RV Window AC Unit Guide: Will It Fit, How to Mount It Safely, and How to Power It
When your RV's rooftop AC struggles in summer or finally gives out, a small window unit can look like a practical replacement. These units are widely available, and you may be able to cool your living space without replacing the entire rooftop system. But an RV isn't a house. Its walls move with the road, its window frames may not support a heavy appliance, and the AC needs a safe way to drain condensation. Before buying an RV window AC unit, check the opening, mounting support, drainage, and travel plan. Then make sure your power source can handle the unit's running load and compressor startup.
Can You Put a Window AC Unit in an RV? What to Check First
Yes, an RV can use a window air conditioner, but the installation needs more thought than sliding a unit into a standard house window. The opening, wall structure, drainage, and travel routine all matter. A window AC isn't designed to stay mounted on a moving RV by default. Start with these four checks before choosing a model.
Opening size: Measure the available height and width. If you're planning a wall cutout, confirm the required opening dimensions in the AC's installation manual.
Wall support: A small window unit can weigh 30 to 50 pounds or more. Have the RV manufacturer or a qualified technician confirm that the wall and frame can carry that weight.
Condensation drainage: The AC needs a clear path for water to drain outside. Water trapped inside a wall can cause damage that isn't obvious until later.
Travel plans: Decide whether you'll remove the unit before driving or use a mounting system specifically designed and approved for travel.
Small window AC units to consider
The following models show the range of sizes available in this category. Their listed specifications come from ENERGY STAR's certified room air conditioner data. They're examples to compare, not recommendations for any particular RV.
Model (ENERGY STAR data) | Cooling capacity | CEER | Weight | H × W × D (in) | Mounting type | Variable-speed compressor |
Frigidaire FHWC055TF1 | 5,000 BTU/h | 14.4 | 30.2 lb | 12.1 × 16.0 × 13.3 | Does not straddle window | Yes |
Whirlpool WHAW050EX | 5,000 BTU/h | 13.1 | 41.9 lb | 12.5 × 16.0 × 15.2 | Straddles window | Yes |
Midea MAW06U1QWT | 6,000 BTU/h | 15.1 | 50.7 lb | 13.5 × 19.2 × 22.0 | Straddles window | Yes |
One important distinction: BTU/h measures cooling capacity, not electrical consumption. A 5,000 BTU/h AC doesn't use 5,000 watts. Its actual power draw depends on the model and operating conditions. If you're still weighing your options, this guide to portable AC vs. window AC explains the main differences. If a window unit looks suitable on paper, don't order it until you know how you'll support it and keep water out of the RV wall. The next step is building a mount that can handle the unit's weight and movement.
How to Mount an RV Window AC Unit Safely
A window AC needs firm support, a weather-resistant seal, and enough clearance for air to move around it. RV owners use different mounting approaches, including a framed wall sleeve, a custom panel fitted into an existing window, or a removable mount for use while parked. The right option depends on the RV's construction and the AC manufacturer's instructions.
Choose a mounting method that supports the weight
A rigid frame or purpose-built sleeve should transfer the unit's weight to a suitable structural part of the RV, not just the window glass or decorative trim. Use the manufacturer's support bracket when one is supplied. If the installation requires cutting the wall, changing structural members, or moving wiring, have an RV technician assess the work first. Before using the AC, check the following:
Secure the unit: Follow the installation manual and confirm that the frame, fasteners, and support bracket are appropriate for the load.
Seal the opening: Close gaps around the unit to keep rain, insects, and outside air from entering the RV.
Plan the drain path: Position the AC as its manual specifies, so condensation can drain correctly. Don't assume every model needs the same tilt.
Keep the outdoor side clear: The condenser needs room to release heat. Blocking its airflow can reduce cooling performance and increase power consumption.
Check it after travel: If the unit stays installed, the mounting system must be suitable for road vibration and movement. Otherwise, remove or secure it before driving.
Restricted airflow can increase an AC’s power draw. In one Build a Green RV test, a Fedders unit’s draw rose from about 1,040W to 1,598W when airflow was restricted. Results vary, but clear airflow matters. See our guide to window AC wattage for more on power needs. Once the unit is secure and drains properly, check its running watts and startup demand to choose a suitable power source and estimate runtime.
Powering an RV window AC without shore power
On campground shore power, a compatible 115V window AC can run from a suitable RV outlet. Away from hookups, you'll need a generator or battery power station that can handle the AC’s running load, startup demand, and runtime needs. Start by checking the unit's nameplate for voltage and amperage.
Estimate the AC's power draw
Divide cooling capacity in BTU/h by the CEER rating for a rough input estimate.
Model | Calculation | Estimated input |
Frigidaire FHWC055TF1 | 5,000 ÷ 14.4 | About 347W |
Midea MAW06U1QWT | 6,000 ÷ 15.1 | About 397W |
These are estimates, not measured running loads. Check the nameplate for actual requirements and confirm the startup peak stays within your power source's surge limit.
Check connections and generator safety
Confirm the plug and outlet are compatible, and follow the AC and power station manuals for safe connections and moisture protection. Run gas generators outdoors, with exhaust directed away from the RV's windows, doors, vents, and AC intake. The CPSC advises keeping portable generators at least 20 feet from a home.
Choose a power station for your setup
A power station can run a small window AC if its rated output, surge capacity, and connections meet the unit's needs. Runtime depends on battery capacity, the AC’s cycling, and other appliances. The two EcoFlow DELTA 3 models below offer different levels of output and capacity for running an AC alone or alongside other loads.
If the EcoFlow DELTA 3 Max doesn’t provide enough capacity for your AC and other appliances, the EcoFlow DELTA 3 Ultra Plus offers higher output, expandable battery capacity, and more charging options for longer trips between recharges.
