Frigidaire Power Outage Reset: How to Clear the Alert and Get Your Fridge Back to Normal
The power is back. The lights work. But your Frigidaire refrigerator is flashing "PF" or beeping. That does not always mean the fridge has a fault. The alert records a power outage or surge. This guide explains what PF means, how to clear it on different control panels, and how to check whether your food is still safe. It also covers simple ways to keep your fridge running during the next outage.
What does the Power Failure (PF) alert on a Frigidaire fridge mean?
The PF or Power Failure alert is usually a record, not a refrigerator fault. It tells you that the unit detected a power outage or power surge. The alert can remain until you acknowledge it.
Frigidaire states that the PF light indicates a "power outage or power surge". The company also notes that a power event can trigger a high-temperature alarm. This means PF can appear even when you do not notice the lights go out.
A related alert is the High Temperature alarm. Depending on the model, you may see H, HI, or High Temp on the display. Frigidaire says a blinking HI temperature display means the refrigerator or freezer temperature has been too high for over one hour.
This matters because PF only tells you that a power event occurred. It does not tell you how long the refrigerator stayed warm. That is important when deciding whether refrigerated food is safe.
Frigidaire alert
What it means
When it clears
PF / Power Failure
The refrigerator detected a power outage or surge.
After the alert is acknowledged or cleared.
H / HI / High Temp
The refrigerator or freezer temperature has been too high.
When the temperature returns to the normal range, depending on the model.
Door Ajar
A refrigerator door has been left open too long.
Close the door; the alarm should stop.
Frigidaire also notes that a Door Ajar alarm can sound after a door has been open for more than five minutes.
Summer storms, winter ice, equipment failures, and other grid problems can cause power interruptions. Knowing the common causes of power outages in your area can also help you estimate how long your refrigerator may have been without power.
Once you know the flashing PF is a power-loss record, clearing it is usually simple. The exact button depends on the control panel on your Frigidaire refrigerator.
How to reset a Frigidaire refrigerator after a power outage?
Before resetting the alert, make sure power to the refrigerator is stable. Then check your model number. You can usually find it inside the fresh food compartment or in the use and care guide. Button names vary between Frigidaire control panels.
French-door and four-door models with a digital display
On many Frigidaire French-door and four-door models, press Alarm Reset after power returns. This acknowledges the power failure alert.
If you also see a Door Ajar alarm, close the refrigerator door. Then press the Set key to clear the alert, as directed for applicable models.
Other electronic control panels
Some Frigidaire refrigerators use a CLEAR ALERTS button. Press this button to clear active alerts on models that have this control.
Do not follow generic hold-time instructions. Frigidaire does not specify one universal hold time for this function. Instead, match the button name to the control panel on your refrigerator.
Top-freezer and dial-control models with no display
Some top-freezer models use mechanical dial controls and do not have a PF alert. There is no power failure message to clear on these units.
Check that the temperature dial has not moved during the outage. Frigidaire recommends using the normal indicator mark as a reference for dial settings. Let the refrigerator stabilize before making further adjustments.
If the panel is frozen or the alert won't clear (hard reset)
A power reset can help if the display is frozen or does not respond.
First, unplug the refrigerator for about 30 seconds, then plug it back in. You can also switch off the refrigerator's circuit breaker and turn it back on.
For a beeping or unresponsive display, Frigidaire also recommends unplugging the refrigerator for 2 to 3 minutes in some cases.
If the refrigerator has no power after the outage, check the circuit breaker or fuse. A breaker may have tripped during the power event.
A fridge keeps your food freshA fridge keeps your food fresh
Give it time before you adjust anything
Do not keep lowering the temperature setting to make the refrigerator cool faster. Frigidaire states that the unit can need 24 hours for the temperature to stabilize.
Frigidaire's recommended settings are generally 37°F for the fresh food compartment and 0°F for the freezer. Some multi-door models with a Custom-Flex Temp Drawer use a 39°F fresh food setting.
The goal is not just to make the PF message disappear. The refrigerator should also return to a safe, stable temperature.
Checking that the fresh food compartment settles near the ideal refrigerator temperature for food is a better sign that the refrigerator has recovered.
