybrid inverters currently range from R12,000 to R20,000. This is an indicative hardware budget, not an installed price.
Check whether solar charge control is already built into the inverter. Many hybrid units include MPPT charge controllers, so a separate controller may not be needed. Smaller battery-based setups may require one, while compatible portable power stations usually manage solar charging internally.
Installation, Mounting and Electrical Work
The cost of the solar panel installation depends on the work required at your property. Roof access, mounting method, cable length and changes to the distribution board can all affect the quote. Before you install solar panels, have the installer assess the mounting location and cable route. A suitable site assessment can identify costs that a basic online package price does not include.
Ask for installation costs to distinguish between:
  • Mounting rails, brackets and roof attachments.
  • Cabling, connectors and electrical protection.
  • Inverter and battery installation.
  • Labour, testing and system setup.
  • Any roof repairs or distribution-board changes.
For fixed electrical work, use a legally registered electrical contractor and ask whether inspection, testing, and the required compliance documentation are included in the quote. See the Department of Employment and Labour’s electrical installation compliance guidance. A portable panel connected to a compatible power station is a different arrangement from an installation connected to your home’s circuits.
What Affects Solar Panel Prices in South Africa?
Panels with similar wattage can carry different prices. Understanding the reason helps you decide which features matter for your setup.
Panel Type, Efficiency and Wattage
Different types of solar panels have different cost structures. Rigid panels use frames and protective glass for fixed installations. Portable designs add features such as folding sections, carry handles and adjustable stands.
Efficiency matters when your available area is limited because it affects how much rated output can fit into that space. Where space is plentiful, the total installed cost may matter more than a small efficiency difference.
Solar cell cost is only one part of the finished panel price. The frame, protective materials, connectors, manufacturing quality and support also contribute. Judge the complete product rather than assuming one cell technology always belongs in a particular price tier.
Warranty, Certification and Local Support
Read the product warranty and performance warranty separately. A performance warranty concerns output under specified conditions; it does not necessarily cover every component or every replacement expense.
Before buying, establish who handles claims in South Africa, what documentation you need, and whether transport or labour is included. For a fixed installation, also ask about the installer’s workmanship warranty.
A clear support process belongs in your price comparison, especially when replacing a panel would involve roof access and another installation visit.
Exchange Rates, Import Costs and Delivery
Exchange rates, freight charges, stock levels and promotions can change retail prices. Delivery can also be significant for large glass modules or pallet orders.
Compare final delivered prices wherever possible. Check whether the quotation already includes import-related costs and VAT, so you do not double-count the same expense.
For online purchases, confirm the selected variant, panel quantity and included accessories before checkout. These details can explain a price difference that initially appears to be a discount.
Solar Panel Budgets for Different Needs
Your budget should follow the electricity you want solar to supply. Start with your recent electricity bills, then identify which appliances run during the day and which use energy after sunset.
Solar can reduce some grid consumption when the generated electricity reaches those loads directly or through storage. The result depends on sunlight, shading, system losses, usable battery capacity and your daily routine.
Small Homes, Apartments and Townhouses
Begin with a manageable group of loads, such as your home office equipment, lighting, and selected household appliances. The bedroom count alone is not enough to size a system.
If you work from home, daytime solar generation may overlap with your laptop, router and other regular demands. If the property is empty through most daylight hours, consider how much energy you can shift to daytime use and how much you would need to store.
For a modest setup, list each appliance’s daily energy requirement. A device drawing 50W for 6 hours uses 300Wh, or 0.3kWh. Add the loads together, then account for system losses and variable weather conditions.
You can also make a simple savings estimate:
Electricity-cost reduction ≈ grid electricity avoided × your applicable unit rate
For illustration, avoiding 150kWh of grid use at an assumed R3/kWh would reduce usage charges by about R450. This is a calculation example, not a current tariff or a promised saving. Fixed charges and ongoing costs remain separate.
Use your own electricity bill for the applicable rate. Households supplied by the City of Cape Town can also consult its residential rates and tariffs calculator for an indicative estimate of municipal charges.
If you only have a balcony or patio, assess direct sunlight, shading and a secure placement position before purchasing. The price of a small solar panel is only part of the budget; you may still need a compatible power station, cables, and a suitable support arrangement.
Portable Solar for Camping and Small Loads
For camping, price the panel and storage together. A panel can recharge a compatible power station during suitable daylight, while the stored energy supplies your devices later.
Build the budget around your daily loads. Phones and lighting require less energy than a fridge operating throughout the day and night. Check the appliance’s energy use rather than choosing a panel solely by its headline wattage.
