What Are the Causes of Wildfires in California?
What are the causes of wildfires in California comes down to two things happening together: something has to spark the fire, and the surrounding conditions have to let it spread. This guide covers the main causes, human activity, utility infrastructure, lightning, climate and drought, and wind, along with what wildfire risk means for power reliability across the state.
What Causes Wildfires in California?
What caused the California wildfires in any given season usually traces back to one of a handful of consistent factors. Each plays a different role. Some provide the spark. Others determine how far and how fast a fire travels once it starts.
Human Activity
Human activity is the leading cause of wildfires in California, accounting for roughly 95% of them according to Cal Fire and CalMatters reporting, though estimates from other agencies range closer to 85 to 90%. When people ask what is causing the California wildfires in a typical year, the honest answer starts here rather than with lightning or dry conditions.
Vehicles, power tools, campfires, debris burning, and discarded cigarettes are common ignition sources, and equipment sparks account for a meaningful share as well. Arson is a smaller factor, generally cited at around 6 to 10% of California wildfires in a given year, according to Cal Fire's law enforcement division.
Power Lines and Utility Infrastructure
Electrical lines and transformers can spark during high winds, equipment failure, or when struck by falling trees or debris. Utility-caused fires make up a minority of the state's total wildfire count, but they have been responsible for some of California's most destructive events. The 2018 Camp Fire, the deadliest wildfire in state history at 85 deaths, was traced to a failing PG&E transmission line in Butte County.
Lightning
Lightning is the primary natural, non-human cause of wildfires in California, and it plays an outsized role in remote and wildland areas that are harder to reach quickly. Dry lightning, storms that produce little or no rainfall, can ignite dozens of fires across a region in a single event.
Climate Change and Drought
Warmer temperatures, reduced precipitation, and longer dry seasons dry out vegetation and extend the length of fire season. Research from UC Irvine found that California's fire season now peaks in July rather than August, a shift from historical patterns. "Whiplash" weather, unusually wet years followed by dry ones, adds to the problem by encouraging vegetation growth that then dries into additional fuel.
Wind
Santa Ana winds in Southern California and Diablo winds in Northern California don't start fires on their own, but they dramatically accelerate how fast one spreads once it's burning. These dry, offshore winds can push fire growth to five to ten times its normal rate and carry embers far ahead of the main fire front, which makes containment significantly harder.
What Makes California Especially Vulnerable to Wildfires?
These individual causes overlap in ways that make California particularly exposed, which is part of why what's causing the wildfires in California is rarely a single-factor answer.
A large share of the state's development sits directly against wildland areas, known as the wildland-urban interface, which puts more structures within reach of a fire that starts in open land. California's dry season also runs longer than in most states, giving vegetation more time to dry out each year.
Decades of aggressive fire suppression policy, dating back to practices adopted in the 1930s, have also left many forests denser and more fuel-heavy than they would be under natural fire cycles. When a fire does start in that kind of landscape, there's simply more available to burn.
What Technologies and Strategies Are Being Used to Predict and Control Wildfire Spread?
Knowing what's causing the California wildfires is only half the picture. California has also invested heavily in tools designed to catch and manage fires earlier:
  • Early detection systems — ALERTCalifornia operates a network of more than 1,200 AI-powered cameras across the state, run through UC San Diego in partnership with Cal Fire, that can spot smoke and alert dispatchers within minutes, sometimes before a 911 call comes in.
  • Weather and fire behavior modeling — Predictive tools forecast fire spread based on wind, humidity, and fuel conditions, which agencies use to issue red flag warnings and guide evacuation planning.
  • Prescribed burns and fuel breaks — Controlled, deliberate burns reduce the amount of fuel available before a wildfire ever starts, limiting how much a future fire can consume.
  • Public Safety Power Shutoffs (PSPS) — Utilities proactively cut power in high-risk conditions to prevent their own equipment from sparking a fire, covered in more detail below.
  • Firefighting technology — Aerial retardant drops, drone-based real-time mapping, and improved coordination tools help crews respond faster once a fire is confirmed.
How Wildfire Risk Affects Power Reliability in California
Public Safety Power Shutoffs are a documented, ongoing practice, not a hypothetical. Utilities including PG&E, Southern California Edison, and San Diego Gas & Electric are authorized under California Public Utilities Commission rules to shut off power proactively when conditions such as high wind, low humidity, and dry vegetation raise the risk that their equipment could spark a fire. This is a direct response to what caused the California wildfires tied to utility equipment in past seasons.
Preparing for Power Outages During Wildfire Season
A PSPS event can last anywhere from a few hours to several days, and the exact timing is difficult to predict in advance. For households in higher-risk areas, having a backup power source on hand is a practical, straightforward part of preparing for wildfire season.
The EcoFlow DELTA Pro Ultra is built for higher-capacity, whole-home-oriented backup during extended outages.
6,144Wh base capacity, expandable up to 90kWh, with 7,200W AC output for whole-home circuits during extended, multi-day outages.
The EcoFlow DELTA Pro Portable Power Station offers a more flexible, mid-tier backup option for households that don't need whole-home capacity.
3,600Wh capacity, expandable up to 25kWh, with 3,600W continuous output for key appliances during a PSPS event.
It's also worth reading more about how wildfire-related power outages affect California households, and this overview of generators for power outages if you're weighing backup options more broadly.
What are the causes of wildfires in California comes down to a mix of factors rather than any single one: human activity accounts for the large majority of ignitions, utility infrastructure and lightning contribute a smaller but significant share, and worsening climate conditions have extended the length and intensity of fire season. Wind determines how fast a fire spreads once it starts, which is often the difference between a contained incident and a major one.
Understanding these causes also explains why proactive power shutoffs happen during high-risk conditions, and why many California households now plan around them as a normal part of wildfire season.
How many fires are in California in 2026?
As of mid-July 2026, Cal Fire's statewide archive showed roughly 3,473 wildfires and about 102,918 acres burned for the year, according to reporting that cited the agency's incident data. These figures are preliminary and change weekly as the season progresses, with activity typically increasing through August and September. For the most current count, Cal Fire's statistics page updates on a weekly basis.
What causes the majority of wildfires in California?
Human activity causes the large majority of California wildfires. Cal Fire and CalMatters reporting puts the figure at around 95%, covering everything from vehicles and equipment sparks to campfires and debris burning, while other federal agencies estimate a slightly lower 85 to 90% nationally. This is the clearest answer to what's causing the California wildfires in most seasons.
Why do California wildfires spread so quickly?
Dry vegetation, low humidity, and strong offshore winds, particularly Santa Ana winds in Southern California and Diablo winds in Northern California, combine to let fires spread rapidly once ignited. These winds can push fire growth to several times its normal rate and carry embers well ahead of the main fire, which is part of what's causing the wildfires in California to grow as large as they do once they start.
What are the top causes of wildfires in California?
The leading causes are human activity, power lines and utility infrastructure, lightning, and climate conditions such as drought and extended dry seasons. Wind is not itself an ignition source but is one of the biggest factors in how far and how fast a fire spreads once started. Taken together, this is what is causing the California wildfires that make headlines most years.
What are the five largest fires in California history?
By acreage, the five largest are the August Complex (2020, about 1,032,648 acres), the Dixie Fire (2021, about 963,309 acres), the Mendocino Complex (2018, about 459,123 acres), the SCU Lightning Complex (2020, about 396,625 acres), and the Creek Fire (2020, about 377,693 acres).
Home Backup
