Rooftop Solar Power in South Africa: Benefits, Costs and System Options
From the fridge and Wi-Fi router to a pool pump or home office setup, many household appliances use electricity throughout the day. Rooftop solar power can cover part of this demand and reduce reliance on grid electricity. When rooftop solar panels are paired with a suitable inverter and battery, the system may also keep selected appliances running during an outage. This guide explains how rooftop solar power works and covers system types, roof suitability, installation, sizing and cost.
What Is Rooftop Solar Power?
A rooftop solar system uses panels installed on a home or commercial building to generate electricity from sunlight. The power produced during the day can run household appliances, reducing the amount drawn from the grid.
In South African homes, rooftop solar power may help cover daytime loads such as a fridge, Wi-Fi router, pool pump, lighting and home office equipment. Adding a battery allows unused solar electricity to be stored for later, including after sunset or during an outage.
System output depends on roof space, orientation, shading, panel capacity and weather conditions.
What Is a Rooftop Solar System Made Of?
A rooftop PV system may include the following components:
  • Solar panels: A key part of the rooftop PV system, these panels are installed on the roof to capture sunlight and convert it into direct current (DC) electricity through photovoltaic technology.
  • Mounting system: The mounting structure secures the panels to the roof. Panel layout depends on the roof shape and pitch, while the fixing method depends on the covering, such as tiles, IBR or Klip-Lok sheeting.
  • Inverter: Once electricity is generated, the inverter converts DC power into alternating current (AC), making it suitable for household or commercial appliances.
  • Battery storage: Extra energy generated during the day can be stored for later use, providing backup power at night or during outages and improving overall energy reliability.
  • Electrical components: A range of safety and connection parts, including DC cables, AC cables, isolators, surge protection devices, and distribution board integration, ensure stable and secure power flow throughout the system.
A battery is not included in every system. A standard grid-tied setup can reduce daytime electricity purchases, but it will normally switch off during an outage unless suitable backup equipment has been installed.
How Does Rooftop Solar Power Work?
  • The panels generate electricity. Photovoltaic cells convert sunlight into direct current power.
  • The inverter converts the power. It changes direct current into alternating current for use in the home.
  • The home uses available solar electricity. Appliances draw from the rooftop system first, with the grid supplying any additional demand.
  • Surplus power is stored or exported. Extra electricity can charge a battery or, where local rules and the connection allow, be sent to the grid.
Stored battery power can be used after sunset or during an outage. Backup time depends on battery capacity, appliance load and the battery’s state of charge.
Main Benefits of Rooftop Solar Power
  • Lower daytime grid use: Appliances can draw power directly from the solar system while the sun is shining.
  • Better use of roof space: Solar power on the roof generates electricity without using additional land.
  • Backup for essential appliances: A suitable inverter and battery can support refrigeration, internet equipment, lighting and security systems during an outage.
  • Clearer energy monitoring: An inverter app can show when electricity is being generated, consumed, stored or drawn from the grid.
  • Flexible system sizing: The system can be planned around household consumption, roof space and budget, with some setups allowing later expansion.
  • Less exposure to electricity price increases: Generating electricity on-site can reduce grid purchases, although actual savings depend on system size, usage patterns and installation cost.
Types of Rooftop Solar Systems
Rooftop solar systems are commonly grouped by their grid connection and battery setup. The three main configurations are grid-tied, hybrid and off-grid.
System Type
Grid Connection
Battery
Works During an Outage
Best For
Grid-tied
Connected to the grid
Usually not included
Not normally, unless suitable backup equipment is installed
Homes that want to reduce daytime grid use at a lower upfront cost than battery-based systems
Hybrid
Usually included or added later
Yes, if battery storage and backup circuits are configured
Homes that want lower grid use, energy storage and outage backup
Off-grid
No grid connection
Usually required
Yes, subject to available solar generation and battery capacity
Remote properties or sites without a grid connection
Is Your Roof Suitable for Rooftop Solar Panels?
A large roof does not automatically mean a high-output solar system. Before rooftop solar installation begins, an installer should check the roof’s direction, sunlight exposure, condition and usable space. These factors affect how many rooftop solar panels can be fitted and how much electricity they are likely to produce.
