Oregon's Worst Wildfire Season on Record: What's Burning and What to Do About It
Over 2.24 million acres had already burned across Oregon by early August 2026, and by mid-August that number pushed past 2.3 million. That broke the previous state record, set in 2024, with roughly two months of fire season still to go. If you live anywhere in Oregon, you cannot afford to wait on preparation this year. Below, we cover how the record broke, which fires burning Oregon right now worry officials most, what the state's evacuation levels mean, and how to keep your household powered through a season that shows no sign of slowing down.
A Record That Wasn't Supposed to Break This Fast
Nobody thought 2026 would be easy. But blowing past the all-time record before mid-August? That caught even veteran fire watchers off guard. Oregon crossed the 2024 mark of 2,081,661 acres in early August, and the number keeps climbing. Between Oregon and Washington, over 3 million acres have burned this year, the worst combined total for both states in at least two decades.
What is fueling all of this? A handful of things hitting at once:
  • Shrinking snowpack. Snow has been melting earlier each spring, leaving grass, brush, and timber dry weeks sooner than they used to be.
  • Hot, dry, windy weather. Conditions this summer have made fuels catch faster and let fires run with almost no resistance.
  • Stubborn high-pressure ridges. Blocking patterns have cranked up the heat and starved the region of rain that normally slows fire growth.
  • A longer burn window. Early dryness on one end and late-season heat on the other mean fires ignite sooner and keep going deeper into fall.
For households across the state, the takeaway is not abstract. With roughly two months of season still ahead, the question is not whether oregon wildfires will keep burning. It is whether your family is actually ready for what could still come.
Staying Powered Through an Extended Fire Season
A record season stretches out the window for both wildfire-caused outages and preventive Public Safety Power Shutoffs (PSPS). If your home sits in a fire-prone zone, planning for one blackout is not going to cut it. Your utility might kill the power several times over weeks or months to lower ignition risk, and fires can knock out transmission lines on top of that.
Here is one thing you absolutely need to know: never run a gas or diesel generator inside your house or garage. Carbon monoxide poisoning kills people during outages every year, and the danger gets worse when wildfire smoke is already making it hard to breathe. The U.S. Consumer Product Safety Commission has put out multiple warnings about this.
Battery backup is a quieter, safer option. EcoFlow's guide on wildfire evacuation and portable backup power essentials walks through what you might need to power on the road and at a shelter.
If your household needs whole-home coverage that can hold up through multiple shutoffs across a full fire season, the EcoFlow DELTA Pro Ultra X was designed for that. No fumes, no noise, and enough output to keep your critical circuits going until power comes back.
Delivers 12kW of single-unit output with full 240V split-phase power, giving your entire home silent, carbon-monoxide-free backup during extended outages. Designed specifically for households facing repeat Public Safety Power Shutoffs, it keeps refrigerators, medical equipment, lighting, and HVAC systems running without fuel, fumes, or generator noise throughout a long and unpredictable wildfire season.
When you have to evacuate, the EcoFlow DELTA 3 Max Plus gives you 2,048Wh of portable capacity in a unit small enough to toss in the trunk next to your go-bags. It keeps phones and medical devices charged wherever you end up.
EcoFlow DELTA 3 Max Plus (2,048Wh)
A compact, portable power station with 2,048Wh of capacity built for evacuation scenarios and shelter stays. Keeps phones, tablets, CPAP machines, and other medical devices charged when you need to leave home quickly. Light enough to load into your car alongside go-bags and supplies, so your household stays connected and powered wherever the evacuation route takes you.
Maybe you do not need a full-size system but still want 240V backup for essential circuits. The EcoFlow DELTA Pro 3 splits the difference, with 4,000W of split-phase output that handles your fridge, well pump, and lights without taking up much space.
EcoFlow DELTA Pro 3
Provides 120/240V split-phase output at 4,000W with a NEMA L14-30R 240V outlet, giving you whole-home backup in a smaller footprint. Ideal for households that need to keep essential circuits running during wildfire outages without dedicating space to a full-size system. Covers refrigerators, well pumps, Wi-Fi routers, and lighting so daily routines continue uninterrupted when the grid goes down.
The Grasshopper Fire and the Portland Metro Threat
Most people picture wild fires Oregon deals with each summer burning through remote forests out east or down south. The Grasshopper Fire flipped that script. This one is burning near Mt. Hood National Forest, close enough to Portland that Oregon Air National Guard crews got called in for structure protection alongside regular wildland teams. That response tells you how different this fire is.
For anyone tracking fires near Oregon cities, this changes the calculus. Smoke, evacuation planning, and protecting homes hit differently when a fire burns near a dense population center. Even miles from the perimeter, a metro-adjacent blaze can choke air quality and snarl traffic well beyond the evacuation zone.
If you are anywhere near the Portland metro, keep a close eye on official channels. The Oregon Department of Emergency Management's wildfire page posts real-time evacuation level updates broken down by county and community.
The Rest of the State: What Else Is Burning
The Grasshopper Fire gets the headlines, but it is one of dozens of fires in Oregon burning right now. The biggest is the Rowe Creek Complex in central Oregon, which has scorched nearly 374,000 acres across Wheeler, Crook, Jefferson, and Wasco counties near the John Day Fossil Beds National Monument. As of mid-August, crews had it about 76 percent contained.