Reset steps by control type
Control type
How to clear the alert
Source
French-door or four-door digital panel
Press Alarm Reset after power is restored.
Frigidaire alarm guidance
Electronic panel with Clear Alerts
Press CLEAR ALERTS.
Frigidaire error codes and alarms guidance
Door Ajar alarm
Close the door and press Set, where applicable.
Top-freezer or dial control
No PF alert to clear. Check the dial and allow the unit to stabilize.
Frigidaire recommended settings guidance
Frozen or unresponsive panel
Unplug for about 30 seconds and reconnect. For some display issues, unplug for 2–3 minutes.
Clearing the alert fixes the display, but it does not protect the refrigerator from the next outage. A battery backup can keep it powered when the grid goes down.
Keep your Frigidaire running through the next outage
Resetting the alert is easy. The harder part is keeping food cold during a long outage. A battery backup can help. In a pass-through setup, the refrigerator plugs into the power station, while the power station stays connected to a wall outlet. When grid power fails, the station switches to battery power.
EcoFlow DELTA 3 Max for a single refrigerator
The EcoFlow DELTA 3 Max has a 10ms auto-switch when used as a UPS-style backup. That fast switch is designed to keep connected equipment powered with little interruption. This can reduce the chance of a refrigerator noticing the power change, but it does not guarantee that a Frigidaire PF alert will never appear.
Frigidaire does not publish a minimum interruption time that its controls will ignore. So, the 10ms switch should be treated as a way to maintain power, not as a guarantee against every PF alert.
The EcoFlow DELTA 3 Max has a 2,048Wh battery and 2,400W rated output, with up to 4,800W surge output. This provides headroom for a refrigerator's start-up load, although the exact starting wattage of a specific Frigidaire model can vary.
EcoFlow DELTA 3 Max (2048Wh)
• 2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
How long can it run a refrigerator?
Runtime depends on the refrigerator's actual energy use. The following examples use ENERGY STAR annual energy ratings to estimate average daily consumption.
A side-by-side Frigidaire FRSS2333A* with a 22.3 cu. ft. capacity is rated at 615 kWh per year.
  • 615,000Wh ÷ 365 = about 1,685Wh per day
  • 1,685Wh ÷ 24 = about 70W average
  • 2,048Wh × 0.85 inverter efficiency = about 1,741Wh usable
  • 1,741Wh ÷ 70W = about 25 hours
A top-freezer Frigidaire FFHI1835V* with an 18.3 cu. ft. capacity is rated at 453 kWh per year.
  • 453,000Wh ÷ 365 = about 1,241Wh per day
  • 1,241Wh ÷ 24 = about 52W average
  • 1,741Wh ÷ 52W = about 34 hours
These are examples, not guaranteed runtimes. ENERGY STAR ratings use standardized testing. Real use can vary with door openings, room temperature, food load, and how hard the refrigerator must work after power returns.
Recharge during a longer outage
The EcoFlow DELTA 3 Max supports four charging methods. EcoFlow states that it can reach 80% charge in 68 minutes when using wall or generator charging.
Its OASIS 3.0 app also includes Storm Guard Mode. This can activate backup charging before extreme weather when the feature is available and configured.
Solar charging can also be used, but the required solar input depends on the setup. No single solar wattage should be assumed for every outage scenario.
EcoFlow DELTA Pro Ultra X for installed backup
The EcoFlow DELTA Pro Ultra X serves a different purpose. It is an installed home energy system, not a portable power station that you simply plug into the refrigerator.
The standard bundle includes one inverter and two Smart Extra Batteries, providing 12kWh of capacity and 12kW of output. EcoFlow notes that actual performance varies by configuration.
With Smart Home Panel 3, the system can back up selected home circuits. Smart Home Panel 3 supports up to 32 smart circuits and requires installation by a licensed electrician. The system can provide about 20ms automatic switchover when configured for backup.
The actual circuits you can run depend on the system configuration and battery capacity. Loads such as central air conditioning, an electric range, a well pump, or an electric water heater may require additional capacity.
