Van Life & Overlanding This Spring: Solar Power That Travels With You
Spring marks the beginning of travel season for van lifers and overlanders eager to get back on the road after a quiet winter. With longer days, mild temperatures, and fewer crowds than summer, it’s the perfect time to explore remote landscapes and go off-grid. With solar panels and battery storage, you can go anywhere and never have to worry about recharging. This article will show you what to consider when choosing your solar setup and provide smart energy tips to help you get the most out of your system this spring. Also, we’ll find out how the EcoFlow DELTA 3 Max Plus can support you on your journey.
Why Spring Is the Perfect Season for Van Life and Overlanding
Spring is perfect for van life and overlanding because the weather is starting to warm, the sun is shining, and the backcountry has fewer crowds to better enjoy the sounds and smells of spring. You also don’t need as much heat now that chilly winter nights are over, and it’s too early to need air conditioning. All this makes it the perfect time to pull out your overland equipment checklist and hit the road.
The Power Challenges of Life on the Road
Life on the road creates challenges for power, especially for those of us who like to head off-grid with no access to a plug. But the good news is that power is easily obtained using solar panels and a battery storage system. With more daylight hours in spring, it also means more solar charging time, so you’ll never have to worry about energy no matter how long you go off-grid.
Why Solar Power Is Ideal for Van Life and Overlanding
Solar power is ideal for sustainable van life because you bring your power generator with you. No need to fill jerrycans or find shore power. Simply park and pop up your portable solar panels. Many van owners also install panels on their roof—no need to set them up over and over; you can even generate power when you drive!
Solar energy is also the ideal setup for those who go overlanding while working remotely. With the ability to generate your own energy, you can stay connected and keep working from deep in the forest or high on a mountain.
Finally, solar-powered generators operate at just above a whisper, so they won’t disturb the peace of your surroundings, and they’re even safe for use inside your van.
Setting Up a Solar-Powered Overlanding System
Calculate The System Size You Need
First, list every electric appliance, LED light, tablet, laptop, phone, etc. that you need electricity for. Find how many watts each requires, then multiply the wattage by the number of hours each appliance runs each day to get watt-hours (Wh). Finally, total up all your watt-hours, and that’s your absolute minimum daily capacity.
Choose Your Panels
Next, decide on portable panels and/or permanent roof panels, which may depend on energy needs, your van, and your budget. Always get 20% more than your minimum energy needs to account for less-than-optimal conditions. Also, high-quality panels with higher wattage and conversion efficiencies allow you to generate more power with less space.
Setting Up Battery Backup
A solar storage battery like the EcoFlow DELTA 3 Max Plus ensures you have power at night for lights, cooking, and entertainment. Starting at 2kWh of expandable capacity (to 10kWh) it’s the perfect van-life companion. And with 3000W of output, it should have no problem running any appliance you have. Keep your battery on the floor behind your seat for easy access when charging and discharging.
Positioning Solar Panels for Maximum Sunlight
Direct sunlight generates the most solar power, so position your panels at an angle facing directly into the sun. If you’re in a tricky location with shade, you may need to reposition your panels throughout the day to maximize production.
You can also recharge pulled over in parking lots or rest stops, setting up your panels while you eat lunch. This is where rooftop panels are helpful, since they can generate power all the time. However, since they are flat, they seldom get direct sun, which is why you may need a portable panel as well.
Tips for Getting the Most Out of Solar Power on the Road
  1. Choose a parking spot in direct sunlight wherever possible. In hot climates, look for morning sun and afternoon shade to balance solar generation and comfort.
  2. Angle the panels toward the sun instead of laying them flat.
  3. Reposition portable panels throughout the day if needed.
  4. Monitor energy usage and production via the EcoFlow app that comes with your battery storage system.
  5. Run high-energy appliances and recharge devices during the day when the sun is strongest to save battery storage for nighttime use.
  6. Use energy-efficient appliances and LED lighting.
  7. Use expandable systems so you can add another battery if your energy needs increase without redoing your whole system.
DELTA 3 Max Plus Portable Power Station
The EcoFlow DELTA 3 Max Plus delivers 3000W of reliable power (6000W surge) with X-Boost™ to handle heavy-duty appliances. Charge to 80% in just 43 minutes, expand up to 10kWh, and control circuits smartly via the app. Durable, whisper-quiet, and backed by up to 5 years of warranty, it’s power you can count on anywhere.
How Much Solar Power Do I Need for Van Life?
How much solar power you need depends on your energy needs. Basic van setups may only need 500W while a fully loaded van might need 5,000W. Look for solar arrays that produce your minimum power needs plus 20% extra to account for less-than-optimal conditions.
Is Solar Power Reliable Enough for Overlanding Trips?
Solar power is extremely reliable, especially when combined with a storage battery. At night or during a blizzard when snow completely covers the panels are the only times you can’t produce any power, and those issues are addressed using a storage battery.
Portable Solar Power Supports Off-Grid Travel and Van Life
Spring offers van lifers and overlanders the perfect opportunity to explore in pleasant weather before the busy peak season begins. Longer daylight hours, comfortable temperatures, and a solar-powered setup that travels with you make it easier to travel farther and stay off-grid longer than before. By pairing solar panels with smart energy use and a reliable portable power system like the EcoFlow DELTA 3 Max Plus, travelers can keep essential appliances and lighting running wherever the road brings them.
RV and Motorhomes
