Smart Inlet Box: The Retrofit Solution for EcoFlow DELTA Pro 3
The EcoFlow Smart Inlet Box is an electrical solution that makes connecting your EcoFlow DELTA Pro 3 to your home’s electrical panel simpler than ever before. By directly tying your power sources to your electrical panel, it allows for automatic switchover during an outage, so your essential appliances keep running whether you’re home or not. This article explains how these components work and how they integrate with your power station and electrical panel to help you create an efficient, reliable backup system.
EcoFlow DELTA Pro 3
What Is the EcoFlow Smart Inlet Box, and Why Does It Matter?
What Is the EcoFlow Smart Inlet Box Designed to Do?
It’s designed to connect a generator to household electrical panels without needing a smart panel or transfer switch for fewer installation complexities.
Which Home Energy Setups Benefit Most?
If you chose a home backup system for running essential appliances but now want the convenience of integrating it into your household electrical system without a major overhaul, this would benefit you. This also includes homes without smart panels or transfer switches, homes with hybrid battery and generator backups, and retrofits in finished homes where new wiring might be costly or invasive.
What Key Features and Specs Should You Know?
Here are some key features to consider before purchasing.
Power Capacity Interfaces and Supported Configurations
Look for a high load capacity, like those that deliver 150A through three 50A interfaces. Also ensure it offers real-time monitoring and control of those interfaces.
Your EcoFlow Smart Inlet Box supports your portable power station and electrical panel, making it easy to connect your EcoFlow DELTA Pro 3 directly to your electrical panel.
How Do Bidirectional Power Flow and Source Switching Work?
Bidirectional power is what allows energy to flow into your system from your backup generator or battery and then out to your household's circuits when needed, ensuring power flows safely without backfeeding into the grid.
Source switching simply means you can switch between the grid, generator, or batteries. This is critical for any backup system, but especially hybrid systems using multiple power sources.
How Do You Install the EcoFlow Smart Inlet Box?
Installation Requirements and Retrofit Planning
  1. Assess your electrical panel and which loads are essential.
  2. Check your local codes to see if you need an electrician.
  3. Choose a safe and compliant mounting location.
  4. Turn off your main power.
  5. Install the box and wire it to your home’s electrical panel.
  6. Connect your EcoFlow DELTA Pro Series to the inlet box via the built-in NEMA L14-30R split-phase socket.
  7. Configure how the system will switch between power sources.
  8. Perform a test outage to confirm it’s working as intended.
Do You Need an Electrician for Installation?
While installation is simpler than many electrical installations, it does require working with your household electrical panel. For most homeowners, and depending on your local codes, this typically means hiring a licensed electrician.
How Does It Work With EcoFlow DELTA Pro 3 and Smart Home Panels?
The system is designed to seamlessly integrate with the EcoFlow DELTA Pro 3 portable power station using the built-in NEMA L14-30R split-phase interface to connect it directly to your household electrical circuits.
How Does Smart Home Panel Integration Support Whole Home Backup?
Since it is also designed to seamlessly integrate with the EcoFlow Smart Home Panel, this allows you to set up a fully automated whole-home backup solution since it allows you to monitor and prioritize critical loads from an app on your phone, significantly extending your backup runtime.
Smart Inlet Box vs Other Backup Connection Options?
You can use a smart home panel or a transfer switch to connect your whole-home generator to your electrical panel, but they require electrical overhauls.
Smart Inlet Box vs Standard Inlet Boxes and Manual Transfer Setups
Standard inlet boxes and manual transfer setups require manually flipping switches or using plugs during an outage. So, if you’re not home when the outage occurs, your essential appliances won’t run. The EcoFlow Smart Inlet Box allows for automation of power switchovers.
When Is the Smart Inlet Box Worth It?
It is preferred anytime you want automatic switchovers or the ability to prioritize circuits. It’s also the easiest way to connect your backup to your household electrical system without a major electrical system overhaul.
Is the EcoFlow Smart Inlet Box Compatible With Older EcoFlow Systems?
While it is primarily designed to work with newer EcoFlow systems, you may still be able to use legacy systems by using an EcoFlow input/output power cable to connect them.
Can I Use the EcoFlow Smart Inlet Box With a Generator?
Yes, the EcoFlow Smart Inlet Box is designed to switch power sources between the grid, batteries, or generators, allowing you to set up hybrid power systems with multiple sources.
Does the Smart Inlet Box Support Solar Input or Solar Charging?
While you cannot plug solar directly in, you can charge your battery using solar, and then the EcoFlow Smart Inlet Box will use your solar-powered battery to run essential appliances via your household electrical panel.
What Is the Difference Between an Inlet Box and a Transfer Switch?
A transfer switch is a physical switch that manually turns on/off household backup power, while a standard inlet box is a weatherproof plug installed outdoors to plug a generator into. However, a smart inlet box is like an automatic transfer switch, requiring no manual flipping.
EcoFlow DELTA Pro is a portable home battery built for plug-and-play backup, delivering 3,600–7,200W AC output to run 99% of appliances. Expand capacity from 3.6kWh up to 25kWh with Smart Extra Batteries, recharge fast with up to 6,500W MultiCharge (as little as 2.7 hours via AC), and even top up at thousands of EV charging stations—powered by a long-lasting LFP battery designed to support up to 10 years of use.
Ready to Retrofit With EcoFlow DELTA Pro 3?
The ability to retrofit your EcoFlow DELTA Pro 3 with a smart inlet box, transforming it into an automatic backup power source for essential appliances, is revolutionary. No more fumbling in the dark for your transfer switch or power cords, or going outdoors in the cold or heat to fill and start a traditional generator. With an easy, inexpensive retrofit, you can simplify home backup without compromising safety or convenience. Whether starting from scratch or retrofitting your EcoFlow DELTA Pro 3, the EcoFlow Smart Inlet Box provides a smarter, safer, and more efficient household backup system.
Portable Power Stations
