EcoFlow DELTA 3800 Gen4 vs. Jackery HomePower 3600 Plus: Which Is Better for Home Backup?
When the power goes out, most households want the same few things running: the refrigerator, lights, phones and the internet. A portable power station can cover that list, but runtime, charging options and ease of use vary from model to model. Both the EcoFlow DELTA 3800 Gen4 and Jackery HomePower 3600 Plus deliver 3,600W of AC output, so the differences are in battery expansion, solar charging and storm prep. Here’s how that plays out for home backup.
Overview of the Two Home Backup Power Stations
When comparing portable power stations for home backup, look beyond the shared 3,600W continuous AC rating. Battery capacity, size, charging features, expansion options, and verified operating conditions set the two stations apart.
A portable power station should be sized around both simultaneous wattage and the watt-hours needed for the planned outage duration.
The EcoFlow DELTA 3800 Gen4 packs a 3,763Wh battery and 3,600W of continuous output into a 37.74L chassis. Its lower idle power draw can help conserve energy when powering smaller loads. It also supports up to 2,000W of solar input and includes Flow Sense™ with Fridge Runtime Boost™, extending refrigerator backup to as long as 70 hours. Storm Guard can prepare the unit for severe weather, while Emergency Power Mode™ provides DC output after the display reaches 0%.
EcoFlow DELTA 3800 Gen4 Portable Power Station
1. Longest Runtime¹: Powers a refrigerator for up to 70 hours — 17 hours (32.6%) longer than the industry average for 3-4kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴ . 3. Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3-4kWh capacity and 3,600W output.
The Jackery HomePower 3600 Plus pairs a 3,584Wh LFP battery with 3,600W of continuous AC output and a 7,200W surge rating. Extra battery packs can take it as high as 21kWh. It weighs 77.2 pounds, so the built-in wheels and telescoping handle matter when you move it around the house. Two units linked together also give you 240V split-phase output.
EcoFlow DELTA 3800 Gen4 vs. Jackery HomePower 3600 Plus: Key Specifications Compared
Here’s how the two stations stack up on paper:
Feature / Specification
Base Battery Capacity
3,763Wh
3,584Wh
Automotive-Grade LFP (LiFePO4)
LFP (LiFePO4)
Expandable Battery Capacity
Up to 12kWh (with extra batteries)
Up to 21kWh (with extra batteries)
Rated AC Output
3,600W (X-Boost up to 4,600W)
3,600W
Surge Power
7,200W
7,200W
Output Voltage
120V Pure Sine Wave
120V (240V capable via dual-unit link)
Bypass / Pass-Through Output
3,600W continuous via X-Fusion
12A Max/1,440W circuit bypass
Max Solar Input
2,000W
1,000W
AC Charging Speed
~2.5 Hours
~2.5 Hours
UPS Transfer Time
< 10ms
< 10ms
No-Load AC Power Draw
14W
23W
Standby Power Draw
3W
Not disclosed
1-Year Battery Retention
Up to 99%
Not disclosed
Dimensions & Volume
37.74 liters
58 liters (~35% larger)
Weight
67.5 lbs
77.2 lbs (+9.7 lbs heavier)
EcoFlow DELTA 3800 Gen4EcoFlow DELTA 3800 Gen4
Which Power Station Provides Longer Backup Runtime?
Like a bigger gas tank, a bigger battery doesn’t always mean longer backup, because runtime also depends on what the station burns just staying on and what you plug into it.
A battery run time calculator can organize usable capacity, connected wattage, conversion losses, standby draw, and appliance cycling into a more realistic planning estimate.
Battery Capacity, Expandability, and Power Consumption
Straight out of the box, the DELTA 3800 Gen4 starts with 3,763Wh against Jackery’s 3,584Wh. Jackery takes the lead if the goal is adding battery packs, scaling up to 21kWh where EcoFlow tops out at 12kWh.
In a real outage, the edge goes to whichever unit wastes less keeping itself awake, since every inverter uses power from the moment it is switched on. The DELTA 3800 Gen4 draws just 14W at no load with the AC inverter engaged, and 3W on standby. In contrast, the Jackery HomePower 3600 Plus draws 23W at idle, meaning the DELTA 3800 Gen4 uses approximately 39% less power under no-load conditions, helping preserve more stored energy for connected devices. Run a 10W Wi-Fi router, LED floor lamps and baby monitors overnight and Jackery’s higher parasitic loss drains the reserve in the background.
Real-World Refrigerator and Critical Appliance Runtime
For most families, the first job in an outage is keeping the food in a fully stocked refrigerator and freezer from spoiling. This is where EcoFlow’s Fridge Runtime Boost™, driven by intelligent Flow Sense™ algorithms, completely changes emergency planning.
Standard power stations feed a compressor the same continuous AC output whether it is running or not, burning inverter energy the whole time the thermostat is idle. Fridge Runtime Boost™ uses on-demand power matching and smart power management to extend refrigerator runtime. Tested on an unloaded Samsung 654L AI refrigerator set to 3°C for the refrigerator compartment and −18°C for the freezer, the DELTA 3800 Gen4 delivers up to 70 hours of refrigerator runtime — nearly three days of refrigerator operation under the specified test conditions.
