Battery Lead Acid Maintenance: What Flooded, AGM, and Gel Batteries Each Need
Lead-acid batteries have varied maintenance requirements based on the kind. Flooded batteries can be maintained by watering and equalizing but this can damage sealed AGM and gel batteries. This handbook details battery lead acid maintenance by type, including safety considerations, state-of-charge checks, watering, equalization, terminal cleaning, seasonal storage, and recycling. Its information comes from the manufacturers of Trojan and Rolls batteries, from OSHA safety requirements, and from EPA disposal instructions. It also looks at how transitioning from a modest lead-acid battery arrangement to a portable power station might ease daily power needs.
Lead Acid Battery Maintenance by Type: Flooded, AGM, and Gel at a Glance
All three battery types use lead plates and sulfuric acid, but they hold their electrolyte differently. Flooded batteries have liquid electrolyte and usually have removable vent caps. AGM batteries employ absorbent glass mats to store electrolytes, while gel batteries use thicker electrolytes. AGM and gel batteries are sealed, valve-regulated lead-acid (VRLA) types.
Maintenance task
Flooded
AGM
Gel
Add distilled water
Yes, as needed
No
No
Measure specific gravity
Yes
No
No
Equalize
Only when the manufacturer recommends it
No
No
Clean terminals and apply an appropriate anti-corrosion product
Yes
Yes
Yes
Use the correct charging profile
Yes
Yes
Yes
Recharge during storage
Yes
Yes
Yes
Before starting maintenance, identify your battery type by checking its label: flooded batteries have removable vent caps, while AGM and gel batteries are sealed. Using the correct charger matters because chargers built for different battery types offer different charging profiles. Manufacturer recommendations can vary, so follow the manual for your specific battery and wear appropriate safety gear when handling flooded batteries, which contain sulfuric acid and can release hydrogen gas.
Before You Open a Cap: Hydrogen, Acid, and the Gear to Wear
Lead-acid batteries contain sulfuric acid and may release flammable hydrogen gas during charging. Before inspecting a flooded battery, prepare your workspace, use appropriate protective equipment, and eliminate ignition sources to reduce the risk of injury.
  • Wear protective gear: Use safety goggles or a face shield, acid-resistant gloves, and suitable protective clothing to guard against electrolyte splashes.
  • Ensure ventilation: Work in a well-ventilated area and never charge a battery inside a completely sealed enclosure.
  • Remove ignition sources: Keep cigarettes, open flames, sparks, and other potential ignition sources away from the battery.
  • Remove metal jewelry: Take off rings, watches, and bracelets to reduce the risk of dangerous short circuits.
  • Prepare for spills: Keep clean water nearby for immediate rinsing and have appropriate spill-management supplies ready.
  • Control your tools: Keep metal objects off the battery and prevent tools from bridging its terminals.
If acid contacts your skin or eyes, immediately flush the affected area with plenty of water. Seek urgent medical attention for eye exposure and follow the manufacturer's emergency instructions. Never work on a cracked, leaking, or visibly damaged battery. Because sulfuric acid is corrosive, understanding its composition and potential hazards reinforces why careful handling and proper protective equipment are essential during battery maintenance.
When a Lead-Acid Battery Only Powers Small Devices: EcoFlow DELTA 3 Classic and EcoFlow DELTA 3 Max
Some lead-acid batteries power small devices such as work lights, fans, and phone chargers rather than starting engines. For these portable needs, an LFP power station can provide convenient AC power without routine watering or acid handling. The EcoFlow DELTA 3 Classic and DELTA 3 Max offer two options, depending on your power requirements.
The EcoFlow DELTA 3 Classic is worth considering for powering small devices at campsites, workshops, or temporary work areas. Its built-in AC outlets provide a convenient alternative to maintaining a small portable lead-acid setup. Check the model's rated output and battery capacity to ensure they meet your devices' power requirements.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
EcoFlow DELTA 3 Max
The EcoFlow DELTA 3 Max is another option for users who need more capacity and higher AC output for compatible appliances. It can support small devices and suitable portable equipment within its rated limits, making it useful for longer or more demanding power needs. Check the appliance's running wattage and the station's available capacity before use.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
To estimate runtime, multiply each device's wattage by its operating time and account for usable battery capacity and conversion losses. Understanding how to calculate battery backup hours helps you compare power needs with available energy before choosing a power station. Actual runtime varies with device behavior, temperature, and battery condition, so always check the manufacturer's guidance when estimating usable energy from a lead-acid battery.
How to Check State of Charge: Specific Gravity and Voltage Chart
The state of charge (SoC) tells us how much charge is left in a battery. Monitor it regularly to know when to recharge, look for uneven cells or consider replacement. Flooded batteries can be tested with a hydrometer or a voltmeter. Sealed AGM and gel batteries should be tested using the procedures specified by their makers, usually resting-voltage readings.
Checking Lead-Acid Battery VoltageChecking Lead-Acid Battery Voltage
Taking a Hydrometer Reading
A hydrometer measures the electrolyte's specific gravity in each flooded lead-acid battery cell to help assess its state of charge and identify differences between cells. Follow the battery manufacturer's safety instructions and measurement procedure before taking readings.
  1. Fully charge the battery: Charge it completely and allow it to rest as directed in the manufacturer's instructions.
  2. Wear protective equipment: Put on safety goggles and acid-resistant gloves before handling the electrolyte.
  3. Draw electrolyte: Carefully use the hydrometer to collect a small amount of electrolyte from one battery cell.
  4. Read the measurement: Hold the hydrometer at eye level, record the specific gravity, and return the electrolyte to the same cell.