The Hay Creek Complex, Akawa Butte, Bench, and Hagen fires are burning across Gilliam, Wheeler, Wasco, Crook, Jefferson, and Umatilla counties. Around 48 wildfires were active as of early August, and containment on many of the biggest ones remains limited thanks to dry, windy weather that will not quit.
Note: Fire count, acreage, and containment figures move daily during an active record season. Confirm current status against the Oregon Department of Emergency Management or the Northwest Interagency Coordination Center before relying on specific numbers.
With that many fires now in Oregon going at once, understanding the state's evacuation system matters more this year than most.
Oregon's Evacuation Levels: Be Ready, Be Set, Go
Oregon runs a three-level evacuation system, and if you live in a fire-prone part of the state, this is the year to memorize it. Especially with this many fires on Oregon landscapes burning at once.
Stay Ready During Wildfire SeasonStay Ready During Wildfire Season
  • Level 1 (Be Ready): Pay attention to conditions. Watch local news and emergency alerts. Get a go-bag packed and by the door. You do not have to leave yet, but you should be able to walk out fast if things change.
  • Level 2 (Be Set): Things have gotten worse. You could need to leave any minute. Load the car and have everyone ready. If you have pets, livestock, or anyone with mobility issues, seriously consider leaving early.
  • Level 3 (Go Now): Get out. This is not a suggestion. Take your designated route and do not stop to grab one more thing.
The five Ps help you grab what counts: People, Pets, Prescriptions, Papers, and Priceless items. Ready.gov's wildfire preparedness guide has checklists for building an emergency kit and mapping evacuation routes ahead of time.
For a deeper look at evacuation planning and home readiness, EcoFlow's article on wildfire season safety, evacuation tips, and home prep breaks it all down step by step.
Reducing Risk Before the Next Red-Flag Day
There are also hands-on steps you can take right now to lower your wildfire risk before the next red-flag warning hits.
Start with defensible space. Clear dead brush, dried-up vegetation, and anything flammable within 30 feet of your house. Push that buffer further if you can, because embers travel well ahead of the fire front. The National Interagency Fire Center's wildfire mitigation guide lays out recommendations for building effective buffer zones.
Clean out your gutters and roof valleys. Screen attic and crawl space vents so embers cannot blow in. Small jobs, but they make a real difference when burning debris rains down from miles away.
Look into your county's burn restrictions too. Jackson and Josephine counties have put restrictions in place as early as May in recent years. If you want to learn how home hardening grants work, EcoFlow's overview of California wildfire home hardening grants and eligibility gives useful background. The CDC's guidance on protecting yourself during power outages is worth a read as part of your plan.
Oregon's 2026 fire season has torn up the record books, and there are still weeks of fire weather ahead. Know your evacuation level, have a plan for each stage, and get your property hardened before the next red-flag warning. If repeat outages are a real possibility this year, figure out backup power now instead of scrambling when the lights go dark. Options like the EcoFlow DELTA Pro Ultra X and portable stations like the DELTA 3 Max Plus and DELTA Pro 3 give you coverage whether you ride it out at home or hit the road across a season that is nowhere near finished.
What wildfires are currently burning in Oregon?
As of mid-August 2026, about 48 wildfires were going across the state. The Rowe Creek Complex in central Oregon is the biggest at close to 374,000 acres. The Grasshopper Fire near Mt. Hood, the Hay Creek Complex, and fires in Umatilla County are the ones officials watch most closely. Check the Oregon Department of Emergency Management for daily updates because things shift fast.
Is a wildfire threatening the Portland metro area right now?
The Grasshopper Fire, burning near Mt. Hood National Forest, has gotten attention because of how close it sits to the Portland metro region. It has not pushed into metro neighborhoods, but its proximity has set off air quality warnings, structure protection operations, and higher evacuation awareness across nearby communities.
Why has Oregon's 2026 wildfire season broken the all-time record?
The state blew past its old record of 2,081,661 acres (from 2024) by early August. Snowpack has been shrinking and melting earlier for years, leaving fuels dry for longer stretches. Layer this year's punishing heat, low humidity, and persistent wind on top of that, and you get a total past 2.3 million acres with a lot of fire season still left.
What do Oregon's Be Ready, Be Set, and Go Now evacuation levels mean?
Level 1 (Be Ready) means stay alert and keep a go-bag packed. Level 2 (Be Set) means get ready to walk out any second, car loaded and essentials staged. Level 3 (Go Now) means leave right now, no hesitation. If you have pets, livestock, or anyone with mobility challenges, think about leaving at Level 2 rather than waiting.
Can a battery backup system keep my home powered through repeat wildfire outages?
Battery systems run your essential appliances during outages without the CO risk or fuel hassle of a generator. For whole-home coverage through repeated blackouts, you want a larger system with 240V split-phase output that handles your fridge, lights, and medical equipment. The trick is sizing it to what you actually use. If you evacuate, a portable power station keeps phones and medical devices charged at a shelter or in the car. Having both bases covered gives you options no matter how the season plays out.
Power Outages
