Utah's Wildfire Season Started Months Early: Here's What's Burning Now
Most years, Utahns do not start thinking about wildfire season until July. This year is different. After the warmest and driest winter on record, fuels across Utah were dry enough to sustain fire conditions as early as March 2026, roughly four months ahead of the typical July through October window. If you live in the state, fire season did not wait for summer, and neither should your preparation. This article covers why the season came early, a statewide fireworks restriction, what is burning right now, and how to stay powered through the utah wildfires outages can cause.
A Season That Started in March, Not July
Have you noticed how brown the hillsides looked this spring? That was not your imagination. Several factors pushed fire conditions months ahead of schedule:
  • Record-warm winter. The 2025 to 2026 winter was the warmest on record for Utah, with snowpack across much of the state among the lowest ever measured.
  • Early snowmelt. Snow that should have been sitting in the mountains through May melted out early, and the vegetation that depends on that slow runoff dried out weeks ahead of schedule.
  • Historic dryness in the south. Southern Utah is dealing with some of the driest vegetation the region has seen in close to a century.
By March, fuels were ready to burn. That is four full months ahead of when Utah's wildfire season normally kicks in. The National Interagency Fire Center's wildfire outlook flagged above-average fire potential statewide heading into summer.
For households in fire-prone parts of the state, that early start changes the math on outages. Preventive shutoffs and downed power lines are a spring-through-fall concern now, and planning needs to start earlier too.
Planning for a Longer Outage Window
When wildfires utah communities are tracking get close to power infrastructure, two things can cut your electricity. The fire itself can damage transmission lines, causing outages that last a week or longer. Utilities also use preventive Public Safety Power Shutoffs (PSPS) to reduce ignition risk, and those events often run around 48 hours.
With fire risk starting months earlier than normal, households in fire-prone zones should be thinking about backup power as a spring-through-fall need, not something to sort out in August. One safety point that cannot be repeated enough: never run a gas or diesel generator indoors or in an attached garage. Carbon monoxide poisoning kills people during outages every year, and the U.S. Consumer Product Safety Commission has issued repeated warnings about generator-related CO deaths.
Battery backup systems run silently and produce zero fumes, which makes them a safer option for homes where ventilation is limited or smoke outside is already a concern. For a full checklist of what to power on the road and at evacuation shelters, EcoFlow's guide on wildfire evacuation and portable backup power essentials covers the basics.
If your household needs whole-home coverage that can hold up through multiple shutoffs across a long fire season, the EcoFlow DELTA Pro Ultra X was built for that kind of extended scenario. No fumes, no noise, and enough output to keep critical circuits running until power comes back.
Delivers 12kW of single-unit output with full 240V split-phase power, giving your entire home silent, carbon-monoxide-free backup during extended outages. Designed for households facing repeat Public Safety Power Shutoffs, it keeps refrigerators, medical equipment, lighting, and HVAC systems running without fuel, fumes, or generator noise throughout a long and unpredictable wildfire season.
When evacuation becomes the plan, the EcoFlow DELTA 3 Max Plus gives you 2,048Wh of portable capacity in a unit you can load into the car alongside your go-bags. It keeps phones, CPAP machines, and other medical devices charged wherever you end up.
EcoFlow DELTA 3 Max Plus (2,048Wh)
A compact, portable power station with 2,048Wh of capacity built for evacuation scenarios and shelter stays. Keeps phones, tablets, CPAP machines, and other medical devices charged when you need to leave home quickly. Light enough to load into your car alongside go-bags and supplies, so your household stays connected and powered wherever the evacuation route takes you.
If you want whole-home backup without the footprint of a larger system, the EcoFlow DELTA Pro 3 splits the difference, with 4,000W of split-phase 240V output that handles essential circuits like your fridge, well pump, and lighting.
EcoFlow DELTA Pro 3
Provides 120/240V split-phase output at 4,000W with a NEMA L14-30R 240V outlet, giving you whole-home backup in a smaller footprint. Ideal for households that need essential circuits running during wildfire outages without dedicating space to a full-size system. Covers refrigerators, well pumps, Wi-Fi routers, and lighting so daily routines continue uninterrupted when the grid goes down.
Why Utah Restricted Fireworks Statewide
Here is a number that should get your attention: human causes are suspected in roughly 75% of Utah's 2026 wildfires in utah so far. That means three out of every four fires this year were preventable, not just bad luck with lightning or weather.
Statewide restrictions help prevent new fires.Statewide restrictions help prevent new fires.
Governor Spencer Cox responded by announcing a statewide fireworks restriction in late June, citing historic utah wildfire conditions. Some cities kept local discretion over the exact rules, but the statewide order set a baseline that applied everywhere.
The takeaway goes well beyond fireworks, though. In a year this dry, any spark source carries outsized risk. Debris burning, dragging trailer chains on pavement, sparking equipment near dry grass: all of it can start a fire that spreads fast. Following current local restrictions is a practical requirement, not just a legal one
Fires Burning in Utah Right Now
If you have been watching the news, you know utah wild fires have been burning across multiple parts of the state. The biggest right now is the Widemouth 2 Fire near Fillmore in Millard County. It more than doubled in size within days, growing past 125,000 acres with only partial containment. That makes it the largest wild fires in utah fire of 2026 so far.
