Hurricane Season 2026: What NOAA & AccuWeather Predict + How to Protect Your Home Power
While it’s impossible to know exactly when and where major weather events like hurricanes will hit, knowing the predictions for hurricane season is a crucial part of being prepared.
This guide not only takes a look at some of the most important predictions for the 2026 hurricane season, but also goes over what regions face the highest risk, what you should prepare before hurricane season begins, and more.
What Are NOAA and AccuWeather Predicting for Hurricane Season 2026?
According to AccuWeather’s forecast of the 2026 hurricane season, 11-16 named storms are predicted this year, with four to seven of them being hurricanes (two to four of these being major hurricanes), and three to five direct U.S. impacts expected throughout the season.
These numbers are near, if not slightly below, the historical averages of 14 named storms, seven hurricanes, three major hurricanes, and four direct U.S. impacts. One of the main reasons why there may be fewer tropical storms this year is because of a developing El Niño.
For those unfamiliar, an El Niño is a climate phenomenon where the ocean surface is unusually warm, which leads to stronger upper-level winds, making it harder for hurricanes and other storms to materialize.
However, keep in mind that these are only forecasts and predictions, and it’s always best to ensure you’re prepared for tropical activity, even if the predictions seem favorable.
As for the National Oceanic and Atmospheric Administration (NOAA), the agency has announced that it will release its outlook on the 2026 hurricane season during a news conference on May 21st.
Hurricanes and other extreme weather situations can often cause power outages and blackouts. If you want your home to continue operating as if there were no outage at all, you may want to invest in a whole-home power solution like the EcoFlow DELTA Pro Ultra X, which is capable of running entire homes when the power goes out.
When Does Hurricane Season 2026 Start and End?
In the USA, the 2026 Atlantic hurricane season officially begins on June 1st and ends on November 30th. But while most hurricanes indeed fall within this range, there have been off-season hurricanes that materialize, but they’re incredibly rare.
An EcoFlow DELTA Pro Ultra X Whole-Home Backup Power
Why Are Hurricanes Causing More Severe Power Outages?
Like many other major storms, hurricanes can devastate the power infrastructure in an area and lead to severe and widespread outages. One of the main reasons hurricanes can cause severe power outages is due to high winds. These winds can knock down power lines, damage power poles, or even knock down trees or branches onto lines, breaking them.
The wind may even be strong enough to throw objects that can damage power poles, lines, substations, or other important pieces of the power system. In addition to winds, flooding may cause damage to power infrastructure or even seep into underground electrical grids and lead to outages.
Delayed repairs may also make outages worse. For instance, when there are incredibly high winds and dangerous flooding, repair crews can’t safely make fixes until the dangerous weather passes, which may lead to many issues and problems piling up, leading to longer and more widespread outages in some cases.
Because of the many ways that hurricanes can lead to severe outages, it’s more important than ever to prioritize managing electricity during a hurricane to ensure you’re not stuck without power for hours or days on end.
What Regions Face the Highest Hurricane Risk?
While hurricanes can occur in several parts of the country, there are a few regions where hurricane risk is the highest. This includes:
  • The Gulf Coast (which includes states like Florida, Texas, Louisiana, Alabama, and Mississippi)
  • The East Coast (especially areas like North Carolina, South Carolina, and Virginia, as their coastlines extend further out into the ocean)
This is largely due to these areas’ proximity to warmer waters, global wind patterns, and many of them having low coastal elevations, especially in places like Louisiana and Florida, which often see some of the worst tropical storms.
What Should You Prepare Before Hurricane Season Begins?
Before hurricane season arrives, here are a few important things you should do to prepare:
  • Stock up on food and water to ensure you have enough to last multiple days if need be.
  • Build an emergency kit that contains things like bandages, medications, a radio, a flashlight, a multi-tool, and more.
  • Have an evacuation plan in place. When a hurricane hits its often very chaotic, so having a plan and even practicing evacuations ahead of time ensures you and your family know what to do and don’t get confused or freeze up in real-life situations.
  • You should consider making your home hurricane-proof your home with a solar generator, so that you don’t need to worry as much about outages, as you’ll have reliable backup power.
  • Take time to properly maintain your property by cleaning out the gutters, trimming your trees, cleaning up objects lying around your yard, and anchoring heavy and/or expensive items down so they don’t get damaged or damage other parts of your property.
  • Consider having a battery backup for hurricanes, as these can store power for when you need it to ensure you can still communicate and run essential appliances and home systems during prolonged outages.
What Backup Power Options Help During Hurricanes?
Several backup power solutions can help give you peace of mind during storm season. First, a compact portable charger can help you keep your devices, like phones and tablets, charged up to ensure you can maintain communication with others and keep up with news of the storm.
Next, a small portable power solution like EcoFlow DELTA Pro is great for running a couple of appliances and keeping your home at least semi-operational during severe outages. Exact capacity and output vary, but many are capable of running multiple appliances at once.
How Active Will Hurricane Season 2026 Be?
While it’s impossible to know for sure, 2026 is predicted to see a slightly less-than-normal level of tropical activity. That being said, it’s still important to be prepared, as even if activity is lower, there are still likely to be several major storms that hit the USA throughout the season.
What Areas Are Most at Risk for Hurricanes in 2026?
Some areas that are most at-risk for hurricanes in 2026 include Florida, Louisiana, Mississippi, Alabama, and much of the East Coast of the United States, especially the Carolinas and Virginia.
EcoFlow DELTA Pro Series
EcoFlow DELTA Pro is a portable home battery built for plug-and-play backup, delivering 3,600–7,200W AC output to run 99% of appliances. Expand capacity from 3.6kWh up to 25kWh with Smart Extra Batteries, recharge fast with up to 6,500W MultiCharge (as little as 2.7 hours via AC), and even top up at thousands of EV charging stations—powered by a long-lasting LFP battery designed to support up to 10 years of use.
Hurricane Forecasts Highlight the Importance of Reliable Backup Power
Keeping up with hurricane forecasts and predictions helps you ensure you’re prepared for the upcoming hurricane season that has the potential to impact millions of people across the country.
But even though 2026 may not be forecasted as an incredibly active hurricane season, it’s important to still have reliable backup power like a whole home generator. These give you peace of mind and ensure you’re prepared in case you find yourself dealing with the long outages that often come along with hurricanes and other tropical storms.
Home Backup