Common Roof Types in South Africa
South African homes use several roof designs. The roof shape affects the size and direction of the available panel area, while the roof covering determines which mounting system is required.
Roof Type
Design
Solar Installation Considerations
Gable roof
Two sloping sides meet at a central ridge
Often provides a broad, continuous area for panels, but only one side may have favourable sun exposure.
Hip roof
Four sides slope down from the ridge
Offers several possible panel orientations, although the smaller roof sections may limit continuous panel rows.
Flat roof
Appears level but includes a slight slope for drainage
Allows the panel angle and direction to be adjusted, but frames or ballast may increase installation complexity.
Mono-pitch roof
A single roof surface slopes in one direction
Can support a simple panel layout when correctly oriented, but poor orientation may limit design flexibility.
Dutch gable roof
Combines a hip roof with a gable above it
Provides several possible mounting areas, though ridges and level changes can reduce usable space.
Butterfly roof
Two roof surfaces slope towards a central valley
May provide usable space on both sides, but drainage valleys and maintenance access must remain clear.
Roof Direction and Sun Exposure
Check the following before deciding where to place the panels:
  • Roof direction: North-facing roof sections often receive good sunlight in South Africa, but east- and west-facing areas may also work depending on the roof layout and system design.
  • Roof pitch: The angle of the roof affects how much sunlight reaches the panels throughout the year.
  • Daily sunlight: Panels should receive direct sunlight for as much of the day as possible.
  • Nearby shade: Trees, neighbouring buildings, chimneys and other structures may reduce solar output.
  • Seasonal shade: Shading patterns can change in winter when the sun sits lower in the sky.
The final layout should be based on a site assessment rather than roof direction or total roof area alone.
Roof Space and Structural Condition
  • Usable space: Panels need clear, connected roof sections rather than small or irregular gaps.
  • Roof obstacles: Chimneys, skylights, vents and access routes reduce the area available for installation.
  • Roof condition: Leaks, damaged tiles, rusted sheeting and weak sections should be repaired before panels are fitted.
  • Structural strength: Older or damaged roofs may need an assessment to confirm that they can support the panels and mounting system.
  • Maintenance access: Enough space should remain for inspections, cleaning and future roof repairs.
Completing any necessary roof work before installation helps avoid the cost and disruption of removing the panels later.
Typical Rooftop Solar System Sizes and Prices in South Africa
The right rooftop solar system size depends on electricity use, daytime loads, battery charging needs and available roof space. The figures below are 2026 market estimates for standard residential installations. Actual output varies by location, season, roof orientation, shading and system losses, while solar system prices vary by installer, equipment brand and installation scope. Prices usually exclude battery storage.
Solar Array Size
Common Configuration
Estimated Daily Output
Indicative Installed Price
3 kW
6–8 panels with a 3 kW hybrid inverter
12–15 kWh
R45,000–R55,000
5 kW
10–12 panels with a 5 kW hybrid inverter
20–25 kWh
R85,000–R95,000
8 kW
16–18 panels with an 8 kW hybrid inverter
32–40 kWh
R130,000–R150,000
10 kW
20–22 panels with a 10 kW hybrid inverter
40–50 kWh
R160,000–R185,000
Rooftop Solar Installation in South Africa
Rooftop solar installation starts with the property’s electricity use and backup needs. The installer can then assess the site, design the rooftop PV system and confirm the relevant connection requirements.
1. Review Electricity Use and Backup Priorities
Check recent electricity bills to estimate average daily use in kilowatt-hours. Separate daytime use from evening loads, then list the appliances that need to run during an outage. This helps determine the required panel, inverter and battery capacity.
2. Complete a Roof and Site Assessment
The assessment should cover:
  • roof condition, direction and usable space
  • daily and seasonal shading
  • panel layout
  • inverter and battery locations
  • distribution board condition
  • cable routes
Complete any necessary roof repairs or electrical upgrades before installation.