The Rocky Canyon Fire in Morgan County has closed state highways and threatened areas near the I-84/I-80 junction, with evacuations ordered in Henefer. Multiple other wild fires utah fires remain active statewide.
This season has also come at a real cost to firefighting crews. On August 7, a Sikorsky Skycrane helicopter supporting operations on the Widemouth 2 Fire in Utah's Fishlake National Forest crashed, killing the pilot and a crewmember. Both were employed by Helicopter Transport Services, a Forest Service exclusive-use contractor.
Evacuation Prep: Building Your Go-Bag
Whether or not a fire is near you yet, having a go-bag packed and ready can save critical minutes if an evacuation order drops. The five Ps give you a quick mental checklist: People, Pets, Prescriptions, Papers, and Priceless items. Think of it as the minimum you grab when time is short.
Keep vital documents (insurance policies, IDs, medical records) in a waterproof, fireproof bag somewhere easy to reach. If you have to hunt through a filing cabinet during a Level 3 evacuation, you have already lost time you cannot afford.
Sign up for your county's emergency text alerts now, before a fire threatens your area. Bookmark county-level evacuation resources while you are thinking about it, not in the middle of a crisis when cell service is spotty. Ready.gov's wildfire preparedness guide has additional checklists for building an emergency kit and mapping your routes.
For a deeper look at evacuation planning and getting your home ready, EcoFlow's article on wildfire season safety, evacuation tips, and home prep walks through the full process.
Hardening Your Home in a Historically Dry Year
Given how many of this season's fires trace back to human causes, hardening your property matters just as much as knowing when to leave. A few steps that make a real difference:
  • Create defensible space. Clear dead brush, dried-out vegetation, and anything flammable within at least 30 feet of your house. Embers travel well ahead of a fire front, so that buffer zone is what stands between airborne sparks and your walls.
  • Clean gutters and roof valleys. Accumulated debris catches embers fast, and most homeowners do not think to check until it is too late.
  • Screen your vents. Cover attic and crawl space vents with fine mesh so embers cannot blow in. Small job, but it makes a real difference when burning debris rains down from miles away.
Pay close attention to current local restrictions on fireworks, debris burning, and outdoor equipment use. Given this season's utah wild fire ignition rate from human causes, these rules carry more weight than usual. The CDC's guidance on protecting yourself during power outages is worth a read as part of your preparedness plan. If you are curious how home hardening grant programs work in other states, EcoFlow's overview of California wildfire home hardening grants and eligibility gives useful background.
Utah's 2026 fire season arrived months ahead of schedule after the state's warmest, driest winter on record, and with roughly 75% of this year's fires traced to human causes, the statewide fireworks restriction is just one piece of a bigger picture. Track active wildfires utah fires through KUER and Utah Fire Info, build a go-bag with the five Ps, follow every burn and fireworks restriction your county has in place, and treat backup power as a spring-through-fall need this year. If repeat outages are a real possibility for your household, whole-home options like the EcoFlow DELTA Pro Ultra X and portable stations like the DELTA 3 Max Plus and DELTA Pro 3 can keep you covered whether you shelter in place or hit the road.
What wildfires are currently burning in Utah?
As of mid-August 2026, several fires are active across the state. The Widemouth 2 Fire near Fillmore in Millard County is the largest, having grown past 125,000 acres with partial containment. The Rocky Canyon Fire in Morgan County has closed highways and triggered evacuations near the I-84/I-80 junction. Check KUER's wildfire tracker or Utah Fire Info for daily updates, since acreage and containment numbers shift quickly.
Why did Utah's 2026 fire season start so early?
The 2025 to 2026 winter was the warmest on record for Utah, with snowpack across much of the state at historic lows. That meant vegetation dried out months ahead of schedule, making fuels ready to burn as early as March instead of the typical July start. Southern Utah is experiencing some of the driest conditions in close to a century.
Why did Utah restrict fireworks statewide this year?
Human causes are suspected in roughly 75% of Utah's 2026 wildfires. Governor Spencer Cox announced a temporary statewide fireworks restriction in late June, citing the historic fire conditions. While some cities retained local discretion over specific rules, the statewide order set a baseline restriction to reduce preventable ignitions during an unusually dry year.
What should be in a wildfire evacuation go-bag?
Start with the five Ps: People, Pets, Prescriptions, Papers, and Priceless items. Keep important documents like insurance policies, IDs, and medical records in a fireproof, waterproof container. Add phone chargers, a battery backup or portable power station, cash, a change of clothes, water, and nonperishable snacks. Sign up for local emergency alerts and map your evacuation routes ahead of time.
Can a battery backup system keep my home powered during a wildfire-related outage?
Battery backup systems can run essential appliances during outages without the CO risk or fuel requirements of a gas generator. For whole-home coverage through extended or repeated shutoffs, you want a system with 240V split-phase output that can handle circuits like your fridge, lights, and medical equipment. The key is matching the system's capacity to what your household actually uses day to day. For evacuations, a portable power station keeps phones and medical devices charged at a shelter or in the car. Having both options covered gives you flexibility no matter how the season plays out.
Power Outages
