RV Breaker Box Guide: Finding the AC Breakers and 12V Fuses and Fixing Trips Safely
The microwave and the air conditioner run at the same time. Then everything goes quiet, and nobody knows where the panel is. Most campers pack two systems into one box. The 120V AC breakers get power from shore power or a generator. The 12V DC fuses get power from the converter and the house battery. This guide maps what each side protects and where to look for your RV breaker box. It covers which checks are safe for owners, when to stop and call a technician, and how to keep essentials running while you wait.
What is inside an RV breaker box?
In many travel trailers, the RV breaker box is part of a power center. That unit also holds the converter and the 12V fuse board. The AC side protects 120V circuits, such as outlets, the microwave, and the air conditioner. The DC side protects 12V circuits, such as lights, the water pump, and fans.
Here is one common example, the WFCO WF-8900 power center:
Part | Voltage | What the manual says |
AC main breaker | 120V | One 30 Amp main breaker |
AC branch breakers | 120V | Up to nine branch circuits with duplex breakers, maximum 20 Amp each. Accepts listed standard residential breakers |
DC fuse board | 12V | Eleven circuits: two up to 30 Amp (F10 and F11, for slide-outs or higher loads) and nine up to 20 Amp |
Blown fuse indicator | 12V | A red LED by each DC fuse lights when that fuse blows |
Converter | 120V in, 12V out | Charges the house battery. Works even without a battery installed |
Source: WFCO WF-8900 Series Operator’s Manual.
This is only one example. Other brands, such as Progressive Dynamics, differ. Not every RV has a 30 Amp main, either. A 50 Amp RV uses a different panel, so check the label on your own unit.
30 amp and 50 amp service in watts
Your service size sets the limit for everything on the AC side. The math is simple.
30A service: 30A × 120V = 3,600W for the whole AC side.
50A service: two 120V legs of 50A each. 2 × 50A × 120V = 12,000W in total.
Appliance labels show the real watts. Add them up before you run several at once. For more detail, see the differences between 30 and 50 amp systems for RVs.
Knowing what the panel does is only useful if you can find it in a hurry.
RV breaker box location and RV fuse panel location
Makers tuck the camper electrical panel out of sight. So owners often search for it in the dark. Find yours before the first trip and add it to your checklist.
Place to check | Often found in |
Low on a wall or under the refrigerator | Travel trailers and fifth wheels |
Inside a cabinet, pantry, or near the entry door | Many layouts |
Under the bed or a dinette seat | Class C motorhomes, fifth wheels, compact trailers |
Exterior storage bay | Some Class A motorhomes |
Source: RVshare.
These are common spots, not a rule. Your owner’s manual or the maker gives the reliable answer. Some RVs keep the 12V fuse panel apart from the AC breakers. Motorhomes also have chassis fuses for the engine side. Check your manual for exact locations.
Makers also set rules for where a power center can go. Progressive Dynamics says its PD4000 must not be mounted in the LP gas or battery compartment. It is made for an interior, dry spot.
Add the panel to your ultimate RV checklist, so you find it before the trip and not during an outage.
Once you know where it is, the next question is what you can safely do when something trips.
When a breaker trips or a fuse blows, safe checks and when to stop
A trip or a blown fuse means the panel is doing its job. Owners can reduce the load and reset a closed-panel breaker once. Before removing or replacing a 12V fuse, switch off the affected loads and follow your RV manufacturer’s procedure to isolate every source that can feed the circuit, including the battery and any converter, shore-power, generator, inverter, or solar supply fitted to your RV. Jayco’s 2025 towable manual, Electrical section: Replacing a fuse requires shore-power disconnection, inverter shutdown, and battery-negative disconnection before fuse removal. Use only the specified fuse voltage, amperage, and type. If you cannot identify or safely isolate the sources, leave the fuse replacement to a qualified RV technician. Opening or servicing the electrical panel also belongs to a qualified technician.
Checks an owner can do
Turn off big loads, such as the air conditioner, microwave, and kettle, before you reset.
Reset the breaker by switching it fully off, then on.
Check the campground pedestal breaker too if the whole RV loses power.
Never fit a larger fuse or breaker. Never use a jumper or any other way around protection.
Stop and call a technician when
A breaker trips again right after a reset with the loads off.
A replacement fuse blows again.
You see scorch marks, smell burning, or feel heat on the panel.
There is a short circuit. WFCO says short circuits are dangerous and the RV needs inspection by a qualified service technician.
Do not remove the panel cover or swap breakers yourself. Breaker work is for a qualified technician. They should have shore power unplugged, the generator stopped, and any inverter off first.
Keeping essentials going while the panel waits for service
Sometimes a circuit stays off until a technician arrives. You can run separate devices from a portable power station in the meantime. Plug them straight into the unit. It never connects to the open or faulty panel, or to the RV’s wiring. Do not plug the RV’s shore cord into it either.
