What Is a Group 27 Battery? Sizing, Capacity and Use in RVs and Boats
An RV owner shopping for a replacement battery might find two Group 27 models rated at 100Ah, yet one weighs much more than the other. That difference often comes down to chemistry. The group number tells you about the battery's case size and terminal layout, while its chemistry affects weight, maintenance, and how much energy you can use. If you're comparing a group 27 deep cycle battery for an RV or boat, start with the fit, then look at usable watt-hours. Those two details will help you choose a battery that matches your setup instead of paying for capacity you don't need.
What is a group 27 battery?
What is a group 27 battery?What is a group 27 battery?
Group 27 is a Battery Council International (BCI) size designation used for batteries in RVs, boats, and other applications. It's common in RV house-battery setups and marine systems that power accessories or trolling motors. The number identifies a general case size and terminal arrangement, not the battery's chemistry, capacity, or purpose. Battery dimensions can vary by model, so don't assume every Group 27 battery will fit the same compartment. Check the manufacturer's specifications and measure your existing tray before ordering.
Example battery (maker page)
Chemistry
Length x width x height
Weight
Trojan 27TMX (12V)
Flooded lead-acid
12.84 x 6.60 x 9.74 in (326 x 168 x 247 mm)
55 lb (25 kg)
Battle Born BB10012 100Ah 12V
LiFePO4
12.76 x 6.86 x 8.95 in
31 lb
These manufacturer-listed examples show why it's worth checking the actual model rather than relying on a generic Group 27 measurement. The Battle Born battery is about 24 pounds lighter than the Trojan example, although the two batteries use different chemistries and have different capacities. Before buying, check four things:
  • Tray and hold-down: Make sure the case fits, and the battery can be secured.
  • Lid clearance: Leave enough room above the terminals and any required connections.
  • Terminal layout: Confirm the posts match your cables and the cable ends can reach without strain.
  • Battery purpose: Check whether the model is deep-cycle, starting, or dual-purpose.
Group 27 deep cycle battery 100Ah: What can you really use?
A 100Ah rating doesn't tell you how much energy you'll get from a battery in everyday use. Voltage matters, and so does the recommended depth of discharge. Converting amp-hours to watt-hours makes it easier to compare a flooded battery with a lithium model.
Use this formula: Watt-hours (Wh) = amp-hours (Ah) × voltage (V). For example, a 12V battery rated at 100Ah stores about 1,200Wh of nominal energy. How much of that energy you should use depends on the manufacturer's guidance and the battery's chemistry.
Comparing usable energy
Battery
Rated capacity
Calculation
Approximate usable DC energy
Trojan 27TMX flooded lead-acid
105Ah at the 20-hour rate, 12V
105Ah × 12V = 1,260Wh; use 50%
About 630Wh
Battle Born BB10012 LiFePO4
100Ah, 12.8V nominal
100Ah × 12.8V = 1,280Wh; rated for 100% depth of discharge
Up to about 1,280Wh based on the rating
These are estimates based on manufacturer specifications, not a guarantee of the energy you'll get in every situation. Trojan generally recommends discharging its lead-acid batteries by about 20% to 50% for the best service life, though deeper cycling is possible under its stated conditions. Battle Born lists 100% usable depth of discharge for its BB10012 lithium battery. The practical difference is substantial. You may need a larger lead-acid bank to get the same usable energy as a lithium battery. On the other hand, lithium usually costs more upfront, and switching from lead-acid may require changes to your charging setup.
Upgrade the group 27 bank or add separate 120V power?
The right choice depends on what you're trying to run. If your RV's lights, water pump, and other 12V equipment need more runtime, upgrading the house battery bank may be the better route. If you mainly want to run a laptop, portable fridge, or cooktop without changing the RV's wiring, a separate power station may be more convenient.
Question
Upgrade or add group 27 batteries
Separate portable power station
What it powers
The RV or boat's own 12V system and its inverter, if fitted
Only the devices plugged into it
Installation
Tray space, cables, fusing and charger profile; often an RV or marine technician
No wiring into the vehicle
Mixing with the old battery
Makers advise matching batteries in a bank; check the manual
Never parallel it with the RV or boat battery
Where it can sit
In the battery compartment
Inside, dry and ventilated; not an exposed deck or battery box
A portable power station doesn't replace a Group 27 battery, start an engine, or connect directly to the RV's 12V system. It supplies power to compatible devices plugged into its outlets. Keep the two systems separate.
Setup
Example load
Calculation
Estimate
EcoFlow DELTA 3 Max (2048Wh)
Portable fridge averaging 45W + laptop 60W + LED lamp 20W = 125W (example values)
2,048Wh x 0.85 / 125W
About 13.9 hours
EcoFlow DELTA 3 Ultra Plus (3072Wh)
The same 125W
3,072Wh x 0.85 / 125W
About 20.9 hours
Induction cooktop on a 1,500W setting (example value)
3,072Wh x 0.85 / 1,500W
About 1.7 hours of cooking time
These estimates give you a starting point, but actual runtime depends on your appliances and how much power they draw. The EcoFlow DELTA 3 Max suits everyday loads like a portable fridge and laptop, while the EcoFlow DELTA 3 Ultra Plus offers more capacity for higher-demand appliances.
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
If you need more capacity for longer trips or higher-demand appliances, the EcoFlow DELTA 3 Ultra Plus offers a larger battery and expandable storage.
