How to Camp in Joshua Tree National Park: Campsites, Rules, and Tips
Joshua Tree National Park has close to 500 campsites. Most of them fill up fast from fall through spring. The desert is stunning, but it doesn't make camping easy. There are no hookups and no showers. Water is only available in a few spots. So a good plan matters more here than in most parks. This guide walks through the nine Joshua Tree campgrounds and how to book them. It also covers RV rules, generator hours, and the best seasons. By the end, you'll know how to camp in Joshua Tree National Park without surprises.
Joshua Tree Campgrounds at a Glance
The park runs nine campgrounds, and each one has its own feel. Some sit among giant boulders. Others are closer to the park entrances and have a few more services.
Campground
Sites
Nightly Fee
Elevation
Water
Booking
Black Rock
99
$35
4,000 ft
Yes, plus dump station
Reservation
Cottonwood
62
$35
3,000 ft
Reservation
Indian Cove
101
$35
3,200 ft
No
Reservation
Jumbo Rocks
124
$30
4,400 ft
No
Reservation
Ryan
31
$30
4,000 ft
No
Reservation
Sheep Pass (group)
6
From $55
4,500 ft
No
Reservation
Belle
18
$25
3,800 ft
No
First come
Hidden Valley
44
$25
4,200 ft
No
First come
White Tank
15
$25
3,800 ft
No
First come
Every site above means dry camping with no hookups. You’ll bring in your own water and your own power. Only Black Rock and Cottonwood have flush toilets. The rest use pit toilets.
Each campground also suits a different kind of trip. Climbers tend to pick Indian Cove or Hidden Valley, since both sit close to popular rock routes. Families love Jumbo Rocks for its huge boulders. Cottonwood is known for dark skies and spring wildflowers. If you want peace and quiet, White Tank has just 15 sites tucked into the rocks.
How to Book Your Site
Most sites in the park can be booked ahead on Recreation.gov. You can reserve up to six months out or on the same day. The National Park Service campgrounds page says to book before you enter the park. That’s good advice, since cell service inside is very limited. Spring is the busiest time, so reserve early for any weekend or holiday.
Hidden Valley, White Tank, and Belle don’t take reservations. At these, you find an open site and set up camp. Then you drive to an entrance station and pay within one hour. The fee is $25 per night, and only cards are accepted.
These first-come sites go fast. They’re full nearly every weekend from September through May. On weekends, they usually fill by Friday afternoon. Arriving early in the week gives you the best shot.
Once you’ve picked a spot, the next question is power. None of these sites will give you any.
Keeping Your Campsite Powered Without Hookups
No campground in the park has electric hookups. That’s part of the charm, but it takes some planning. Your phone, lights, fridge, and CPAP all need a power source you bring yourself.
Generator Hours in the Park
Gas generators are allowed, but only at set times. The park limits them to 7 a.m. to 9 a.m., noon to 2 p.m., and 5 p.m. to 7 p.m. That’s six hours total. Anything you need overnight has to run on stored power. For a CPAP or a small fridge, that’s a real problem.
Setting up here works a lot like off-grid boondocking in the desert, where every watt counts. A battery power station is the easiest fix. It runs silently at any hour, so it never breaks the generator rules. It can also recharge from solar panels during those long, sunny desert days. For tent campers and small groups, a compact unit covers most needs.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
The EcoFlow DELTA 3 Plus handles phones, lights, and a CPAP for a night or two. But RV campers often run more at once. A 12V fridge, a few fans, and a coffee maker can add up quickly. For that kind of load, a bigger battery makes more sense.
EcoFlow DELTA 3 Max Plus (2048Wh)
• 3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. • 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging. • 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. • Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
Planning Your Daily Power Use
It helps to add up your gear before you leave home. The numbers below are typical ranges. Always check the label on your own devices.
Device
Typical Draw
Hours per Day
Rough Daily Use
Phone charging
10 to 20W
2
20 to 40Wh
LED lantern
5 to 10W
5
25 to 50Wh
CPAP (no humidifier)
30 to 60W
8
240 to 480Wh
12V fridge
40 to 60W
10 (cycling)
400 to 600Wh
Box fan
50 to 100W
4
200 to 400Wh
Add up your totals and leave some extra room. Cloudy days are rare here, but shade from boulders can cut solar output.
 rv camping in joshua tree national park rv camping in joshua tree national park
RV Camping in Joshua Tree National Park
RV camping in Joshua Tree National Park works well if your rig fits. The roads and sites were built long before big motorhomes. So length is the first thing to check.
