How Many Watts Does a Crock Pot Use? Crockpot Wattage Guide
Knowing crock pot wattage can help you estimate electricity use and choose a suitable backup power source, whether that's for managing a utility bill or planning power for an outage. So, how many watts does a crock pot use? This guide covers typical wattage by size, how to find the exact figure for your own unit, what that means for electricity use, and how to power one with a portable power station when a wall outlet isn't an option.
For anyone planning to cook off-grid or during an outage, keeping something like the EcoFlow DELTA 3 Plus on hand is one way to keep a slow cooker running without relying on the wall.
How Many Watts Does a Crockpot Use
Crock pot watt usage depends on the size, model, cooking setting, and manufacturer, so there's no single number that applies to every unit. Wattage scales fairly predictably with capacity, since larger ceramic inserts need more heating element power to bring a bigger volume of food up to temperature. Here's how it typically breaks down by size:
Crock Pot Size
Typical Wattage
Notes
1.5 to 3 quart (small)
70 to 150W
Personal-size or dip warmers
4 to 6 quart (standard)
150 to 250W
Most common household size, averages around 175 to 180W
7 to 8 quart (large)
250 to 320W
Family-size, holiday cooking
10 quart and up (extra-large)
400W and up
Less common, catering or large-batch use
A standard 4 to 6 quart model, the size most households actually own, is why 175 to 180 watts is the figure most often cited as typical crockpot wattage.
Where to Find Your Crockpot's Wattage?
The size ranges above give a solid estimate, but the most reliable way to know exactly how much power does a crock pot use is to check the specific unit. The wattage is usually listed in one of these places:
  • The rating label on the appliance
  • The bottom or back of the crock pot
  • The user manual
  • The manufacturer's product page
  • The original packaging
If the label only lists volts (V) and amps (A) instead of watts, the wattage can be calculated using the basic relationship: Watts = Volts × Amps. Since most household crock pots run on a standard 120-volt outlet, a unit rated at 1.5 amps would use approximately 120 × 1.5 = 180 watts.
How Much Electricity Does a Crockpot Use?
Wattage (power) and electricity consumption (energy) aren't the same thing. Wattage tells you how much power the crockpot draws at a given moment, while electricity consumption tells you how much total energy it uses over time, which is what actually shows up on a utility bill.
Key factors that affect electricity usage:
  • Rated wattage
  • Cooking time
  • Low vs. high settings
  • Crock pot size and model
  • How often the heating element cycles on and off
How to calculate:
  • Electricity used (kWh) = Watts × Hours ÷ 1,000
For example, a 180-watt crock pot run for 7 hours uses 180 × 7 ÷ 1,000 = 1.26 kWh. To estimate cost, multiply that figure by your local electricity rate: cost = kWh used × local electricity rate. At a national average residential rate of around $0.1883 per kWh, that same 7-hour cook costs roughly $0.24.
Power Your Crockpot Anywhere With an EcoFlow Portable Power Station
A crock pot still needs a wall outlet to run, which is fine at home but a real problem anywhere else, like a campsite, a job site, an RV, or during a power outage. That's the actual gap a portable power station closes: it gives the crock pot somewhere to plug in even when there's no outlet nearby. EcoFlow builds its solar cookers around this same idea, using stored or solar power instead of a fixed power line, so running a crock pot the same way isn't a stretch.
EcoFlow DELTA 3 Plus Portable Power Station, best for a standard crock pot and everyday off-grid cooking.
The EcoFlow DELTA 3 Classic is a solid starting point for anyone running a single appliance like a crock pot away from an outlet. At 1,800W of continuous output, it comfortably handles even a large 8-quart crock pot running on high, with nothing to set up beyond plugging it in. It's compact enough to toss in a camping bag or leave in the car, so it's ready whenever a trip calls for it.
1–5kWh expandable with DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery, or DELTA Pro 3 Extra Battery via an Alternator Charger XT150 Output Cable. 1800W AC output, 2200W (surge 3600W) with X-Boost 5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
EcoFlow DELTA 3 Max Plus (2048Wh), best for a large crock pot or running it alongside other appliances.
The EcoFlow DELTA 3 Max Plus makes more sense once the crock pot isn't the only thing drawing power. Its larger battery and higher output leave room to run a mini fridge, lights, or other devices at the same time, which matters most on longer outings or when cooking for a bigger group.
3000W Powerful Output: 6000W surge output. With X-Boost™ mode,it supports heavy-duty appliances up to 3800W, such as refrigerators, coffee makers, washers, and circular saws. 5 Ways to Charge, Ready in Just 43 Mins: Ready in just 43 mins (0-80%) with generator charging. 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop.
Crock pot wattage varies by model, but most household crock pots fall within a relatively moderate power range, generally 70 to 320 watts depending on size. That modest draw is part of why crock pots are one of the easiest kitchen appliances to run off a portable power station, whether you're managing a utility bill or cooking through an outage. If you're looking to keep a crock pot running anywhere, the EcoFlow DELTA 3 Max Plus is a solid place to start.
What size generator do I need to run a crock pot?
Most crock pots draw well under 500 watts, even large 8-quart models, so a compact portable power station with at least 300 to 500W of continuous output comfortably covers the appliance itself. The bigger factor is usually capacity (watt-hours) rather than output, since that determines how many hours of cooking you get per charge.
Will a 400 watt inverter run a crock pot?
In most cases, yes. A 400-watt inverter covers small to mid-size crock pots comfortably, and even most standard 6-quart models, which typically run 150 to 250W. It may not have enough headroom for a large 8-quart or extra-large 10-quart unit running on its highest setting, so it's worth checking the wattage label on the specific crock pot first.
How many watts does a crock pot use per hour?
Crock pot watt usage per hour is close to its rated wattage, since it's a continuous draw rather than a short burst. A 180-watt crock pot uses roughly 180 watt-hours for every hour it runs, though actual draw dips somewhat once the thermostat starts cycling the heating element on and off to hold temperature.
How many amps does a crock pot use?
On a standard 120-volt outlet, most crock pots draw between about 0.6 and 4.2 amps, depending on size. A small 2-quart model runs around 0.6 to 0.8 amps, while a large 8 to 10-quart unit can reach 3.5 to 4.2 amps on its highest setting.
Save Bills