3. Finalise the System Design
Based on the load review and site assessment, the installer should confirm:
  • Total solar panel capacity
  • Panel layout and orientation
  • Inverter rated output
  • Usable battery capacity
  • Selected backup circuits
  • Inverter and battery locations
  • Options for future expansion
The final design should show how the panels, inverter, battery and backup circuits will work together before installation begins.
4. Confirm SSEG and Electricity Supplier Requirements
Confirm whether the property receives electricity from Eskom or a local municipality. A grid-connected small-scale embedded generation system must be registered with the relevant electricity supplier.
Application, metering and export requirements vary by supplier and municipality. Confirm the local process before installation begins.
5. Install, Test and Commission the System
The installer should:
  • fit the mounting system and rooftop solar panels
  • install the inverter and battery
  • complete the wiring and protection
  • connect the selected backup circuits
  • configure system monitoring
  • test solar, grid and battery operation
The final tests should confirm that backup switching works correctly and that the system disconnects safely from the grid when required.
6. Obtain the CoC and Final Documentation
An appropriately registered electrical contractor should inspect and test the installation before issuing a valid Electrical Certificate of Compliance.
Keep the following documents where applicable:
  • Electrical Certificate of Compliance
  • system diagram and equipment datasheets
  • commissioning report
  • SSEG registration or approval records
  • equipment and workmanship warranties
  • monitoring account details
  • maintenance instructions
How to Choose the Right Rooftop Solar System?
The right rooftop solar system depends on when electricity is used, which appliances need backup and how much roof space is available. The panels, inverter and battery should be selected around the same load profile.
Review Daily and Daytime Electricity Use
Check recent electricity bills to estimate average daily use in kilowatt-hours, then separate daytime demand from evening and overnight use.
Pool pumps, washing machines and home office equipment can be scheduled to run while the panels are generating electricity. Loads used after sunset depend on the grid or stored battery power.
Decide What Needs Backup
List the appliances and circuits that should remain available during an outage. Common priorities include:
  • Fridge
  • Wi-Fi router
  • Lighting
  • Security equipment
  • Home office equipment
  • Selected plug circuits
Check their combined running power, starting power and required runtime. Fridges, pumps and other motor-driven appliances may draw more power when starting, while high-consumption equipment can shorten battery runtime.
Match the System to the Main Goal
Once the household load and backup requirements are clear, choose the system type that best matches the main goal. A grid-tied system may be suitable when the priority is reducing daytime grid use. Homes that need selected appliances to remain available during outages require a hybrid system with a compatible inverter, battery and correctly configured backup circuits. Properties without a grid connection generally require an off-grid setup.
Match the Inverter and Battery to the Load
Inverter output determines how much equipment can run at the same time, while usable battery capacity determines how long those appliances can operate.
A battery may store enough energy for several hours, but an undersized inverter may still be unable to start or run several high-power appliances together. Allow for the starting power of fridges, pumps and other motor-driven equipment.
For flexible backup alongside a rooftop solar system, the EcoFlow DELTA 3 Ultra Plus Portable Power Station can power selected appliances during an outage and recharge from compatible solar panels. It is suited to essentials such as refrigeration, internet equipment, lighting and home office devices. Actual runtime depends on the connected load and available charge, and it does not replace a professionally installed home battery system and backup circuits.
EcoFlow DELTA 3 Ultra Plus Power Station
EcoFlow DELTA 3 Ultra Plus Power Station features a 3–7 kWh expandable capacity and delivers 3600 W of AC output, with X-Boost mode reaching up to 4700 W to support most household appliances. It offers five fast charging methods for flexible use across different scenarios. A 10 ms UPS automatic switching function ensures seamless backup power during outages, reducing downtime. It also includes an advanced X-Guard BMS battery management system for safe, efficient energy control and extended battery life.
Check Component Quality and Warranties
Check the specifications and support available for each main component:
  • Solar panel product and performance warranties
  • Inverter warranty and operating limits
  • Usable battery capacity and cycle life
  • Mounting system suitability
  • Installer workmanship warranty
  • Local technical and after-sales support
For fixed rooftop solar installations, the EcoFlow 400 W Rigid Solar Panel offers up to 23% conversion efficiency, which can provide more generation from the available roof area than a lower-efficiency panel of the same size under comparable conditions. System voltage, current, inverter limits, connectors and mounting requirements should still be checked before installation.
