Watt's Law vs. Ohm's Law: Formulas, Differences, and When To Use Each
Ohm's Law describes how voltage, current, and resistance relate in a circuit. Watt's Law describes how voltage and current produce power. Both laws use overlapping variables, and combining them gives you every formula you need to size a breaker, estimate an electricity bill, or pick the right portable power station for your home.
This article is for informational purposes only. Electrical work carries safety risks. For any wiring, circuit modification, or permanent installation, consult a licensed electrician and follow all applicable local codes.
What Is Ohm's Law?
Ohm's Law is the foundation of every circuit calculation. It connects three variables: voltage, current, and resistance. Named after German physicist Georg Simon Ohm, who published his findings in 1827, the law states that current increases when voltage rises, and decreases when resistance rises.
The Ohm's Law Formula and Its Three Forms
The core ohms law formula is:
V = I x R
V stands for voltage (measured in volts), I stands for current (measured in amps), and R stands for resistance (measured in ohms). Two rearrangements cover every other scenario:
  • I = V / R calculates current when voltage and resistance are known.
  • R = V / I calculates resistance when voltage and current are known.
A simple triangle with V on top and I and R on the bottom helps you remember all three. Cover the variable you want to find, and the remaining two show you the formula.
A Simple Way To Picture It
Electricity behaves like water in a pipe. Voltage is the water pressure pushing flow through the pipe. Current is the actual flow rate. Resistance is the narrowness of the pipe that restricts that flow.
A 120V household circuit with a device that has 20 ohms of resistance draws 6 amps of current (120 / 20 = 6). If resistance drops to 10 ohms, current doubles to 12 amps.
EcoFlow DELTA 3 Plus + 220W Portable Solar Panel
Get next-level battery safety & performance with X-Core 3.0 Technology. Fast-Charge using Solar, Grid, 800W Alternator Charger, Inverter Generators
What Is Watt's Law?
Watt's Law shifts the focus from resistance to power. Where Ohm's Law tells you how current flows through a circuit, Watt's Law tells you how much electrical work that circuit performs. The law is named after James Watt, the Scottish engineer behind the unit of power.
The Watts Law Formula and Its Three Forms
The core watts law formula is:
P = V x I
P stands for power (measured in watts), V for voltage, and I for current. Like Ohm's Law, the formula can be rearranged:
  • V = P / I finds voltage when power and current are known.
  • I = P / V finds current when power and voltage are known.
The power triangle works the same way as the Ohm's Law triangle. Place P on top and V and I on the bottom. Cover the unknown, and the remaining two variables show the calculation.
Why Power Affects Your Wallet and Your Circuits
Power determines two things most homeowners care about: electricity cost and device compatibility.
Your utility company charges by the kilowatt-hour (kWh). To find energy consumption, multiply watts by hours of use and divide by 1,000. A 1,500W space heater running 4 hours a day uses 6 kWh, which adds roughly $1.08 per day at approximately $0.18/kWh (U.S. average).
Power ratings also tell you if a circuit, outlet, or backup power source can handle the device you want to run. A portable power station rated at 1,800W can support any single appliance that draws up to 1,800 watts.
Watt's Law vs. Ohm's Law: What's the Difference?
Both laws describe how electricity behaves, but they answer different questions and involve different variables. Ohm's Law focuses on the relationship between voltage, current, and resistance. Watt's Law focuses on the relationship between power, voltage, and current.
Different Variables, Different Questions
Ohm's Law answers: "How much current will flow through this circuit?" It requires you to know resistance.
Watt's Law answers: "How much power will this device use or produce?" It does not involve resistance at all in its basic form.
Resistance (R) only appears in Ohm's Law. Power (P) only appears in Watt's Law. Voltage (V) and current (I) appear in both.
Side-by-Side Comparison Table
Feature
Ohm's Law
Watt's Law
Named After
Georg Simon Ohm (1827)
James Watt
Core Formula
V = I x R
P = V x I
Variables
Voltage, Current, Resistance
Power, Voltage, Current
Unit of Measure
Ohms
Watts
Primary Question
How much current flows?
How much power is used?
Typical Use
Wire sizing, circuit design, troubleshooting
Energy cost, appliance load, breaker capacity
Ohm's Law is the go-to formula for anyone working on circuit design or diagnosing electrical faults. Watt's Law is the go-to formula for anyone calculating power consumption or checking if a device fits within a circuit's capacity.
Why the Two Laws Seem To Contradict Each Other (and Don't)
A common point of confusion: Ohm's Law says that raising voltage increases current (when resistance stays constant). But Watt's Law seems to say the opposite, that raising voltage decreases current (when power stays constant). Both statements are correct because each assumes a different constant.
  • Under constant resistance, V goes up and I goes up (Ohm's Law).
  • Under constant power, V goes up and I goes down (Watt's Law).
The two laws do not conflict. They describe different scenarios. Any time you apply a formula, ask first: "What stays fixed in this situation?" The answer tells you which law to reach for.
Man playing video games with a TV and console powered by the EcoFlow DELTA 3 Classic portable power station in a cozy living room
How Ohm's Law and Watt's Law Work Together
Because both laws share voltage and current, you can substitute one into the other to create combined formulas. These derived equations let you solve problems even when you only know two out of four variables (V, I, R, P).
The Combined Formulas You Actually Need
Substituting Ohm's Law into Watt's Law produces two additional power formulas:
  • P = I² x R calculates power when you know current and resistance.
  • P = V² / R calculates power when you know voltage and resistance.
No new physics is involved here. These are the same two laws combined through basic algebra. Together with P = V x I, they form a complete set that covers every combination of known values.
Which Formula To Use: A Quick Decision Guide
The right formula depends on what values you already have:
  • Know voltage and current? Use P = V x I to find power directly.
