NIPSCO Outage Map: How to Check and Report Outages
NIPSCO serves electric customers across northern Indiana, where strong winds, ice, and equipment problems can knock out power. If your lights go out, the outage map is a good place to start. You can check your area, report an outage, and see restoration information when it's available. This guide covers the main ways to check and report NIPSCO outages. It also explains what to do during a longer outage and how to stay safe around damaged electrical equipment.
How to Check the NIPSCO Outage Map
The NIPSCO outage map shows current outages across its service area. It updates about every 10 minutes, so you can check back as crews assess damage and update the status of an outage. The map can show the affected area, the likely cause, and an estimated restoration time when that information is available. You can also use the mobile version if you're checking from your phone during an active outage.
Find your outage on the map
Start with NIPSCO's outage page and open the outage map. Look for your area to see whether NIPSCO has already identified the outage and whether an estimated restoration time is listed. The map may change as crews inspect power lines, substations, and other equipment. An estimated restoration time can also change if crews find more damage than expected or run into difficult weather and road conditions. If you're checking from a phone, NIPSCO's mobile outage map provides the same outage information in a format that's easier to use on a smaller screen. For a broader look at how outage maps work, you can also compare it with AEP Ohio's outage map during a regional power outage.
How to Report a NIPSCO Outage
If your power is out but you don't see your location on the map, report the outage to NIPSCO. You can do it by phone, text, or online, so you have more than one way to get the report in. Reporting the outage also gives NIPSCO information about the affected location. That can help the utility confirm the extent of an outage as crews work through repairs.
How to Report a NIPSCO OutageHow to Report a NIPSCO Outage
Report by phone
Call 1-800-4NIPSCO (1-800-464-7726) and follow the automated prompts to report an outage. Save the number in your phone before storm season so you don't have to look it up after the power goes out. Phone reporting can also be useful when your internet connection is down. If you see a downed power line, stay away from it and call 911 first if there's an immediate safety risk. Report the line to NIPSCO separately once you've moved to a safe location.
Report by text
Text OUT to 444111 to report a NIPSCO outage. Texting gives you another option if you don't want to call or phone lines are busy after a major storm. Keep your phone charged before severe weather arrives. A charged phone can be useful for reporting the outage, checking updates, and staying in touch with family while you're waiting for power to return.
Report online
You can also report an outage through NIPSCO's Outage Center or the NIPSCO mobile app. This can be convenient if you're already checking the outage map from your computer or phone. After you report the outage, check the map again for updates. Restoration information can change as crews inspect the damage and determine what repairs are needed. If the repair takes several hours, having backup power ready can make the wait a lot easier.
Backup Power While Waiting on NIPSCO
A widespread outage can leave some households without power for hours while crews work through damaged lines and equipment. A portable power station can keep phones, lights, a refrigerator, Wi-Fi equipment, and other essential devices running during that time. For larger power needs, a whole-home battery can support more household circuits when it's properly installed and connected.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. • High Savings: Saves up to $6,000 per year with a 3-year ROI. • Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
For smaller backup needs, a portable power station can be a practical choice. The EcoFlow DELTA 3 Max can keep essential appliances and devices running while giving you the flexibility to move your backup power where it's needed.
EcoFlow DELTA 3 Max (2048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
The cause of an outage can affect how quickly power comes back, so it helps to know what can take the NIPSCO system offline.
NIPSCO’s Service Area and Common Outage Causes
NIPSCO serves communities across northern Indiana, including Gary, Hammond, Michigan City, Crown Point, and the La Porte area. Outages don't affect every part of the service area in the same way, and the cause can vary from one storm to another. Strong winds can bring down trees and branches that damage power lines. Winter ice can add weight to lines and equipment, while equipment or substation failures can also cause outages without a major storm.
