Camping Solar Panels: What Size Do You Need for Your Trip?
Choosing camping solar panels starts with a practical question: what do you need to power? A 60W–100W panel can suit phones and small devices, whereas a 160W–200W setup offers more capacity for a portable fridge and everyday camping gear. For heavier loads and longer trips, a 300W+ setup provides greater charging headroom. Whether you’re camping in the bushveld or heading out on an overlanding trip, camping solar panels can keep your essential devices powered throughout your adventure.
Key Takeaways
Size camping solar panels around daily energy use in watt-hours (Wh), then allow for the sun and charging time available at your campsite.
Measure a camping fridge’s daily consumption where possible. Its compressor does not necessarily run at its rated wattage for 24 hours.
Choose battery capacity for overnight use and periods without useful solar charging. Extra nights do not automatically mean you need a higher-wattage panel.
Check solar input voltage, current, connectors and cable compatibility before buying. Matching wattage alone is not enough.
Remember that solar panels generate rather than store energy. Pair your panel with a compatible battery or power station if you need power after sunset.
How Many Watts of Solar Power Do You Need for Camping?
For a first estimate, compare your daily consumption with the energy a panel could supply. The table below uses four peak sun hours and a 75% overall delivery factor, allowing for reduced panel output and system losses. These are calculation assumptions, not a South African average or a guarantee for your campsite.
Panel rating | Calculated usable energy per day | Where it may fit |
60W–110W | 180–330Wh | Phone and camera charging, plus modest LED lighting |
160W–220W | 480–660Wh | An efficient compressor fridge and small devices, if measured use leaves a margin |
300W–400W | 900–1,200Wh | Higher daily consumption or more room to recover battery charge |
At only two peak sun hours, each estimate halves. A larger panel helps only if your power station or controller can accept its electrical output and you have space to put it in the sun.
How to Calculate Your Daily Energy Use for Camping Solar Power
For a device drawing steady power, multiply watts by hours used. For a fridge, use a measured 24-hour total or a manufacturer’s consumption figure with stated test conditions. Hot weather, freezer settings and frequent opening can increase demand.
Here is an illustrative daily budget, not a claim about a particular fridge or phone:
Device | Example daily use |
12V compressor fridge | 480Wh measured over 24 hours |
Two phones | 40Wh combined |
LED camp lights | 10W × 4 hours = 40Wh |
Camera charging | 40Wh |
Total | 600Wh per day |
Required panel wattage ≈ daily energy use ÷ peak sun hours ÷ overall delivery factor
600Wh ÷ 4h ÷ 0.75 = 200W
Under those assumptions, 200W only balances the daily load. A 220W–300W panel gives some extra charging capacity, but cannot guarantee enough energy through poor weather. If you expect only two peak sun hours, the same calculation needs 400W just to balance that load.
Peak sun hours express the day’s solar energy as equivalent hours of full-strength sunlight. They differ from the total hours of daylight. Use a location- and season-specific estimate, then account for time the panel will be packed away or shaded. The 75% factor here is also different from the panel’s advertised solar conversion efficiency.
Allow for Your Trip Length and Battery Reserve
A weekend away may need only a modest solar top-up if you leave with a full battery. On a longer stay without mains power, daily charging needs to keep up with daily use. If you spend the day driving with a portable panel packed away, you cannot count that time as solar charging.
Size the battery separately. For example, supplying 600Wh through one full day without charging would require 750Wh of nominal storage if 80% reaches your devices. That 80% is an illustrative assumption; usable capacity, output losses and standby consumption vary by system. Allow additional reserve before choosing a battery.
What Type of Solar Panel Is Best for Camping?
Choose a panel that fits how you camp and the space you have. Foldable panels and solar blankets can be packed away between stops. Rigid panels suit permanent installations on caravans, camper trailers and suitable bakkie canopies. Flexible panels may suit gently curved surfaces, depending on their mounting requirements.
Foldable Solar Panels
Briefcase-style foldable solar panels for camping are designed for easy transport and quick setup. They fold into a compact form for storage and can be repositioned towards the sun throughout the day. They are a practical choice for car camping, overlanding and other portable power setups where easy setup and storage matter.
Solar Blankets
Solar blankets pack down well when space is tight on a 4x4 or overlanding trip. Unfold them in a sunny spot and position them as the manufacturer recommends. Check whether the model has support legs or needs another way to hold it at the right angle.
Semi-Flexible and Flexible Solar Panels
Semi-flexible and flexible solar panels can fit suitable flat or gently curved surfaces, including some vehicle, caravan and camper roofs. Their thin profile makes them useful for vehicle-based camping setups where a permanently positioned panel makes more sense than a panel you unpack at each stop.
Fixed Solar Panels
Fixed solar panels use rigid frames and durable glass for permanent mounting on suitable caravans, camper vans and other vehicle-based setups. Once installed, they can recharge a compatible battery or power station whenever sunlight is available. Their main limitation is positioning, since you cannot move the panel around camp to follow better sunlight.
Will the Solar Panel Work with Your Battery or Power Station?