Renters should get landlord approval before making electrical changes.
Running a fridge as a portable power station as a UPS can be a simple option for people who need backup for one appliance without installing a whole-home system.
•Whole-Home Backup (with the right setup): 12kW output and 12kWh capacity in the standard bundle (1 inverter + 2 Smart Extra Batteries), expandable up to 36kW and 180kWh with added inverters and batteries. Whole-home backup requires Smart Home Panel 3 installed by a licensed electrician, and coverage depends on your home's loads. •Fast Switchover: Automatic switchover in about 20ms with Smart Home Panel 3, so selected circuits stay on when the grid drops. • Installation: Plug-and-play design that EcoFlow says can be installed in 7 days. Permitting, your electrical panel, and installer schedules can change that timeline. • Comprehensive Safety: End-to-end system protection built to high safety standards.
EcoFlow DELTA Pro Ultra X vs. EcoFlow DELTA 3 Max
Backup option
Best suited to
Main setup
EcoFlow DELTA 3 Max
One refrigerator or a few appliances
Plug-in power station
About 10ms
Refrigerator plus selected home circuits
Installed home backup system
About 20ms with Smart Home Panel 3
The EcoFlow DELTA 3 Max is the simpler option for a single refrigerator, especially in an apartment or rental. The EcoFlow DELTA Pro Ultra X is designed for homeowners who want backup for the refrigerator and other essential circuits.
Backup power can reduce the impact of the next outage. But if your refrigerator has already been without power, the next question is whether the food inside is still safe.
Is your food still safe after the power comes back?
A cleared PF alert does not prove that your food stayed cold. The same applies if the refrigerator feels cold again after an hour. Food safety depends on time and temperature, not just the display.
According to FoodSafety.gov, an unopened refrigerator keeps food cold for about 4 hours during a power outage. Perishable food that has been at 40°F or above for more than 2 hours should be discarded.
A full freezer can keep food frozen for about 48 hours if the door stays closed. A half-full freezer can hold food for about 24 hours. Food that still has ice crystals or is at 40°F or below can generally be refrozen, although its quality may change.
The FDA also recommends keeping appliance thermometers in both the refrigerator and freezer. The refrigerator should stay at 40°F or below, while the freezer should stay at 0°F or below. Check the temperature as soon as power returns.
Maintaining the ideal refrigerator temperature for your foods is keyMaintaining the ideal refrigerator temperature for your foods is key
What does the Frigidaire High Temp alert tell you?
A Frigidaire High Temp alarm can indicate that the refrigerator reached 55°F or warmer, depending on the model and alarm system. This is higher than the FDA's 40°F safety threshold for refrigerated food.
That makes a High Temp alert a useful warning, but it does not replace a food safety check. The absence of a High Temp alert also does not prove that food stayed below 40°F.
If you are unsure how long the food was warm, do not taste it to test whether it is safe. When in doubt, throw it out.
Knowing how long your fridge and freezer food stays safe before the next storm can make this decision easier.
Situation
Keep or toss
What to do
Refrigerator stayed closed for less than 4 hours
Keep, if food remains properly chilled
Check the temperature before eating.
Perishable food reached 40°F or above for more than 2 hours
Toss
Do not taste the food to test it.
Full freezer without power for up to about 48 hours
Usually keep
Keep the door closed and check for ice crystals or safe temperatures.
Half-full freezer without power for up to about 24 hours
Usually keep
Keep the door closed and check the food when power returns.
Food still has ice crystals or is 40°F or below
Can generally be refrozen
Quality may change after refreezing.
You cannot confirm how long the food was warm
Toss questionable perishables
If the food checks out but the refrigerator still is not cooling after a full day, the problem may be more than a leftover power failure alert.
When a reset doesn't fix it: troubleshooting and service
Most Frigidaire refrigerators should begin cooling again after power returns. If yours does not, check the basic power and airflow points before assuming the outage caused a major fault.
Check the power supply
Frigidaire recommends checking that the refrigerator is connected to a dedicated, grounded 115–120V outlet. The circuit should use a 15 or 20 amp breaker, depending on the installation.