Wind and winter weather
Northern Indiana can see strong winds, snow, and ice during the colder months. A heavy storm can damage lines, knock branches into equipment, or make it harder for crews to reach an affected area. If a winter storm is in the forecast, charge your phones and backup batteries ahead of time. It's also a good time to check flashlights, make sure your refrigerator and freezer are closed, and have a way to stay warm that doesn't depend entirely on electricity.
Equipment and substation problems
Not every NIPSCO outage starts with severe weather. Equipment failures at substations or along the electrical system can also interrupt service. These outages may affect a smaller area than a major windstorm, but the restoration time still depends on what failed and how difficult the repair is. The outage map can give you a better idea of what NIPSCO knows about the problem and whether an estimated restoration time is available.
Staying Safe During a NIPSCO Outage
A power outage can create hazards beyond the loss of electricity. Downed lines, damaged electrical equipment, and improperly used generators can all create serious risks. Keep everyone away from damaged equipment until utility crews or a qualified professional says the area is safe. A few basic precautions can also help you avoid adding another problem while the power is out.
Staying Safe During a NIPSCO OutageStaying Safe During a NIPSCO Outage
Stay away from downed power lines
Treat every downed power line as if it's energized. Don't touch the line, step over it, or approach a vehicle or tree that may be in contact with it. If there's an immediate danger, move to a safe location and call 911. You can then report the downed line to NIPSCO so utility crews can assess the damage. If a tree has fallen across your driveway and taken down a power line, don't try to cut the tree or move it yourself. Keep children and pets away from the area until the utility confirms that it's safe.
Keep generators outside
Never run a gas generator inside your home, garage, basement, or another enclosed area. Carbon monoxide can build up without warning and can be deadly. Place the generator outside and away from doors, windows, and vents. Follow the manufacturer's instructions for connecting appliances and refueling the unit. A battery power station doesn't produce exhaust, but you should still follow the manufacturer's instructions for where to place it, how to charge it, and what equipment you connect.
Sign up for outage alerts
NIPSCO's outage alerts can give you updates without requiring you to keep refreshing the outage map. Sign up before severe weather arrives so you're already set up when an outage occurs. Alerts can be especially useful during a longer outage when restoration information changes. You can also keep checking the map if you want to see how the outage is developing. For additional preparation ideas, this guide to Duke Energy outage preparation covers similar steps for staying ready during a major Midwest power outage.
When a NIPSCO outage hits, knowing where to check for updates and how to report the problem can make the situation easier to manage. Save the NIPSCO outage number, keep your phone charged, and check the outage map for restoration updates. If an outage lasts for hours, backup power can help keep essential appliances, lights, phones, and other devices running. EcoFlow DELTA Pro Ultra X and EcoFlow DELTA 3 Max offer options for whole-home and portable backup power during longer outages.
How do I report a NIPSCO outage?
You can report a NIPSCO outage by calling 1-800-4NIPSCO (1-800-464-7726), texting OUT to 444111, or using the NIPSCO Outage Center or mobile app. If you see a dangerous downed power line, call 911 first when there's an immediate safety risk.
What's the phone number for NIPSCO outages?
The NIPSCO outage phone number is 1-800-4NIPSCO (1-800-464-7726). You can follow the automated prompts to report an outage by phone. Save the number in your phone so you have it ready during a storm or other power interruption.
How often does the NIPSCO outage map update?
NIPSCO's outage map updates approximately every 10 minutes, so you can check back regularly for the latest outage information. Restoration times may change as crews inspect damaged lines, equipment, or substations. If you're waiting for power to return, check the map again for updated restoration details.
What areas does NIPSCO serve?
NIPSCO serves electric customers across northern Indiana, including communities such as Gary, Hammond, Michigan City, Crown Point, and the La Porte area. The size and location of an outage can vary depending on the cause.
How do I sign up for NIPSCO outage alerts?
You can sign up for NIPSCO outage alerts through the utility's available account and outage notification options. Setting up alerts before severe weather can make it easier to receive updates without repeatedly checking the outage map.
Power Outages