Check this before deciding on a panel size. A suitable plug does not, by itself, make two products compatible.
Check Voltage and Current Limits
Compare the panel’s open-circuit voltage (Voc), operating voltage and current with the receiving device’s solar input specifications. Open-circuit voltage rises in cold conditions, so allow the margin required by the manufacturer. Also check the maximum accepted solar wattage.
A 400W solar panel cannot make a power station accept 400W if its input is limited to less. Never assume excess voltage will simply be capped. Before combining panels, check the total voltage and current of the proposed arrangement.
Check the Charge Controller and Cables
A standalone battery needs an appropriate solar charge controller, often called a regulator. Many power stations already have one built in. Follow the receiving device’s instructions rather than adding a second controller by default.
Confirm the exact connector type, polarity and cable rating for your panel and charging system. An adapter may let the connectors fit together, but it does not make an incompatible voltage suitable.
Check Weight, Packing Size and Weather Resistance
A large panel may fit in the vehicle but be awkward to put out at a small stand. Check its open dimensions, weight and stand design. An IP rating applies to the component tested. It does not make your power station or every cable joint waterproof.
How to Maximise Solar Panel Output While Camping
Once the panel is matched to your camping equipment, a few practical habits help you get more from it:
Give it a clear view of the sun. In South Africa, facing north is a useful starting point around midday. Adjust the panel towards the sun as it moves. Watch for shadows from the awning, roof rack and nearby trees.
Keep the battery cool. Put the panel in the sun and the power station in a dry, shaded, ventilated spot within the approved cable’s reach. Do not cover its vents.
Clean off dust as directed. After a gravel-road drive, inspect the panel and use the cleaning method in its manual.
Check the charging display. If output drops, look for shade, a poor angle or a loose connection. You may also see lower input when the battery is nearly full.
Reduce the fridge’s workload. Pre-cool it before leaving and keep it ventilated and out of direct sun. A larger solar panel is not the only way to improve your energy balance.
Plan for a poor charging day. Check the forecast and leave with a full battery. Only count vehicle or mains charging if your equipment supports it and you expect to have access to it.
Which EcoFlow Camping Solar Panel Suits Your Setup?
With your power needs and camping setup in mind, the next step is choosing a solar panel that fits the way you camp. EcoFlow’s portable options below cover different camping needs, from lighter everyday loads to higher-demand camping setups.
EcoFlow 110W Lightweight Portable Solar Panel: For Light Daily Use
The EcoFlow 110W Lightweight Portable Solar Panel suits a modest charging budget and a compatible power station. At about 3.3kg, it is easier to pack and move around camp than a larger panel. It is worth considering when phones, a camera and lights make up most of your load.
EcoFlow 220W Lightweight Portable Solar Panel: A Middle Option for Fridge Setups
The EcoFlow 220W Lightweight Portable Solar Panel offers a middle ground when your daily budget includes a compressor fridge. In the 600Wh example above, it provides only a small margin at four peak sun hours, so check your actual consumption and expected conditions.
EcoFlow 400W Lightweight Portable Solar Panel: For Higher Daily Demand
For longer trips or camping setups with higher energy demands, the EcoFlow 400W Lightweight Portable Solar Panel provides more solar input for charging a compatible power station. It is better suited to setups that need to support a portable fridge, multiple devices or higher daily energy use.
*For all three, plan to charge a compatible power station or battery system; do not assume direct USB phone charging. Confirm the approved cable arrangement before buying extensions or planning to connect multiple panels.
Choose camping solar panels by working out a day’s electricity use, allowing for the sun you can actually use, and checking the charging system. Pack enough battery reserve for the night and poor weather. A setup that fits your campsite and covers your measured load is more useful than buying by wattage alone.
Is a 200W Solar Panel Enough for Camping?
It can be enough for a modest setup. With four peak sun hours and a 75% overall delivery factor, the calculated supply is about 600Wh a day. Compare that with your fridge, lights and device charging, and leave a margin. Less sun means less energy.
Can you run a 12V fridge straight from a solar panel?
For a standard 12V camping fridge, use a compatible battery or power station between the panel and the fridge. This provides a stable supply when solar output drops or after sunset. A standalone battery also needs a suitable solar charge controller. Size the panel and battery for the fridge’s daily consumption and any other devices you use.
Do I need a battery or power station with a camping solar panel?
It depends on the situation. The power generated by solar panels fluctuates with clouds or shade. Adding a compatible power station gives you somewhere to store that energy for later use. This is especially useful for overnight camping or when running devices after sunset.
Can I charge my phone directly from a solar panel?
Only if the panel has a regulated USB output compatible with your phone. Otherwise, use a compatible power station to charge your phone. Check the panel’s ports before buying, as not all models support direct USB charging.
How long does it take to charge a portable power station with a camping solar panel?
There is no fixed charging time because it depends on the panel’s actual output, the power station’s capacity and available sunlight. A higher-output solar panel can charge a compatible power station faster, but actual output varies with sunlight, temperature, shading and other conditions. For camping, check that the panel’s output matches the station’s solar input before pairing them.