Based on an estimate derived from available refrigerator-runtime data for the Jackery HomePower 3000, the Jackery HomePower 3600 Plus may provide approximately 44.33 hours of refrigerator runtime. That 25+ hour margin for the DELTA 3800 Gen4 gives families a whole extra day of protection for hundreds of dollars’ worth of fresh meat, produce and milk, without having to recharge right away.
Which Power Station Can Run More Home Appliances?
If you are comparing either battery station with a home backup generator, note that both units deliver 3,600W of continuous AC output without engine exhaust. The remaining differences appear when several high-power appliances are running or the station is charging at the same time.
Before choosing either system, define the backup power loads that must run together and account for motor startup demand as well as continuous wattage.
Rated Output and High-Power Appliance Support
Both stations comfortably deliver a robust 3,600W of continuous AC output and handle up to a 7,200W starting surge. That baseline covers full-size microwave ovens, induction cooktops, circular saws and sump pumps.
Where EcoFlow pulls ahead is in supporting high-power appliances. With its proprietary X-Boost technology, the DELTA 3800 Gen4 can support certain compatible appliances rated up to 4,600W, while its continuous rated output remains 3,600W. This can help keep compatible high-demand appliances, such as electric heaters, kettles, and induction cooktops, running without immediately triggering overload protection. X-Boost is unavailable when the unit is connected to AC input or operating in charging or bypass mode.
Powering Appliances While Recharging
Many portable power stations throttle their output when you plug them into a wall outlet or a gas generator while running high-wattage equipment.
Pass-through output limits vary among portable power stations. The Jackery HomePower 3600 Plus is rated for up to 1,440W (120V, 12A) in AC bypass mode. Loads above this limit may interrupt bypass operation or activate overload protection.
EcoFlow resolves this with X-Fusion bypass technology, which intelligently blends grid or generator supply with the battery in real time. The DELTA 3800 Gen4 can charge its cells from a wall outlet and still deliver up to a full 3,600W across its AC ports. You can run several high-draw kitchen appliances during rolling brownouts, use power tools in a garage workshop, or stay plugged into shore power at an RV site, and the output never drops to 1,800W.
Which Power Station Is More Convenient for Charging and Emergency Home Backup?
Charging speed, outage switching, weather preparation and portability all matter when choosing a backup station, since they determine how ready the unit is when an outage starts.
For longer outages, a solar generator can combine stored battery power with compatible solar charging when panel placement, weather, and daylight conditions allow.
AC and Solar Charging Speed and Flexibility
If a winter storm knocks out power for days, sunlight becomes your sole off-grid fuel, and the two stations take it in at very different rates:
  • EcoFlow DELTA 3800 Gen4: Supports up to 2,000W of solar input through two ports, each rated for up to 1,000W. Under clear skies with a portable or rooftop array, the 3.76kWh battery can reach a full charge in roughly 2.3 to 2.5 hours.
  • Jackery HomePower 3600 Plus: Supports up to 1,000W of solar input. Jackery’s support page lists about 6 hours with two SolarSaga 500 X panels under its test conditions; actual charging time varies.
When solar hours are limited in winter or between storm fronts, EcoFlow’s 2,000W intake lets you capture twice as much energy in a narrow midday window. For AC wall charging, EcoFlow reports approximately 146 minutes for the DELTA 3800 Gen4, while Jackery reports approximately 2.5 hours for the HomePower 3600 Plus.
Backup Power Continuity During Sudden Outages
When power lines come down in high winds, even a brief power interruption can cause computer workstations and NAS systems to reboot or lose unsaved data, while security and home automation systems may temporarily go offline.
Both units provide rapid switching, but their backup performance and specifications differ. The EcoFlow DELTA 3800 Gen4 offers a UPS switchover time of less than 10ms, helping reduce interruptions to compatible electronics such as desktop PCs, NAS systems and home security equipment.
Crucially, EcoFlow incorporates Emergency Power Mode™. While standard power stations typically shut down entirely once the battery display hits 0%, EcoFlow activates a dedicated reserve layer at that point to supply emergency DC power. That backup reserve is capable of charging an iPhone from 0% to over 90%, preserving an indispensable communications lifeline so you can call emergency services, check your utility’s outage map or contact family.
Emergency Power Preparation for Severe Weather
Storm Guard Mode 2.0 is a weather-monitoring and backup-preparation feature available through the EcoFlow app. In the U.S., it uses professional weather data from the National Weather Service for more accurate monitoring. When a disaster alert is detected, it can automatically initiate charging through the app, helping ensure the DELTA 3800 Gen4 is charged and ready for a potential outage before extreme weather arrives.
Because emergencies are unpredictable, how well a station holds its charge on the shelf is paramount. Built with automotive-grade LFP cells and advanced battery management, the DELTA 3800 Gen4 retains up to 99% of its charge after a full year in storage. Users should still follow EcoFlow’s storage and maintenance guidance.