Folded dimensions, handling weight and cable length matter when you set up and pack away regularly. These features may justify spending more on a portable design even though a rigid panel has a lower price per watt.
Allow for cloudy periods too. A setup that only just meets your estimated consumption in good sunshine leaves little margin when conditions change.
How to Compare Itemised Solar Quotes
Give each supplier the same brief: the loads you want to support, your electricity use, the mounting location and the hours when you need power.
Then compare the following details:
Quote item
What to check
Panels
Model, quantity, individual wattage and total array capacity
Inverter
Continuous output, solar-input limits and battery compatibility
Battery
Nominal and usable capacity, discharge limits and warranty
Installation
Mounting, cable runs, electrical work and testing
Extras
Delivery, accessories, roof work and optional monitoring
Support
Equipment warranties and installation aftercare
Ask for a seasonal generation estimate and the assumptions behind it. An annual total alone may hide months when output is lower than your demand.
If one quote is cheaper, identify the specific difference. It may have fewer panels, less storage or a narrower installation scope. Choose the configuration that meets your needs before comparing the final totals.
EcoFlow Solar Panel Options for Different Setups
A fixed array, a temporary patio setup and a compact travel kit have different requirements. The following panels serve those separate situations. For each option, check compatibility with your inverter or portable power station and confirm the package contents.
EcoFlow 400W Rigid Solar Panel
If you have a permanent mounting location, the EcoFlow 400W Rigid Solar Panel can form part of a compatible fixed solar installation. Plan the layout, mounting hardware and electrical connections together so the panel purchase fits the overall system budget. Include the required mounting sets and connection equipment when comparing the package cost with your installation quote.
- 400W Per Panel Rated Output - 23% Conversion Efficiency - IP68-rated Construction - 10 Years Product Warranty - Solar-to-XT60 Charging Cables Compatible
EcoFlow 160W Lightweight Portable Solar Panel
For a patio or campsite where you put the panel out during the day and store it afterwards, the EcoFlow 160W Lightweight Portable Solar Panel offers a foldable design with an integrated connection cable. Its adjustable support helps you position the panel as sunlight changes. You can also use it on your balcony when choosing a secure, supported position.
- 160W Rated Output - 25% Conversion Efficiency - Built-in 2.5m XT60 Cable - 30–60° Adjustable Support Angle
EcoFlow 110W Lightweight Portable Solar Panel
If your travel kit centres on phones, lighting and laptop charging, the EcoFlow 110W Lightweight Portable Solar Panel offers a compact folding format for use with a compatible power station. Check how much energy you need each day and how much direct sunlight your campsite receives before deciding whether one panel is enough. The panel supplies charging energy, and the connected power station determines available appliance output and stored runtime. Include that equipment in your budget if you do not already own a compatible unit.
- 110W Rated Output - Approximately 3.3kg in Weight - 544 × 413 × 36mm Folded Dimensions - XT60I-F Connector Type
The solar panel price is only one part of the total cost. Compare fixed and portable panels separately, check whether the listed price covers one panel or a pack, and include the inverter, battery, accessories and installation you may need. For a home installation, request an itemised quote with the panel capacity, inverter output, usable battery storage and installation scope. Choose a setup based on your daily energy needs, available sunlight and intended appliances rather than price or wattage alone.
Can You Add Solar Panels to an Existing Inverter-and-Battery System?
Yes, if the existing equipment supports solar charging and has enough input capacity. Give your installer the inverter model and the proposed panel specifications before purchasing.
The installer should check the MPPT operating range, maximum input voltage and current, and the proposed panel arrangement. Having a battery system does not automatically mean you can connect any panel to it.
Can You Start with a Few Solar Panels and Expand Later?
Yes, provided the initial design allows expansion. Ask the installer to identify spare solar input capacity, suitable mounting space, and any equipment that would need to be replaced when more panels are added.
Some fixed inverters also need a minimum string voltage to start operating, so a very small number of panels may not work. For portable setups, follow the power station’s supported panel configurations and connection limits.
Can a 200W or 400W Solar Panel Run a Fridge?
A suitable panel, battery, inverter, or power station can support a fridge, but panel wattage alone cannot guarantee continuous operation. Check the fridge’s daily energy consumption and starting demand first.
For an illustrative estimate, a 200W panel receiving five peak sun hours with an assumed 75% overall energy yield would provide about 0.75kWh per day. Under the same assumptions, a 400W panel would provide about 1.5kWh. Actual output varies with location, season, temperature and shading.
Compare that energy with the fridge’s measured daily use, allow for other loads, and size storage for the hours without sunlight. The inverter or power station must also support the compressor’s starting surge.
Solar Panels