If the refrigerator has no power:
  • Check the circuit breaker.
  • Check for a blown fuse, if applicable.
  • Test the outlet with another appliance.
  • Do not use an extension cord unless the refrigerator's installation instructions allow it.
Check the doors and vents
A poor door seal can let warm air into the refrigerator. You can test the seal with a dollar bill. Close the door on the bill, then try to pull it out. If it slides out very easily, inspect the gasket for damage or gaps.
Also check the vents inside the refrigerator. Food or containers can block airflow and prevent cold air from moving through the compartments.
Give the refrigerator time to recover before making repeated temperature changes. Frigidaire states that the unit can need 24 hours for its temperature to stabilize.
Watch for service error codes
A code that remains after the power returns may point to a separate problem. Frigidaire lists several codes that may require service on certain models.
For some French-door models, these include:
  • SY CF
  • SY CE
  • SY EF
Four-door models can display codes such as:
  • Er CE
  • Er T1
  • Er T2
The exact codes depend on the refrigerator model. If one appears after the outage, check the model-specific guidance before attempting further resets.
When should you call for service?
If the refrigerator still does not cool after the basic checks and enough time to stabilize, service may be needed.
Frigidaire advises contacting the installer if the refrigerator was installed within the first 30 days. After that period, contact Frigidaire to arrange service through its owner support resources.
If the refrigerator is still under warranty, have the model and serial number ready before contacting support.
Stay safe around electrical equipment
Do not approach damaged power lines. If a fallen line creates an immediate danger, call 911. Never touch a breaker panel if there is standing water nearby.
Because Frigidaire says a PF alert can also result from a power surge, understanding power surge causes and protection can help you decide whether additional protection is suitable for your refrigerator.
Quick checks before booking service
  1. Confirm the refrigerator has power.
  2. Check the circuit breaker or fuse.
  3. Test the outlet with another appliance.
  4. Check the door gasket and close the doors fully.
  5. Clear anything blocking the internal vents.
  6. Allow up to 24 hours for the temperature to stabilize.
If the refrigerator still does not cool or shows a service code after these checks, contact Frigidaire or a qualified appliance technician.
The Frigidaire PF or Power Failure alert records a detected power outage or surge. On compatible digital panels, you can usually clear it with Alarm Reset or CLEAR ALERTS. If the panel becomes unresponsive, unplugging the refrigerator for about 30 seconds can reset it.
After clearing the alert, check the refrigerator and freezer temperatures. Keep the refrigerator at 40°F or below and the freezer at 0°F or below for food safety. Frigidaire also recommends allowing up to 24 hours for the refrigerator to stabilize before changing the temperature settings.
For the next outage, backup power can keep the refrigerator running. An EcoFlow DELTA 3 Max can provide plug-in backup for one refrigerator, while an EcoFlow DELTA Pro Ultra X with Smart Home Panel 3 can support selected home circuits when professionally installed. Compare the two based on your home, backup needs, and installation requirements.
How do I turn off the power outage alert on my Frigidaire refrigerator?
Press Alarm Reset or CLEAR ALERTS, depending on your control panel. If the display does not respond, unplug the refrigerator for about 30 seconds and reconnect it.
Why does my Frigidaire refrigerator say power outage when the power never went out?
Frigidaire states that the PF alert can indicate a power outage or power surge. A brief power event can therefore trigger the alert even if you did not notice the lights go out.
How long does a Frigidaire fridge take to get cold after a power outage?
Frigidaire states that a refrigerator can need up to 24 hours for its temperature to stabilize. Keep the doors closed as much as possible and avoid repeatedly changing the temperature setting.
Is food safe if my Frigidaire showed a power failure alert?
The PF alert alone does not determine food safety. An unopened refrigerator keeps food cold for about 4 hours. Perishable food held at 40°F or above for more than 2 hours should be discarded.
Can a battery backup keep my Frigidaire from showing a power outage alert?
A battery backup with automatic switching can help maintain power during an outage. The EcoFlow DELTA 3 Max has a 10ms auto-switch, but this does not guarantee that every Frigidaire model will avoid displaying a PF alert.
Power Outages