RV Size Limits and Services
Each campground has its own limits. Keep these in mind when you book:
  • White Tank and Hidden Valley: 25 feet combined length.
  • Belle: Up to 35 feet, but most sites fit 25 to 30 feet.
  • Reservation campgrounds: Check each site’s max length on Recreation.gov.
  • Group sites at Indian Cove: Small RVs or trailers up to 25 feet combined.
A vehicle towing a trailer counts as two vehicles. So does a motorhome towing a car. Most sites allow two vehicles, and some allow only one. There’s no overflow parking in the park.
Black Rock and Cottonwood have RV water fill stations and dump stations. Dumping costs $5, and you pay at any entrance station. The middle of the park has no drinking water at all, so fill your tanks before you head in.
Running a rooftop AC is tough here, since most rigs need shore power for that. Keeping a campsite cool without hookups takes other tricks, like shade and good airflow. Many RVers simply skip summer trips.
If every campground is full, don’t sleep on a roadside or at a trailhead. It isn’t allowed, and rangers can write you a ticket. Your best backup is Bureau of Land Management land outside the park. Private campgrounds in nearby towns are another option.
When to Go and How to Stay Safe
Timing makes or breaks a desert trip. The weather can feel perfect in March and brutal in July. Knowing the seasons helps you plan the right kind of trip.
According to Recreation.gov, the busy season runs from October through May. Daytime highs often land between 70°F and 90°F. Nights drop to between 40°F and 60°F. Fall brings warm days and busy weekends. Winter is quieter, with cold nights and the odd frost. Spring is peak season, when wildflowers bloom and campgrounds fill up. Spring winds can be strong, so stake your tent down well. Clear nights in any season are a bonus, since the park is a certified International Dark Sky Park. Moonless nights are best for spotting the Milky Way.
Summer is the off-season for good reason. Heat is extreme, and some campgrounds close, including White Tank and Belle. A campfire ban also runs from June 15 to October 1 each year.
Desert Safety and Packing Tips
The desert is dry, hot, and remote. A few simple habits go a long way:
  • Carry more water than you think you’ll need.
  • Buy firewood in town, since gathering it in the park isn’t allowed.
  • Lock food and trash in your car to keep ravens and rodents out.
  • Don’t tie lines or hammocks to Joshua trees or other plants.
  • Keep pets on a six-foot leash and off the trails.
Heat is the biggest risk from late spring on. Temperatures can climb fast by midmorning. The basics of staying safe in extreme heat apply here, even on a short hike. Rest in the shade during midday and watch for dizziness or cramps.
Your packing list should cover both hot days and cold nights. Bring at least a gallon of water per person, per day. Pack sunscreen, a wide-brim hat, and warm layers for after dark. Stakes built for hard, rocky ground make setup easier. A headlamp, a solar panel, and a power station round out the kit.
Buy everything before you leave town. There are no stores inside the park, and the nearest shops can be a long drive away.
A great trip here starts with the right site. Book early for reservation campgrounds, or arrive midweek for first-come sites. Check RV length limits, fill your water tanks, and plan around the short generator windows. Fall and spring bring the best weather. Camping in Joshua Tree National Park in comfort brings quiet power that works at any hour. The EcoFlow DELTA 3 Plus and EcoFlow DELTA 3 Max Plus are both worth a look before you go.
Q1: Do you need a reservation to camp in Joshua Tree National Park?
Most campgrounds require one. Black Rock, Cottonwood, Indian Cove, Jumbo Rocks, Ryan, and Sheep Pass all need reservations. Hidden Valley, White Tank, and Belle are first-come, first-served.
Q2: Are there hookups at Joshua Tree campgrounds?
No. None of the campgrounds offer electric, water, or sewer hookups. Black Rock and Cottonwood do have water fill stations and dump stations.
Q3: When can you run a generator in Joshua Tree?
Generators are allowed from 7 to 9 a.m., noon to 2 p.m., and 5 to 7 p.m. A portable power station like the EcoFlow DELTA 3 Plus runs quietly outside those hours.
Q4: What is the best Joshua Tree campground for RVs?
Black Rock and Cottonwood are the easiest picks. They have water and dump stations nearby. Always check each site's length limit before you book.
Q5: Are there showers in Joshua Tree National Park?
No campground in the park has showers. Some private campgrounds, gyms, and motels in nearby towns offer paid showers.