EcoFlow 400 W Rigid Solar Panel is a high-efficiency solar solution. With up to 23% solar conversion efficiency, it maximizes energy output. The panel is built with high-strength tempered glass and a corrosion-resistant aluminum frame, specifically designed to withstand extreme weather conditions in South Africa, and it can endure up to 2400 Pa wind load and 5400 Pa snow load. Its IP68 waterproof rating ensures reliable operation even in heavy rain, while the pre-drilled design allows for safe and low-maintenance installation in any off-grid location.
A long warranty is more useful when the manufacturer, supplier and installer provide accessible local support.
Compare the Full Quote
Do not compare quotes by total price or inverter size alone. Check whether each quotation includes:
  • Panel quantity and rated wattage
  • Inverter capacity
  • Mounting equipment
  • Cabling and protection devices
  • Backup circuit work
  • Installation and commissioning
  • SSEG support where required
  • Monitoring setup
  • Equipment and workmanship warranties
  • After-sales support
Ask the installer to list exclusions and optional work separately.
How to Maintain Rooftop Solar Panels
Maintenance needs vary by roof design, local conditions and the equipment installed. Regular checks can reveal output losses, damage and electrical faults.
Panel and Roof Checks
Inspect the system from a safe position and look for:
  • Cracked or damaged panels
  • Loose mounting parts
  • Corrosion
  • New shading from tree growth
  • Roof damage or water entry
Dirt, leaves and other debris may also reduce solar output. Understanding the correct methods for cleaning solar panels in South Africa can help remove buildup without damaging the panels or roof. Avoid climbing onto a wet, steep or difficult-to-access roof. Use a qualified service provider when safe access or specialist equipment is required.
Inverter, Battery and Electrical Checks
Use the monitoring system to spot unexpected drops in solar generation. Check the inverter for warning lights or recurring error messages.
Keep the inverter and, where fitted, the battery area clear and dry, following the manufacturer’s temperature and ventilation requirements. Visible cables, switches and protection devices should not show signs of corrosion, damage or overheating.
Only a qualified professional should open the inverter, battery enclosure or distribution board.
When to Call an Installer
Arrange a professional inspection when:
  • Solar output drops without a clear weather-related cause
  • Inverter errors keep returning
  • The battery charges or discharges abnormally
  • Panels or mounting parts appear damaged
  • Cables or protection devices show signs of overheating
  • A roof leak develops near the installation
Contact the installer before adding panels or battery capacity. System expansion may affect inverter limits, electrical protection, the CoC and electricity supplier requirements.
Rooftop solar power can help South African households reduce daytime grid use and keep selected appliances running during outages when paired with suitable battery storage and backup equipment. The right setup should reflect the home’s electricity use, roof conditions, budget and backup priorities, with the panels, inverter and battery sized as one system. A portable power station charged from compatible solar panels can provide flexible backup for essentials such as a fridge, Wi-Fi router, lights and home office equipment, but it does not replace the professional design, electrical protection, CoC or any required registration for a permanent grid-connected installation.
Do rooftop solar systems still work during cloudy or rainy days?
Yes. Rooftop solar panels can still generate electricity from diffuse sunlight on cloudy or rainy days, but output will be lower than in direct sunlight. A battery may help cover periods of reduced solar generation, depending on its capacity, charge level and the connected load.
Do rooftop solar systems work during a power outage?
A standard grid-tied system normally shuts down during an outage to prevent power from feeding back into the network. A hybrid or off-grid system can keep selected appliances running if it has a compatible inverter, battery and properly configured backup circuits.
What happens after 25 years of solar?
Solar panels do not suddenly stop working after 25 years. Their output gradually declines, but many continue generating electricity beyond their performance warranty period. Panels, wiring and mounting equipment should still be checked for wear or damage.
Is it better to have more solar panels or more batteries?
It depends on the goal. More panels provide more electricity for daytime use and battery charging, while more battery capacity can extend evening or outage runtime. The solar array, inverter and battery should be sized together around electricity use and backup needs.
Home Backup