•Smart Output Priority: Choose in the app which outputs stay powered to stretch runtime when it counts. Controlling home circuits requires a compatible home connection installed by an electrician. • Expandable Capacity: 3kWh base, expandable to approximately 11kWh. Pairs with a compatible EcoFlow Smart Generator for automatic start and stop. •6 Ways to Charge: Reaches 0 to 80% in 48 minutes with combined solar and generator charging.
The EcoFlow DELTA 3 Max can handle everyday loads like a compatible portable fridge and laptop. The EcoFlow DELTA 3 Ultra Plus offers more capacity for higher-demand devices, such as a compatible induction cooktop or power tools. Neither replaces your Group 27 battery or connects to the RV or boat's battery system. To compare capacity accurately, see our guide to battery amp-hours. On a boat, a Group 27 battery has a different job, and choosing the right battery type matters.
Deep cycle marine battery Group 27: Trolling motors and boat use
On a boat, a Group 27 battery may power a trolling motor, fish finder, lights, or other accessories for hours at a time. That's why a deep-cycle model is often a better fit for accessory loads than a starting battery, which is designed to deliver a short burst of high current to start an engine. Before choosing a deep-cycle marine battery Group 27, make sure it matches the job and the boat's electrical requirements.
Deep-cycle, starting, or dual-purpose?
Batteries serve different purposes on a boat, so choose one based on whether you need to power accessories, start an engine, or do both.
  • Deep-cycle battery: Designed to provide sustained power over time and tolerate repeated discharging within the manufacturer's limits.
  • Starting battery: Designed to deliver a strong burst of current to start an engine. Repeated deep discharges can shorten its life.
  • Dual-purpose battery: Offers a compromise between starting power and deep-cycle use. Check the model's specifications to see whether it suits your needs.
Don't assume a deep-cycle battery can start your engine. Use the type specified by the engine or boat manufacturer.
How to estimate trolling motor runtime
Estimate runtime by dividing usable amp-hours by the motor's current draw. For example, 50Ah of usable capacity at a 10A draw gives about five hours, though speed, wind, and boat weight affect actual runtime. Check the motor's manual for voltage, cable size, and circuit protection. A 24V or 36V motor may require two or three 12V batteries wired in series.
How to charge and care for a Group 27 RV battery
Battery care depends on chemistry, but two habits help across most setups: use the correct charging profile and avoid leaving the battery discharged for long periods. Storage conditions matter, too, especially during freezing weather or hot summers. If you're still deciding which battery suits your camping setup, see our guide to RV batteries for dry camping.
How to charge and care for a Group 27 RV batteryHow to charge and care for a Group 27 RV battery
Flooded lead-acid batteries
Flooded batteries need regular checks and proper ventilation while charging. Trojan recommends checking electrolyte levels and adding distilled water according to its instructions, generally after a full charge. Keep sparks and open flames away from charging batteries. Cold weather is another concern. Trojan notes that a battery at about 40% charge can freeze at roughly 16°F. Keep the battery charged during cold-weather storage, and follow the manufacturer's guidance for storage and maintenance.
Lithium batteries
Lithium batteries don't need watering, but they do have specific charging limits. Battle Born lists a 14.2V to 14.6V charging range and a rated cycle life of 3,000 to 5,000 cycles for its BB10012. It also advises against charging below about 25°F without suitable heating. Before switching from lead-acid, ask an RV or marine technician to check that your converter, solar charge controller, and alternator support lithium charging.
A Group 27 battery's size tells you whether it may fit your RV or boat, but chemistry and usable watt-hours determine how much power it can provide. Flooded lead-acid batteries can be a sensible choice if you can maintain them, while lithium models often offer lower weight and more usable energy. Measure the battery compartment, confirm the terminal layout, and check the charging system before you buy. If your goal is to power separate 120V appliances rather than expand the RV's 12V bank, compare the EcoFlow DELTA 3 Max for everyday loads or the EcoFlow DELTA 3 Ultra Plus for higher energy needs. Keep either power station separate from the vehicle's battery system and size it for the equipment you plan to run.
What is a Group 27 battery?
A Group 27 battery follows a BCI case-size and terminal-layout designation. It's commonly used as an RV house battery or boat accessory battery, but the label alone doesn't tell you its chemistry, capacity, or whether it's designed for starting or deep-cycle use.
How long will a Group 27 deep cycle battery 100Ah last?
Runtime depends on usable capacity and the current draw of your equipment. Divide usable amp-hours by the load's amp draw for a rough estimate, then account for changing loads and operating conditions. A flooded battery used within a 50% discharge guideline provides less usable capacity than a lithium model rated for 100% depth of discharge.
How much does a Group 27 battery weigh?
Weight depends on the battery's chemistry and model. Trojan's flooded 27TMX weighs 55 lb, while Battle Born's 100Ah lithium battery weighs 31 lb. Check the dimensions and weight before buying to ensure it fits your RV or boat.
Can I use a Group 27 deep-cycle battery to start an engine?
Only if the battery is rated for starting and approved by the engine manufacturer. Deep-cycle batteries provide sustained power, while starting batteries deliver a quick burst of current. Dual-purpose models offer a middle ground.
Can a portable power station replace a Group 27 battery?
No. A portable power station won't fit as a direct battery replacement, start an engine, or connect to your RV or boat's 12V system. It powers compatible appliances plugged directly into its outlets, without replacing the existing battery bank.
RV and Motorhomes