The EcoFlow DELTA 3 Max may suit a small 120V window AC if its running load and startup surge stay within the unit's limits. If you also need to power a fridge or other appliances, or want more energy between recharges, the EcoFlow DELTA 3 Ultra Plus offers higher output and expandable capacity. Both provide limited runtime, so plan for a few hours of cooling rather than all night.
Labeled runtime estimates
Runtime depends on the AC's average power draw, not just its advertised cooling capacity. The estimates below assume 85% of the battery's rated capacity is available after conversion losses. They use an example AC load of 450W and a fridge averaging 60W; your equipment may draw more or less.
Setup (example window AC running at 450W) | Calculation | Estimate |
EcoFlow DELTA 3 Max (2048Wh), AC only | 2,048Wh × 0.85 ÷ 450W | About 3.9 hours |
EcoFlow DELTA 3 Max (2048Wh), AC + fridge averaging 60W | 2,048Wh × 0.85 ÷ 510W | About 3.4 hours |
EcoFlow DELTA 3 Ultra Plus (3072Wh), AC only | 3,072Wh × 0.85 ÷ 450W | About 5.8 hours |
EcoFlow DELTA 3 Ultra Plus (3072Wh), AC + fridge averaging 60W | 3,072Wh × 0.85 ÷ 510W | About 5.1 hours |
These are planning estimates, not guaranteed runtimes. The 450W AC draw and 60W fridge draw are examples, not specifications for every appliance. An AC compressor cycles on and off with the thermostat, so mild weather may extend runtime while hot weather can shorten it. For more guidance, see how to run an AC with a portable power station. The EcoFlow DELTA 3 Max may suit a smaller window AC if its running load, startup peak, and plug meet the unit's limits. The EcoFlow DELTA 3 Ultra Plus offers more output and capacity for extra loads or longer periods between recharges. Check your actual power needs before choosing.
RV Window AC vs Rooftop AC vs Portable AC
A window unit isn't the only way to cool an RV. A rooftop AC is built for an RV roof opening, while a portable AC sits inside and vents hot air through an exhaust hose. Each option comes with different installation and travel considerations.
Option | Install | Travel days | Main watch-outs |
Window unit | Frame or sleeve through a window or wall | Remove or secure before driving | Wall support, sealing, condensate drainage |
Rooftop RV AC | Built for the RV roof opening | Stays in place | Higher cost; roof work for replacement |
Portable AC | Sits inside with an exhaust hose | Stows like luggage | Takes floor space; hose must vent outside |
Think about how you use the RV. If you mostly stay parked for several days at a time, a properly mounted window unit may be workable. If you move frequently, removing and reinstalling it can become a hassle. A portable AC avoids a permanent window mount, but it takes up interior space and needs a suitable way to vent hot air outside. Compare portable ACs for RV living if you're considering that option. Before choosing, compare the installation requirements and power needs of the actual models you're considering. A different form factor doesn't automatically mean lower power consumption or easier off-grid use.
Tips to Help a Small Window AC Cool an RV
A 5,000 to 6,000 BTU/h window AC is a relatively small cooling unit. Reducing the amount of heat entering the RV can help it keep the space comfortable without running as hard. Try these practical steps:
Park in the shade when possible. If you can choose your spot, keep the largest windows out of the afternoon sun.
Use reflective window covers. Close blinds or shades on sunny windows, especially during the hottest part of the day.
Seal gaps around the AC. Check the frame and surrounding panels for openings that let warm air or humidity in.
Cool one area at a time. Close doors or partitions where practical instead of trying to cool every part of the RV at once.
Clean the filter regularly. Follow the AC manufacturer's instructions to maintain airflow.
Keep the condenser clear. Don't store gear or place other objects where they block the outdoor side of the unit.
These changes won't make an undersized AC perform like a larger one, but they can reduce the heat load it has to handle. That matters when you're running from a limited battery supply.
An RV window AC unit can be a practical way to cool your rig without replacing the rooftop system, but the installation needs to be safe for a moving vehicle. Check the opening and the unit's weight, confirm that the wall can support it, plan for condensation drainage, and decide whether it must come out before travel. Then use the AC's nameplate and startup requirements to choose a suitable power source. For a small window unit that fits within its output and surge limits, the EcoFlow DELTA 3 Max may provide a useful amount of portable power. If you need more capacity or want to run other appliances at the same time, consider the EcoFlow DELTA 3 Ultra Plus. Check the actual load and connection requirements first, and plan around realistic runtime rather than assuming the AC will run all night.
Can you put a regular window AC in an RV?
Yes, provided the opening, mounting frame, and wall can safely support the unit. You'll also need a sealed installation and a drainage path that directs condensation outside. Ask the RV manufacturer or a qualified technician to assess structural changes.
What size window AC do I need for a camper?
Small campers may use a 5,000 to 6,000 BTU/h window AC, but the right size depends on the space, insulation, sun exposure, and climate. BTU/h measures cooling capacity, not electrical power consumption.
How many watts does a 5,000 BTU window AC use?
It depends on the model. For example, a 5,000 BTU/h Frigidaire model with a CEER rating of 14.4 gives a rough estimate of about 347W using the BTU/h-to-CEER calculation. Check the unit's nameplate for its actual electrical requirements.
Can I leave a window AC in my RV while driving?
Only if the mounting system is designed for travel and the AC manufacturer permits that use. Many window units aren't intended to remain installed in a moving RV, so remove or secure the unit before driving unless the setup is specifically approved.
Can a portable power station run an RV window AC?
Yes, for a limited time, if the AC's running watts, startup peak, and plug are compatible with the power station. For example, a 2,048Wh EcoFlow DELTA 3 Max could run a 450W load for about 3.9 hours under the assumptions used in this guide. Actual runtime will vary.