Portability and Noise Levels During Home Backup
High-capacity batteries are notoriously heavy, but their shape decides how easily you can get one around furniture or into an SUV trunk:
  • Footprint & Weight: The DELTA 3800 Gen4 comes in at 67.5 lbs and 37.74 liters, against 77.2 lbs (9.7 lbs heavier) and 58 liters (~54% larger) for Jackery’s 3600 Plus.
  • Mobility Hardware: Jackery builds rear wheels and an extendable luggage-style handle into the chassis. EcoFlow uses high-strength integrated side carry handles and pairs with an optional quick-detach heavy-duty rolling cart, which keeps the base unit lighter and significantly more compact for shelf storage or loading into a vehicle.
  • Acoustics: Jackery lists a 30dB Quiet Mode. EcoFlow lists approximately 30dB at loads up to 600W, 40dB at loads up to 1,800W and 50dB at loads up to 3,600W, measured at one meter and 25°C. Because noise varies with load, charging rate, temperature and measurement conditions, users should compare figures recorded under similar conditions.
Which Should You Choose: EcoFlow DELTA 3800 Gen4 or Jackery HomePower 3600 Plus?
The better fit depends on which features matter most for your home. EcoFlow is stronger on runtime, solar charging and automated preparation, while Jackery offers more expansion capacity and built-in rolling mobility.
Choose EcoFlow DELTA 3800 Gen4 If You:
  • Want the longest food preservation: You get up to 70 hours of refrigerator runtime via Fridge Runtime Boost™, more than a full day longer than conventional units.
  • Rely heavily on rapid solar recharging: Your setup uses, or will use, extensive solar arrays, taking full advantage of 2,000W solar input to recharge in half the time.
  • Want automated storm prep and emergency peace of mind: You value smart features like Storm Guard weather tracking, 99% annual charge retention and Emergency Power Mode™ for critical phone recharging at 0% battery.
  • Need serious pass-through capability: You frequently run high-draw kitchen appliances, heaters or power tools on X-Fusion’s 3,600W output while the station charges.
  • Prefer a lighter, more compact profile: You need a high-capacity 4kWh-class station that is roughly 35% smaller and nearly 10 pounds lighter to carry or transport.
Choose Jackery HomePower 3600 Plus If You:
  • Need massive long-term expansion capacity: Your goal is larger-capacity home backup, scaling up to 21kWh with extra batteries.
  • Require 240V split-phase power: You need to power heavy-duty 240V appliances (like certain well pumps, dryers or workshop tools) by bridging two units together.
  • Prefer built-in rolling mobility: You want integrated, non-detachable wheels and a telescoping handle ready to roll at a moment’s notice.
  • Prioritize an ultra-quiet inverter: You prefer exceptionally low noise levels when the unit runs indoors.
Both stations will run the essentials in an outage, but they suit different backup plans. The Jackery HomePower 3600 Plus makes sense if you plan to expand storage to 21kWh, need 240V output through a paired setup, or want wheels built into the chassis. If you care most about a refrigerator that stays cold longer, a fast solar recharge, a station that tops itself up before a storm and a reserve of phone power when the display reads 0%, the DELTA 3800 Gen4 packs more of those features into a smaller, lighter unit. In the end, the right call comes down to the appliances you need to keep running and how you expect to recharge once the power is out.
Does Adding an Extra Battery Increase the Power Output?
No, an expansion battery adds total capacity (watt-hours) and overall runtime, but it does not raise the main unit’s rated 3,600W continuous AC output. The inverter rating stays fixed no matter how many battery packs are chained together.
Which Power Station Provides More Power While Recharging from an Ac Outlet?
The EcoFlow DELTA 3800 Gen4 delivers significantly more power while recharging, supplying up to its full 3,600W continuous output thanks to X-Fusion bypass technology. By comparison, the Jackery HomePower 3600 Plus is rated for up to 1,440W (120V, 12A) in AC bypass mode.
Can Either Power Station Prepare Automatically for Severe Weather?
Only the EcoFlow DELTA 3800 Gen4 has automated storm readiness through its built-in Storm Guard feature. The EcoFlow app tracks local National Weather Service alerts and automatically tops the battery up to 100% when hazardous weather is detected in your area, whereas with the Jackery you have to watch for alerts and plug it in yourself.
What Happens When the Displayed Battery Level Reaches 0%?
The Jackery HomePower 3600 Plus shuts down all outputs completely when the battery reads 0%, while the EcoFlow DELTA 3800 Gen4 activates Emergency Power Mode™ to provide reserve DC power capable of recharging an iPhone from 0% to over 90%.
Can These Power Stations Run a Space Heater During a Power Outage?
Yes, both power stations can easily run a standard 1,500W electric space heater for roughly 2 to 2.3 hours of continuous warmth on their base battery capacities. When other high-draw appliances kick on at the same time, EcoFlow’s X-Boost handles the extra heating load up to 4,600W without tripping.
Power Outages