  • Know voltage and resistance? Use P = V² / R to find power without measuring current.
  • Know current and resistance? Use P = I² x R to find power without measuring voltage.
  • Know power and voltage? Use I = P / V to find the current draw for breaker sizing.
  • Know power and current? Use V = P / I to find the required voltage.
This decision logic is the fastest path to the right answer. Pick your two known values, match them to the correct formula, and solve.
Practical Uses of Ohm's Law and Watt's Law at Home
Three everyday situations show how Ohm's Law and Watt's Law directly affect safety, cost, and convenience.
Sizing Circuits and Breakers
A 1,500W space heater on a standard 120V circuit draws 12.5 amps (1,500 / 120 = 12.5). A 15-amp breaker can technically handle that load, but electricians follow the 80% rule for continuous loads: only use up to 80% of the breaker's rating, which is 12 amps for a 15A breaker. That single heater already exceeds the safe continuous limit.
Adding a second device to the same circuit will trip the breaker. Watt's Law makes this easy to predict. For permanent installations, please consult a licensed electrician.
Estimating Appliance Power and Electricity Costs
To estimate monthly cost for any appliance, follow three steps.
  • First, find the device wattage (check the label or use I = P / V).
  • Second, multiply watts by daily hours of use and divide by 1,000 to get kWh.
  • Third, multiply kWh by your electricity rate.
A 1,500W space heater running 4 hours per day uses 6 kWh daily. At approximately $0.18/kWh (U.S. average), that costs about $1.08 per day or around $32 per month.
Choosing the Right Portable Power Station
To find the right backup power source, add up the wattage of every appliance you plan to run at the same time. That total is the minimum output wattage you need.
For example, running a 1,200W microwave and two 60W LED light setups at the same time requires 1,320W of output. The EcoFlow DELTA 3 Classic Portable Power Station (1024Wh) delivers 1,800W of continuous output with 3,600W surge capacity, so it handles that combined load with room to spare. Its 1,024Wh battery keeps that microwave and lights running for approximately 45 minutes or more on a full charge, depending on real-world conditions, and X-Boost™ supports devices drawing up to 2,600W. You can charge it from a wall outlet to 80% in 45 minutes, which keeps downtime short during outages.
Ohm's Law also applies here: longer or thinner extension cables increase resistance, which causes voltage drop and reduces the power reaching your devices. Keeping cable runs short and using proper gauge wire protects both performance and safety.
Charge to 80% in 45 mins, 1800W output, 10ms auto-switch, and whisper-quiet 30dB operation. Durable LFP cells, app control, and 5-year warranty.
Common Mistakes When Applying Ohm's Law and Watt's Law
Even simple formulas produce wrong answers when the inputs are wrong. Two errors show up repeatedly in online forums and DIY discussions.
Mixing Up DC and AC Calculations
The basic ohms law formula and watts law formula apply cleanly to DC (direct current) circuits. For AC (alternating current) circuits found in most U.S. homes, a factor called power factor (PF) affects the actual usable power. Devices with motors or compressors, like refrigerators and air conditioners, often have a power factor below 1.0. That makes the real power lower than a simple V x I calculation suggests.
For resistive loads like heaters and incandescent bulbs, PF is close to 1.0, so the basic formulas work fine. For reactive loads, the adjusted formula is P = V x I x PF.
Forgetting To Convert Units
Milliamps need to become amps in any formula. Kilohms need to become ohms. A reading of 500 milliamps is 0.5 amps, not 500. A 2.2 kilohm resistor is 2,200 ohms.
Always convert every value to base units (volts, amps, ohms, watts) first. This single habit eliminates the most common source of errors.
Put Ohm's Law and Watt's Law to Work Today
Ohm's Law handles voltage, current, and resistance. Watt's Law handles power. Together, they cover every basic circuit calculation a homeowner or DIYer needs, from breaker sizing to energy cost estimates. Apply these formulas to your next power decision, and check out the DELTA 3 Classic Portable Power Station (1024Wh) for backup power that matches the math.
FAQs About Watt's Law and Ohm's Law
Q1: Does Ohm's Law Apply to All Materials?
No. Ohm's Law applies to ohmic materials like most metals, where resistance stays constant across different voltages. Non-ohmic materials, such as diodes and transistors, have resistance that changes with voltage or current. For those components, the basic V = I x R formula does not hold.
Q2: Can You Use Ohm's Law in Both Series and Parallel Circuits?
Yes. Ohm's Law (V = I x R) applies to both series and parallel circuits, but total resistance is calculated differently. In a series circuit, resistances add up directly. In a parallel circuit, total resistance is lower than the resistance of any single component in the group. Apply the correct total resistance first, and the formula works the same way in both cases.
Q3: What Is the Difference Between Watts and Watt-Hours?
Watts measure the rate of power use at any given moment. Watt-hours measure total energy consumed over time. A 100W bulb running for 10 hours uses 1,000 watt-hours, or 1 kilowatt-hour (kWh). Watts tell you how fast energy flows. Watt-hours tell you how much total energy was used.
Q4: What Is the Difference Between Resistance and Impedance?
Resistance (R) opposes current flow in both DC and AC circuits and stays constant regardless of frequency. Impedance (Z) applies to AC circuits and accounts for additional opposition from components like capacitors and coils, beyond simple resistance. For everyday home calculations using Ohm's Law and Watt's Law, resistance is the value you work with.
Q5: What Happens if Resistance Increases in a Circuit?
Current decreases when resistance increases, assuming voltage stays the same. Ohm's Law (I = V / R) shows this directly. Higher resistance can result from corroded wiring, loose connections, or damaged components. Reduced current flow may cause devices to underperform or stop working entirely.
Save Bills
