The Four Clean, Green Home Generator Options You Didn’t Know You Needed
Year on year, our responsibility to look after the environment grows. In 2020, the University of Michigan reported that 78% of US energy consumption came from fossil fuels. A staggering figure when affordable, eco-efficient technology is being created every day.
product
But how can a home generator help reduce this figure? It’s no secret that home generators have been around for decades. However, thanks to technological advances, there’s been a significant rise in affordable generators powered by renewable energy sources. Making a slight change in how we power our homes could make a significant positive impact on our planet in the long term.
This guide will discuss the premise of home generators and their benefits — and introduce the idea of clean, green alternatives for home generators.
What Is a Home Generator?
home generator
A home generator is a device that produces electricity from a variety of sources. Home generators are powered by fossil fuels or renewable sources like solar energy. Typically, home generators are used for home backup. But thanks to swift technological advancements, many are now portable and double up for outdoor use too.
Home Backup benefits:
  • Protect your home during power outages
  • Keep your family safe and comfortable in emergencies
  • Generate your own clean, green energy using solar power
Outdoor benefits:
  • Perfect for off-the-grid living
  • Can power RVs
  • Useful on campsites for lighting and portable appliances
  • Charge and power devices on the move using solar power
What Types of Home Generators Are Available on the Market Today?
There are several different types of home backup generators out there. Traditionally, standby power generators have been the most common. Standby generators use natural gas or propane and are expensive to run. This type of generator is usually permanently installed outside your house. Their primary use is to kick in when a blackout hits.
In recent years, microgrid systems have become more popular. Microgrid systems use a number of small renewable energy sources, such as solar panels and wind turbines. They can power your home or be connected to the grid to provide backup power. You can learn more about microgrid systems here.
Another type of home generator growing in popularity is a portable solar generator. These are arguably the best generators for home power outages.
Why?
Simply put, you can easily move them, and they pack enough power to keep your home running for days.
Traditionally, portable generators are powered by gasoline or diesel. However, battery-powered generators using renewable energy sources are starting to change the game.
Clean, Green Home Generators and Their Benefits
green generators
As we look for ways to reduce our carbon footprint, home backup generators powered by renewable energy sources are becoming more popular. Battery-powered solar generators offer many benefits. One main attraction is that they allow you to generate your power sustainably. Additionally, home generators can provide backup power when a blackout strikes or as an alternative to mains power.
EcoFlow DELTA Pro: The Best Green Backup Generator For a Home Power Outage
For the ultimate home backup system, EcoFlow DELTA Pro is the best generator for home power outages. With a sizeable 3600Wh capacity and output, it can power the whole house. If a blackout hits, you can be confident you’ll have power for hours on end. Plus, you can connect up to three 400W solar panels and utilize the sun’s rays for unlimited power.
green backup
  • It packs a 3600W expandable capacity & output
  • Use the expandable ecosystem and add up to 2 more EcoFlow DELTA Pro units with extra batteries too
  • Get up to 1600W solar input and receive a 100% recharge in 2.8 – 5.6 hours
  • Up to 13 ports and outlets per EcoFlow DELTA Pro
  • Seamless home integration with the EcoFlow Smart Home Panel
EcoFlow DELTA Max: A Sustainable Backup Power Generator For Your Home
If you’re looking for a backup generator or just something to power appliances sustainably, EcoFlow DELTA Max is ideal. It can power 99% of home appliances. It’s a great tool if you’re looking to shave some dollars off your electricity bill.
DELTA MAX
  • Be covered for emergencies with a massive 2400W output
  • Expandable capacity up to 6kWh with smart extra batteries
  • Get up to 800W max solar charging speeds with two 400W solar panels
  • Lightweight at 48lbs
EcoFlow DELTA: A Portable Power Generator For a variety of Homes
Whether you’re in a house or living in an apartment, EcoFlow DELTA provides both humble abodes with an excellent, green source of backup power.
DELTA
  • Up to 13 ports & outlets
  • Go from 0-100% battery with three 160W solar panels in 3.5 – 7 hours
  • Whopping 1280Wh capacity & 1800W output
  • Lightweight at 30.9lbs
  • Fast charge from AC level 2 EV stations
EcoFlow DELTA Mini: A Portable Electric Generator Alternative for Smaller Living Spaces
For smaller living spaces or life on the road, EcoFlow DELTA mini is the most portable option in the EcoFlow DELTA family. This pint-sized powerhouse can keep your devices and appliances up and running for hours. Thanks to its capacity, output, and solar input size, it’s great to take on campsites or power your RV.
DELTA MINI
  • The lightest EcoFlow DELTA at 23.6lbs
  • With 882Wh capacity & 1400W output, you can still power the bigger stuff
  • Reach 100% battery with two 160W solar panels in 4 – 8 hours
  • Charge up to 12 devices simultaneously
  • Control and monitor power consumption with the EcoFlow app
Interested in a more in-depth comparison of the EcoFlow DELTA series? Find that here.
Thanks to technological advancements, green, clean portable generators are starting to change the backup power supply game. It’s evident that being able to create an unlimited but sustainable power supply is beginning to take precedence over using traditional generators. Plus, battery-powered power stations can be used for home backup and outdoor use. By making the change to a home generator powered by renewable energy sources, we work towards creating a healthier planet. If you want to take a deeper dive into battery-powered generators, you can check out the EcoFlow DELTA Series comparison here.
• First portable home battery designed for home backup • 3.6-25kWh expandable capacity with DELTA Pro Smart Extra Battery • 3600W-7200W AC output for 99% appliances • Plug & Play home backup solution • Incredible 6500W MultiCharge, 2.7 hours AC charging • Industry first: recharge at thousands of EV stations worldwide • Long-lasting LFP battery supports up to 10 years
Portable Power Stations
