What Is a Photovoltaic Power Station? How Solar Electricity Generation Works
As the world shifts to renewable energy, photovoltaic power stations are playing a central role, converting sunlight into usable energy.
But how do they work?
In this guide, we’ll go over the process to explain exactly how these power stations generate energy from the sun.
A photovoltaic (PV) power station is a large solar park or solar farm that generates power from PV solar panels.
Unlike traditional power plants that burn fossil fuels, these facilities use PV solar panels to harvest sunlight, converting it into energy that’s then stabilized and fed into the localized grid.
A portable power station is essentially a much smaller version. This consists of a small device with a battery and solar panels, like the EcoFlow DELTA Pro 3 Solar Generator. It uses the same PV technology as a larger station, but it works on a smaller scale.
An EcoFlow DELTA Pro 3 Solar Generator + 400W Solar Panel
How Do Photovoltaic Cells Generate Electricity?
While you probably know that solar energy comes from the sun, it’s the photovoltaic cell that’s at the heart of the system. Whether it’s used in a large-scale solar power station or a whole-home generator like the EcoFlow DELTA Pro Ultra X, this cell is made from semiconductor materials, usually silicon.
The photovoltaic effect is what generates electricity.
When photons from solar energy strike the photovoltaic cell, they are absorbed by the semiconductor material.
This absorption excites the electrons within the semiconductor, causing them to break free and flow. It’s this movement of electrons that generates electricity in direct current (DC) form.
This happens at the atomic level, with no moving parts and no noise, making solar generation reliable and low-maintenance.
A man installing portable solar panels and an EcoFlow DELTA Pro Ultra X in a garage
What Are the Main Components of a Photovoltaic Power Station?
A photovoltaic power station combines several components that work together:
  • Solar Panels or Modules: The main units that contain the PV cells to capture sunlight and convert it into DC electricity.
  • Mounting Equipment: The structural framework required to hold the panels in place. The panels are often tilted at an angle to maximize sun exposure.
  • Inverters: These critical components convert DC electricity into alternating current (AC), which is the form of electricity used by the grid and that we all use in our home appliances.
  • Wiring and Connections: This network of cables collects electricity from the panels and feeds it into the inverters.
  • Transformers: These are used to increase the voltage of the AC electricity so it can be transmitted efficiently over long distances.
  • Monitoring and Control Systems: These systems comprise specialized hardware and software to track energy production and identify where maintenance is needed.
What Are the Different Types of Photovoltaic Power Stations?
There are several types of photovoltaic power stations, which are categorized by their scale as well as installation method.
  • Ground-Mounted Stations: These are large solar farms where the panels are mounted on the ground in open areas. They take up a lot of land area, and they are designed to maximize output.
  • Distributed PV Systems: These power stations are smaller-scale installations that are often installed on commercial rooftops and feed power directly into the grid.
  • Floating Solar (Floatovoltaics): These are systems where solar panels are installed on floating structures like lakes and reservoirs. This saves land space while the water cools the panels to improve efficiency.
These are all very different from Concentrated Solar Power (CSP) plants. These are thermodynamic plants that use mirrors to focus sunlight to heat fluid, create steam, and drive a turbine. CSP plants rely on thermal generation instead of the direct photovoltaic effect.
How Efficient Are Photovoltaic Power Stations?
The efficiency of PV power stations refers to the photovoltaic panels and how much of the sunlight that hits the panels is converted into usable electricity.
Modern solar modules usually achieve anywhere from 21% to 24% efficiency. However, the efficiency depends on several factors:
  • Cell Technology: Advancements are pushing the boundaries significantly, especially relating to N-type silicon and heterojunction (HJT) cells.
  • Environmental Factors: Temperature, shading, and even dust accumulation can all reduce output.
  • Configuration: The layout and orientation of the panels can impact the capture rate, and they must be positioned optimally to capture the maximum amount of sunlight.
How Do Photovoltaic Power Stations Connect to the Grid or Battery Storage?
The PV power station is where the sunlight is converted into energy, but this energy must then be sent to the grid or battery storage so it can be used.
For this to happen, the DC power first travels to an inverter, where it is converted to AC. It then goes through transformers to match the voltage of the local grid.
However, if the station includes energy storage, the electricity is routed into large battery banks, which are usually lithium-ion based, and stored as DC or converted to AC before entering the grid.
This allows the facility to store excess energy during peak sunlight hours and release it during periods of high demand, providing greater stability.
Harness up to 2600W solar input via dual PV ports for flexible setups and faster charging with high conversion efficiency. Enjoy powerful AC output and 99% MPPT efficiency for optimal energy capture. Manage it all seamlessly through the app—monitor usage, set priorities, and stay powered effortlessly.
High-end commercial solar modules in 2026 reach efficiency rates of about 21% to 24%. The efficiency is affected by factors like the panel design and cell technology, which determine the real-world output.
What Is the Difference Between a Photovoltaic Power Station and a Solar Generator?
The main differences are scale and purpose. A photovoltaic power station is a utility facility connected to the grid and designed for large-scale energy production. A solar generator, on the other hand, is a compact and portable device that’s used to provide off-grid energy or a backup supply during outages.
Reliable Power, Lower Bills, and Energy Independence
By converting sunlight to clean electricity, photovoltaic technology provides a way to reduce reliance on fossil fuels. The same technology powering utility-scale solar farms can now work for individual homes.
If you want to generate solar power in your own home, explore a whole-home backup power solution from EcoFlow, which uses the same PV technology to help you keep your home powered during outages.
Solar Energy