  5. Check every cell: Record each reading and rinse the hydrometer between uses as appropriate. Trojan recommends investigating equalization if the specific gravity spread exceeds 0.030 after a full charge; follow your battery's manual before taking corrective action.
How often should you check?
Check stored flooded batteries regularly to monitor their condition and recharge them when needed. Trojan recommends checking specific gravity or voltage every 4 to 6 weeks during storage, while Rolls recommends specific gravity checks every 45 to 60 days, at least every 90 days. Since readings vary by chemistry, using a battery voltage chart by type helps you interpret measurements correctly and avoid applying lead-acid voltage standards to lithium batteries.
Watering, Equalizing, and Cleaning Terminals on Flooded Batteries
These are the main hands-on tasks involved in maintaining flooded lead-acid batteries. Watering replaces lost electrolyte water, equalization addresses certain cell imbalances, and cleaning helps maintain reliable electrical connections. Watering and equalization are not routine procedures for sealed AGM and gel batteries.
Watering With Distilled Water
Flooded lead-acid batteries lose water during use, particularly as gassing during charging causes water loss. Check the electrolyte level regularly and add distilled water when needed, following the battery manufacturer's recommendations. The manufacturer's instructions will specify when to add water, what type of water to use, and the correct fill level to prevent damage and maintain safe operation.
  • When to water: Trojan recommends watering after the charge cycle. If the plates are exposed before charging, add only enough water to cover them, then finish charging and top up as directed.
  • What to use: Add distilled water. Deionized water may also be acceptable under the manufacturer's instructions. Never add sulfuric acid during normal topping up.
  • How much to add: Trojan specifies approximately 1/8 inch below the bottom of the fill well, while Rolls specifies 6–13 mm below the vent tube. Follow your battery's manual and never fill the cap.
  • How often to check: Trojan recommends checking monthly until you understand the battery's water consumption pattern.
Equalizing a Flooded Battery
Equalization is a controlled overcharge that can help correct certain cell imbalances in flooded lead-acid batteries, but it should only be performed when recommended by the manufacturer. Trojan and Rolls have different voltage settings and thresholds, so always follow the instructions for your specific battery model. Monitor the process and stop when the manufacturer's completion criteria are met. Never equalize AGM or gel batteries unless the manufacturer specifically states that the particular model can be equalized.
Cleaning Terminals and the Case
Clean battery terminals and the case regularly using the method recommended by your manufacturer, such as baking soda and water. Keep the vent caps on during exterior cleaning to prevent the solution from entering the cells, and disconnect the battery safely before cleaning the terminals. Since common causes of battery corrosion include gas venting, overcharging, and moisture, inspect connections for buildup and apply a suitable anti-corrosion product after reconnecting them.
Storing Lead-Acid Batteries Between Seasons and Recycling Them at the End
A lead-acid battery slowly loses charge even when it is not being used, and heat accelerates that process. Leaving a seasonal boat, mower, or RV battery partly discharged for months can shorten its service life.
Storing Lead-Acid BatteriesStoring Lead-Acid Batteries
Storage checklist
  • Fully charge before storage: Charge the battery fully using the charging profile recommended by its manufacturer to help prevent damage during extended storage.
  • Choose a suitable location: Store the battery in a cool, dry, well-ventilated area, keeping flooded batteries upright and all batteries away from flames and sparks.
  • Schedule recharge checks: Trojan recommends recharging every three to six months during extended storage, while Rolls recommends every three months for stored flooded batteries.
  • Account for temperature and chemistry: At 77°F, Trojan reports monthly self-discharge of up to 15% for flooded batteries and less than 3% for VRLA batteries; Rolls report 10–12% for flooded batteries and about 2% for AGM batteries. These are manufacturer-specific figures, so follow your battery's manual.
Recycling a Worn-Out Battery
Replace lead-acid batteries that cannot hold a charge, show significantly uneven cell readings, or have cracked, bulging, or leaking cases. Before reusing a battery after winter storage, check its resting voltage and follow the steps to recharge a boat battery after storage. For disposal, the EPA advises returning lead-acid batteries to a battery retailer or local household hazardous waste collection program rather than placing them in household trash or municipal recycling bins.
Proper lead-acid battery maintenance depends on whether you have a flooded, AGM, or gel battery. Follow the manufacturer's instructions for charging, watering, specific gravity checks, terminal cleaning, and storage to help protect battery performance and lifespan. Check your battery label and schedule regular maintenance reminders. If you need portable power for small devices without routine watering or acid handling, the EcoFlow DELTA 3 Classic and DELTA 3 Max are alternatives worth considering for compatible loads.
How often should you add water to a lead-acid battery?
Check flooded batteries monthly until you understand their water consumption. Add distilled water as needed, generally after charging, following the manufacturer's specified fill level. AGM and gel batteries must not be opened or watered.
Can you use tap water in a lead-acid battery?
No. Use distilled water or another water type explicitly approved by the manufacturer, such as deionized water. Never add acid during normal electrolyte top-ups.
Do AGM and gel batteries need maintenance?
Yes. They need suitable charging profiles, clean terminals, condition checks, and periodic recharging during storage. They do not need watering or routine equalization.
How do I know if my lead-acid battery is fully charged?
For a flooded battery, use the manufacturer's specific gravity chart and rest voltage guidance. Trojan's reference for a fully charged 12V flooded battery at 80°F is approximately 12.73V and 1.277 specific gravity. Other designs may differ.
How long can a lead-acid battery sit without charging?
It depends on battery type, temperature, age, and connected loads. Trojan recommends a full charge every three to six months during extended storage, but warmer conditions and parasitic loads may require more frequent checks.