The table below shows rough runtimes. The loads are example values, and 0.85 is an assumed conversion efficiency.
Setup | Example load | Calculation | Estimate |
EcoFlow DELTA 3 Classic (1024Wh) | LED lamp 20W + laptop 45W + phone charging 15W = 80W | 1,024Wh × 0.85 ÷ 80W | About 10.9 hours |
EcoFlow DELTA 3 Ultra Plus (3072Wh) | Portable fridge averaging 45W + the same 80W = 125W | 3,072Wh × 0.85 ÷ 125W | About 20.9 hours |
EcoFlow DELTA 3 Ultra Plus (3072Wh) | Electric hot plate on a 1,500W setting | 3,072Wh × 0.85 ÷ 1,500W | About 1.7 hours of cooking time |
Check each appliance’s running and starting watts against the unit’s outlets and output before you plug in.
Two EcoFlow DELTA 3 models run separate devices while you wait, split by load size.
Here is how the two divide the job. The EcoFlow DELTA 3 Classic suits low loads, such as lights, phones, a router, and a laptop. The EcoFlow DELTA 3 Ultra Plus suits owners who also need a compatible fridge and a cooking appliance. In that case, the combined running and starting watts, or the energy needed, is clearly higher. Both run only the separate devices plugged into them, never the panel under repair. Runtime is limited by capacity.
For how breakers relate to wire size, see 30 amp breaker wire size.
Owners who know home panels often ask how an RV breaker panel differs.
RV breaker panel vs a home breaker panel
The AC breakers in an RV can look just like household ones. Some RV panels even accept listed residential breakers. The real differences are the smaller main, the built-in converter and 12V fuse board, and the power source: shore power or a generator.
Point | Typical RV power center (WFCO WF-8900 example) | Home panel |
Main breaker | 30 Amp main | Usually much larger |
Branch breakers | Up to nine, maximum 20 Amp, listed residential types | Many more circuits |
12V side | Built-in DC fuse board and converter | Usually none |
Power source | Shore power cord or generator | Utility service |
Never connect an RV to a house panel. Never back-feed power through an outlet. Both are dangerous and can hurt people or damage equipment.
Plugging in at a campground is covered in the RV electric hookup guide.
For owners thinking about a new or upgraded panel, the rule is simple: plan it with a professional.
Replacing or upgrading a camper breaker panel
A new breaker panel for RV use can add circuits or a better converter. But it touches 120V and 12V wiring at once. So this section covers what to discuss with the technician, not how to wire it.
Match the service. Pick 30A or 50A, and count the AC and DC circuits you need.
Mount it where the maker allows. Progressive Dynamics says its PD4000 is not ignition protected. It must not go in the LP gas or battery compartment. It needs ventilation and an interior, dry location.
Check the charging profile. The converter should suit your house battery chemistry.
Hire a licensed pro. Progressive Dynamics recommends a licensed electrician or RV technician for installation.
Source: Progressive Dynamics PD4000 manual.
The converter's role is explained in converter vs inverter.
An RV breaker box usually combines 120V AC breakers and 12V DC fuses. Each trip or blown fuse is protection doing its job.
Before your next trip, find your panel and fuse board and learn your service size. Reset a closed-panel breaker only once. Before removing a fuse, turn off the affected loads and isolate all circuit power sources according to your RV’s manual; replace it only with the specified voltage, amperage, and type. Use a qualified RV technician if you cannot safely isolate the circuit, if the breaker trips again, or if there is a short circuit.
If you need lights, phones, and a laptop to keep running while you wait for repairs, consider the EcoFlow DELTA 3 Classic. If a fridge and cooking must keep going, look at the EcoFlow DELTA 3 Ultra Plus.
Where is the breaker box in a travel trailer?
Often low on a wall, under the refrigerator, in a cabinet near the door, or under the bed. Your owner’s manual gives the exact place.
Where is the RV fuse panel location?
In many trailers, the 12V fuses sit in the same power center as the AC breakers. Some RVs have a separate fuse panel. Motorhomes also have chassis fuses.
Why does my RV breaker keep tripping?
Usually it means too many large loads at once. If it trips again with loads off, or a fuse keeps blowing, stop. Have a qualified RV technician check for a short.
Can I use a higher-rated fuse if one keeps blowing?
No. Before removing a blown fuse, turn off the affected loads and isolate all sources feeding that circuit according to your RV manufacturer’s manual. Replace it only with the specified voltage, amperage, and type. If it blows again, stop using the circuit and have a qualified RV technician check for a short or overload. If you are unsure how to isolate the circuit safely, have the technician replace the fuse.
Can a portable power station replace my RV breaker box?
No. It does not protect circuits. It can run separate devices plugged into it, such as lights or a compatible fridge, while the panel waits for repair.
